[U-Boot] [PATCH] rockchip: enable SPL_OF_PLATDATA for rk3288 board
It seems ddr auto detect make SPL image to large. So we have to use SPL_OF_PLATDATA to reduce size.
Signed-off-by: Jacob Chen jacob2.chen@rock-chips.com ---
configs/evb-rk3288_defconfig | 4 ++++ configs/fennec-rk3288_defconfig | 3 +++ configs/miniarm-rk3288_defconfig | 3 +++ 3 files changed, 10 insertions(+)
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index c7396a5..89cf3c1 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -29,10 +29,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +# CONFIG_SPL_SIMPLE_BUS is not set CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y @@ -59,7 +61,9 @@ CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y +CONFIG_ROCKCHIP_SERIAL=y CONFIG_SYSRESET=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y +# CONFIG_SPL_OF_LIBFDT is not set diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index a5c089b..0ff7264 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y @@ -58,7 +59,9 @@ CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y +CONFIG_ROCKCHIP_SERIAL=y CONFIG_SYSRESET=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y +# CONFIG_SPL_OF_LIBFDT is not set diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 6354d1a..c8939a8 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y @@ -57,7 +58,9 @@ CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y +CONFIG_ROCKCHIP_SERIAL=y CONFIG_SYSRESET=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y +# CONFIG_SPL_OF_LIBFDT is not set
In patch "rk3288: config change for enable dram capacity auto-detect", Kever have use CONFIG_ROCKCHIP_SPL_BACK_TO_BROM to reduce spl size, so this patch is no longer needed.
2016-09-28 23:46 GMT+08:00 Simon Glass sjg@chromium.org:
Acked-by: Simon Glass sjg@chromium.org _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
OK, then I will drop this patch for now.
Jacob Chen
陈豪
