[PATCH] board: rockchip: add Khadas Edge2 RK3588 board
Khadas Edge2 is a Rockchip RK3588S based SBC (Single Board Computer) by Khadas.
There are tree variants depending on the DRAM size : 8G and 16G.
Specification:
Rockchip RK3588S SoC 4x ARM Cortex-A76, 4x ARM Cortex-A55 8/16GB memory LPDDR4x Mali G610MP4 GPU 3x MIPI CSI 4x lanes 2x MIPI-DSI DPHY 4x lanes 32/64GB eMMC 1x USB 2.0, 1x USB 3.0, 2x USB-Type-C 1x HDMI 2.1 output, 1x DP 1.4 output USB PD over USB Type-C
Kernel commit: 04d552993522 ("arm64: dts: rockchip: Add Khadas edge2 board")
Signed-off-by: Jacobe Zang jacobe.zang@wesion.com --- Add support for Khadas Edge2 --- arch/arm/mach-rockchip/rk3588/Kconfig | 23 +++ board/khadas/khadas-edge2-rk3588s/Kconfig | 12 ++ board/khadas/khadas-edge2-rk3588s/MAINTAINERS | 6 + configs/khadas-edge2-rk3588s_defconfig | 215 ++++++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/khadas-edge2-rk3588s.h | 15 ++ 6 files changed, 272 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index b5a0e624a53..7d817e7f1bd 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -74,6 +74,28 @@ config TARGET_JAGUAR_RK3588 - fan controller (AMC6821 emulation) * 80-pin Mezzanine connector
+config TARGET_KHADAS_EDGE2_RK3588 + bool "Khadas Edge2 RK3588 board" + select BOARD_LATE_INIT + help + Khadas Edge2 is a Rockchip RK3588S based SBC (Single Board Computer) + by Khadas. + + There are tree variants depending on the DRAM size : 8G and 16G. + + Specification: + + Rockchip RK3588S SoC + 4x ARM Cortex-A76, 4x ARM Cortex-A55 + 8/16GB memory LPDDR4x + Mali G610MP4 GPU + 3x MIPI CSI 4x lanes + 2x MIPI-DSI DPHY 4x lanes + 32/64GB eMMC + 1x USB 2.0, 1x USB 3.0, 2x USB-Type-C + 1x HDMI 2.1 output, 1x DP 1.4 output + USB PD over USB Type-C + config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT @@ -393,6 +415,7 @@ source "board/friendlyelec/nanopi-r6c-rk3588s/Kconfig" source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/hardkernel/odroid_m2/Kconfig" source "board/indiedroid/nova/Kconfig" +source "board/khadas/khadas-edge2-rk3588s/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" diff --git a/board/khadas/khadas-edge2-rk3588s/Kconfig b/board/khadas/khadas-edge2-rk3588s/Kconfig new file mode 100644 index 00000000000..dd7b6cd8054 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_KHADAS_EDGE2_RK3588 + +config SYS_BOARD + default "khadas-edge2-rk3588s" + +config SYS_VENDOR + default "khadas" + +config SYS_CONFIG_NAME + default "khadas-edge2-rk3588s" + +endif diff --git a/board/khadas/khadas-edge2-rk3588s/MAINTAINERS b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS new file mode 100644 index 00000000000..3f16923b0f2 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS @@ -0,0 +1,6 @@ +KHADAS-EDGE2-RK3588S +M: Jacobe Zang jacobe.zang@wesion.com +S: Maintained +F: configs/khadas-edge2-rk3588s_defconfig +F: include/configs/khadas-edge2-rk3588s.h +F: dts/upstream/src/arm64/rockchip/rk3588s-khadas-edge2.dts \ No newline at end of file diff --git a/configs/khadas-edge2-rk3588s_defconfig b/configs/khadas-edge2-rk3588s_defconfig new file mode 100644 index 00000000000..208c72ca425 --- /dev/null +++ b/configs/khadas-edge2-rk3588s_defconfig @@ -0,0 +1,215 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-khadas-edge2" +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x80000 +CONFIG_ROCKCHIP_RK3588=y +CONFIG_ROCKCHIP_FIT_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_KHADAS_EDGE2_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-khadas-edge2.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_MMC_WRITE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_ATF=y +CONFIG_SPL_AB=y +CONFIG_SYS_PROMPT="kedge2# " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DTIMG=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_SPI=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DM=y +CONFIG_DM_SPI=y +CONFIG_DM_MMC=y +# CONFIG_DM_SPI_FLASH=y +CONFIG_MMC=y +# CONFIG_MMC_SPI=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTP_BOOTM=y +CONFIG_CMD_TFTP_FLASH=y +CONFIG_CMD_MTD_BLK=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_DTB_MINIMUM=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_OF_U_BOOT_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_SARADC_ROCKCHIP_V2=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x1 +CONFIG_FASTBOOT_BUF_ADDR=0xc00800 +CONFIG_FASTBOOT_BUF_SIZE=0x07000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_ROCKCHIP_GPIO_V2=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_I2C_MUX=y +CONFIG_DM_KEY=y +CONFIG_RK8XX_PWRKEY=y +CONFIG_ADC_KEY=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SPL_MISC=y +CONFIG_MISC_DECOMPRESS=y +CONFIG_SPL_MISC_DECOMPRESS=y +CONFIG_ROCKCHIP_OTP=y +CONFIG_ROCKCHIP_HW_DECOMPRESS=y +CONFIG_SPL_ROCKCHIP_HW_DECOMPRESS=y +CONFIG_SPL_ROCKCHIP_SECURE_OTP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_MTD=y +CONFIG_MTD_BLK=y +CONFIG_MTD_DEVICE=y +# CONFIG_NAND=y +# CONFIG_MTD_SPI_NAND=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=80000000 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_FUEL_GAUGE=y +CONFIG_POWER_FG_CW201X=y +CONFIG_POWER_FG_CW221X=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_SPI_RK8XX=y +CONFIG_DM_POWER_DELIVERY=y +CONFIG_TYPEC_TCPM=y +CONFIG_TYPEC_TCPCI=y +CONFIG_TYPEC_HUSB311=y +CONFIG_TYPEC_FUSB302=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK860X=y +CONFIG_REGULATOR_RK806=y +CONFIG_CHARGER_BQ25700=y +CONFIG_CHARGER_BQ25890=y +CONFIG_CHARGER_SC8551=y +CONFIG_CHARGER_SGM41542=y +CONFIG_DM_CHARGE_DISPLAY=y +CONFIG_CHARGE_ANIMATION=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RAMDISK=y +CONFIG_RAMDISK_RO=y +CONFIG_DM_RESET=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_RESET_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x350a +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_DRM_ROCKCHIP=y +CONFIG_DRM_MAXIM_MAX96745=y +CONFIG_DRM_MAXIM_MAX96755F=y +CONFIG_DRM_PANEL_ROHM_BU18RL82=y +CONFIG_DRM_PANEL_MAXIM_MAX96752F=y +CONFIG_DRM_ROHM_BU18XL82=y +CONFIG_DRM_ROCKCHIP_DW_HDMI_QP=y +CONFIG_DRM_ROCKCHIP_DW_MIPI_DSI2=y +CONFIG_DRM_ROCKCHIP_DW_DP=y +CONFIG_DRM_ROCKCHIP_ANALOGIX_DP=y +CONFIG_DRM_ROCKCHIP_SAMSUNG_MIPI_DCPHY=y +CONFIG_PHY_ROCKCHIP_SAMSUNG_HDPTX_HDMI=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_LIB_RAND=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_N_SIZE=0x200 +CONFIG_RSA_E_SIZE=0x10 +CONFIG_RSA_C_SIZE=0x20 +CONFIG_XBC=y +CONFIG_LZ4=y +CONFIG_LZMA=y +CONFIG_ERRNO_STR=y +CONFIG_AVB_LIBAVB=y +CONFIG_AVB_LIBAVB_AB=y +CONFIG_AVB_LIBAVB_ATX=y +CONFIG_AVB_LIBAVB_USER=y +CONFIG_RK_AVB_LIBAVB_USER=y +CONFIG_OPTEE_CLIENT=y +CONFIG_OPTEE_V2=y +CONFIG_OPTEE_ALWAYS_USE_SECURITY_PARTITION=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d2347..ea98b73d33c 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -137,6 +137,7 @@ List of mainline supported Rockchip boards: - Generic RK3588S/RK3588 (generic-rk3588) - Hardkernel ODROID-M2 (odroid-m2-rk3588s) - Indiedroid Nova (nova-rk3588s) + - Khadas Edge2 (khadas-edge2-rk3588s) - Pine64 QuartzPro64 (quartzpro64-rk3588) - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) diff --git a/include/configs/khadas-edge2-rk3588s.h b/include/configs/khadas-edge2-rk3588s.h new file mode 100644 index 00000000000..d279cf3826a --- /dev/null +++ b/include/configs/khadas-edge2-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024 Khadas Technology Co., Ltd. + */ + +#ifndef __KHADAS_EDGE2_RK3588_H +#define __KHADAS_EDGE2_RK3588_H + +#include <configs/rk3588_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif /* __KHADAS_EDGE2_RK3588_H */
--- base-commit: cca05617a8f585f3a98a8fa82f75cc68a530d771 change-id: 20241119-edge2-18ac09a490ab
Hi Jacobe,
On 11/19/24 8:46 AM, Jacobe Zang wrote:
[You don't often get email from jacobe.zang@wesion.com. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
Specification:
help
by Khadas.
Specification:
Mali G610MP4 GPU
32/64GB eMMC
- config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT
+config SYS_BOARD
+config SYS_VENDOR
default "khadas"
This config option doesn't exist upstream.
The above options do not exist upstream.
etc..
Please generate a defconfig that is actually made for upstream and enables what's needed.
Cheers, Quentin
On 2024/11/25 22:05, Quentin Schulz wrote:
Hi Jacobe,
Specification:
arch/arm/mach-rockchip/rk3588/Kconfig | 23 +++ board/khadas/khadas-edge2-rk3588s/Kconfig | 12 ++ board/khadas/khadas-edge2-rk3588s/MAINTAINERS | 6 + configs/khadas-edge2-rk3588s_defconfig | 215 ++++++++++++++++ ++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/khadas-edge2-rk3588s.h | 15 ++ 6 files changed, 272 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach- rockchip/rk3588/Kconfig index b5a0e624a53..7d817e7f1bd 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -74,6 +74,28 @@ config TARGET_JAGUAR_RK3588 - fan controller (AMC6821 emulation) * 80-pin Mezzanine connector
+ Specification:
config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT @@ -393,6 +415,7 @@ source "board/friendlyelec/nanopi-r6c-rk3588s/ Kconfig" source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/hardkernel/odroid_m2/Kconfig" source "board/indiedroid/nova/Kconfig" +source "board/khadas/khadas-edge2-rk3588s/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" diff --git a/board/khadas/khadas-edge2-rk3588s/Kconfig b/board/khadas/ khadas-edge2-rk3588s/Kconfig new file mode 100644 index 00000000000..dd7b6cd8054 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_KHADAS_EDGE2_RK3588
+endif diff --git a/board/khadas/khadas-edge2-rk3588s/MAINTAINERS b/board/ khadas/khadas-edge2-rk3588s/MAINTAINERS new file mode 100644 index 00000000000..3f16923b0f2 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS @@ -0,0 +1,6 @@ +KHADAS-EDGE2-RK3588S +M: Jacobe Zang jacobe.zang@wesion.com +S: Maintained +F: configs/khadas-edge2-rk3588s_defconfig +F: include/configs/khadas-edge2-rk3588s.h +F: dts/upstream/src/arm64/rockchip/rk3588s-khadas-edge2.dts \ No newline at end of file diff --git a/configs/khadas-edge2-rk3588s_defconfig b/configs/khadas- edge2-rk3588s_defconfig new file mode 100644 index 00000000000..208c72ca425 --- /dev/null +++ b/configs/khadas-edge2-rk3588s_defconfig @@ -0,0 +1,215 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-khadas-edge2" +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x80000 +CONFIG_ROCKCHIP_RK3588=y +CONFIG_ROCKCHIP_FIT_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_KHADAS_EDGE2_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-khadas-edge2.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_MMC_WRITE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_ATF=y +CONFIG_SPL_AB=y +CONFIG_SYS_PROMPT="kedge2# " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DTIMG=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_SPI=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DM=y +CONFIG_DM_SPI=y +CONFIG_DM_MMC=y +# CONFIG_DM_SPI_FLASH=y +CONFIG_MMC=y +# CONFIG_MMC_SPI=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTP_BOOTM=y +CONFIG_CMD_TFTP_FLASH=y +CONFIG_CMD_MTD_BLK=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_DTB_MINIMUM=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned- clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_OF_U_BOOT_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock- parents"
etc..
Okay~ Thanks for correction! I will recheck ;-)
Jacobe Zang
Quentin Schulz
