[PATCH] CI: Update to LLVM-13
- Switch sources and CI scripts to install and use LLVM-13 - Update to latest "focal" tag.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 4 ++-- .gitlab-ci.yml | 4 ++-- tools/docker/Dockerfile | 6 +++--- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 53f86f5184c5..2ca146c0fdf4 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -2,7 +2,7 @@ variables: windows_vm: vs2017-win2016 ubuntu_vm: ubuntu-18.04 macos_vm: macOS-10.15 - ci_runner_image: trini/u-boot-gitlab-ci-runner:focal-20210827-30Sep2021 + ci_runner_image: trini/u-boot-gitlab-ci-runner:focal-20210921-05Oct2021 # Add '-u 0' options for Azure pipelines, otherwise we get "permission # denied" error when it tries to "useradd -m -u 1001 vsts_azpcontainer", # since our $(ci_runner_image) user is not root. @@ -183,7 +183,7 @@ jobs: TEST_PY_BD: "sandbox" sandbox_clang: TEST_PY_BD: "sandbox" - OVERRIDE: "-O clang-12" + OVERRIDE: "-O clang-13" sandbox_spl: TEST_PY_BD: "sandbox_spl" TEST_PY_TEST_SPEC: "test_ofplatdata or test_handoff or test_spl" diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 5a3e2f0ceb85..699ce991fb37 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -2,7 +2,7 @@
# Grab our configured image. The source for this is found at: # https://source.denx.de/u-boot/gitlab-ci-runner -image: trini/u-boot-gitlab-ci-runner:focal-20210827-30Sep2021 +image: trini/u-boot-gitlab-ci-runner:focal-20210921-05Oct2021
# We run some tests in different order, to catch some failures quicker. stages: @@ -190,7 +190,7 @@ sandbox test.py: sandbox with clang test.py: variables: TEST_PY_BD: "sandbox" - OVERRIDE: "-O clang-12" + OVERRIDE: "-O clang-13" <<: *buildman_and_testpy_dfn
sandbox_spl test.py: diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 92113dcb72f9..1a44423d77b7 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -2,7 +2,7 @@ # This Dockerfile is used to build an image containing basic stuff to be used # to build U-Boot and run our test suites.
-FROM ubuntu:focal-20210827 +FROM ubuntu:focal-20210921 MAINTAINER Tom Rini trini@konsulko.com LABEL Description=" This image is for building U-Boot inside a container"
@@ -12,7 +12,7 @@ ENV DEBIAN_FRONTEND=noninteractive # Add LLVM repository RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib/apt/lists/* RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add - -RUN echo deb http://apt.llvm.org/focal/ llvm-toolchain-focal-12 main | tee /etc/apt/sources.list.d/llvm.list +RUN echo deb http://apt.llvm.org/focal/ llvm-toolchain-focal-13 main | tee /etc/apt/sources.list.d/llvm.list
# Manually install the kernel.org "Crosstool" based toolchains for gcc-11.1.0 RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/11.1.0/... | tar -C /opt -xJ @@ -39,7 +39,7 @@ RUN apt-get update && apt-get install -y \ binutils-dev \ bison \ build-essential \ - clang-12 \ + clang-13 \ coreutils \ cpio \ cppcheck \
