[U-Boot] [PATCH v2] fsl_qspi: Improve QSPI driver to incorporate 4 byte commands
Previously, the SPI framework supported only 3-byte opcodes but the FSL QSPI controller used to deal with flashes that work with 4-byte opcodes. As a workaround to resolve this, for every 3-byte opcodes sent by framework FSL QSPI driver used to explicitly send corresponding 4-byte opcodes.
Now the framework has been updated to send 4-byte opcodes and FSL QSPI driver needs correction. This change will be applicable for the following defconfig where we disable CONFIG_FLASH_BAR: LS1088A, LS1046A, LS1043A, LS1012A, LS2088A defconfigs
Signed-off-by: Ashish Kumar ashish.kumar@nxp.com Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com --- Changes in v2: - Update commit message - Reduce patchset to one patch - This patch is no more applicable: https://patchwork.ozlabs.org/patch/1090122/
drivers/spi/fsl_qspi.c | 45 +++++++++++++++++++++++++++++------------- 1 file changed, 31 insertions(+), 14 deletions(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 1598c4f698..217005f525 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -26,7 +26,8 @@ DECLARE_GLOBAL_DATA_PTR; #define TX_BUFFER_SIZE 0x40 #endif
-#define OFFSET_BITS_MASK GENMASK(23, 0) +#define OFFSET_BITS_MASK GENMASK(27, 0) +#define OFFSET_BITS_MASK_24 GENMASK(23, 0)
#define FLASH_STATUS_WEL 0x02
@@ -754,7 +755,8 @@ static void qspi_op_erase(struct fsl_qspi_priv *priv) while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) ;
- if (priv->cur_seqid == QSPI_CMD_SE) { + if ((priv->cur_seqid == QSPI_CMD_SE_4B) || + (priv->cur_seqid == QSPI_CMD_SE)) { qspi_write32(priv->flags, ®s->ipcr, (SEQID_SE << QSPI_IPCR_SEQID_SHIFT) | 0); } else if (priv->cur_seqid == QSPI_CMD_BE_4K) { @@ -775,31 +777,44 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, u32 txbuf;
WATCHDOG_RESET(); - if (dout) { if (flags & SPI_XFER_BEGIN) { priv->cur_seqid = *(u8 *)dout; - memcpy(&txbuf, dout, 4); + if (FSL_QSPI_FLASH_SIZE > SZ_16M && bytes > 4) + memcpy(&txbuf, dout + 1, 4); + else + memcpy(&txbuf, dout, 4); }
if (flags == SPI_XFER_END) { priv->sf_addr = wr_sfaddr; - qspi_op_write(priv, (u8 *)dout, bytes); - return 0; + if (priv->cur_seqid == QSPI_CMD_PP || + priv->cur_seqid == QSPI_CMD_PP_4B || + priv->cur_seqid == QSPI_CMD_WRAR) { + qspi_op_write(priv, (u8 *)dout, bytes); + return 0; + } }
- if (priv->cur_seqid == QSPI_CMD_FAST_READ || - priv->cur_seqid == QSPI_CMD_RDAR) { + if ((priv->cur_seqid == QSPI_CMD_FAST_READ) || + (priv->cur_seqid == QSPI_CMD_FAST_READ_4B)) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; + } else if (priv->cur_seqid == QSPI_CMD_RDAR) { + priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK_24; } else if ((priv->cur_seqid == QSPI_CMD_SE) || - (priv->cur_seqid == QSPI_CMD_BE_4K)) { + priv->cur_seqid == QSPI_CMD_SE_4B) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; qspi_op_erase(priv); + } else if (priv->cur_seqid == QSPI_CMD_BE_4K) { + priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK_24; + qspi_op_erase(priv); } else if (priv->cur_seqid == QSPI_CMD_PP || - priv->cur_seqid == QSPI_CMD_WRAR) { + priv->cur_seqid == QSPI_CMD_PP_4B) { wr_sfaddr = swab32(txbuf) & OFFSET_BITS_MASK; + } else if (priv->cur_seqid == QSPI_CMD_WRAR) { + wr_sfaddr = swab32(txbuf) & OFFSET_BITS_MASK_24; } else if ((priv->cur_seqid == QSPI_CMD_BRWR) || - (priv->cur_seqid == QSPI_CMD_WREAR)) { + (priv->cur_seqid == QSPI_CMD_WREAR)) { #ifdef CONFIG_SPI_FLASH_BAR wr_sfaddr = 0; #endif @@ -807,7 +822,8 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, }
if (din) { - if (priv->cur_seqid == QSPI_CMD_FAST_READ) { + if ((priv->cur_seqid == QSPI_CMD_FAST_READ) || + (priv->cur_seqid == QSPI_CMD_FAST_READ_4B)) { #ifdef CONFIG_SYS_FSL_QSPI_AHB qspi_ahb_read(priv, din, bytes); #else @@ -815,10 +831,11 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, #endif } else if (priv->cur_seqid == QSPI_CMD_RDAR) { qspi_op_read(priv, din, bytes); - } else if (priv->cur_seqid == QSPI_CMD_RDID) + } else if (priv->cur_seqid == QSPI_CMD_RDID) { qspi_op_rdid(priv, din, bytes); - else if (priv->cur_seqid == QSPI_CMD_RDSR) + } else if (priv->cur_seqid == QSPI_CMD_RDSR) { qspi_op_rdsr(priv, din, bytes); + } #ifdef CONFIG_SPI_FLASH_BAR else if ((priv->cur_seqid == QSPI_CMD_BRRD) || (priv->cur_seqid == QSPI_CMD_RDEAR)) {
On Fri, Apr 26, 2019 at 6:12 PM Rajat Srivastava rajat.srivastava@nxp.com wrote:
Changes in v2:
WATCHDOG_RESET();
else
memcpy(&txbuf, dout, 4); } if (flags == SPI_XFER_END) { priv->sf_addr = wr_sfaddr;
I wonder why we still have flash specific stuff handling, we have spi-mem like Linux. can't we handle these via spi-mem?
Hi Jagan,
Changes in v2:
WATCHDOG_RESET();
else
Sure we can. I started working on porting the Linux driver to U-Boot some weeks ago, but didn't have time to continue with this recently.
See this branch for the current state: https://github.com/fschrempf/u-boot/commits/fsl_qspi_spimem_port.
Regards, Frieder
Hi Frieder,
On Wed, May 29, 2019 at 6:14 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Jagan,
Changes in v2:
WATCHDOG_RESET();
else
Look promising, I think it would be better have this conversion instead of concentrating code which were moved/remove later and indeed we have enough time for next MW.
Jagan.
Jagan Teki
Rajat Srivastava
Schrempf Frieder
