[PATCH v2,RESEND] mmc: mtk-sd: increase the minimum bus frequency
With a 48MHz input clock, the lowest bus frequency can be as low as 48000000 / (4 * 4095) = 2930Hz. Such an extremely low frequency will cause the mmc framework take seconds to finish the initialization.
Limiting the minimum bus frequency to a slightly higher value can solve the issue without any side effects.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/mmc/mtk-sd.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 48a764be82..8599f095bc 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -232,6 +232,8 @@
#define SCLK_CYCLES_SHIFT 20
+#define MIN_BUS_CLK 200000 + #define CMD_INTS_MASK \ (MSDC_INT_CMDRDY | MSDC_INT_RSPCRCERR | MSDC_INT_CMDTMO)
@@ -1639,6 +1641,9 @@ static int msdc_drv_probe(struct udevice *dev) else cfg->f_min = host->src_clk_freq / (4 * 4095);
+ if (cfg->f_min < MIN_BUS_CLK) + cfg->f_min = MIN_BUS_CLK; + if (cfg->f_max < cfg->f_min || cfg->f_max > host->src_clk_freq) cfg->f_max = host->src_clk_freq;
Weijie Gao
