[U-Boot] [PATCH] gpio: zynq: Read of mach data in platdata with dev_get_driver_data
Remove bogus zynq_gpio_getplat_data() and read driver data directly.
Driver should use platdata structure but this change should be fine before this is fixed. Simon: Is ofdata_to_platdata correct function where this should be read?
--- drivers/gpio/zynq_gpio.c | 29 ++--------------------------- 1 file changed, 2 insertions(+), 27 deletions(-)
diff --git a/drivers/gpio/zynq_gpio.c b/drivers/gpio/zynq_gpio.c index 9a915544784d..26f69b1a713f 100644 --- a/drivers/gpio/zynq_gpio.c +++ b/drivers/gpio/zynq_gpio.c @@ -15,8 +15,6 @@ #include <dm.h> #include <fdtdec.h>
-DECLARE_GLOBAL_DATA_PTR; - /* Maximum banks */ #define ZYNQ_GPIO_MAX_BANK 4
@@ -334,36 +332,11 @@ static const struct udevice_id zynq_gpio_ids[] = { { } };
-static void zynq_gpio_getplat_data(struct udevice *dev) -{ - const struct udevice_id *of_match = zynq_gpio_ids; - int ret; - struct zynq_gpio_privdata *priv = dev_get_priv(dev); - - while (of_match->compatible) { - ret = fdt_node_offset_by_compatible(gd->fdt_blob, -1, - of_match->compatible); - if (ret >= 0) { - priv->p_data = - (struct zynq_platform_data *)of_match->data; - break; - } else { - of_match++; - continue; - } - } - - if (!priv->p_data) - printf("No Platform data found\n"); -} - static int zynq_gpio_probe(struct udevice *dev) { struct zynq_gpio_privdata *priv = dev_get_priv(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- zynq_gpio_getplat_data(dev); - if (priv->p_data) uc_priv->gpio_count = priv->p_data->ngpio;
@@ -376,6 +349,8 @@ static int zynq_gpio_ofdata_to_platdata(struct udevice *dev)
priv->base = (phys_addr_t)dev_read_addr(dev);
+ priv->p_data = (struct zynq_platform_data *)dev_get_driver_data(dev); + return 0; }
Yes.
Michal Simek
