Re: [U-Boot] [PATCH v6 0/2] armv8: Support loading 32-bit OS in AArch32 execution state
-----邮件原件----- 发件人: york sun [mailto:york.sun@nxp.com] 发送时间: Thursday, October 06, 2016 3:00 AM 收件人: Alison Wang b18965@freescale.com; agraf@suse.de; Scott Wood scott.wood@nxp.com; Stuart Yoder stuart.yoder@nxp.com; Leo Li leoyang.li@nxp.com; fenghua@phytium.com.cn; linus.walleij@linaro.org; ryan.harkin@linaro.org; monstr@monstr.eu; thomas.ab@samsung.com; mk7.kang@samsung.com; u-boot@lists.denx.de 抄送: Jason Jin jason.jin@nxp.com 主题: Re: [PATCH v6 0/2] armv8: Support loading 32-bit OS in AArch32 execution state
On 09/09/2016 01:56 AM, Alison Wang wrote:
This series is to support loading a 32-bit OS, the execution state will change from AArch64 to AArch32 when jumping to kernel. The architecture information will be got through checking FIT image, then U-Boot will
load 32-bit OS or 64-bit OS automatically.
Spin-table method is used for secondary cores to load 32-bit OS. The architecture information will be got through checking FIT image and saved in the os_arch element of spin-table, then the secondary cores will check os_arch and jump to 32-bit OS or 64-bit OS automatically.
Changes in v6:
- Modified armv8_switch_to_el1(). It will always jump to ep when
switching to AArch64 or AArch32 modes.
- Make other platforms compatible with the new armv8_switch_to_el2()
and armv8_switch_to_el1().
Changes in v5:
- Modified armv8_switch_to_el2(). It will always jump to ep when
- Make secondary_switch_to_el2() always jump to ep when switching to
Changes in v4:
- Correct config ARM64_SUPPORT_AARCH32.
- Omit arch and ftaddr arguments.
- Rename "xreg5" to "tmp".
- Use xxx_RES1 to combine all RES1 fields in xxx register.
- Use an immediate cmp directly.
- Use #ifdef for CONFIG_ARM64_SUPPORT_AARCH32.
Changes in v3:
- Comments the functions and the arguments.
- Rename the real parameters.
- Use the macros instead of the magic values.
- Remove the redundant codes.
- Clean up all of the mess in boot_jump_linux().
- Add CONFIG_ARM64_SUPPORT_AARCH32 to detect for some ARM64 system
doesn't support AArch32 state.
- Adjust the arguments for armv8_switch_to_el2_m and
armv8_switch_to_el1_m.
Changes in v2:
- armv8_switch_to_el2_aarch32() is removed. armv8_switch_to_el2_m is
used
to switch to AArch64 EL2 or AArch32 Hyp.
- armv8_switch_to_el1_aarch32() is removed. armv8_switch_to_el1_m is
used
to switch to AArch64 EL1 or AArch32 SVC.
- Support to call armv8_switch_to_el2_m and armv8_switch_to_el1_m.
Alison Wang (2): armv8: Support loading 32-bit OS in AArch32 execution state armv8: fsl-layerscape: SMP support for loading 32-bit OS
Alison,
The change overall is OK, but the way you split the patches is not. If you apply the first patch and then compile, you will see all our armv8 platforms are broken. You changed the definition of macro armv8_switch_to_el2_m in the first patch, but you change the call in the second patch.
[Alison Wang] Sorry for the mistake. I will split the patches correctly in v7.
Thanks.
Best Regards, Alison Wang
Alison Wang
