[PATCH 1/1] tpm2: Add a TPMv2 MMIO TIS driver
Add a TPMv2 TIS MMIO compatible driver. This useful for a couple of reasons. First of all we can support a TPMv2 on devices that have this hardware (e.g the newly added SynQuacer box). We can also use the driver in our QEMU setups and test the EFI TCG2 protocol, which cannot be tested with our sandbox.
Ideally we should create an abstraction for all TIS compatible TPMs we support. Let's plug in the mmio driver first.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/Kconfig | 9 + drivers/tpm/Makefile | 1 + drivers/tpm/tpm2_tis_mmio.c | 516 ++++++++++++++++++++++++++++++++++++ drivers/tpm/tpm_tis.h | 8 + include/tpm-v2.h | 1 + 5 files changed, 535 insertions(+) create mode 100644 drivers/tpm/tpm2_tis_mmio.c
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 9eebab5cfd90..406ee8716e1e 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -161,6 +161,15 @@ config TPM2_FTPM_TEE help This driver supports firmware TPM running in TEE.
+config TPM2_MMIO + bool "MMIO based TPM2 Interface" + depends on TPM_V2 + help + This driver supports firmware TPM2.0 MMIO interface. + The usual TPM operations and the 'tpm' command can be used to talk + to the device using the standard TPM Interface Specification (TIS) + protocol. + endif # TPM_V2
endmenu diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index f64d20067f88..42fca3315bff 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_$(SPL_TPL_)TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_spi.o obj-$(CONFIG_TPM2_FTPM_TEE) += tpm2_ftpm_tee.o +obj-$(CONFIG_TPM2_MMIO) += tpm2_tis_mmio.o diff --git a/drivers/tpm/tpm2_tis_mmio.c b/drivers/tpm/tpm2_tis_mmio.c new file mode 100644 index 000000000000..422af4ff0b51 --- /dev/null +++ b/drivers/tpm/tpm2_tis_mmio.c @@ -0,0 +1,516 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * swtpm driver for TCG/TIS TPM (trusted platform module). + * Specifications at www.trustedcomputinggroup.org + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <tpm-v2.h> +#include <linux/bitops.h> +#include <linux/compiler.h> +#include <linux/delay.h> +#include <linux/errno.h> +#include <linux/types.h> +#include <linux/io.h> +#include <linux/unaligned/be_byteshift.h> +#include "tpm_tis.h" +#include "tpm_internal.h" + +enum tis_int_flags { + TPM_GLOBAL_INT_ENABLE = 0x80000000, + TPM_INTF_BURST_COUNT_STATIC = 0x100, + TPM_INTF_CMD_READY_INT = 0x080, + TPM_INTF_INT_EDGE_FALLING = 0x040, + TPM_INTF_INT_EDGE_RISING = 0x020, + TPM_INTF_INT_LEVEL_LOW = 0x010, + TPM_INTF_INT_LEVEL_HIGH = 0x008, + TPM_INTF_LOCALITY_CHANGE_INT = 0x004, + TPM_INTF_STS_VALID_INT = 0x002, + TPM_INTF_DATA_AVAIL_INT = 0x001, +}; + +struct tpm_tis_chip_data { + unsigned int pcr_count; + unsigned int pcr_select_min; + unsigned int time_before_first_cmd_ms; + void __iomem *iobase; +}; + +static int tpm_tis_read_bytes(struct udevice *udev, u32 addr, u16 len, + u8 *result) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + while (len--) + *result++ = ioread8(drv_data->iobase + addr); + return 0; +} + +static int tpm_tis_write_bytes(struct udevice *udev, u32 addr, u16 len, + const u8 *value) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + while (len--) + iowrite8(*value++, drv_data->iobase + addr); + return 0; +} + +static __maybe_unused int tpm_tis_read16(struct udevice *udev, u32 addr, + u16 *result) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + *result = ioread16(drv_data->iobase + addr); + return 0; +} + +static int tpm_tis_read32(struct udevice *udev, u32 addr, u32 *result) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + *result = ioread32(drv_data->iobase + addr); + return 0; +} + +static int tpm_tis_write32(struct udevice *udev, u32 addr, u32 value) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + iowrite32(value, drv_data->iobase + addr); + return 0; +} + +static int tpm_tis_get_desc(struct udevice *udev, char *buf, int size) +{ + struct tpm_chip *chip = dev_get_priv(udev); + + if (size < 80) + return -ENOSPC; + + return snprintf(buf, size, + "%s v2.0: VendorID 0x%04x, DeviceID 0x%04x, RevisionID 0x%02x [%s]", + udev->name, chip->vend_dev & 0xFFFF, + chip->vend_dev >> 16, chip->rid, + (chip->is_open ? "open" : "closed")); +} + +static bool tpm_tis_check_locality(struct udevice *udev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(udev); + u8 locality; + + tpm_tis_read_bytes(udev, TPM_ACCESS(loc), 1, &locality); + if ((locality & (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID | + TPM_ACCESS_REQUEST_USE)) == + (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID)) { + chip->locality = loc; + return true; + } + + return false; +} + +static int tpm_tis_request_locality(struct udevice *udev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(udev); + u8 buf = TPM_ACCESS_REQUEST_USE; + unsigned long start, stop; + + if (tpm_tis_check_locality(udev, loc)) + return 0; + + tpm_tis_write_bytes(udev, TPM_ACCESS(loc), 1, &buf); + start = get_timer(0); + stop = chip->timeout_a; + do { + if (tpm_tis_check_locality(udev, loc)) + return 0; + mdelay(TPM_TIMEOUT_MS); + } while (get_timer(start) < stop); + + return -1; +} + +static int tpm_tis_status(struct udevice *udev, u8 *status) +{ + struct tpm_chip *chip = dev_get_priv(udev); + + if (chip->locality < 0) + return -EINVAL; + + tpm_tis_read_bytes(udev, TPM_STS(chip->locality), 1, status); + + if ((*status & TPM_STS_READ_ZERO)) { + log_err("TPM returned invalid status\n"); + return -EINVAL; + } + + return 0; +} + +static int tpm_tis_release_locality(struct udevice *udev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(udev); + u8 buf = TPM_ACCESS_ACTIVE_LOCALITY; + int ret; + + if (chip->locality < 0) + return 0; + + ret = tpm_tis_write_bytes(udev, TPM_ACCESS(loc), 1, &buf); + chip->locality = -1; + + return ret; +} + +static int tpm_tis_wait_for_stat(struct udevice *udev, u8 mask, + unsigned long timeout, u8 *status) +{ + unsigned long start = get_timer(0); + unsigned long stop = timeout; + int ret; + + do { + mdelay(TPM_TIMEOUT_MS); + ret = tpm_tis_status(udev, status); + if (ret) + return ret; + + if ((*status & mask) == mask) + return 0; + } while (get_timer(start) < stop); + + return -ETIMEDOUT; +} + +static int tpm_tis_get_burstcount(struct udevice *udev, size_t *burstcount) +{ + struct tpm_chip *chip = dev_get_priv(udev); + unsigned long start, stop; + u32 burst; + + if (chip->locality < 0) + return -EINVAL; + + /* wait for burstcount */ + start = get_timer(0); + /* + * This is the TPMv2 defined timeout. Change this in case you want to + * make the driver compatile to TPMv1 + */ + stop = chip->timeout_a; + do { + tpm_tis_read32(udev, TPM_STS(chip->locality), &burst); + *burstcount = (burst >> 8) & 0xFFFF; + if (*burstcount) + return 0; + + mdelay(TPM_TIMEOUT_MS); + } while (get_timer(start) < stop); + + return -ETIMEDOUT; +} + +static int tpm_tis_ready(struct udevice *udev) +{ + struct tpm_chip *chip = dev_get_priv(udev); + u8 data = TPM_STS_COMMAND_READY; + + /* This will cancel any pending commands */ + return tpm_tis_write_bytes(udev, TPM_STS(chip->locality), 1, &data); +} + +static int tpm_tis_send(struct udevice *udev, const u8 *buf, size_t len) +{ + struct tpm_chip *chip = dev_get_priv(udev); + size_t burstcnt, wr_size, sent = 0; + u8 data = TPM_STS_GO; + u8 status; + int ret; + + if (!chip) + return -ENODEV; + + ret = tpm_tis_request_locality(udev, 0); + if (ret < 0) + return -EBUSY; + + ret = tpm_tis_status(udev, &status); + if (ret) + goto release_locality; + + if (!(status & TPM_STS_COMMAND_READY)) { + ret = tpm_tis_ready(udev); + if (ret) { + log_err("Can't cancel previous TPM operation\n"); + goto release_locality; + } + ret = tpm_tis_wait_for_stat(udev, TPM_STS_COMMAND_READY, + chip->timeout_b, &status); + if (ret) { + log_err("TPM not ready\n"); + goto release_locality; + } + } + + while (len > 0) { + ret = tpm_tis_get_burstcount(udev, &burstcnt); + if (ret) + goto release_locality; + + wr_size = min(len, burstcnt); + ret = tpm_tis_write_bytes(udev, TPM_DATA_FIFO(chip->locality), + wr_size, buf + sent); + if (ret < 0) + goto release_locality; + + ret = tpm_tis_wait_for_stat(udev, TPM_STS_VALID, + chip->timeout_c, &status); + if (ret) + goto release_locality; + + sent += wr_size; + len -= wr_size; + /* make sure the TPM expects more data */ + if (len && !(status & TPM_STS_DATA_EXPECT)) { + ret = -EIO; + goto release_locality; + } + } + + /* + * Make a final check ensuring everything is ok and the TPM expects no + * more data + */ + ret = tpm_tis_wait_for_stat(udev, TPM_STS_VALID, chip->timeout_c, + &status); + if (ret) + goto release_locality; + + if (status & TPM_STS_DATA_EXPECT) { + ret = -EIO; + goto release_locality; + } + + ret = tpm_tis_write_bytes(udev, TPM_STS(chip->locality), 1, &data); + if (ret) + goto release_locality; + + tpm_tis_release_locality(udev, chip->locality); + return sent; + +release_locality: + tpm_tis_ready(udev); + tpm_tis_release_locality(udev, chip->locality); + + return ret; +} + +static int tpm_tis_recv_data(struct udevice *udev, u8 *buf, size_t count) +{ + struct tpm_chip *chip = dev_get_priv(udev); + int size = 0, len, ret; + size_t burstcnt; + u8 status; + + while (size < count && + tpm_tis_wait_for_stat(udev, TPM_STS_DATA_AVAIL | TPM_STS_VALID, + chip->timeout_c, &status) == 0) { + ret = tpm_tis_get_burstcount(udev, &burstcnt); + if (ret) + return burstcnt; + + len = min_t(int, burstcnt, count - size); + ret = tpm_tis_read_bytes(udev, TPM_DATA_FIFO(chip->locality), + len, buf + size); + if (ret < 0) + return ret; + + size += len; + } + + return size; +} + +static int tpm_tis_recv(struct udevice *udev, u8 *buf, size_t count) +{ + struct tpm_chip *chip = dev_get_priv(udev); + int ret; + int size, expected; + + if (!chip) + return -ENODEV; + + if (count < TPM_HEADER_SIZE) + return -E2BIG; + + ret = tpm_tis_request_locality(udev, 0); + if (ret < 0) + return -EBUSY; + + size = tpm_tis_recv_data(udev, buf, TPM_HEADER_SIZE); + if (size < TPM_HEADER_SIZE) { + log_err("TPM error, unable to read header\n"); + goto out; + } + + expected = get_unaligned_be32(buf + TPM_CMD_COUNT_OFFSET); + if (expected > count) { + size = -EIO; + log_warning("Too much data: %d > %zu\n", expected, count); + goto out; + } + + size += tpm_tis_recv_data(udev, &buf[TPM_HEADER_SIZE], + expected - TPM_HEADER_SIZE); + if (size < expected) { + log(LOGC_NONE, LOGL_ERR, + "TPM error, unable to read remaining bytes of result\n"); + size = -EIO; + goto out; + } + +out: + tpm_tis_ready(udev); + tpm_tis_release_locality(udev, chip->locality); + + return size; +} + +static int tpm_tis_probe(struct udevice *udev) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + struct tpm_chip_priv *priv = dev_get_uclass_priv(udev); + struct tpm_chip *chip = dev_get_priv(udev); + int ret = 0; + fdt_addr_t ioaddr; + u32 tmp; + u64 sz; + + ioaddr = dev_read_addr(udev); + if (ioaddr == FDT_ADDR_T_NONE) + return -EINVAL; + + ret = dev_read_u64(udev, "reg", &sz); + if (ret) + return -EINVAL; + + drv_data->iobase = ioremap(ioaddr, sz); + log_info("Remapped TPM2 base: 0x%llx size: 0x%llx\n", ioaddr, sz); + + ret = tpm_tis_request_locality(udev, 0); + if (ret) + goto iounmap; + + chip->timeout_a = TIS_SHORT_TIMEOUT_MS; + chip->timeout_b = TIS_LONG_TIMEOUT_MS; + chip->timeout_c = TIS_SHORT_TIMEOUT_MS; + chip->timeout_d = TIS_SHORT_TIMEOUT_MS; + priv->pcr_count = drv_data->pcr_count; + priv->pcr_select_min = drv_data->pcr_select_min; + + /* Disable interrupts */ + tpm_tis_read32(udev, TPM_INT_ENABLE(chip->locality), &tmp); + tmp |= TPM_INTF_CMD_READY_INT | TPM_INTF_LOCALITY_CHANGE_INT | + TPM_INTF_DATA_AVAIL_INT | TPM_INTF_STS_VALID_INT; + tmp &= ~TPM_GLOBAL_INT_ENABLE; + tpm_tis_write32(udev, TPM_INT_ENABLE(chip->locality), tmp); + + /* + * Although the driver probably works with a TPMv1 our Kconfig + * limits the driver to TPMv2 only + */ + priv->version = TPM_V2; + tpm_tis_read_bytes(udev, TPM_RID(chip->locality), 1, &chip->rid); + tpm_tis_read32(udev, TPM_DID_VID(chip->locality), &chip->vend_dev); + + tpm_tis_release_locality(udev, chip->locality); + + return ret; + +iounmap: + iounmap(drv_data->iobase); + return -EINVAL; +} + +static int tpm_tis_remove(struct udevice *udev) +{ + struct tpm_chip *chip = dev_get_priv(udev); + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + + iounmap(drv_data->iobase); + return tpm_tis_release_locality(udev, chip->locality); +} + +static int tpm_tis_cleanup(struct udevice *udev) +{ + struct tpm_chip *chip = dev_get_priv(udev); + + tpm_tis_ready(udev); + tpm_tis_release_locality(udev, chip->locality); + + return 0; +} + +static int tpm_tis_open(struct udevice *udev) +{ + struct tpm_chip *chip = dev_get_priv(udev); + int ret; + + if (chip->is_open) + return -EBUSY; + + ret = tpm_tis_request_locality(udev, 0); + if (!ret) + chip->is_open = 1; + + return ret; +} + +static int tpm_tis_close(struct udevice *udev) +{ + struct tpm_chip *chip = dev_get_priv(udev); + int ret = 0; + + if (chip->is_open) { + ret = tpm_tis_release_locality(udev, chip->locality); + chip->is_open = 0; + } + + return ret; +} + +static const struct tpm_ops tpm_tis_ops = { + .open = tpm_tis_open, + .close = tpm_tis_close, + .get_desc = tpm_tis_get_desc, + .send = tpm_tis_send, + .recv = tpm_tis_recv, + .cleanup = tpm_tis_cleanup, +}; + +static const struct tpm_tis_chip_data tpm_tis_std_chip_data = { + .pcr_count = 24, + .pcr_select_min = 3, +}; + +static const struct udevice_id tpm_tis_ids[] = { + { + .compatible = "tcg,tpm-tis-mmio", + .data = (ulong)&tpm_tis_std_chip_data, + }, + { } +}; + +U_BOOT_DRIVER(tpm_tis_mmio) = { + .name = "tpm_tis_mmio", + .id = UCLASS_TPM, + .of_match = tpm_tis_ids, + .ops = &tpm_tis_ops, + .probe = tpm_tis_probe, + .remove = tpm_tis_remove, + .priv_auto = sizeof(struct tpm_chip), +}; diff --git a/drivers/tpm/tpm_tis.h b/drivers/tpm/tpm_tis.h index 2a160fe05c9a..a561aa37d45a 100644 --- a/drivers/tpm/tpm_tis.h +++ b/drivers/tpm/tpm_tis.h @@ -29,6 +29,14 @@ enum tpm_timeout { SLEEP_DURATION_LONG_US = 210, };
+#define TPM_ACCESS(l) (0x0000 | ((l) << 12)) +#define TPM_INT_ENABLE(l) (0x0008 | ((l) << 12)) +#define TPM_STS(l) (0x0018 | ((l) << 12)) +#define TPM_DATA_FIFO(l) (0x0024 | ((l) << 12)) +#define TPM_DID_VID(l) (0x0F00 | ((l) << 12)) +#define TPM_RID(l) (0x0F04 | ((l) << 12)) +#define TPM_INTF_CAPS(l) (0x0014 | ((l) << 12)) + /* Size of external transmit buffer (used in tpm_transmit)*/ #define TPM_BUFSIZE 4096
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 7de7d6a57dca..b1710f28f5ad 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -360,6 +360,7 @@ enum { TPM_STS_DATA_EXPECT = 1 << 3, TPM_STS_SELF_TEST_DONE = 1 << 2, TPM_STS_RESPONSE_RETRY = 1 << 1, + TPM_STS_READ_ZERO = 0x23 };
enum {
This would match Linux' linux/drivers/char/tpm/tpm_tis_core.c. The individual drivers provide the TIS level operations of struct tpm_tis_phy_ops and call tpm_tis_core_init() to load the tpm_tis_core module which supplies the TPM level operations of struct tpm_class_ops.
Why don't you start with a separate tis_core module supporting the tis_mmio driver? This would avoid pulling out the core functions out of this driver and provide a template for refactoring the other drivers.
+config TPM2_MMIO
depends on TPM_V2
help
protocol.
endif # TPM_V2
endmenu
- swtpm driver for TCG/TIS TPM (trusted platform module).
swtpm is not easy to understand. I would prefer something like
'Driver for the TPM software emulation provided by the swtpm package (https://github.com/stefanberger/swtpm)'.
- Specifications at www.trustedcomputinggroup.org
- TPM_GLOBAL_INT_ENABLE = 0x80000000,
- TPM_INTF_BURST_COUNT_STATIC = 0x100,
- TPM_INTF_CMD_READY_INT = 0x080,
- TPM_INTF_INT_EDGE_FALLING = 0x040,
- TPM_INTF_INT_EDGE_RISING = 0x020,
- TPM_INTF_INT_LEVEL_LOW = 0x010,
- TPM_INTF_INT_LEVEL_HIGH = 0x008,
- TPM_INTF_LOCALITY_CHANGE_INT = 0x004,
- TPM_INTF_STS_VALID_INT = 0x002,
- TPM_INTF_DATA_AVAIL_INT = 0x001,
These definitions match Linux' tpm_tis_core.h.
Should they be moved to an include of the same name in U-Boot?
- unsigned int pcr_count;
- unsigned int pcr_select_min;
- unsigned int time_before_first_cmd_ms;
- void __iomem *iobase;
u8 *result)
- struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev);
- while (len--)
I would prefer if you would add these functions to a structure struct tpm_tis_phy_ops which you can use to pull out the core driver.
Best regards
Heinrich
const u8 *value)
- while (len--)
u16 *result)
- *result = ioread16(drv_data->iobase + addr);
- *result = ioread32(drv_data->iobase + addr);
- iowrite32(value, drv_data->iobase + addr);
- struct tpm_chip *chip = dev_get_priv(udev);
- if (size < 80)
return -ENOSPC;
- return snprintf(buf, size,
- u8 locality;
- tpm_tis_read_bytes(udev, TPM_ACCESS(loc), 1, &locality);
- if ((locality & (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID |
return true;
- return false;
- u8 buf = TPM_ACCESS_REQUEST_USE;
- unsigned long start, stop;
- if (tpm_tis_check_locality(udev, loc))
- tpm_tis_write_bytes(udev, TPM_ACCESS(loc), 1, &buf);
- start = get_timer(0);
- stop = chip->timeout_a;
- do {
- } while (get_timer(start) < stop);
- return -1;
- if (chip->locality < 0)
return -EINVAL;
- tpm_tis_read_bytes(udev, TPM_STS(chip->locality), 1, status);
- if ((*status & TPM_STS_READ_ZERO)) {
return -EINVAL;
- u8 buf = TPM_ACCESS_ACTIVE_LOCALITY;
- int ret;
- ret = tpm_tis_write_bytes(udev, TPM_ACCESS(loc), 1, &buf);
- chip->locality = -1;
- return ret;
- unsigned long start = get_timer(0);
- unsigned long stop = timeout;
- int ret;
- do {
if (ret)
return ret;
- return -ETIMEDOUT;
- u32 burst;
return -EINVAL;
- /* wait for burstcount */
- do {
if (*burstcount)
- u8 data = TPM_STS_COMMAND_READY;
- /* This will cancel any pending commands */
- return tpm_tis_write_bytes(udev, TPM_STS(chip->locality), 1, &data);
- size_t burstcnt, wr_size, sent = 0;
- u8 data = TPM_STS_GO;
- u8 status;
- int ret;
- if (!chip)
return -ENODEV;
- ret = tpm_tis_request_locality(udev, 0);
- if (ret < 0)
return -EBUSY;
- ret = tpm_tis_status(udev, &status);
- if (ret)
- if (!(status & TPM_STS_COMMAND_READY)) {
if (ret) {
if (ret) {
- while (len > 0) {
if (ret)
if (ret < 0)
if (ret)
sent += wr_size;
len -= wr_size;
ret = -EIO;
* more data
- ret = tpm_tis_wait_for_stat(udev, TPM_STS_VALID, chip->timeout_c,
&status);
- if (ret)
- if (status & TPM_STS_DATA_EXPECT) {
ret = -EIO;
- ret = tpm_tis_write_bytes(udev, TPM_STS(chip->locality), 1, &data);
- if (ret)
- tpm_tis_release_locality(udev, chip->locality);
- return sent;
+release_locality:
- tpm_tis_ready(udev);
- return ret;
- int size = 0, len, ret;
- size_t burstcnt;
- u8 status;
- while (size < count &&
if (ret)
return burstcnt;
len, buf + size);
if (ret < 0)
return ret;
size += len;
- return size;
- int ret;
- int size, expected;
- if (!chip)
return -ENODEV;
- if (count < TPM_HEADER_SIZE)
return -E2BIG;
- if (ret < 0)
return -EBUSY;
- size = tpm_tis_recv_data(udev, buf, TPM_HEADER_SIZE);
- if (size < TPM_HEADER_SIZE) {
goto out;
- expected = get_unaligned_be32(buf + TPM_CMD_COUNT_OFFSET);
- if (expected > count) {
size = -EIO;
goto out;
- size += tpm_tis_recv_data(udev, &buf[TPM_HEADER_SIZE],
- if (size < expected) {
size = -EIO;
goto out;
+out:
- return size;
- struct tpm_chip_priv *priv = dev_get_uclass_priv(udev);
- int ret = 0;
- fdt_addr_t ioaddr;
- u32 tmp;
- u64 sz;
- ioaddr = dev_read_addr(udev);
- if (ioaddr == FDT_ADDR_T_NONE)
return -EINVAL;
- ret = dev_read_u64(udev, "reg", &sz);
- if (ret)
return -EINVAL;
- drv_data->iobase = ioremap(ioaddr, sz);
- log_info("Remapped TPM2 base: 0x%llx size: 0x%llx\n", ioaddr, sz);
- if (ret)
goto iounmap;
- chip->timeout_a = TIS_SHORT_TIMEOUT_MS;
- chip->timeout_b = TIS_LONG_TIMEOUT_MS;
- chip->timeout_c = TIS_SHORT_TIMEOUT_MS;
- chip->timeout_d = TIS_SHORT_TIMEOUT_MS;
- priv->pcr_count = drv_data->pcr_count;
- priv->pcr_select_min = drv_data->pcr_select_min;
- /* Disable interrupts */
- tpm_tis_read32(udev, TPM_INT_ENABLE(chip->locality), &tmp);
- tmp |= TPM_INTF_CMD_READY_INT | TPM_INTF_LOCALITY_CHANGE_INT |
- tmp &= ~TPM_GLOBAL_INT_ENABLE;
- tpm_tis_write32(udev, TPM_INT_ENABLE(chip->locality), tmp);
- priv->version = TPM_V2;
- tpm_tis_read_bytes(udev, TPM_RID(chip->locality), 1, &chip->rid);
- tpm_tis_read32(udev, TPM_DID_VID(chip->locality), &chip->vend_dev);
- return ret;
+iounmap:
- iounmap(drv_data->iobase);
- return -EINVAL;
- return tpm_tis_release_locality(udev, chip->locality);
- int ret;
- if (chip->is_open)
return -EBUSY;
- if (!ret)
chip->is_open = 1;
- return ret;
- int ret = 0;
- if (chip->is_open) {
chip->is_open = 0;
- return ret;
- .open = tpm_tis_open,
- .close = tpm_tis_close,
- .get_desc = tpm_tis_get_desc,
- .send = tpm_tis_send,
- .recv = tpm_tis_recv,
- .cleanup = tpm_tis_cleanup,
- .pcr_count = 24,
- .pcr_select_min = 3,
- .name = "tpm_tis_mmio",
- .id = UCLASS_TPM,
- .of_match = tpm_tis_ids,
- .ops = &tpm_tis_ops,
- .probe = tpm_tis_probe,
- .remove = tpm_tis_remove,
- .priv_auto = sizeof(struct tpm_chip),
- /* Size of external transmit buffer (used in tpm_transmit)*/ #define TPM_BUFSIZE 4096
enum {
Yep, I am commenting more on this below. [...]
Sure
I got a tpm_tis.h in this series, so I might as well move those there
Me too :). In fact that matches the design I proposed over IRC. I just didn't have too much free time to fix it, so I went ahead and posted the driver matching what's already in U-Boot. That being said, what's proposed here is the right was forward. Basically if we do it like this then any future TPM TIS driver will only have to define the read/write ops for the underlyng bus.
Best regards
Heinrich
const u8 *value)
- while (len--)
u16 *result)
- if (size < 80)
return -ENOSPC;
- u8 locality;
return true;
- return false;
- do {
- return -1;
return -EINVAL;
return -EINVAL;
- int ret;
- return ret;
Hi Ilias,
On Fri, 2 Jul 2021 at 14:29, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Sure
I'm not sure about the irc side, but it is best to do things on the mailing list so people can see it.
There seems to be quite a bit of duplicated code in this new driver. I think it would be better to come up with the interface first, as Heinrich suggests. Would something like regmap be good enough?
There's duplicated code in *every* TPM driver we have right now. That.. includes the cr50 and the TPM2 spi implementation we have. That's why I posted it as is. The interface you are looking for is the TIS described one from TCG. I am not sure if regmap is a good idea in that regard, but since I agree with both of you that having an abstracted TIS core makes sense in general, I'll go ahead and split my code. Then we can take a step back and port the remaining drivers to that.
Cheers /Ilias
Ilias Apalodimas
