[PATCH v2] cmd: Handle CONFIG_(SPL_|TPL_)ENV_SUPPORT for toggling nvedit object
When CONFIG_SPL_ENV_SUPPORT is disabled, nvedit was still being included as part of the build. Use the CONFIG_ENV_SUPPORT, CONFIG_SPL_ENV_SUPPORT or CONFIG_TPL_ENV_SUPPORT values to enable/disable the inclusion of nvedit.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com --- Changes in v2: * Changed $(SPL_) to $(SPL_TPL_) to cover CONFIG_TPL_ENV_SUPPORT --- cmd/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/Makefile b/cmd/Makefile index 4f29b72c69..21b867d3a9 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -186,7 +186,7 @@ endif # !CONFIG_SPL_BUILD obj-$(CONFIG_$(SPL_)CMD_TLV_EEPROM) += tlv_eeprom.o
# core command -obj-y += nvedit.o +obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += nvedit.o
obj-$(CONFIG_TI_COMMON_CMD_OPTIONS) += ti/
--- 2.24.1
Dear Nathan,
Why should the availability of these commands depend on any of these settings? I think this is wrong - whether someone wants to have environment commands in SPL or TPM is an independent decision. You must not dictate it in such a way for all users.
Thanks.
On Sun, 2 Feb 2020 at 23:52, Wolfgang Denk wd@denx.de wrote:
Dear Nathan,
This file is dependent on code from env/, specifically code that is conditional on the various ENV_SUPPORT configs. As the underlying compilation issue stems from nvedit providing what appears to be common environment code (e.g. env_get), it made sense to have nvedit conditional on the same config.
Regards, Nathan
Nathan Rossi
