[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
Summary: - Beelink-x2 STB support (Marcus) - H6 DDR3, LPDDR3 changes (Andre, Jernej) - H6 pin controller, USB PHY (Andre)
thanks, Jagan.
The following changes since commit 6070ef409c1018860e8dd1f077297546d9d80115:
Merge branch '2019-07-12-master-imports' (2019-07-14 09:05:20 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-sunxi master
for you to fetch changes up to f96238e253661b43168352010a2628957940bd4b:
sunxi: H6: Enable USB for existing boards (2019-07-16 17:13:15 +0530)
---------------------------------------------------------------- Andre Przywara (11): sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to Kconfig sunxi: H6: DRAM: avoid memcpy() on MMIO registers sunxi: H6: DRAM: follow recommended PHY init algorithm sunxi: H6: move LPDDR3 timing definition into separate file sunxi: H6: Add DDR3 support to DRAM controller driver sunxi: H6: Add DDR3-1333 timings sunxi: move SUNXI_GPIO to Kconfig sunxi: gpio: Enable support for H6 pin controller sunxi: clocks: Add H6 USB clock gates and resets sunxi: phy: Add USB PHY support for Allwinner H6 sunxi: H6: Enable USB for existing boards
Jernej Skrabec (1): sunxi: H6: Add DDR3 DRAM delay values
Marcus Cooper (1): sun8i: h3: Add support for the Beelink-x2 STB
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-h3-beelink-x2.dts | 216 +++++++++++++++++++ arch/arm/include/asm/arch-sunxi/dram_sun50i_h6.h | 35 ++++ arch/arm/mach-sunxi/Kconfig | 19 +- arch/arm/mach-sunxi/Makefile | 1 + arch/arm/mach-sunxi/dram_sun50i_h6.c | 251 +++++++---------------- arch/arm/mach-sunxi/dram_timings/Makefile | 2 + arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c | 144 +++++++++++++ arch/arm/mach-sunxi/dram_timings/h6_lpddr3.c | 132 ++++++++++++ board/sunxi/MAINTAINERS | 6 + common/spl/Kconfig | 3 + configs/A10-OLinuXino-Lime_defconfig | 1 - configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-OLinuXino-Lime_defconfig | 1 - configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 - configs/A20-OLinuXino_MICRO_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 - configs/A20-Olimex-SOM204-EVB_defconfig | 1 - configs/A33-OLinuXino_defconfig | 1 - configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_M2_Ultra_defconfig | 1 - configs/Bananapi_defconfig | 1 - configs/Bananapi_m2m_defconfig | 1 - configs/Bananapro_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - configs/CSQ_CS908_defconfig | 1 - configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard2_defconfig | 1 - configs/Cubieboard4_defconfig | 1 - configs/Cubieboard_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Cubietruck_plus_defconfig | 1 - configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 1 - configs/Hyundai_A7HD_defconfig | 1 - configs/Itead_Ibox_A20_defconfig | 1 - configs/Lamobo_R1_defconfig | 1 - configs/LicheePi_Zero_defconfig | 1 - configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino3_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 1 - configs/MK808C_defconfig | 1 - configs/MSI_Primo73_defconfig | 1 - configs/MSI_Primo81_defconfig | 1 - configs/Marsboard_A10_defconfig | 1 - configs/Mele_A1000G_quad_defconfig | 1 - configs/Mele_A1000_defconfig | 1 - configs/Mele_I7_defconfig | 1 - configs/Mele_M3_defconfig | 1 - configs/Mele_M5_defconfig | 1 - configs/Mele_M9_defconfig | 1 - configs/Merrii_A80_Optimus_defconfig | 1 - configs/Mini-X_defconfig | 1 - configs/Nintendo_NES_Classic_Edition_defconfig | 1 - configs/Orangepi_defconfig | 1 - configs/Orangepi_mini_defconfig | 1 - configs/Sinlinx_SinA31s_defconfig | 1 - configs/Sinlinx_SinA33_defconfig | 1 - configs/Sinovoip_BPI_M2_defconfig | 1 - configs/Sinovoip_BPI_M3_defconfig | 1 - configs/Sunchip_CX-A99_defconfig | 1 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wits_Pro_A20_DKT_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/Yones_Toptech_BS1078_V2_defconfig | 1 - configs/a64-olinuxino_defconfig | 1 - configs/amarula_a64_relic_defconfig | 1 - configs/ba10_tv_box_defconfig | 1 - configs/bananapi_m1_plus_defconfig | 1 - configs/bananapi_m2_berry_defconfig | 1 - configs/bananapi_m2_plus_h3_defconfig | 1 - configs/bananapi_m2_plus_h5_defconfig | 1 - configs/bananapi_m2_zero_defconfig | 1 - configs/bananapi_m64_defconfig | 1 - configs/beelink_gs1_defconfig | 4 +- configs/beelink_x2_defconfig | 16 ++ configs/colorfly_e708_q1_defconfig | 1 - configs/difrnce_dit4350_defconfig | 1 - configs/dserve_dsrv9703c_defconfig | 1 - configs/emlid_neutis_n5_devboard_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/h8_homlet_v2_defconfig | 1 - configs/i12-tvbox_defconfig | 1 - configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 1 - configs/icnova-a20-swac_defconfig | 1 - configs/inet1_defconfig | 1 - configs/inet86dz_defconfig | 1 - configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/inet_q972_defconfig | 1 - configs/jesurun_q5_defconfig | 1 - configs/libretech_all_h3_cc_h2_plus_defconfig | 1 - configs/libretech_all_h3_cc_h3_defconfig | 1 - configs/libretech_all_h3_cc_h5_defconfig | 1 - configs/mixtile_loftq_defconfig | 1 - configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/mk802ii_defconfig | 1 - configs/nanopi_a64_defconfig | 1 - configs/nanopi_m1_defconfig | 1 - configs/nanopi_m1_plus_defconfig | 1 - configs/nanopi_neo2_defconfig | 1 - configs/nanopi_neo_air_defconfig | 1 - configs/nanopi_neo_defconfig | 1 - configs/nanopi_neo_plus2_defconfig | 1 - configs/oceanic_5205_5inmfd_defconfig | 1 - configs/orangepi_2_defconfig | 1 - configs/orangepi_lite2_defconfig | 4 +- configs/orangepi_lite_defconfig | 1 - configs/orangepi_one_defconfig | 1 - configs/orangepi_one_plus_defconfig | 4 +- configs/orangepi_pc2_defconfig | 1 - configs/orangepi_pc_defconfig | 1 - configs/orangepi_pc_plus_defconfig | 1 - configs/orangepi_plus2e_defconfig | 1 - configs/orangepi_plus_defconfig | 1 - configs/orangepi_prime_defconfig | 1 - configs/orangepi_r1_defconfig | 1 - configs/orangepi_win_defconfig | 1 - configs/orangepi_zero_defconfig | 1 - configs/orangepi_zero_plus2_defconfig | 1 - configs/orangepi_zero_plus_defconfig | 1 - configs/parrot_r16_defconfig | 1 - configs/pine64-lts_defconfig | 1 - configs/pine64_plus_defconfig | 1 - configs/pine_h64_defconfig | 5 +- configs/pinebook_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 - configs/sopine_baseboard_defconfig | 1 - configs/sun8i_a23_evb_defconfig | 1 - configs/sunxi_Gemei_G9_defconfig | 1 - configs/tbs_a711_defconfig | 1 - configs/teres_i_defconfig | 1 - drivers/clk/sunxi/clk_h6.c | 29 +++ drivers/gpio/Kconfig | 6 + drivers/gpio/sunxi_gpio.c | 2 + drivers/phy/allwinner/phy-sun4i-usb.c | 20 ++ include/configs/sunxi-common.h | 3 - scripts/config_whitelist.txt | 1 - 165 files changed, 719 insertions(+), 328 deletions(-) create mode 100644 arch/arm/dts/sun8i-h3-beelink-x2.dts create mode 100644 arch/arm/mach-sunxi/dram_timings/h6_ddr3_1333.c create mode 100644 arch/arm/mach-sunxi/dram_timings/h6_lpddr3.c create mode 100644 configs/beelink_x2_defconfig
On Tue, Jul 16, 2019 at 08:29:57PM +0530, Jagan Teki wrote:
Hi Tom,
Summary:
thanks, Jagan.
Jagan Teki
