[PATCH] defconfig: xea: Change default spi-nor memory bus to 2 (single binary)
After the re-sync with Linux kernel (v6.0) of the XEA DTS (SHA1: 7d08ddd09b75e7a3c103cc0d0d3ed700287f268e) the alias for SPI bus, to which SPI-NOR memory is connected, has changed from 'spi3' to 'spi2'.
To be in sync with current u-boot's xea dts, the default bus number (which allows running 'sf probe' without any extra parameters given) has been adjusted.
Signed-off-by: Lukasz Majewski lukma@denx.de
configs/imx28_xea_sb_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx28_xea_sb_defconfig b/configs/imx28_xea_sb_defconfig index 0b3259866e..9872d35c1b 100644 --- a/configs/imx28_xea_sb_defconfig +++ b/configs/imx28_xea_sb_defconfig @@ -74,7 +74,7 @@ CONFIG_MMC_MXS=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_DM_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_BUS=2 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_SPANSION=y
Applied, thanks.
Fabio Estevam
Lukasz Majewski
