[U-Boot] [PATCH 0/4] tools/env: minor refactorings
various patches, see individual patch descriptions
Andreas Fenkart (4): tools/env: return with error if redundant environments have unequal size tools/env: javadoc for fw_printenv, fw_getenv and fw_parse_script tools/env: move envmatch further up in file to avoid forward declarations tools/env: reuse fw_getenv in fw_printenv function
tools/env/fw_env.c | 105 ++++++++++++++++++++++++----------------------------- tools/env/fw_env.h | 75 +++++++++++++++++++++++++++++++++++++- 2 files changed, 121 insertions(+), 59 deletions(-)
For double buffering to work, the target buffer must always be big enough to hold all data. This can only be ensured if buffers are of equal size, otherwise one must be smaller and we risk data loss when copying from the bigger to the smaller buffer.
Signed-off-by: Andreas Fenkart andreas.fenkart@digitalstrom.com --- tools/env/fw_env.c | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 692abda..b1c8217 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1382,18 +1382,19 @@ static int parse_config(struct env_opts *opts) return -1; }
- if (HaveRedundEnv && stat (DEVNAME (1), &st)) { - fprintf (stderr, - "Cannot access MTD device %s: %s\n", - DEVNAME (1), strerror (errno)); - return -1; - } + if (HaveRedundEnv) { + if (stat(DEVNAME(1), &st)) { + fprintf(stderr, + "Cannot access MTD device %s: %s\n", + DEVNAME(1), strerror(errno)); + return -1; + }
- if (HaveRedundEnv && ENVSIZE(0) != ENVSIZE(1)) { - ENVSIZE(0) = ENVSIZE(1) = min(ENVSIZE(0), ENVSIZE(1)); - fprintf(stderr, - "Redundant environments have inequal size, set to 0x%08lx\n", - ENVSIZE(1)); + if (ENVSIZE(0) != ENVSIZE(1)) { + fprintf(stderr, + "Redundant environments have unequal size"); + return -1; + } }
usable_envsize = CUR_ENVSIZE - sizeof(uint32_t);
On 27 June 2016 at 16:06, Andreas Fenkart andreas.fenkart@digitalstrom.com wrote:
there are two groups of functions: - application ready tools: fw_setenv/fw_getenv/fw_parse_script these are used, when creating a single binary containing multiple tools (busybox like) - file access like: open/read/write/close above functions are implemented on top of these. applications can use those to modify several variables without creating a temporary batch script file
Signed-off-by: Andreas Fenkart andreas.fenkart@digitalstrom.com --- tools/env/fw_env.h | 75 +++++++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 74 insertions(+), 1 deletion(-)
diff --git a/tools/env/fw_env.h b/tools/env/fw_env.h index dac964d..8bf74f3 100644 --- a/tools/env/fw_env.h +++ b/tools/env/fw_env.h @@ -67,12 +67,85 @@ struct env_opts {
int parse_aes_key(char *key, uint8_t *bin_key);
+/** + * fw_printenv - print one or several environment variables + * + * @argc number of variables names to be printed, print all if 0 + * @argv array of variable names to be printed + * @value_only do not repeat the variable name, only print the value, + * only one variable allowed with this option, argc must be 1 + * @opts encryption key, configuration file, defaults are used if NULL + */ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts); -char *fw_getenv(char *name); + +/** + * fw_setenv - adds or removes one variable from the environment + * + * @argc number of strings in argv, argv[0] is variable name, + * argc==1 means erase variable, argc > 1 means add a variable + * @argv argv[0] is variable name, argv[1..argc-1] are concatenated separated + * by single blank and set as the new value of the variable + * @opts how to retrieve environment from flash, defaults are used if NULL + * @ret EROFS if variable must not be changed (ethaddr, serial#) + */ int fw_setenv(int argc, char *argv[], struct env_opts *opts); + +/** + * fw_parse_script - add/remove multiple variables with a batch script + * + * @fname batch script file name + * @opts encryption key, configuration file, defaults are used if NULL + * + * Script Syntax: + * key [[space]+ value] + * lines starting with '#' treated as comment + * + * A variable without value will be deleted. Any number of spaces are allowed + * between key and value. The value starts with the first non-space character + * and ends with newline. No comments allowed on these lines. Spaces inside + * the value are preserved verbatim. + * + * Script Example:" + * netdev eth0 + * kernel_addr 400000 + * foo spaces are copied verbatim + * # delete variable bar + * bar\n" + */ int fw_parse_script(char *fname, struct env_opts *opts); + + +/** + * fw_env_open - read enviroment from flash and cache it in RAM + * + * @opts encryption key, configuration file, defaults are used if NULL + */ int fw_env_open(struct env_opts *opts); + +/** + * fw_getenv - lookup variable in RAM cache + * + * @name variable to be searched + * @ret NULL if not found + */ +char *fw_getenv(char *name); + +/** + * fw_env_write - set/clear a single variable in the RAM cache + * + * This is called in sequence to update the environment in RAM without updating + * the copy in flash after each set + * + * @name variable + * @value delete variable if NULL, otherwise create or overwrite the variable + */ int fw_env_write(char *name, char *value); + +/** + * fw_env_close - writes environment from RAM back to flash + * + * @opts encryption key, configuration file, defaults are used if NULL + */ int fw_env_close(struct env_opts *opts);
unsigned long crc32(unsigned long, const unsigned char *, unsigned);
Great to see this, thank you.
Nit below
- fw_printenv - print one or several environment variables
We normally add function brackets:
fw_printenv() - print ...
- @argc number of variables names to be printed, print all if 0
- @argv array of variable names to be printed
- @value_only do not repeat the variable name, only print the value,
- @opts encryption key, configuration file, defaults are used if NULL
@returns
- fw_setenv - adds or removes one variable from the environment
- @argc number of strings in argv, argv[0] is variable name,
- @argv argv[0] is variable name, argv[1..argc-1] are concatenated separated
- @opts how to retrieve environment from flash, defaults are used if NULL
- @ret EROFS if variable must not be changed (ethaddr, serial#)
@returns
- fw_parse_script - add/remove multiple variables with a batch script
- @fname batch script file name
@returns
(please do for all)
- Script Syntax:
- key [[space]+ value]
- lines starting with '#' treated as comment
- A variable without value will be deleted. Any number of spaces are allowed
- between key and value. The value starts with the first non-space character
- and ends with newline. No comments allowed on these lines. Spaces inside
- the value are preserved verbatim.
- Script Example:"
- netdev eth0
- kernel_addr 400000
- foo spaces are copied verbatim
- # delete variable bar
- bar\n"
- fw_env_open - read enviroment from flash and cache it in RAM
- fw_getenv - lookup variable in RAM cache
- @name variable to be searched
- @ret NULL if not found
- fw_env_write - set/clear a single variable in the RAM cache
- This is called in sequence to update the environment in RAM without updating
- the copy in flash after each set
- @name variable
- @value delete variable if NULL, otherwise create or overwrite the variable
- fw_env_close - writes environment from RAM back to flash
2.8.1
Hi Simon,
I sent out a v2 of this series, you should have received by now. Some comments in the context:
2016-07-09 16:39 GMT+02:00 Simon Glass sjg@chromium.org:
[snip]
Hmm, I wonder what actually is used, since it's neither javadoc nor kernel-doc
http://www.oracle.com/technetwork/java/javase/documentation/index-137868.htm... http://www.mjmwired.net/kernel/Documentation/kernel-doc-nano-HOWTO.txt
For javadoc we would have to use @param <arg> keyword instead of the shorter @arg used in the patch. But kernel-doc does not support @return/@returns, it requires a 'Return:' section.
I verified the markup using: ./scripts/kernel-doc -html -v tools/env/fw_env.h
This was just for convenience, since the script comes with the source. I can switch to whatever format is preferred.
@returns
$ grep -re '\W@return\W' * | wc -l 1280
$ grep -re '\W@returns\W' * | wc -l 12
javadoc uses @return
Is there a tool that processes the existing documentation markup, probably it's not kernel-doc since it doesn't know the @return keyword
[snip]
/Andi
+Marek
Hi Andreas,
On 16 July 2016 at 09:35, Andreas Fenkart afenkart@gmail.com wrote:
Hi Simon,
[snip]
@returns
I'm (hopefully) following instructions from Marek who may have more info on this. I believe it is docbook (make pdfdocs), but only a few files are included at present.
On 07/17/2016 04:12 PM, Simon Glass wrote:
+Marek
Hi Andreas,
Hi Simon,
[snip]
@returns
I'm not sure what the question is, I didn't manage to extrapolate it from the previous discussion -- but kerneldoc is the preferred doc format for u-boot.
forward declaration not needed when re-ordered
Signed-off-by: Andreas Fenkart andreas.fenkart@digitalstrom.com --- tools/env/fw_env.c | 38 ++++++++++++++++++-------------------- 1 file changed, 18 insertions(+), 20 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index b1c8217..ca839d1 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -121,7 +121,6 @@ static unsigned char obsolete_flag = 0; #include <env_default.h>
static int flash_io (int mode); -static char *envmatch (char * s1, char * s2); static int parse_config(struct env_opts *opts);
#if defined(CONFIG_FILE) @@ -147,6 +146,24 @@ static char *skip_blanks(char *s) }
/* + * s1 is either a simple 'name', or a 'name=value' pair. + * s2 is a 'name=value' pair. + * If the names match, return the value of s2, else NULL. + */ +static char *envmatch(char *s1, char *s2) +{ + if (s1 == NULL || s2 == NULL) + return NULL; + + while (*s1 == *s2++) + if (*s1++ == '=') + return s2; + if (*s1 == '\0' && *(s2 - 1) == '=') + return s2; + return NULL; +} + +/** * Search the environment for a variable. * Return the value, if found, or NULL, if not found. */ @@ -1121,25 +1138,6 @@ exit: }
/* - * s1 is either a simple 'name', or a 'name=value' pair. - * s2 is a 'name=value' pair. - * If the names match, return the value of s2, else NULL. - */ - -static char *envmatch (char * s1, char * s2) -{ - if (s1 == NULL || s2 == NULL) - return NULL; - - while (*s1 == *s2++) - if (*s1++ == '=') - return s2; - if (*s1 == '\0' && *(s2 - 1) == '=') - return s2; - return NULL; -} - -/* * Prevent confusion if running from erased flash memory */ int fw_env_open(struct env_opts *opts)
Try to avoid adhoc iteration of the environment. Reuse fw_getenv to find the variables that should be printed. Only use open-coded iteration when printing all variables. For backwards compatibility, keep emitting a newline when printing with noheader.
Signed-off-by: Andreas Fenkart andreas.fenkart@digitalstrom.com --- tools/env/fw_env.c | 44 +++++++++++++++++--------------------------- 1 file changed, 17 insertions(+), 27 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index ca839d1..9733950 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -249,9 +249,14 @@ int parse_aes_key(char *key, uint8_t *bin_key) */ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts) { - char *env, *nxt; int i, rc = 0;
+ if (value_only && argc != 1) { + fprintf(stderr, + "## Error: `-n' option requires exactly one argument\n"); + return -1; + } + if (!opts) opts = &default_opts;
@@ -259,6 +264,7 @@ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts) return -1;
if (argc == 0) { /* Print all env variables */ + char *env, *nxt; for (env = environment.data; *env; env = nxt + 1) { for (nxt = env; *nxt; ++nxt) { if (nxt >= &environment.data[ENV_SIZE]) { @@ -273,39 +279,23 @@ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts) return 0; }
- if (value_only && argc != 1) { - fprintf(stderr, - "## Error: `-n' option requires exactly one argument\n"); - return -1; - } - - for (i = 0; i < argc; ++i) { /* print single env variables */ + for (i = 0; i < argc; ++i) { /* print a subset of env variables */ char *name = argv[i]; char *val = NULL;
- for (env = environment.data; *env; env = nxt + 1) { - - for (nxt = env; *nxt; ++nxt) { - if (nxt >= &environment.data[ENV_SIZE]) { - fprintf (stderr, "## Error: " - "environment not terminated\n"); - return -1; - } - } - val = envmatch (name, env); - if (val) { - if (!value_only) { - fputs (name, stdout); - putc ('=', stdout); - } - puts (val); - break; - } - } + val = fw_getenv(name); if (!val) { fprintf (stderr, "## Error: "%s" not defined\n", name); rc = -1; + continue; } + + if (value_only) { + puts(val); + break; + } + + printf("%s=%s\n", name, val); }
return rc;
Andreas Fenkart
Andreas Fenkart
