[PATCH v2 0/4] Update Microchip PolarFire SoC
This patch set updates Microchip PolarFire SoC Icicle Kit support of RISC-V U-Boot.
The patches are based upon latest U-Boot tree (https://source.denx.de/u-boot/u-boot) at commit id d843273a8022e70ccbdb6ad446b3335c3753e84f
The memory device node is updated based on the latest FPGA reference design v2022.10 and a small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use, add Microchip QSPI driver.
Changes in v2: - Add Co-developed-by with patch - Replace spi-nand with flash in device node - Add board details for QSPI NAND - Rename QSPI driver file with microchip-coreqspi - Add microchip,coreqspi-rtl-v2 to the compatible list - Use MICROCHIP_COREQSPI instead of MICROCHIP_QSPI in kconfig
Padmarao Begari (4): riscv: dts: Update memory configuration riscv: dts: Add QSPI NAND device node spi: Add Microchip PolarFire SoC QSPI driver riscv: Update Microchip MPFS Icicle Kit support
arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 85 ++-- board/microchip/mpfs_icicle/Kconfig | 7 + configs/microchip_mpfs_icicle_defconfig | 1 + drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/microchip_coreqspi.c | 505 +++++++++++++++++++ 6 files changed, 549 insertions(+), 56 deletions(-) create mode 100644 drivers/spi/microchip_coreqspi.c
In the v2022.10 Icicle reference design, the seg registers are going to be changed, resulting in a required change to the memory map. A small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use, so that it can cache its payload between reboots of a specific context.
Co-developed-by: Conor Dooley conor.dooley@microchip.com Signed-off-by: Conor Dooley conor.dooley@microchip.com Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Conor Dooley conor.dooley@microchip.com --- arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 70 ++++---------------- 1 file changed, 14 insertions(+), 56 deletions(-)
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts index 287ef3d23b..876c475069 100644 --- a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright (C) 2021 Microchip Technology Inc. + * Copyright (C) 2021-2022 Microchip Technology Inc. * Padmarao Begari padmarao.begari@microchip.com */
@@ -28,70 +28,28 @@ timebase-frequency = <RTCCLK_FREQ>; };
- reserved-memory { - ranges; - #size-cells = <2>; - #address-cells = <2>; - - fabricbuf0: fabricbuf@0 { - compatible = "shared-dma-pool"; - reg = <0x0 0xae000000 0x0 0x2000000>; - label = "fabricbuf0-ddr-c"; - }; - - fabricbuf1: fabricbuf@1 { - compatible = "shared-dma-pool"; - reg = <0x0 0xc0000000 0x0 0x8000000>; - label = "fabricbuf1-ddr-nc"; - }; - - fabricbuf2: fabricbuf@2 { - compatible = "shared-dma-pool"; - reg = <0x0 0xd8000000 0x0 0x8000000>; - label = "fabricbuf2-ddr-nc-wcb"; - }; - }; - - udmabuf0 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-c0"; - minor-number = <0>; - size = <0x0 0x2000000>; - memory-region = <&fabricbuf0>; - sync-mode = <3>; - }; - - udmabuf1 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-nc0"; - minor-number = <1>; - size = <0x0 0x8000000>; - memory-region = <&fabricbuf1>; - sync-mode = <3>; - }; - - udmabuf2 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-nc-wcb0"; - minor-number = <2>; - size = <0x0 0x8000000>; - memory-region = <&fabricbuf2>; - sync-mode = <3>; - }; - ddrc_cache_lo: memory@80000000 { device_type = "memory"; - reg = <0x0 0x80000000 0x0 0x2e000000>; - clocks = <&clkcfg CLK_DDRC>; + reg = <0x0 0x80000000 0x0 0x40000000>; status = "okay"; };
ddrc_cache_hi: memory@1000000000 { device_type = "memory"; - reg = <0x10 0x0 0x0 0x40000000>; - clocks = <&clkcfg CLK_DDRC>; + reg = <0x10 0x40000000 0x0 0x40000000>; status = "okay"; }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + hss_payload: region@BFC00000 { + reg = <0x0 0xBFC00000 0x0 0x400000>; + no-map; + }; + }; };
&uart1 {
Hey Padmarao, Since the release was done the other day I think that this should be s/are going to be/have been
- Copyright (C) 2021 Microchip Technology Inc.
- Copyright (C) 2021-2022 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
FWIW I think we should add the compatible that the linux dt has, signifying that this memory layout is compatible with the v2022.10 release and later (w/ appropriate line-wrapping ofc): compatible = "microchip,mpfs-icicle-reference-rtlv2210", "microchip,mpfs-icicle-kit", "microchip,mpfs";
Other than that: Reviewed-by: Conor Dooley conor.dooley@microchip.com
- reserved-memory {
ranges;
#size-cells = <2>;
- udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
- udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
- udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
status = "okay"; };
status = "okay"; };reg = <0x10 0x40000000 0x0 0x40000000>;
- reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
On 22/10/2022 12:21, Conor Dooley wrote:
EXTERNAL EMAIL: Do not click links or open attachments unless you know the content is safe
reserved-memory {
ranges;
#size-cells = <2>;
udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
reg = <0x0 0x80000000 0x0 0x40000000>; status = "okay"; }; ddrc_cache_hi: memory@1000000000 {
Sorry for not noticing prior, but this should bee changed too to match the reg property shouldn't it..
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
Hi Conor,
On Tue, 2022-10-25 at 19:50 +0000, Conor Dooley - M52691 wrote: On 22/10/2022 12:21, Conor Dooley wrote:
reserved-memory {
ranges;
#size-cells = <2>;
udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
Yes, will update same.
Regards Padmarao
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
Ok, will update same.
Ok, will add compatible "microchip,mpfs-icicle-reference-rtlv2210"
Regards Padmarao
reserved-memory {
ranges;
#size-cells = <2>;
udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
reg = <0x0 0x80000000 0x0 0x40000000>; status = "okay"; }; ddrc_cache_hi: memory@1000000000 { device_type = "memory";
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
Add QSPI NAND device node to the Microchip PolarFire SoC Icicle kit device tree.
The Winbond NAND flash memory can be connected to the Icicle Kit by using the Mikroe Flash 5 click board and the Pi 3 Click shield.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts index 876c475069..e1fbedc507 100644 --- a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -18,6 +18,7 @@ aliases { serial1 = &uart1; ethernet0 = &mac1; + spi0 = &qspi; };
chosen { @@ -113,3 +114,17 @@ ti,fifo-depth = <0x1>; }; }; + +&qspi { + status = "okay"; + num-cs = <1>; + flash0: flash@0 { + compatible = "spi-nand"; + reg = <0x0>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + spi-max-frequency = <20000000>; + spi-cpol; + spi-cpha; + }; +};
spi0 = &qspi;
chosen {
+&qspi {
- status = "okay";
- num-cs = <1>;
Convention suggests a blank line before children, right? Other than that, LGTM.. Reviewed-by: Conor Dooley conor.dooley@microchip.com
- flash0: flash@0 {
reg = <0x0>;
spi-cpol;
spi-cpha;
2.25.1
Add QSPI driver code for the Microchip PolarFire SoC. This driver supports the QSPI standard, dual and quad mode interfaces.
Co-developed-by: Naga Sureshkumar Relli nagasuresh.relli@microchip.com Signed-off-by: Naga Sureshkumar Relli nagasuresh.relli@microchip.com Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/microchip_coreqspi.c | 505 +++++++++++++++++++++++++++++++ 3 files changed, 512 insertions(+) create mode 100644 drivers/spi/microchip_coreqspi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 2f12081f88..994bfd563e 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -237,6 +237,12 @@ config MESON_SPIFC This driver can be used to access the SPI NOR flash chips on Amlogic Meson SoCs.
+config MICROCHIP_COREQSPI + bool "Microchip FPGA QSPI Controller driver" + help + Enable the QSPI driver for Microchip FPGA QSPI controllers. + This driver can be used on Polarfire SoC. + config MPC8XX_SPI bool "MPC8XX SPI Driver" depends on MPC8xx diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 50ba43550b..6d1154b902 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -40,6 +40,7 @@ obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_IPROC_QSPI) += iproc_qspi.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_MESON_SPIFC) += meson_spifc.o +obj-$(CONFIG_MICROCHIP_COREQSPI) += microchip_coreqspi.o obj-$(CONFIG_MPC8XX_SPI) += mpc8xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MTK_SNFI_SPI) += mtk_snfi_spi.o diff --git a/drivers/spi/microchip_coreqspi.c b/drivers/spi/microchip_coreqspi.c new file mode 100644 index 0000000000..ea81ddd03c --- /dev/null +++ b/drivers/spi/microchip_coreqspi.c @@ -0,0 +1,505 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + * Naga Sureshkumar Relli nagasuresh.relli@microchip.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <log.h> +#include <malloc.h> +#include <spi.h> +#include <spi-mem.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/types.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * QSPI Control register mask defines + */ +#define CONTROL_ENABLE BIT(0) +#define CONTROL_MASTER BIT(1) +#define CONTROL_XIP BIT(2) +#define CONTROL_XIPADDR BIT(3) +#define CONTROL_CLKIDLE BIT(10) +#define CONTROL_SAMPLE_MASK GENMASK(12, 11) +#define CONTROL_MODE0 BIT(13) +#define CONTROL_MODE12_MASK GENMASK(15, 14) +#define CONTROL_MODE12_EX_RO BIT(14) +#define CONTROL_MODE12_EX_RW BIT(15) +#define CONTROL_MODE12_FULL GENMASK(15, 14) +#define CONTROL_FLAGSX4 BIT(16) +#define CONTROL_CLKRATE_MASK GENMASK(27, 24) +#define CONTROL_CLKRATE_SHIFT 24 + +/* + * QSPI Frames register mask defines + */ +#define FRAMES_TOTALBYTES_MASK GENMASK(15, 0) +#define FRAMES_CMDBYTES_MASK GENMASK(24, 16) +#define FRAMES_CMDBYTES_SHIFT 16 +#define FRAMES_SHIFT 25 +#define FRAMES_IDLE_MASK GENMASK(29, 26) +#define FRAMES_IDLE_SHIFT 26 +#define FRAMES_FLAGBYTE BIT(30) +#define FRAMES_FLAGWORD BIT(31) + +/* + * QSPI Interrupt Enable register mask defines + */ +#define IEN_TXDONE BIT(0) +#define IEN_RXDONE BIT(1) +#define IEN_RXAVAILABLE BIT(2) +#define IEN_TXAVAILABLE BIT(3) +#define IEN_RXFIFOEMPTY BIT(4) +#define IEN_TXFIFOFULL BIT(5) + +/* + * QSPI Status register mask defines + */ +#define STATUS_TXDONE BIT(0) +#define STATUS_RXDONE BIT(1) +#define STATUS_RXAVAILABLE BIT(2) +#define STATUS_TXAVAILABLE BIT(3) +#define STATUS_RXFIFOEMPTY BIT(4) +#define STATUS_TXFIFOFULL BIT(5) +#define STATUS_READY BIT(7) +#define STATUS_FLAGSX4 BIT(8) +#define STATUS_MASK GENMASK(8, 0) + +#define BYTESUPPER_MASK GENMASK(31, 16) +#define BYTESLOWER_MASK GENMASK(15, 0) + +#define MAX_DIVIDER 16 +#define MIN_DIVIDER 0 +#define MAX_DATA_CMD_LEN 256 + +/* QSPI ready time out value */ +#define TIMEOUT_MS (1000 * 60) + +/* + * QSPI Register offsets. + */ +#define REG_CONTROL (0x00) +#define REG_FRAMES (0x04) +#define REG_IEN (0x0c) +#define REG_STATUS (0x10) +#define REG_DIRECT_ACCESS (0x14) +#define REG_UPPER_ACCESS (0x18) +#define REG_RX_DATA (0x40) +#define REG_TX_DATA (0x44) +#define REG_X4_RX_DATA (0x48) +#define REG_X4_TX_DATA (0x4c) +#define REG_FRAMESUP (0x50) + +/** + * struct mchp_coreqspi - Defines qspi driver instance + * @regs: Address of the QSPI controller registers + * @freq: QSPI Input frequency + * @txbuf: TX buffer + * @rxbuf: RX buffer + * @tx_len: Number of bytes left to transfer + * @rx_len: Number of bytes left to receive + */ +struct mchp_coreqspi { + void __iomem *regs; + u32 freq; + u8 *txbuf; + u8 *rxbuf; + int tx_len; + int rx_len; +}; + +static void mchp_coreqspi_init_hw(struct mchp_coreqspi *qspi) +{ + u32 control; + + control = CONTROL_CLKIDLE | CONTROL_ENABLE; + + writel(control, qspi->regs + REG_CONTROL); + writel(0, qspi->regs + REG_IEN); +} + +static inline void mchp_coreqspi_read_op(struct mchp_coreqspi *qspi) +{ + u32 control, data; + + if (!qspi->rx_len) + return; + + control = readl(qspi->regs + REG_CONTROL); + + /* + * Read 4-bytes from the SPI FIFO in single transaction and then read + * the reamaining data byte wise. + */ + control |= CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->rx_len >= 4) { + while (readl(qspi->regs + REG_STATUS) & STATUS_RXFIFOEMPTY) + ; + data = readl(qspi->regs + REG_X4_RX_DATA); + *(u32 *)qspi->rxbuf = data; + qspi->rxbuf += 4; + qspi->rx_len -= 4; + } + + control &= ~CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->rx_len--) { + while (readl(qspi->regs + REG_STATUS) & STATUS_RXFIFOEMPTY) + ; + data = readl(qspi->regs + REG_RX_DATA); + *qspi->rxbuf++ = (data & 0xFF); + } +} + +static inline void mchp_coreqspi_write_op(struct mchp_coreqspi *qspi, bool word) +{ + u32 control, data; + + control = readl(qspi->regs + REG_CONTROL); + control |= CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->tx_len >= 4) { + while (readl(qspi->regs + REG_STATUS) & STATUS_TXFIFOFULL) + ; + data = *(u32 *)qspi->txbuf; + qspi->txbuf += 4; + qspi->tx_len -= 4; + writel(data, qspi->regs + REG_X4_TX_DATA); + } + + control &= ~CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->tx_len--) { + while (readl(qspi->regs + REG_STATUS) & STATUS_TXFIFOFULL) + ; + data = *qspi->txbuf++; + writel(data, qspi->regs + REG_TX_DATA); + } +} + +static inline void mchp_coreqspi_config_op(struct mchp_coreqspi *qspi, + const struct spi_mem_op *op) +{ + u32 idle_cycles = 0; + int total_bytes, cmd_bytes, frames, ctrl; + + cmd_bytes = op->cmd.nbytes + op->addr.nbytes; + total_bytes = cmd_bytes + op->data.nbytes; + + /* + * As per the coreQSPI IP spec,the number of command and data bytes are + * controlled by the frames register for each SPI sequence. This supports + * the SPI flash memory read and writes sequences as below. so configure + * the cmd and total bytes accordingly. + * --------------------------------------------------------------------- + * TOTAL BYTES | CMD BYTES | What happens | + * ______________________________________________________________________ + * | | | + * 1 | 1 | The SPI core will transmit a single byte | + * | | and receive data is discarded | + * | | | + * 1 | 0 | The SPI core will transmit a single byte | + * | | and return a single byte | + * | | | + * 10 | 4 | The SPI core will transmit 4 command | + * | | bytes discarding the receive data and | + * | | transmits 6 dummy bytes returning the 6 | + * | | received bytes and return a single byte | + * | | | + * 10 | 10 | The SPI core will transmit 10 command | + * | | | + * 10 | 0 | The SPI core will transmit 10 command | + * | | bytes and returning 10 received bytes | + * ______________________________________________________________________ + */ + + if (!(op->data.dir == SPI_MEM_DATA_IN)) + cmd_bytes = total_bytes; + + frames = total_bytes & BYTESUPPER_MASK; + writel(frames, qspi->regs + REG_FRAMESUP); + frames = total_bytes & BYTESLOWER_MASK; + frames |= cmd_bytes << FRAMES_CMDBYTES_SHIFT; + + if (op->dummy.buswidth) + idle_cycles = op->dummy.nbytes * 8 / op->dummy.buswidth; + + frames |= idle_cycles << FRAMES_IDLE_SHIFT; + ctrl = readl(qspi->regs + REG_CONTROL); + + if (ctrl & CONTROL_MODE12_MASK) + frames |= (1 << FRAMES_SHIFT); + + frames |= FRAMES_FLAGWORD; + writel(frames, qspi->regs + REG_FRAMES); +} + +static int mchp_coreqspi_wait_for_ready(struct spi_slave *slave) +{ + struct mchp_coreqspi *qspi = dev_get_priv(slave->dev->parent); + unsigned long count = 0; + + while (1) { + if (readl(qspi->regs + REG_STATUS) & STATUS_READY) + return 0; + + udelay(1); + count += 1; + if (count == TIMEOUT_MS) + return -ETIMEDOUT; + } +} + +static int mchp_coreqspi_set_operate_mode(struct mchp_coreqspi *qspi, + const struct spi_mem_op *op) +{ + u32 control = readl(qspi->regs + REG_CONTROL); + + /* + * The operating mode can be configured based on the command that needs + * to be send. + * bits[15:14]: Sets whether multiple bit SPI operates in normal, + * extended or full modes. + * 00: Normal (single DQ0 TX and single DQ1 RX lines) + * 01: Extended RO (command and address bytes on DQ0 only) + * 10: Extended RW (command byte on DQ0 only) + * 11: Full. (command and address are on all DQ lines) + * bit[13]: Sets whether multiple bit SPI uses 2 or 4 bits of data + * 0: 2-bits (BSPI) + * 1: 4-bits (QSPI) + */ + if (op->data.buswidth == 4 || op->data.buswidth == 2) { + control &= ~CONTROL_MODE12_MASK; + if (op->cmd.buswidth == 1 && (op->addr.buswidth == 1 || + op->addr.buswidth == 0)) + control |= CONTROL_MODE12_EX_RO; + else if (op->cmd.buswidth == 1) + control |= CONTROL_MODE12_EX_RW; + else + control |= CONTROL_MODE12_FULL; + + control |= CONTROL_MODE0; + } else { + control &= ~(CONTROL_MODE12_MASK | CONTROL_MODE0); + } + + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct mchp_coreqspi *qspi = dev_get_priv(slave->dev->parent); + + u32 address = op->addr.val; + u8 opcode = op->cmd.opcode; + u8 opaddr[5]; + int err = 0, i; + + err = mchp_coreqspi_wait_for_ready(slave); + if (err) + return err; + + err = mchp_coreqspi_set_operate_mode(qspi, op); + if (err) + return err; + + mchp_coreqspi_config_op(qspi, op); + if (op->cmd.opcode) { + qspi->txbuf = &opcode; + qspi->rxbuf = NULL; + qspi->tx_len = op->cmd.nbytes; + qspi->rx_len = 0; + mchp_coreqspi_write_op(qspi, false); + } + + qspi->txbuf = &opaddr[0]; + if (op->addr.nbytes) { + for (i = 0; i < op->addr.nbytes; i++) + qspi->txbuf[i] = address >> (8 * (op->addr.nbytes - i - 1)); + + qspi->rxbuf = NULL; + qspi->tx_len = op->addr.nbytes; + qspi->rx_len = 0; + mchp_coreqspi_write_op(qspi, false); + } + + if (op->data.nbytes) { + if (op->data.dir == SPI_MEM_DATA_OUT) { + qspi->txbuf = (u8 *)op->data.buf.out; + qspi->rxbuf = NULL; + qspi->rx_len = 0; + qspi->tx_len = op->data.nbytes; + mchp_coreqspi_write_op(qspi, true); + } else { + qspi->txbuf = NULL; + qspi->rxbuf = (u8 *)op->data.buf.in; + qspi->rx_len = op->data.nbytes; + qspi->tx_len = 0; + mchp_coreqspi_read_op(qspi); + } + } + + return 0; +} + +static bool mchp_coreqspi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + if (!spi_mem_default_supports_op(slave, op)) + return false; + + if ((op->data.buswidth == 4 || op->data.buswidth == 2) && + (op->cmd.buswidth == 1 && (op->addr.buswidth == 1 || + op->addr.buswidth == 0))) { + /* + * If the command and address are on DQ0 only, then this + * controller doesn't support sending data on dual and + * quad lines. but it supports reading data on dual and + * quad lines with same configuration as command and + * address on DQ0. + * i.e. The control register[15:13] :EX_RO(read only) is + * meant only for the command and address are on DQ0 but + * not to write data, it is just to read. + * Ex: 0x34h is Quad Load Program Data which is not + * supported. Then the spi-mem layer will iterate over + * each command and it will chose the supported one. + */ + if (op->data.dir == SPI_MEM_DATA_OUT) + return false; + } + + return true; +} + +static int mchp_coreqspi_adjust_op_size(struct spi_slave *slave, + struct spi_mem_op *op) +{ + if (op->data.dir == SPI_MEM_DATA_OUT) { + if (op->data.nbytes > MAX_DATA_CMD_LEN) + op->data.nbytes = MAX_DATA_CMD_LEN; + } + + return 0; +} + +static int mchp_coreqspi_set_speed(struct udevice *dev, uint speed) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + u32 control, baud_rate_val = 0; + + if (speed > (qspi->freq / 2)) + speed = qspi->freq / 2; + + baud_rate_val = DIV_ROUND_UP(qspi->freq, 2 * speed); + if (baud_rate_val >= MAX_DIVIDER || baud_rate_val <= MIN_DIVIDER) + return -EINVAL; + + control = readl(qspi->regs + REG_CONTROL); + control &= ~CONTROL_CLKRATE_MASK; + control |= baud_rate_val << CONTROL_CLKRATE_SHIFT; + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_set_mode(struct udevice *dev, uint mode) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + u32 control; + + control = readl(qspi->regs + REG_CONTROL); + + if ((mode & SPI_CPOL) && (mode & SPI_CPHA)) + control |= CONTROL_CLKIDLE; + else + control &= ~CONTROL_CLKIDLE; + + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_claim_bus(struct udevice *dev) +{ + return 0; +} + +static int mchp_coreqspi_release_bus(struct udevice *dev) +{ + return 0; +} + +static int mchp_coreqspi_probe(struct udevice *dev) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + struct clk clk; + ulong clk_rate; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&clk); + if (ret) + return ret; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) + return -EINVAL; + qspi->freq = clk_rate; + + qspi->regs = dev_read_addr_ptr(dev); + if (!qspi->regs) + return -EINVAL; + + /* Init the mpfs qspi hw */ + mchp_coreqspi_init_hw(qspi); + + return 0; +} + +static const struct spi_controller_mem_ops mchp_coreqspi_mem_ops = { + .adjust_op_size = mchp_coreqspi_adjust_op_size, + .supports_op = mchp_coreqspi_supports_op, + .exec_op = mchp_coreqspi_exec_op, +}; + +static const struct dm_spi_ops mchp_coreqspi_ops = { + .claim_bus = mchp_coreqspi_claim_bus, + .release_bus = mchp_coreqspi_release_bus, + .set_speed = mchp_coreqspi_set_speed, + .set_mode = mchp_coreqspi_set_mode, + .mem_ops = &mchp_coreqspi_mem_ops, +}; + +static const struct udevice_id mchp_coreqspi_ids[] = { + { .compatible = "microchip,mpfs-coreqspi-rtl-v2" }, + { .compatible = "microchip,mpfs-qspi" }, + { } +}; + +U_BOOT_DRIVER(mchp_coreqspi) = { + .name = "mchp_coreqspi", + .id = UCLASS_SPI, + .of_match = mchp_coreqspi_ids, + .ops = &mchp_coreqspi_ops, + .priv_auto = sizeof(struct mchp_coreqspi), + .probe = mchp_coreqspi_probe, +};
Hey Padmarao, just zipping through and cross referencing against the linux driver.. Why's this a 60 * 1000 when linux times out after 500 ms? Other than that, things look identical modulo the required interrupt and clocking changes for U-Boot. Reviewed-by: Conor Dooley conor.dooley@microchip.com
Thanks, Conor.
Co-developed-by: Naga Sureshkumar Relli < nagasuresh.relli@microchip.com> Signed-off-by: Naga Sureshkumar Relli < nagasuresh.relli@microchip.com> Signed-off-by: Padmarao Begari padmarao.begari@microchip.com
Ok, will update as per Linux time out(500ms)
Regards Padmarao
Thanks, Conor.
This patch updates Microchip MPFS Icicle Kit support. For now, add Microchip QSPI driver and a small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Conor Dooley conor.dooley@microchip.com --- board/microchip/mpfs_icicle/Kconfig | 7 +++++++ configs/microchip_mpfs_icicle_defconfig | 1 + 2 files changed, 8 insertions(+)
diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig index 092e411215..332f03f0da 100644 --- a/board/microchip/mpfs_icicle/Kconfig +++ b/board/microchip/mpfs_icicle/Kconfig @@ -50,5 +50,12 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_I2C imply DM_I2C imply SYS_I2C_MICROCHIP + imply SPI + imply DM_SPI + imply MICROCHIP_COREQSPI + imply MTD_SPI_NAND + imply CMD_MTD + imply MTD_PARTITIONS + imply CMD_MTDPARTS
endif diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 6113c5be80..c295b9bad3 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -17,6 +17,7 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=282 CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_SYS_MEM_TOP_HIDE=0x400000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MTD=y
Conor Dooley
Conor.Dooley@microchip.com
Padmarao Begari
Padmarao.Begari@microchip.com
