[U-Boot] [PATCH] imx: mx6: fix USB bmode to use reserved value
Currently the bmode "usb" uses BOOT_CFG1 to 0x01, -which means BOOT_CFG1[7:4] is set to b0000. According to Table 8-7 Boot Device Selection this is NOR/OneNAND and not Reserved.
Use 0x10 which leads to b0001, which is a Reserved boot device. With that the SoC reliably falls back to the serial loader.
Cc: Troy Kisky troy.kisky@boundarydevices.com Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
arch/arm/cpu/armv7/mx6/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 88fcfdc..c343c57 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -494,7 +494,7 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) const struct boot_mode soc_boot_modes[] = { {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, /* reserved value should start rom usb */ - {"usb", MAKE_CFGVAL(0x01, 0x00, 0x00, 0x00)}, + {"usb", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)}, {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, {"ecspi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)}, {"ecspi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)},
- {"usb", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)}, {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, {"ecspi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)}, {"ecspi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)},
Tested-by: Troy Kisky troy.kisky@boundarydevices.com
Best regards, Stefano Babic
Stefan Agner
Stefano Babic
Troy Kisky
