[U-Boot] Please pull u-boot-x86.git branch 'buildman'
Hi Tom,
Here are all the pending changes for patman/buildman. Mostly these add tests but there are also several fixes, some found by the tests. I believe it is worth applying these now, to make it easier to find other issues that might come up.
Branch is 'buildman'.
The following changes since commit 0b703dbcee7103f07804d0a4328d1593355c4324:
patman: Fix detection of git version (2014-09-05 13:40:43 -0600)
git://git.denx.de/u-boot-x86.git
for you to fetch changes up to d0ea61d9caf85e4285d5c2da508db9fac70e4aba:
buildman: fix typos of --dry-run help message (2014-09-09 16:48:06 -0600)
---------------------------------------------------------------- Masahiro Yamada (1): buildman: fix typos of --dry-run help message
Simon Glass (18): patman: Add a way of recording terminal output for testing buildman: Send builder output through a function for testing buildman: Enhance basic test to check summary output patman: RunPipe() should not pipe stdout/stderr unless asked buildman: Move the command line code into its own file buildman: Move full help code into the control module patman: Provide a way to intercept commands for testing buildman: Add a functional test buildman: Set up bsettings outside the control module buildman: Avoid looking at config file or toolchains in tests buildman: Allow tests to have their own boards buildman: Correct counting of build failures on retry buildman: Provide an internal option to clean the outpur dir patman: Start with a clean series when needed buildman: Add additional functional tests buildman: Expand output test to cover directory prefixes buildman: Permit branch names with an embedded '/' buildman: Ignore conflicting tags
Thierry Reding (1): buildman: Create parent directories as necessary
Vadim Bendebury (1): patman: make run results better visible
tools/buildman/bsettings.py | 15 ++- tools/buildman/builder.py | 60 +++++----- tools/buildman/builderthread.py | 22 ++-- tools/buildman/buildman.py | 98 ++-------------- tools/buildman/cmdline.py | 85 ++++++++++++++ tools/buildman/control.py | 73 ++++++++---- tools/buildman/func_test.py | 519 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/buildman/test.py | 153 +++++++++++++++++++++++-- tools/buildman/toolchain.py | 4 +- tools/patman/command.py | 22 ++++ tools/patman/gitutil.py | 8 +- tools/patman/patchstream.py | 6 +- tools/patman/patman.py | 7 +- tools/patman/terminal.py | 72 ++++++++++++ 14 files changed, 972 insertions(+), 172 deletions(-) create mode 100644 tools/buildman/cmdline.py create mode 100644 tools/buildman/func_test.py
On Tue, Sep 09, 2014 at 04:52:18PM -0600, Simon Glass wrote:
Hi Tom,
