[U-Boot] [PATCH 1/1] tools: imx8image: use correct printf escape sequence
core is of type uint64_t. So for printing we need "%"PRIu64 (not "%lu").
Without the patch a warning is issued when building on a 32bit system.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- tools/imx8image.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tools/imx8image.c b/tools/imx8image.c index 6e8ac464e7..f3158bc434 100644 --- a/tools/imx8image.c +++ b/tools/imx8image.c @@ -555,7 +555,8 @@ static void set_image_array_entry(flash_header_v3_t *container, } else if (soc == QM && core == CORE_CA72) { meta = IMAGE_A72_DEFAULT_META(custom_partition); } else { - fprintf(stderr, "Error: invalid AP core id: %lu\n", + fprintf(stderr, + "Error: invalid AP core id: %" PRIu64 "\n", core); exit(EXIT_FAILURE); } @@ -577,7 +578,9 @@ static void set_image_array_entry(flash_header_v3_t *container, core = CORE_CM4_1; meta = IMAGE_M4_1_DEFAULT_META(custom_partition); } else { - fprintf(stderr, "Error: invalid m4 core id: %lu\n", core); + fprintf(stderr, + "Error: invalid m4 core id: %" PRIu64 "\n", + core); exit(EXIT_FAILURE); } img->hab_flags |= IMG_TYPE_EXEC;
fprintf(stderr,
}"Error: invalid AP core id: %" PRIu64 "\n", core); exit(EXIT_FAILURE);
fprintf(stderr,
} img->hab_flags |= IMG_TYPE_EXEC;core); exit(EXIT_FAILURE);
Hello Stefano,
in patchwork this patch has been assigned to you. Could you, please, review it.
Best regards
Heinrich
fprintf(stderr,
fprintf(stderr,
Hello Stefano,
Patch is fine, it is merged in my private tree, I will push after I complete current merge and buid on Travis will report success.
Regards, Stefano
core is of type uint64_t. So for printing we need "%"PRIu64 (not "%lu"). Without the patch a warning is issued when building on a 32bit system. Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de
Best regards, Stefano Babic
sbabic@denx.de
Stefano Babic
