[U-Boot] [PATCH v3] zlib: updated to v.1.2.3
This patch updates zlib to the latest stable version. Only relevant zlib parts were ported to u-boot tree, as already did for the current zlib (0.95). New zlib guarantees a faster inflate performances other then others improvements as explained at www.zlib.net
Signed-off-by: Giuseppe Condorelli giuseppe.condorelli@st.com Reviewed-by: Angelo Castello angelo.castello@st.com --- include/u-boot/zlib.h | 718 ++++++--- lib_generic/zlib.c | 3931 +++++++++++++++++++++++++------------------------ 2 files changed, 2464 insertions(+), 2185 deletions(-)
diff --git a/include/u-boot/zlib.h b/include/u-boot/zlib.h index e441494..fb27081 100644 --- a/include/u-boot/zlib.h +++ b/include/u-boot/zlib.h @@ -1,21 +1,21 @@ /* - * This file is derived from zlib.h and zconf.h from the zlib-0.95 + * This file is derived from zlib.h and zconf.h from the zlib-1.2.3 * distribution by Jean-loup Gailly and Mark Adler, with some additions * by Paul Mackerras to aid in implementing Deflate compression and * decompression for PPP packets. */
-/* - * ==FILEVERSION 960122== - * - * This marker is used by the Linux installation script to determine - * whether an up-to-date version of this file is already installed. - */ + /* + * ==FILEVERSION 960122== + * + * This marker is used by the Linux installation script to determine + * whether an up-to-date version of this file is already installed. + */
/* zlib.h -- interface of the 'zlib' general purpose compression library - version 0.95, Aug 16th, 1995. + version 1.2.3, July 18th, 2005
- Copyright (C) 1995 Jean-loup Gailly and Mark Adler + Copyright (C) 1995-2005 Jean-loup Gailly and Mark Adler
This software is provided 'as-is', without any express or implied warranty. In no event will the authors be held liable for any damages @@ -34,44 +34,151 @@ 3. This notice may not be removed or altered from any source distribution.
Jean-loup Gailly Mark Adler - gzip@prep.ai.mit.edu madler@alumni.caltech.edu - */ + jloup@gzip.org madler@alumni.caltech.edu +
-#ifndef _ZLIB_H -#define _ZLIB_H + The data format used by the zlib library is described by RFCs (Request for + Comments) 1950 to 1952 in the files http://www.ietf.org/rfc/rfc1950.txt + (zlib format), rfc1951.txt (deflate format) and rfc1952.txt (gzip format). +*/ + +#ifndef ZLIB_H +#define ZLIB_H + +#ifdef __cplusplus +extern "C" { +#endif
-/* #include "zconf.h" */ /* included directly here */ +#define ZLIB_VERSION "1.2.3" +#define ZLIB_VERNUM 0x1230
+/* #include "zconf.h" */ /* included directly here */ /* zconf.h -- configuration of the zlib compression library - * Copyright (C) 1995 Jean-loup Gailly. + * Copyright (C) 1995-2005 Jean-loup Gailly. * For conditions of distribution and use, see copyright notice in zlib.h */
-/* From: zconf.h,v 1.12 1995/05/03 17:27:12 jloup Exp */ - +/* Begin of new zconf.h */ /* - The library does not install any signal handler. It is recommended to - add at least a handler for SIGSEGV when decompressing; the library checks - the consistency of the input data whenever possible but may go nuts - for some forms of corrupted input. + * If you *really* need a unique prefix for all types and library functions, + * compile with -DZ_PREFIX. The "standard" zlib should be compiled without it. */ +#ifdef Z_PREFIX +# define deflateInit_ z_deflateInit_ +# define deflate z_deflate +# define deflateEnd z_deflateEnd +# define inflateInit_ z_inflateInit_ +# define inflate z_inflate +# define inflateEnd z_inflateEnd +# define deflateInit2_ z_deflateInit2_ +# define deflateSetDictionary z_deflateSetDictionary +# define deflateCopy z_deflateCopy +# define deflateReset z_deflateReset +# define deflateParams z_deflateParams +# define deflateBound z_deflateBound +# define deflatePrime z_deflatePrime +# define inflateInit2_ z_inflateInit2_ +# define inflateSetDictionary z_inflateSetDictionary +# define inflateSync z_inflateSync +# define inflateSyncPoint z_inflateSyncPoint +# define inflateCopy z_inflateCopy +# define inflateReset z_inflateReset +# define inflateBack z_inflateBack +# define inflateBackEnd z_inflateBackEnd +# define compress z_compress +# define compress2 z_compress2 +# define compressBound z_compressBound +# define uncompress z_uncompress +# define adler32 z_adler32 +# define crc32 z_crc32 +# define get_crc_table z_get_crc_table +# define zError z_zError + +# define alloc_func z_alloc_func +# define free_func z_free_func +# define in_func z_in_func +# define out_func z_out_func +# define Byte z_Byte +# define uInt z_uInt +# define uLong z_uLong +# define Bytef z_Bytef +# define charf z_charf +# define intf z_intf +# define uIntf z_uIntf +# define uLongf z_uLongf +# define voidpf z_voidpf +# define voidp z_voidp +#endif + +#if defined(__MSDOS__) && !defined(MSDOS) +# define MSDOS +#endif +#if (defined(OS_2) || defined(__OS2__)) && !defined(OS2) +# define OS2 +#endif +#if defined(_WINDOWS) && !defined(WINDOWS) +# define WINDOWS +#endif +#if defined(_WIN32) || defined(_WIN32_WCE) || defined(__WIN32__) +# ifndef WIN32 +# define WIN32 +# endif +#endif +#if (defined(MSDOS) || defined(OS2) || defined(WINDOWS)) && !defined(WIN32) +# if !defined(__GNUC__) && !defined(__FLAT__) && !defined(__386__) +# ifndef SYS16BIT +# define SYS16BIT +# endif +# endif +#endif
/* * Compile with -DMAXSEG_64K if the alloc function cannot allocate more * than 64k bytes at a time (needed on systems with 16-bit int). - * Compile with -DUNALIGNED_OK if it is OK to access shorts or ints - * at addresses which are not a multiple of their size. - * Under DOS, -DFAR=far or -DFAR=__far may be needed. */ +#ifdef SYS16BIT +# define MAXSEG_64K +#endif +#ifdef MSDOS +# define UNALIGNED_OK +#endif
-#ifndef STDC -# if defined(MSDOS) || defined(__STDC__) || defined(__cplusplus) +#ifdef __STDC_VERSION__ +# ifndef STDC # define STDC # endif +# if __STDC_VERSION__ >= 199901L +# ifndef STDC99 +# define STDC99 +# endif +# endif +#endif +#if !defined(STDC) && (defined(__STDC__) || defined(__cplusplus)) +# define STDC +#endif +#if !defined(STDC) && (defined(__GNUC__) || defined(__BORLANDC__)) +# define STDC +#endif +#if !defined(STDC) && (defined(MSDOS) || defined(WINDOWS) || defined(WIN32)) +# define STDC +#endif +#if !defined(STDC) && (defined(OS2) || defined(__HOS_AIX__)) +# define STDC +#endif + +#if defined(__OS400__) && !defined(STDC) /* iSeries (formerly AS/400). */ +# define STDC +#endif + +#ifndef STDC +# ifndef const /* cannot use !defined(STDC) && !defined(const) on Mac */ +# define const /* note: need a more gentle solution here */ +# endif #endif
-#ifdef __MWERKS__ /* Metrowerks CodeWarrior declares fileno() in unix.h */ -# include <unix.h> +/* Some Mac compilers merge all .h files incorrectly: */ +#if defined(__MWERKS__)||defined(applec)||defined(THINK_C)||defined(__SC__) +# define NO_DUMMY_DECL #endif
/* Maximum value for memLevel in deflateInit2 */ @@ -83,17 +190,17 @@ # endif #endif
-#ifndef FAR -# define FAR -#endif - -/* Maximum value for windowBits in deflateInit2 and inflateInit2 */ +/* Maximum value for windowBits in deflateInit2 and inflateInit2. + * WARNING: reducing MAX_WBITS makes minigzip unable to extract .gz files + * created by gzip. (Files created by minigzip can still be extracted by + * gzip.) + */ #ifndef MAX_WBITS # define MAX_WBITS 15 /* 32K LZ77 window */ #endif
/* The memory requirements for deflate are (in bytes): - 1 << (windowBits+2) + 1 << (memLevel+9) + (1 << (windowBits+2)) + (1 << (memLevel+9)) that is: 128K for windowBits=15 + 128K for memLevel = 8 (default values) plus a few kilobytes for small objects. For example, if you want to reduce the default memory requirements from 256K to 128K, compile with @@ -105,7 +212,7 @@ for small objects. */
- /* Type declarations */ + /* Type declarations */
#ifndef OF /* function prototypes */ # ifdef STDC @@ -115,124 +222,268 @@ # endif #endif
+/* The following definitions for FAR are needed only for MSDOS mixed + * model programming (small or medium model with some far allocations). + * This was tested only with MSC; for other MSDOS compilers you may have + * to define NO_MEMCPY in zutil.h. If you don't need the mixed model, + * just define FAR to be empty. + */ +#ifdef SYS16BIT +# if defined(M_I86SM) || defined(M_I86MM) + /* MSC small or medium model */ +# define SMALL_MEDIUM +# ifdef _MSC_VER +# define FAR _far +# else +# define FAR far +# endif +# endif +# if (defined(__SMALL__) || defined(__MEDIUM__)) + /* Turbo C small or medium model */ +# define SMALL_MEDIUM +# ifdef __BORLANDC__ +# define FAR _far +# else +# define FAR far +# endif +# endif +#endif + +#if defined(WINDOWS) || defined(WIN32) + /* If building or using zlib as a DLL, define ZLIB_DLL. + * This is not mandatory, but it offers a little performance increase. + */ +# ifdef ZLIB_DLL +# if defined(WIN32) && (!defined(__BORLANDC__) || (__BORLANDC__ >= 0x500)) +# ifdef ZLIB_INTERNAL +# define ZEXTERN extern __declspec(dllexport) +# else +# define ZEXTERN extern __declspec(dllimport) +# endif +# endif +# endif /* ZLIB_DLL */ + /* If building or using zlib with the WINAPI/WINAPIV calling convention, + * define ZLIB_WINAPI. + * Caution: the standard ZLIB1.DLL is NOT compiled using ZLIB_WINAPI. + */ +# ifdef ZLIB_WINAPI +# ifdef FAR +# undef FAR +# endif +# include <windows.h> + /* No need for _export, use ZLIB.DEF instead. */ + /* For complete Windows compatibility, use WINAPI, not __stdcall. */ +# define ZEXPORT WINAPI +# ifdef WIN32 +# define ZEXPORTVA WINAPIV +# else +# define ZEXPORTVA FAR CDECL +# endif +# endif +#endif + +#if defined (__BEOS__) +# ifdef ZLIB_DLL +# ifdef ZLIB_INTERNAL +# define ZEXPORT __declspec(dllexport) +# define ZEXPORTVA __declspec(dllexport) +# else +# define ZEXPORT __declspec(dllimport) +# define ZEXPORTVA __declspec(dllimport) +# endif +# endif +#endif + +#ifndef ZEXTERN +# define ZEXTERN extern +#endif +#ifndef ZEXPORT +# define ZEXPORT +#endif +#ifndef ZEXPORTVA +# define ZEXPORTVA +#endif + +#ifndef FAR +# define FAR +#endif + +#if !defined(__MACTYPES__) typedef unsigned char Byte; /* 8 bits */ +#endif typedef unsigned int uInt; /* 16 bits or more */ typedef unsigned long uLong; /* 32 bits or more */
-typedef Byte FAR Bytef; -typedef char FAR charf; -typedef int FAR intf; -typedef uInt FAR uIntf; +#ifdef SMALL_MEDIUM + /* Borland C/C++ and some old MSC versions ignore FAR inside typedef */ +# define Bytef Byte FAR +#else + typedef Byte FAR Bytef; +#endif +typedef char FAR charf; +typedef int FAR intf; +typedef uInt FAR uIntf; typedef uLong FAR uLongf;
#ifdef STDC - typedef void FAR *voidpf; - typedef void *voidp; + typedef void const *voidpc; + typedef void FAR *voidpf; + typedef void *voidp; #else - typedef Byte FAR *voidpf; - typedef Byte *voidp; + typedef Byte const *voidpc; + typedef Byte FAR *voidpf; + typedef Byte *voidp; #endif
-/* end of original zconf.h */ +# ifdef VMS +# include <unixio.h> /* for off_t */ +# endif +# define z_off_t off_t +#ifndef SEEK_SET +# define SEEK_SET 0 /* Seek from beginning of file. */ +# define SEEK_CUR 1 /* Seek from current position. */ +# define SEEK_END 2 /* Set file pointer to EOF plus "offset" */ +#endif +#ifndef z_off_t +# define z_off_t long +#endif + +#if defined(__OS400__) +# define NO_vsnprintf +#endif
-#define ZLIB_VERSION "0.95P" +#if defined(__MVS__) +# define NO_vsnprintf +# ifdef FAR +# undef FAR +# endif +#endif + +/* MVS linker does not support external names larger than 8 bytes */ +#if defined(__MVS__) +# pragma map(deflateInit_,"DEIN") +# pragma map(deflateInit2_,"DEIN2") +# pragma map(deflateEnd,"DEEND") +# pragma map(deflateBound,"DEBND") +# pragma map(inflateInit_,"ININ") +# pragma map(inflateInit2_,"ININ2") +# pragma map(inflateEnd,"INEND") +# pragma map(inflateSync,"INSY") +# pragma map(inflateSetDictionary,"INSEDI") +# pragma map(compressBound,"CMBND") +# pragma map(inflate_table,"INTABL") +# pragma map(inflate_fast,"INFA") +# pragma map(inflate_copyright,"INCOPY") +#endif +/* End of new zconf.h */
/* The 'zlib' compression library provides in-memory compression and decompression functions, including integrity checks of the uncompressed data. This version of the library supports only one compression method - (deflation) but other algorithms may be added later and will have the same + (deflation) but other algorithms will be added later and will have the same stream interface.
- For compression the application must provide the output buffer and - may optionally provide the input buffer for optimization. For decompression, - the application must provide the input buffer and may optionally provide - the output buffer for optimization. - Compression can be done in a single step if the buffers are large enough (for example if an input file is mmap'ed), or can be done by repeated calls of the compression function. In the latter case, the application must provide more input and/or consume the output (providing more output space) before each call. -*/ - -typedef voidpf (*alloc_func) OF((voidpf opaque, uInt items, uInt size)); -typedef void (*free_func) OF((voidpf opaque, voidpf address, uInt nbytes));
-typedef void (*cb_func) OF((Bytef *buf, uInt len)); - -struct internal_state; + The compressed data format used by default by the in-memory functions is + the zlib format, which is a zlib wrapper documented in RFC 1950, wrapped + around a deflate stream, which is itself documented in RFC 1951.
-typedef struct z_stream_s { - Bytef *next_in; /* next input byte */ - uInt avail_in; /* number of bytes available at next_in */ - uLong total_in; /* total nb of input bytes read so far */ + The library also supports reading and writing files in gzip (.gz) format + with an interface similar to that of stdio using the functions that start + with "gz". The gzip format is different from the zlib format. gzip is a + gzip wrapper, documented in RFC 1952, wrapped around a deflate stream.
- Bytef *next_out; /* next output byte should be put there */ - uInt avail_out; /* remaining free space at next_out */ - uLong total_out; /* total nb of bytes output so far */ + This library can optionally read and write gzip streams in memory as well.
- char *msg; /* last error message, NULL if no error */ - struct internal_state FAR *state; /* not visible by applications */ + The zlib format was designed to be compact and fast for use in memory + and on communications channels. The gzip format was designed for single- + file compression on file systems, has a larger header than zlib to maintain + directory information, and uses a different, slower check method than zlib.
- alloc_func zalloc; /* used to allocate the internal state */ - free_func zfree; /* used to free the internal state */ - voidp opaque; /* private data object passed to zalloc and zfree */ + The library does not install any signal handler. The decoder checks + the consistency of the compressed data, so the library should never + crash even in case of corrupted input. +*/
- Byte data_type; /* best guess about the data type: ascii or binary */ +typedef voidpf (*alloc_func) OF((voidpf opaque, uInt items, uInt size)); +typedef void (*free_func) OF((voidpf opaque, voidpf address, uInt size)); +typedef void (*cb_func) OF((Bytef *buf, uInt len));
- cb_func outcb; /* called regularly just before blocks of output */ +struct internal_state;
+typedef struct z_stream_s { + Bytef *next_in; /* next input byte */ + uInt avail_in; /* number of bytes available at next_in */ + uLong total_in; /* total nb of input bytes read so far */ + Bytef *next_out; /* next output byte should be put there */ + uInt avail_out; /* remaining free space at next_out */ + uLong total_out; /* total nb of bytes output so far */ + char *msg; /* last error message, NULL if no error */ + struct internal_state FAR *state; /* not visible by applications */ + alloc_func zalloc; /* used to allocate the internal state */ + free_func zfree; /* used to free the internal state */ + voidpf opaque; /* private data object passed to zalloc and zfree */ + int data_type; /* best guess about the data type: + binary or text */ + cb_func outcb; /* called regularly just before blocks of output */ + uLong adler; /* adler32 value of the uncompressed data */ + uLong reserved; /* reserved for future use */ } z_stream;
+typedef z_stream FAR *z_streamp; + /* - The application must update next_in and avail_in when avail_in has - dropped to zero. It must update next_out and avail_out when avail_out - has dropped to zero. The application must initialize zalloc, zfree and - opaque before calling the init function. All other fields are set by the - compression library and must not be updated by the application. - - The opaque value provided by the application will be passed as the first - parameter for calls of zalloc and zfree. This can be useful for custom - memory management. The compression library attaches no meaning to the - opaque value. - - zalloc must return Z_NULL if there is not enough memory for the object. - On 16-bit systems, the functions zalloc and zfree must be able to allocate - exactly 65536 bytes, but will not be required to allocate more than this - if the symbol MAXSEG_64K is defined (see zconf.h). WARNING: On MSDOS, - pointers returned by zalloc for objects of exactly 65536 bytes *must* - have their offset normalized to zero. The default allocation function - provided by this library ensures this (see zutil.c). To reduce memory - requirements and avoid any allocation of 64K objects, at the expense of - compression ratio, compile the library with -DMAX_WBITS=14 (see zconf.h). - - The fields total_in and total_out can be used for statistics or - progress reports. After compression, total_in holds the total size of - the uncompressed data and may be saved for use in the decompressor - (particularly if the decompressor wants to decompress everything in - a single step). + gzip header information passed to and from zlib routines. See RFC 1952 + for more details on the meanings of these fields. */ - - /* constants */ - +typedef struct gz_header_s { + int text; /* true if compressed data believed to be text */ + uLong time; /* modification time */ + int xflags; /* extra flags (not used when writing a gzip file) */ + int os; /* operating system */ + Bytef *extra; /* pointer to extra field or Z_NULL if none */ + uInt extra_len; /* extra field length (valid if extra != Z_NULL) */ + uInt extra_max; /* space at extra (only when reading header) */ + Bytef *name; /* pointer to zero-terminated file name or Z_NULL */ + uInt name_max; /* space at name (only when reading header) */ + Bytef *comment; /* pointer to zero-terminated comment or Z_NULL */ + uInt comm_max; /* space at comment (only when reading header) */ + int hcrc; /* true if there was or will be a header crc */ + int done; /* true when done reading gzip header (not used + when writing a gzip file) */ +} gz_header; + +typedef gz_header FAR *gz_headerp; + + /* constants */ #define Z_NO_FLUSH 0 -#define Z_PARTIAL_FLUSH 1 -#define Z_FULL_FLUSH 2 -#define Z_SYNC_FLUSH 3 /* experimental: partial_flush + byte align */ +#define Z_PARTIAL_FLUSH 1 /* will be removed, use Z_SYNC_FLUSH instead */ +#define Z_SYNC_FLUSH 2 +#define Z_FULL_FLUSH 3 #define Z_FINISH 4 -#define Z_PACKET_FLUSH 5 -/* See deflate() below for the usage of these constants */ +#define Z_BLOCK 5 +/* Allowed flush values; see deflate() and inflate() below for details */
#define Z_OK 0 #define Z_STREAM_END 1 +#define Z_NEED_DICT 2 #define Z_ERRNO (-1) #define Z_STREAM_ERROR (-2) #define Z_DATA_ERROR (-3) #define Z_MEM_ERROR (-4) #define Z_BUF_ERROR (-5) -/* error codes for the compression/decompression functions */ +#define Z_VERSION_ERROR (-6) +/* Return codes for the compression/decompression functions. Negative + * values are errors, positive values are used for special but normal events. + */
+#define Z_NO_COMPRESSION 0 #define Z_BEST_SPEED 1 #define Z_BEST_COMPRESSION 9 #define Z_DEFAULT_COMPRESSION (-1) @@ -240,40 +491,42 @@ typedef struct z_stream_s {
#define Z_FILTERED 1 #define Z_HUFFMAN_ONLY 2 +#define Z_RLE 3 +#define Z_FIXED 4 #define Z_DEFAULT_STRATEGY 0 +/* compression strategy; see deflateInit2() below for details */
#define Z_BINARY 0 -#define Z_ASCII 1 +#define Z_TEXT 1 +#define Z_ASCII Z_TEXT /* for compatibility with 1.2.2 and earlier */ #define Z_UNKNOWN 2 -/* Used to set the data_type field */ +/* Possible values of the data_type field (though see inflate()) */ + +#define Z_DEFLATED 8 +/* The deflate compression method (the only one supported in this version) */
#define Z_NULL 0 /* for initializing zalloc, zfree, opaque */
-extern char *zlib_version; -/* The application can compare zlib_version and ZLIB_VERSION for consistency. + /* basic functions */ + +/* The application can compare zlibVersion and ZLIB_VERSION for consistency. If the first character differs, the library code actually used is not compatible with the zlib.h header file used by the application. + This check is automatically made by deflateInit and inflateInit. */
- /* basic functions */ +ZEXTERN int ZEXPORT inflateInit_ OF((z_streamp strm, const char *version, + int stream_size));
-extern int inflateInit OF((z_stream *strm)); +ZEXTERN int ZEXPORT inflate OF((z_streamp strm, int flush)); /* - Initializes the internal stream state for decompression. The fields - zalloc and zfree must be initialized before by the caller. If zalloc and - zfree are set to Z_NULL, inflateInit updates them to use default allocation - functions. - - inflateInit returns Z_OK if success, Z_MEM_ERROR if there was not - enough memory. msg is set to null if there is no error message. - inflateInit does not perform any decompression: this will be done by - inflate(). -*/ - + inflate decompresses as much data as possible, and stops when the input + buffer becomes empty or the output buffer becomes full. It may introduce + some output latency (reading input without producing any output) except when + forced to flush.
-extern int inflate OF((z_stream *strm, int flush)); -/* - Performs one or both of the following actions: + The detailed semantics are as follows. inflate performs one or both of the + following actions:
- Decompress more input starting at next_in and update next_in and avail_in accordingly. If not all input can be processed (because there is not @@ -281,24 +534,39 @@ extern int inflate OF((z_stream *strm, int flush)); will resume at this point for the next call of inflate().
- Provide more output starting at next_out and update next_out and avail_out - accordingly. inflate() always provides as much output as possible - (until there is no more input data or no more space in the output buffer). + accordingly. inflate() provides as much output as possible, until there + is no more input data or no more space in the output buffer (see below + about the flush parameter).
Before the call of inflate(), the application should ensure that at least one of the actions is possible, by providing more input and/or consuming more output, and updating the next_* and avail_* values accordingly. The application can consume the uncompressed output when it wants, for example when the output buffer is full (avail_out == 0), or after each - call of inflate(). - - If the parameter flush is set to Z_PARTIAL_FLUSH or Z_PACKET_FLUSH, - inflate flushes as much output as possible to the output buffer. The - flushing behavior of inflate is not specified for values of the flush - parameter other than Z_PARTIAL_FLUSH, Z_PACKET_FLUSH or Z_FINISH, but the - current implementation actually flushes as much output as possible - anyway. For Z_PACKET_FLUSH, inflate checks that once all the input data - has been consumed, it is expecting to see the length field of a stored - block; if not, it returns Z_DATA_ERROR. + call of inflate(). If inflate returns Z_OK and with zero avail_out, it + must be called again after making room in the output buffer because there + might be more output pending. + + The flush parameter of inflate() can be Z_NO_FLUSH, Z_SYNC_FLUSH, + Z_FINISH, or Z_BLOCK. Z_SYNC_FLUSH requests that inflate() flush as much + output as possible to the output buffer. Z_BLOCK requests that inflate() stop + if and when it gets to the next deflate block boundary. When decoding the + zlib or gzip format, this will cause inflate() to return immediately after + the header and before the first block. When doing a raw inflate, inflate() + will go ahead and process the first block, and will return when it gets to + the end of that block, or when it runs out of data. + + The Z_BLOCK option assists in appending to or combining deflate streams. + Also to assist in this, on return inflate() will set strm->data_type to the + number of unused bits in the last byte taken from strm->next_in, plus 64 + if inflate() is currently decoding the last block in the deflate stream, + plus 128 if inflate() returned immediately after decoding an end-of-block + code or decoding the complete header up to just before the first byte of the + deflate stream. The end-of-block will not be indicated until all of the + uncompressed data from that block has been written to strm->next_out. The + number of unused bits may in general be greater than seven, except when + bit 7 of data_type is set, in which case the number of unused bits will be + less than eight.
inflate() should normally be called until it returns Z_STREAM_END or an error. However if all decompression is to be performed in a single step @@ -308,21 +576,47 @@ extern int inflate OF((z_stream *strm, int flush)); uncompressed data. (The size of the uncompressed data may have been saved by the compressor for this purpose.) The next operation on this stream must be inflateEnd to deallocate the decompression state. The use of Z_FINISH - is never required, but can be used to inform inflate that a faster routine + is never required, but can be used to inform inflate that a faster approach may be used for the single inflate() call.
- inflate() returns Z_OK if some progress has been made (more input - processed or more output produced), Z_STREAM_END if the end of the - compressed data has been reached and all uncompressed output has been - produced, Z_DATA_ERROR if the input data was corrupted, Z_STREAM_ERROR if - the stream structure was inconsistent (for example if next_in or next_out - was NULL), Z_MEM_ERROR if there was not enough memory, Z_BUF_ERROR if no - progress is possible or if there was not enough room in the output buffer - when Z_FINISH is used. In the Z_DATA_ERROR case, the application may then - call inflateSync to look for a good compression block. */ - + In this implementation, inflate() always flushes as much output as + possible to the output buffer, and always uses the faster approach on the + first call. So the only effect of the flush parameter in this implementation + is on the return value of inflate(), as noted below, or when it returns early + because Z_BLOCK is used. + + If a preset dictionary is needed after this call (see inflateSetDictionary + below), inflate sets strm->adler to the adler32 checksum of the dictionary + chosen by the compressor and returns Z_NEED_DICT; otherwise it sets + strm->adler to the adler32 checksum of all output produced so far (that is, + total_out bytes) and returns Z_OK, Z_STREAM_END or an error code as described + below. At the end of the stream, inflate() checks that its computed adler32 + checksum is equal to that saved by the compressor and returns Z_STREAM_END + only if the checksum is correct. + + inflate() will decompress and check either zlib-wrapped or gzip-wrapped + deflate data. The header type is detected automatically. Any information + contained in the gzip header is not retained, so applications that need that + information should instead use raw inflate, see inflateInit2() below, or + inflateBack() and perform their own processing of the gzip header and + trailer. + + inflate() returns Z_OK if some progress has been made (more input processed + or more output produced), Z_STREAM_END if the end of the compressed data has + been reached and all uncompressed output has been produced, Z_NEED_DICT if a + preset dictionary is needed at this point, Z_DATA_ERROR if the input data was + corrupted (input stream not conforming to the zlib format or incorrect check + value), Z_STREAM_ERROR if the stream structure was inconsistent (for example + if next_in or next_out was NULL), Z_MEM_ERROR if there was not enough memory, + Z_BUF_ERROR if no progress is possible or if there was not enough room in the + output buffer when Z_FINISH is used. Note that Z_BUF_ERROR is not fatal, and + inflate() can be called again with more input and more output space to + continue decompressing. If Z_DATA_ERROR is returned, the application may then + call inflateSync() to look for a good compression block if a partial recovery + of the data is desired. +*/
-extern int inflateEnd OF((z_stream *strm)); +ZEXTERN int ZEXPORT inflateEnd OF((z_streamp strm)); /* All dynamically allocated data structures for this stream are freed. This function discards any unprocessed input and does not flush any @@ -333,85 +627,21 @@ extern int inflateEnd OF((z_stream *strm)); static string (which must not be deallocated). */
- /* advanced functions */ + /* Advanced functions */
-extern int inflateInit2 OF((z_stream *strm, - int windowBits)); -/* - This is another version of inflateInit with more compression options. The - fields next_out, zalloc and zfree must be initialized before by the caller. - - The windowBits parameter is the base two logarithm of the maximum window - size (the size of the history buffer). It should be in the range 8..15 for - this version of the library (the value 16 will be allowed soon). The - default value is 15 if inflateInit is used instead. If a compressed stream - with a larger window size is given as input, inflate() will return with - the error code Z_DATA_ERROR instead of trying to allocate a larger window. - - If next_out is not null, the library will use this buffer for the history - buffer; the buffer must either be large enough to hold the entire output - data, or have at least 1<<windowBits bytes. If next_out is null, the - library will allocate its own buffer (and leave next_out null). next_in - need not be provided here but must be provided by the application for the - next call of inflate(). - - If the history buffer is provided by the application, next_out must - never be changed by the application since the decompressor maintains - history information inside this buffer from call to call; the application - can only reset next_out to the beginning of the history buffer when - avail_out is zero and all output has been consumed. - - inflateInit2 returns Z_OK if success, Z_MEM_ERROR if there was - not enough memory, Z_STREAM_ERROR if a parameter is invalid (such as - windowBits < 8). msg is set to null if there is no error message. - inflateInit2 does not perform any decompression: this will be done by - inflate(). -*/ +ZEXTERN int ZEXPORT inflateReset OF((z_streamp strm));
-extern int inflateSync OF((z_stream *strm)); -/* - Skips invalid compressed data until the special marker (see deflate() - above) can be found, or until all available input is skipped. No output - is provided. - - inflateSync returns Z_OK if the special marker has been found, Z_BUF_ERROR - if no more input was provided, Z_DATA_ERROR if no marker has been found, - or Z_STREAM_ERROR if the stream structure was inconsistent. In the success - case, the application may save the current current value of total_in which - indicates where valid compressed data was found. In the error case, the - application may repeatedly call inflateSync, providing more input each time, - until success or end of the input data. -*/ + /* utility functions */
-extern int inflateReset OF((z_stream *strm)); /* - This function is equivalent to inflateEnd followed by inflateInit, - but does not free and reallocate all the internal decompression state. - The stream will keep attributes that may have been set by inflateInit2. - - inflateReset returns Z_OK if success, or Z_STREAM_ERROR if the source - stream state was inconsistent (such as zalloc or state being NULL). + The following utility functions are implemented on top of the + basic stream-oriented functions. To simplify the interface, some + default options are assumed (compression level and memory usage, + standard memory allocation functions). The source code of these + utility functions can easily be modified if you need special options. */
-extern int inflateIncomp OF((z_stream *strm)); -/* - This function adds the data at next_in (avail_in bytes) to the output - history without performing any output. There must be no pending output, - and the decompressor must be expecting to see the start of a block. - Calling this function is equivalent to decompressing a stored block - containing the data at next_in (except that the data is not output). -*/ - - /* checksum functions */ - -/* - This function is not related to compression but is exported - anyway because it might be useful in applications using the - compression library. -*/ - -extern uLong adler32 OF((uLong adler, Bytef *buf, uInt len)); - +ZEXTERN uLong ZEXPORT adler32 OF((uLong adler, const Bytef *buf, uInt len)); /* Update a running Adler-32 checksum with the bytes buf[0..len-1] and return the updated checksum. If buf is NULL, this function returns @@ -427,8 +657,42 @@ extern uLong adler32 OF((uLong adler, Bytef *buf, uInt len)); if (adler != original_adler) error(); */
-#ifndef _Z_UTIL_H - struct internal_state {int dummy;}; /* hack for buggy compilers */ +/* + Combine two Adler-32 checksums into one. For two sequences of bytes, seq1 + and seq2 with lengths len1 and len2, Adler-32 checksums were calculated for + each, adler1 and adler2. adler32_combine() returns the Adler-32 checksum of + seq1 and seq2 concatenated, requiring only adler1, adler2, and len2. +*/ + +ZEXTERN uInt ZEXPORT crc32 OF((uInt crc, const Bytef *buf, uInt len)); +/* + Update a running CRC-32 with the bytes buf[0..len-1] and return the + updated CRC-32. If buf is NULL, this function returns the required initial + value for the for the crc. Pre- and post-conditioning (one's complement) is + performed within this function so it shouldn't be done by the application. + Usage example: + + uLong crc = crc32(0L, Z_NULL, 0); + + while (read_buffer(buffer, length) != EOF) { + crc = crc32(crc, buffer, length); + } + if (crc != original_crc) error(); +*/ + +ZEXTERN int ZEXPORT inflateInit2_ OF((z_streamp strm, int windowBits, + const char *version, int stream_size)); +#define inflateInit(strm) \ + inflateInit_((strm), ZLIB_VERSION, sizeof(z_stream)) +#define inflateInit2(strm, windowBits) \ + inflateInit2_((strm), (windowBits), ZLIB_VERSION, sizeof(z_stream)) + +#if !defined(ZUTIL_H) && !defined(NO_DUMMY_DECL) + struct internal_state {int dummy;}; /* hack for buggy compilers */ +#endif + +#ifdef __cplusplus +} #endif
-#endif /* _ZLIB_H */ +#endif /* ZLIB_H */ diff --git a/lib_generic/zlib.c b/lib_generic/zlib.c index d1cd44c..f415f6b 100644 --- a/lib_generic/zlib.c +++ b/lib_generic/zlib.c @@ -1,5 +1,5 @@ /* - * This file is derived from various .h and .c files from the zlib-0.95 + * This file is derived from various .h and .c files from the zlib-1.2.3 * distribution by Jean-loup Gailly and Mark Adler, with some additions * by Paul Mackerras to aid in implementing Deflate compression and * decompression for PPP packets. See zlib.h for conditions of @@ -14,7 +14,7 @@
/*+++++*/ /* zutil.h -- internal interface and configuration of the compression library - * Copyright (C) 1995 Jean-loup Gailly. + * Copyright (C) 1995-2005 Jean-loup Gailly. * For conditions of distribution and use, see copyright notice in zlib.h */
@@ -23,28 +23,28 @@ subject to change. Applications should only use zlib.h. */
-/* From: zutil.h,v 1.9 1995/05/03 17:27:12 jloup Exp */ - -#define _Z_UTIL_H +#define ZUTIL_H +#define ZLIB_INTERNAL
#include "u-boot/zlib.h" +/* To avoid a build time warning */ +#ifdef STDC +#include <malloc.h> +#endif
#ifndef local -# define local static +#define local static #endif /* compile with -Dlocal if your debugger can't find static symbols */
-#define FAR - -typedef unsigned char uch; +typedef unsigned char uch; typedef uch FAR uchf; typedef unsigned short ush; typedef ush FAR ushf; -typedef unsigned long ulg; - -extern char *z_errmsg[]; /* indexed by 1-zlib_error */ +typedef unsigned long ulg;
-#define ERR_RETURN(strm,err) return (strm->msg=z_errmsg[1-err], err) +#define ERR_MSG(err) z_errmsg[Z_NEED_DICT-(err)] +#define ERR_RETURN(strm,err) return (strm->msg = (char*)ERR_MSG(err), (err)) /* To be used only when the state is known to be valid */
#ifndef NULL @@ -53,17 +53,15 @@ extern char *z_errmsg[]; /* indexed by 1-zlib_error */
/* common constants */
-#define DEFLATED 8 - #ifndef DEF_WBITS -# define DEF_WBITS MAX_WBITS +#define DEF_WBITS MAX_WBITS #endif /* default windowBits for decompression. MAX_WBITS is for compression only */
#if MAX_MEM_LEVEL >= 8 -# define DEF_MEM_LEVEL 8 +#define DEF_MEM_LEVEL 8 #else -# define DEF_MEM_LEVEL MAX_MEM_LEVEL +#define DEF_MEM_LEVEL MAX_MEM_LEVEL #endif /* default memLevel */
@@ -72,51 +70,47 @@ extern char *z_errmsg[]; /* indexed by 1-zlib_error */ #define DYN_TREES 2 /* The three kinds of block type */
-#define MIN_MATCH 3 -#define MAX_MATCH 258 +#define MIN_MATCH 3 +#define MAX_MATCH 258 /* The minimum and maximum match lengths */
/* functions */
#include <linux/string.h> #define zmemcpy memcpy -#define zmemzero(dest, len) memset(dest, 0, len) +#define zmemcmp memcmp +#define zmemzero(dest, len) memset(dest, 0, len)
/* Diagnostic functions */ -#ifdef DEBUG_ZLIB -# include <stdio.h> -# ifndef verbose -# define verbose 0 -# endif -# define Assert(cond,msg) {if(!(cond)) z_error(msg);} -# define Trace(x) fprintf x -# define Tracev(x) {if (verbose) fprintf x ;} -# define Tracevv(x) {if (verbose>1) fprintf x ;} -# define Tracec(c,x) {if (verbose && (c)) fprintf x ;} -# define Tracecv(c,x) {if (verbose>1 && (c)) fprintf x ;} +#ifdef DEBUG +#include <stdio.h> + extern int z_verbose; + extern void z_error OF((char *m)); +#define Assert(cond,msg) {if(!(cond)) z_error(msg);} +#define Trace(x) {if (z_verbose>=0) fprintf x ;} +#define Tracev(x) {if (z_verbose>0) fprintf x ;} +#define Tracevv(x) {if (z_verbose>1) fprintf x ;} +#define Tracec(c,x) {if (z_verbose>0 && (c)) fprintf x ;} +#define Tracecv(c,x) {if (z_verbose>1 && (c)) fprintf x ;} #else -# define Assert(cond,msg) -# define Trace(x) -# define Tracev(x) -# define Tracevv(x) -# define Tracec(c,x) -# define Tracecv(c,x) +#define Assert(cond,msg) +#define Trace(x) +#define Tracev(x) +#define Tracevv(x) +#define Tracec(c,x) +#define Tracecv(c,x) #endif
- -typedef uLong (*check_func) OF((uLong check, Bytef *buf, uInt len)); - -/* voidpf zcalloc OF((voidpf opaque, unsigned items, unsigned size)); */ -/* void zcfree OF((voidpf opaque, voidpf ptr)); */ +voidpf zcalloc OF((voidpf opaque, unsigned items, unsigned size)); +void zcfree OF((voidpf opaque, voidpf ptr, unsigned size));
#define ZALLOC(strm, items, size) \ - (*((strm)->zalloc))((strm)->opaque, (items), (size)) -#define ZFREE(strm, addr, size) \ - (*((strm)->zfree))((strm)->opaque, (voidpf)(addr), (size)) -#define TRY_FREE(s, p, n) {if (p) ZFREE(s, p, n);} + (*((strm)->zalloc))((strm)->opaque, (items), (size)) +#define ZFREE(strm, addr) (*((strm)->zfree))((strm)->opaque, (voidpf)(addr), 0)
-/* deflate.h -- internal compression state - * Copyright (C) 1995 Jean-loup Gailly +/*+++++*/ +/* inftrees.h -- header to use inftrees.c + * Copyright (C) 1995-2005 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
@@ -125,9 +119,47 @@ typedef uLong (*check_func) OF((uLong check, Bytef *buf, uInt len)); subject to change. Applications should only use zlib.h. */
+/* Structure for decoding tables. Each entry provides either the + information needed to do the operation requested by the code that + indexed that table entry, or it provides a pointer to another + table that indexes more bits of the code. op indicates whether + the entry is a pointer to another table, a literal, a length or + distance, an end-of-block, or an invalid code. For a table + pointer, the low four bits of op is the number of index bits of + that table. For a length or distance, the low four bits of op + is the number of extra bits to get after the code. bits is + the number of bits in this code or part of the code to drop off + of the bit buffer. val is the actual byte to output in the case + of a literal, the base length or distance, or the offset from + the current table to the next table. Each entry is four bytes. */ + +typedef struct { + unsigned char op; /* operation, extra bits, table bits */ + unsigned char bits; /* bits in this part of the code */ + unsigned short val; /* offset in table or code value */ +} code; + +/* Maximum size of dynamic tree. The maximum found in a long but non- + exhaustive search was 1444 code structures (852 for length/literals + and 592 for distances, the latter actually the result of an + exhaustive search). The true maximum is not known, but the value + below is more than safe. */ +#define ENOUGH 2048 +#define MAXD 592 + +/* Type of code to build for inftable() */ +typedef enum { + CODES, + LENS, + DISTS +} codetype; + +extern int inflate_table OF((codetype type, unsigned short FAR *lens, + unsigned codes, code FAR * FAR *table, + unsigned FAR *bits, unsigned short FAR *work)); /*+++++*/ -/* infblock.h -- header to use infblock.c - * Copyright (C) 1995 Mark Adler +/* inflate.h -- internal inflate state definition + * Copyright (C) 1995-2004 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
@@ -136,101 +168,113 @@ typedef uLong (*check_func) OF((uLong check, Bytef *buf, uInt len)); subject to change. Applications should only use zlib.h. */
-struct inflate_blocks_state; -typedef struct inflate_blocks_state FAR inflate_blocks_statef; - -local inflate_blocks_statef * inflate_blocks_new OF(( - z_stream *z, - check_func c, /* check function */ - uInt w)); /* window size */ - -local int inflate_blocks OF(( - inflate_blocks_statef *, - z_stream *, - int)); /* initial return code */ - -local void inflate_blocks_reset OF(( - inflate_blocks_statef *, - z_stream *, - uLongf *)); /* check value on output */ - -local int inflate_blocks_free OF(( - inflate_blocks_statef *, - z_stream *, - uLongf *)); /* check value on output */ - -local int inflate_addhistory OF(( - inflate_blocks_statef *, - z_stream *)); - -local int inflate_packet_flush OF(( - inflate_blocks_statef *)); +#define GUNZIP + +/* Possible inflate modes between inflate() calls */ +typedef enum { + HEAD, /* i: waiting for magic header */ + FLAGS, /* i: waiting for method and flags (gzip) */ + TIME, /* i: waiting for modification time (gzip) */ + OS, /* i: waiting for extra flags and operating system (gzip) */ + EXLEN, /* i: waiting for extra length (gzip) */ + EXTRA, /* i: waiting for extra bytes (gzip) */ + NAME, /* i: waiting for end of file name (gzip) */ + COMMENT, /* i: waiting for end of comment (gzip) */ + HCRC, /* i: waiting for header crc (gzip) */ + DICTID, /* i: waiting for dictionary check value */ + DICT, /* waiting for inflateSetDictionary() call */ + TYPE, /* i: waiting for type bits, including last-flag bit */ + TYPEDO, /* i: same, but skip check to exit inflate on new block */ + STORED, /* i: waiting for stored size (length and complement) */ + COPY, /* i/o: waiting for input or output to copy stored block */ + TABLE, /* i: waiting for dynamic block table lengths */ + LENLENS, /* i: waiting for code length code lengths */ + CODELENS, /* i: waiting for length/lit and distance code lengths */ + LEN, /* i: waiting for length/lit code */ + LENEXT, /* i: waiting for length extra bits */ + DIST, /* i: waiting for distance code */ + DISTEXT, /* i: waiting for distance extra bits */ + MATCH, /* o: waiting for output space to copy string */ + LIT, /* o: waiting for output space to write literal */ + CHECK, /* i: waiting for 32-bit check value */ + LENGTH, /* i: waiting for 32-bit length (gzip) */ + DONE, /* finished check, done -- remain here until reset */ + BAD, /* got a data error -- remain here until reset */ + MEM, /* got an inflate() memory error -- remain here until reset */ + SYNC, /* looking for synchronization bytes to restart inflate() */ + START, + WASH, + END, + BADCODE +} inflate_mode;
-/*+++++*/ -/* inftrees.h -- header to use inftrees.c - * Copyright (C) 1995 Mark Adler - * For conditions of distribution and use, see copyright notice in zlib.h - */ - -/* WARNING: this file should *not* be used by applications. It is - part of the implementation of the compression library and is - subject to change. Applications should only use zlib.h. +/* + State transitions between above modes - + + (most modes can go to the BAD or MEM mode -- not shown for clarity) + + Process header: + HEAD -> (gzip) or (zlib) + (gzip) -> FLAGS -> TIME -> OS -> EXLEN -> EXTRA -> NAME + NAME -> COMMENT -> HCRC -> TYPE + (zlib) -> DICTID or TYPE + DICTID -> DICT -> TYPE + Read deflate blocks: + TYPE -> STORED or TABLE or LEN or CHECK + STORED -> COPY -> TYPE + TABLE -> LENLENS -> CODELENS -> LEN + Read deflate codes: + LEN -> LENEXT or LIT or TYPE + LENEXT -> DIST -> DISTEXT -> MATCH -> LEN + LIT -> LEN + Process trailer: + CHECK -> LENGTH -> DONE */
-/* Huffman code lookup table entry--this entry is four bytes for machines - that have 16-bit pointers (e.g. PC's in the small or medium model). */ - -typedef struct inflate_huft_s FAR inflate_huft; - -struct inflate_huft_s { - union { - struct { - Byte Exop; /* number of extra bits or operation */ - Byte Bits; /* number of bits in this code or subcode */ - } what; - uInt Nalloc; /* number of these allocated here */ - Bytef *pad; /* pad structure to a power of 2 (4 bytes for */ - } word; /* 16-bit, 8 bytes for 32-bit machines) */ - union { - uInt Base; /* literal, length base, or distance base */ - inflate_huft *Next; /* pointer to next level of table */ - } more; +/* state maintained between inflate() calls. Approximately 7K bytes. */ +struct inflate_state { + inflate_mode mode; /* current inflate mode */ + int last; /* true if processing last block */ + int wrap; /* bit 0 true for zlib, bit 1 true for gzip */ + int havedict; /* true if dictionary provided */ + int flags; /* gzip header method and flags (0 if zlib) */ + unsigned dmax; /* zlib header max distance (INFLATE_STRICT) */ + unsigned long check; /* protected copy of check value */ + unsigned long total; /* protected copy of output count */ + gz_headerp head; /* where to save gzip header information */ + /* sliding window */ + unsigned wbits; /* log base 2 of requested window size */ + unsigned wsize; /* window size or zero if not using window */ + unsigned whave; /* valid bytes in the window */ + unsigned write; /* window write index */ + unsigned char FAR *window; /* allocated sliding window, if needed */ + /* bit accumulator */ + unsigned long hold; /* input bit accumulator */ + unsigned bits; /* number of bits in "in" */ + /* for string and stored block copying */ + unsigned length; /* literal or length of data to copy */ + unsigned offset; /* distance back to copy string from */ + /* for table and code decoding */ + unsigned extra; /* extra bits needed */ + /* fixed and dynamic code tables */ + code const FAR *lencode; /* starting table for length/literal codes */ + code const FAR *distcode; /* starting table for distance codes */ + unsigned lenbits; /* index bits for lencode */ + unsigned distbits; /* index bits for distcode */ + /* dynamic table building */ + unsigned ncode; /* number of code length code lengths */ + unsigned nlen; /* number of length code lengths */ + unsigned ndist; /* number of distance code lengths */ + unsigned have; /* number of code lengths in lens[] */ + code FAR *next; /* next available space in codes[] */ + unsigned short lens[320]; /* temporary storage for code lengths */ + unsigned short work[288]; /* work area for code table building */ + code codes[ENOUGH]; /* space for code tables */ };
-#ifdef DEBUG_ZLIB - local uInt inflate_hufts; -#endif - -local int inflate_trees_bits OF(( - uIntf *, /* 19 code lengths */ - uIntf *, /* bits tree desired/actual depth */ - inflate_huft * FAR *, /* bits tree result */ - z_stream *)); /* for zalloc, zfree functions */ - -local int inflate_trees_dynamic OF(( - uInt, /* number of literal/length codes */ - uInt, /* number of distance codes */ - uIntf *, /* that many (total) code lengths */ - uIntf *, /* literal desired/actual bit depth */ - uIntf *, /* distance desired/actual bit depth */ - inflate_huft * FAR *, /* literal/length tree result */ - inflate_huft * FAR *, /* distance tree result */ - z_stream *)); /* for zalloc, zfree functions */ - -local int inflate_trees_fixed OF(( - uIntf *, /* literal desired/actual bit depth */ - uIntf *, /* distance desired/actual bit depth */ - inflate_huft * FAR *, /* literal/length tree result */ - inflate_huft * FAR *)); /* distance tree result */ - -local int inflate_trees_free OF(( - inflate_huft *, /* tables to free */ - z_stream *)); /* for zfree function */ - - /*+++++*/ -/* infcodes.h -- header to use infcodes.c - * Copyright (C) 1995 Mark Adler +/* inffast.h -- header to use inffast.c + * Copyright (C) 1995-2003 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
@@ -239,1923 +283,1894 @@ local int inflate_trees_free OF(( subject to change. Applications should only use zlib.h. */
-struct inflate_codes_state; -typedef struct inflate_codes_state FAR inflate_codes_statef; - -local inflate_codes_statef *inflate_codes_new OF(( - uInt, uInt, - inflate_huft *, inflate_huft *, - z_stream *)); - -local int inflate_codes OF(( - inflate_blocks_statef *, - z_stream *, - int)); +void inflate_fast OF((z_streamp strm, unsigned start)); +/*+++++*/ + /* inffixed.h -- table for decoding fixed codes + * Generated automatically by makefixed(). + */
-local void inflate_codes_free OF(( - inflate_codes_statef *, - z_stream *)); + /* WARNING: this file should *not* be used by applications. It + is part of the implementation of the compression library and + is subject to change. Applications should only use zlib.h. + */
+ static const code lenfix[512] = { + {96,7,0},{0,8,80},{0,8,16},{20,8,115},{18,7,31},{0,8,112},{0,8,48}, + {0,9,192},{16,7,10},{0,8,96},{0,8,32},{0,9,160},{0,8,0},{0,8,128}, + {0,8,64},{0,9,224},{16,7,6},{0,8,88},{0,8,24},{0,9,144},{19,7,59}, + {0,8,120},{0,8,56},{0,9,208},{17,7,17},{0,8,104},{0,8,40},{0,9,176}, + {0,8,8},{0,8,136},{0,8,72},{0,9,240},{16,7,4},{0,8,84},{0,8,20}, + {21,8,227},{19,7,43},{0,8,116},{0,8,52},{0,9,200},{17,7,13},{0,8,100}, + {0,8,36},{0,9,168},{0,8,4},{0,8,132},{0,8,68},{0,9,232},{16,7,8}, + {0,8,92},{0,8,28},{0,9,152},{20,7,83},{0,8,124},{0,8,60},{0,9,216}, + {18,7,23},{0,8,108},{0,8,44},{0,9,184},{0,8,12},{0,8,140},{0,8,76}, + {0,9,248},{16,7,3},{0,8,82},{0,8,18},{21,8,163},{19,7,35},{0,8,114}, + {0,8,50},{0,9,196},{17,7,11},{0,8,98},{0,8,34},{0,9,164},{0,8,2}, + {0,8,130},{0,8,66},{0,9,228},{16,7,7},{0,8,90},{0,8,26},{0,9,148}, + {20,7,67},{0,8,122},{0,8,58},{0,9,212},{18,7,19},{0,8,106},{0,8,42}, + {0,9,180},{0,8,10},{0,8,138},{0,8,74},{0,9,244},{16,7,5},{0,8,86}, + {0,8,22},{64,8,0},{19,7,51},{0,8,118},{0,8,54},{0,9,204},{17,7,15}, + {0,8,102},{0,8,38},{0,9,172},{0,8,6},{0,8,134},{0,8,70},{0,9,236}, + {16,7,9},{0,8,94},{0,8,30},{0,9,156},{20,7,99},{0,8,126},{0,8,62}, + {0,9,220},{18,7,27},{0,8,110},{0,8,46},{0,9,188},{0,8,14},{0,8,142}, + {0,8,78},{0,9,252},{96,7,0},{0,8,81},{0,8,17},{21,8,131},{18,7,31}, + {0,8,113},{0,8,49},{0,9,194},{16,7,10},{0,8,97},{0,8,33},{0,9,162}, + {0,8,1},{0,8,129},{0,8,65},{0,9,226},{16,7,6},{0,8,89},{0,8,25}, + {0,9,146},{19,7,59},{0,8,121},{0,8,57},{0,9,210},{17,7,17},{0,8,105}, + {0,8,41},{0,9,178},{0,8,9},{0,8,137},{0,8,73},{0,9,242},{16,7,4}, + {0,8,85},{0,8,21},{16,8,258},{19,7,43},{0,8,117},{0,8,53},{0,9,202}, + {17,7,13},{0,8,101},{0,8,37},{0,9,170},{0,8,5},{0,8,133},{0,8,69}, + {0,9,234},{16,7,8},{0,8,93},{0,8,29},{0,9,154},{20,7,83},{0,8,125}, + {0,8,61},{0,9,218},{18,7,23},{0,8,109},{0,8,45},{0,9,186},{0,8,13}, + {0,8,141},{0,8,77},{0,9,250},{16,7,3},{0,8,83},{0,8,19},{21,8,195}, + {19,7,35},{0,8,115},{0,8,51},{0,9,198},{17,7,11},{0,8,99},{0,8,35}, + {0,9,166},{0,8,3},{0,8,131},{0,8,67},{0,9,230},{16,7,7},{0,8,91}, + {0,8,27},{0,9,150},{20,7,67},{0,8,123},{0,8,59},{0,9,214},{18,7,19}, + {0,8,107},{0,8,43},{0,9,182},{0,8,11},{0,8,139},{0,8,75},{0,9,246}, + {16,7,5},{0,8,87},{0,8,23},{64,8,0},{19,7,51},{0,8,119},{0,8,55}, + {0,9,206},{17,7,15},{0,8,103},{0,8,39},{0,9,174},{0,8,7},{0,8,135}, + {0,8,71},{0,9,238},{16,7,9},{0,8,95},{0,8,31},{0,9,158},{20,7,99}, + {0,8,127},{0,8,63},{0,9,222},{18,7,27},{0,8,111},{0,8,47},{0,9,190}, + {0,8,15},{0,8,143},{0,8,79},{0,9,254},{96,7,0},{0,8,80},{0,8,16}, + {20,8,115},{18,7,31},{0,8,112},{0,8,48},{0,9,193},{16,7,10},{0,8,96}, + {0,8,32},{0,9,161},{0,8,0},{0,8,128},{0,8,64},{0,9,225},{16,7,6}, + {0,8,88},{0,8,24},{0,9,145},{19,7,59},{0,8,120},{0,8,56},{0,9,209}, + {17,7,17},{0,8,104},{0,8,40},{0,9,177},{0,8,8},{0,8,136},{0,8,72}, + {0,9,241},{16,7,4},{0,8,84},{0,8,20},{21,8,227},{19,7,43},{0,8,116}, + {0,8,52},{0,9,201},{17,7,13},{0,8,100},{0,8,36},{0,9,169},{0,8,4}, + {0,8,132},{0,8,68},{0,9,233},{16,7,8},{0,8,92},{0,8,28},{0,9,153}, + {20,7,83},{0,8,124},{0,8,60},{0,9,217},{18,7,23},{0,8,108},{0,8,44}, + {0,9,185},{0,8,12},{0,8,140},{0,8,76},{0,9,249},{16,7,3},{0,8,82}, + {0,8,18},{21,8,163},{19,7,35},{0,8,114},{0,8,50},{0,9,197},{17,7,11}, + {0,8,98},{0,8,34},{0,9,165},{0,8,2},{0,8,130},{0,8,66},{0,9,229}, + {16,7,7},{0,8,90},{0,8,26},{0,9,149},{20,7,67},{0,8,122},{0,8,58}, + {0,9,213},{18,7,19},{0,8,106},{0,8,42},{0,9,181},{0,8,10},{0,8,138}, + {0,8,74},{0,9,245},{16,7,5},{0,8,86},{0,8,22},{64,8,0},{19,7,51}, + {0,8,118},{0,8,54},{0,9,205},{17,7,15},{0,8,102},{0,8,38},{0,9,173}, + {0,8,6},{0,8,134},{0,8,70},{0,9,237},{16,7,9},{0,8,94},{0,8,30}, + {0,9,157},{20,7,99},{0,8,126},{0,8,62},{0,9,221},{18,7,27},{0,8,110}, + {0,8,46},{0,9,189},{0,8,14},{0,8,142},{0,8,78},{0,9,253},{96,7,0}, + {0,8,81},{0,8,17},{21,8,131},{18,7,31},{0,8,113},{0,8,49},{0,9,195}, + {16,7,10},{0,8,97},{0,8,33},{0,9,163},{0,8,1},{0,8,129},{0,8,65}, + {0,9,227},{16,7,6},{0,8,89},{0,8,25},{0,9,147},{19,7,59},{0,8,121}, + {0,8,57},{0,9,211},{17,7,17},{0,8,105},{0,8,41},{0,9,179},{0,8,9}, + {0,8,137},{0,8,73},{0,9,243},{16,7,4},{0,8,85},{0,8,21},{16,8,258}, + {19,7,43},{0,8,117},{0,8,53},{0,9,203},{17,7,13},{0,8,101},{0,8,37}, + {0,9,171},{0,8,5},{0,8,133},{0,8,69},{0,9,235},{16,7,8},{0,8,93}, + {0,8,29},{0,9,155},{20,7,83},{0,8,125},{0,8,61},{0,9,219},{18,7,23}, + {0,8,109},{0,8,45},{0,9,187},{0,8,13},{0,8,141},{0,8,77},{0,9,251}, + {16,7,3},{0,8,83},{0,8,19},{21,8,195},{19,7,35},{0,8,115},{0,8,51}, + {0,9,199},{17,7,11},{0,8,99},{0,8,35},{0,9,167},{0,8,3},{0,8,131}, + {0,8,67},{0,9,231},{16,7,7},{0,8,91},{0,8,27},{0,9,151},{20,7,67}, + {0,8,123},{0,8,59},{0,9,215},{18,7,19},{0,8,107},{0,8,43},{0,9,183}, + {0,8,11},{0,8,139},{0,8,75},{0,9,247},{16,7,5},{0,8,87},{0,8,23}, + {64,8,0},{19,7,51},{0,8,119},{0,8,55},{0,9,207},{17,7,15},{0,8,103}, + {0,8,39},{0,9,175},{0,8,7},{0,8,135},{0,8,71},{0,9,239},{16,7,9}, + {0,8,95},{0,8,31},{0,9,159},{20,7,99},{0,8,127},{0,8,63},{0,9,223}, + {18,7,27},{0,8,111},{0,8,47},{0,9,191},{0,8,15},{0,8,143},{0,8,79}, + {0,9,255} + }; + + static const code distfix[32] = { + {16,5,1},{23,5,257},{19,5,17},{27,5,4097},{17,5,5},{25,5,1025}, + {21,5,65},{29,5,16385},{16,5,3},{24,5,513},{20,5,33},{28,5,8193}, + {18,5,9},{26,5,2049},{22,5,129},{64,5,0},{16,5,2},{23,5,385}, + {19,5,25},{27,5,6145},{17,5,7},{25,5,1537},{21,5,97},{29,5,24577}, + {16,5,4},{24,5,769},{20,5,49},{28,5,12289},{18,5,13},{26,5,3073}, + {22,5,193},{64,5,0} + };
/*+++++*/ -/* inflate.c -- zlib interface to inflate modules - * Copyright (C) 1995 Mark Adler +/* inffast.c -- fast decoding + * Copyright (C) 1995-2004 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
-/* inflate private state */ -struct internal_state { - - /* mode */ - enum { - METHOD, /* waiting for method byte */ - FLAG, /* waiting for flag byte */ - BLOCKS, /* decompressing blocks */ - CHECK4, /* four check bytes to go */ - CHECK3, /* three check bytes to go */ - CHECK2, /* two check bytes to go */ - CHECK1, /* one check byte to go */ - DONE, /* finished check, done */ - BAD} /* got an error--stay here */ - mode; /* current inflate mode */ - - /* mode dependent information */ - union { - uInt method; /* if FLAGS, method byte */ - struct { - uLong was; /* computed check value */ - uLong need; /* stream check value */ - } check; /* if CHECK, check values to compare */ - uInt marker; /* if BAD, inflateSync's marker bytes count */ - } sub; /* submode */ - - /* mode independent information */ - int nowrap; /* flag for no wrapper */ - uInt wbits; /* log2(window size) (8..15, defaults to 15) */ - inflate_blocks_statef - *blocks; /* current inflate_blocks state */ - -}; - - -int inflateReset(z) -z_stream *z; -{ - uLong c; - - if (z == Z_NULL || z->state == Z_NULL) - return Z_STREAM_ERROR; - z->total_in = z->total_out = 0; - z->msg = Z_NULL; - z->state->mode = z->state->nowrap ? BLOCKS : METHOD; - inflate_blocks_reset(z->state->blocks, z, &c); - Trace((stderr, "inflate: reset\n")); - return Z_OK; -} - - -int inflateEnd(z) -z_stream *z; -{ - uLong c; - - if (z == Z_NULL || z->state == Z_NULL || z->zfree == Z_NULL) - return Z_STREAM_ERROR; - if (z->state->blocks != Z_NULL) - inflate_blocks_free(z->state->blocks, z, &c); - ZFREE(z, z->state, sizeof(struct internal_state)); - z->state = Z_NULL; - Trace((stderr, "inflate: end\n")); - return Z_OK; -} - - -int inflateInit2(z, w) -z_stream *z; -int w; -{ - /* initialize state */ - if (z == Z_NULL) - return Z_STREAM_ERROR; -/* if (z->zalloc == Z_NULL) z->zalloc = zcalloc; */ -/* if (z->zfree == Z_NULL) z->zfree = zcfree; */ - if ((z->state = (struct internal_state FAR *) - ZALLOC(z,1,sizeof(struct internal_state))) == Z_NULL) - return Z_MEM_ERROR; - z->state->blocks = Z_NULL; - - /* handle undocumented nowrap option (no zlib header or check) */ - z->state->nowrap = 0; - if (w < 0) - { - w = - w; - z->state->nowrap = 1; - } - - /* set window size */ - if (w < 8 || w > 15) - { - inflateEnd(z); - return Z_STREAM_ERROR; - } - z->state->wbits = (uInt)w; - - /* create inflate_blocks state */ - if ((z->state->blocks = - inflate_blocks_new(z, z->state->nowrap ? Z_NULL : adler32, 1 << w)) - == Z_NULL) - { - inflateEnd(z); - return Z_MEM_ERROR; - } - Trace((stderr, "inflate: allocated\n")); - - /* reset state */ - inflateReset(z); - return Z_OK; -} - - -int inflateInit(z) -z_stream *z; -{ - return inflateInit2(z, DEF_WBITS); -} - - -#define NEEDBYTE {if(z->avail_in==0)goto empty;r=Z_OK;} -#define NEXTBYTE (z->avail_in--,z->total_in++,*z->next_in++) - -int inflate(z, f) -z_stream *z; -int f; -{ - int r; - uInt b; - - if (z == Z_NULL || z->next_in == Z_NULL) - return Z_STREAM_ERROR; - r = Z_BUF_ERROR; - while (1) switch (z->state->mode) - { - case METHOD: - NEEDBYTE - if (((z->state->sub.method = NEXTBYTE) & 0xf) != DEFLATED) - { - z->state->mode = BAD; - z->msg = "unknown compression method"; - z->state->sub.marker = 5; /* can't try inflateSync */ - break; - } - if ((z->state->sub.method >> 4) + 8 > z->state->wbits) - { - z->state->mode = BAD; - z->msg = "invalid window size"; - z->state->sub.marker = 5; /* can't try inflateSync */ - break; - } - z->state->mode = FLAG; - case FLAG: - NEEDBYTE - if ((b = NEXTBYTE) & 0x20) - { - z->state->mode = BAD; - z->msg = "invalid reserved bit"; - z->state->sub.marker = 5; /* can't try inflateSync */ - break; - } - if (((z->state->sub.method << 8) + b) % 31) - { - z->state->mode = BAD; - z->msg = "incorrect header check"; - z->state->sub.marker = 5; /* can't try inflateSync */ - break; - } - Trace((stderr, "inflate: zlib header ok\n")); - z->state->mode = BLOCKS; - case BLOCKS: - r = inflate_blocks(z->state->blocks, z, r); - if (f == Z_PACKET_FLUSH && z->avail_in == 0 && z->avail_out != 0) - r = inflate_packet_flush(z->state->blocks); - if (r == Z_DATA_ERROR) - { - z->state->mode = BAD; - z->state->sub.marker = 0; /* can try inflateSync */ - break; - } - if (r != Z_STREAM_END) - return r; - r = Z_OK; - inflate_blocks_reset(z->state->blocks, z, &z->state->sub.check.was); - if (z->state->nowrap) - { - z->state->mode = DONE; - break; - } - z->state->mode = CHECK4; - case CHECK4: - NEEDBYTE - z->state->sub.check.need = (uLong)NEXTBYTE << 24; - z->state->mode = CHECK3; - case CHECK3: - NEEDBYTE - z->state->sub.check.need += (uLong)NEXTBYTE << 16; - z->state->mode = CHECK2; - case CHECK2: - NEEDBYTE - z->state->sub.check.need += (uLong)NEXTBYTE << 8; - z->state->mode = CHECK1; - case CHECK1: - NEEDBYTE - z->state->sub.check.need += (uLong)NEXTBYTE; - - if (z->state->sub.check.was != z->state->sub.check.need) - { - z->state->mode = BAD; - z->msg = "incorrect data check"; - z->state->sub.marker = 5; /* can't try inflateSync */ - break; - } - Trace((stderr, "inflate: zlib check ok\n")); - z->state->mode = DONE; - case DONE: - return Z_STREAM_END; - case BAD: - return Z_DATA_ERROR; - default: - return Z_STREAM_ERROR; - } - - empty: - if (f != Z_PACKET_FLUSH) - return r; - z->state->mode = BAD; - z->state->sub.marker = 0; /* can try inflateSync */ - return Z_DATA_ERROR; -} +/* Allow machine dependent optimization for post-increment or pre-increment. + Based on testing to date, + Pre-increment preferred for: + - PowerPC G3 (Adler) + - MIPS R5000 (Randers-Pehrson) + Post-increment preferred for: + - none + No measurable difference: + - Pentium III (Anderson) + - M68060 (Nikl) + */ +#define OFF 1 +#define PUP(a) *++(a)
/* - * This subroutine adds the data at next_in/avail_in to the output history - * without performing any output. The output buffer must be "caught up"; - * i.e. no pending output (hence s->read equals s->write), and the state must - * be BLOCKS (i.e. we should be willing to see the start of a series of - * BLOCKS). On exit, the output will also be caught up, and the checksum - * will have been updated if need be. + Decode literal, length, and distance codes and write out the resulting + literal and match bytes until either not enough input or output is + available, an end-of-block is encountered, or a data error is encountered. + When large enough input and output buffers are supplied to inflate(), for + example, a 16K input buffer and a 64K output buffer, more than 95% of the + inflate execution time is spent in this routine. + + Entry assumptions: + + state->mode == LEN + strm->avail_in >= 6 + strm->avail_out >= 258 + start >= strm->avail_out + state->bits < 8 + + On return, state->mode is one of: + + LEN -- ran out of enough output space or enough available input + TYPE -- reached end of block code, inflate() to interpret next block + BAD -- error in block data + + Notes: + + - The maximum input bits used by a length/distance pair is 15 bits for the + length code, 5 bits for the length extra, 15 bits for the distance code, + and 13 bits for the distance extra. This totals 48 bits, or six bytes. + Therefore if strm->avail_in >= 6, then there is enough input to avoid + checking for available input while decoding. + + - The maximum bytes that a single length/distance pair can output is 258 + bytes, which is the maximum length that can be coded. inflate_fast() + requires strm->avail_out >= 258 for each loop to avoid checking for + output space. */ - -int inflateIncomp(z) -z_stream *z; +void inflate_fast(strm, start) +z_streamp strm; +unsigned start; /* inflate()'s starting value for strm->avail_out */ { - if (z->state->mode != BLOCKS) - return Z_DATA_ERROR; - return inflate_addhistory(z->state->blocks, z); -} - - -int inflateSync(z) -z_stream *z; -{ - uInt n; /* number of bytes to look at */ - Bytef *p; /* pointer to bytes */ - uInt m; /* number of marker bytes found in a row */ - uLong r, w; /* temporaries to save total_in and total_out */ - - /* set up */ - if (z == Z_NULL || z->state == Z_NULL) - return Z_STREAM_ERROR; - if (z->state->mode != BAD) - { - z->state->mode = BAD; - z->state->sub.marker = 0; - } - if ((n = z->avail_in) == 0) - return Z_BUF_ERROR; - p = z->next_in; - m = z->state->sub.marker; - - /* search */ - while (n && m < 4) - { - if (*p == (Byte)(m < 2 ? 0 : 0xff)) - m++; - else if (*p) - m = 0; - else - m = 4 - m; - p++, n--; - } - - /* restore */ - z->total_in += p - z->next_in; - z->next_in = p; - z->avail_in = n; - z->state->sub.marker = m; - - /* return no joy or set up to restart on a new block */ - if (m != 4) - return Z_DATA_ERROR; - r = z->total_in; w = z->total_out; - inflateReset(z); - z->total_in = r; z->total_out = w; - z->state->mode = BLOCKS; - return Z_OK; + struct inflate_state FAR *state; + unsigned char FAR *in; /* local strm->next_in */ + unsigned char FAR *last; /* while in < last, enough input available */ + unsigned char FAR *out; /* local strm->next_out */ + unsigned char FAR *beg; /* inflate()'s initial strm->next_out */ + unsigned char FAR *end; /* while out < end, enough space available */ +#ifdef INFLATE_STRICT + unsigned dmax; /* maximum distance from zlib header */ +#endif + unsigned wsize; /* window size or zero if not using window */ + unsigned whave; /* valid bytes in the window */ + unsigned write; /* window write index */ + unsigned char FAR *window; /* allocated sliding window, if wsize != 0 */ + unsigned long hold; /* local strm->hold */ + unsigned bits; /* local strm->bits */ + code const FAR *lcode; /* local strm->lencode */ + code const FAR *dcode; /* local strm->distcode */ + unsigned lmask; /* mask for first level of length codes */ + unsigned dmask; /* mask for first level of distance codes */ + code this; /* retrieved table entry */ + unsigned op; /* code bits, operation, extra bits, or */ + /* window position, window bytes to copy */ + unsigned len; /* match length, unused bytes */ + unsigned dist; /* match distance */ + unsigned char FAR *from; /* where to copy match from */ + + /* copy state to local variables */ + state = (struct inflate_state FAR *)strm->state; + in = strm->next_in - OFF; + last = in + (strm->avail_in - 5); + out = strm->next_out - OFF; + beg = out - (start - strm->avail_out); + end = out + (strm->avail_out - 257); +#ifdef INFLATE_STRICT + dmax = state->dmax; +#endif + wsize = state->wsize; + whave = state->whave; + write = state->write; + window = state->window; + hold = state->hold; + bits = state->bits; + lcode = state->lencode; + dcode = state->distcode; + lmask = (1U << state->lenbits) - 1; + dmask = (1U << state->distbits) - 1; + + /* decode literals and length/distances until end-of-block or not enough + input data or output space */ + do { + if (bits < 15) { + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + } + this = lcode[hold & lmask]; + dolen: + op = (unsigned)(this.bits); + hold >>= op; + bits -= op; + op = (unsigned)(this.op); + if (op == 0) { /* literal */ + Tracevv((stderr, this.val >= 0x20 && this.val < 0x7f ? + "inflate: literal '%c'\n" : + "inflate: literal 0x%02x\n", this.val)); + PUP(out) = (unsigned char)(this.val); + } + else if (op & 16) { /* length base */ + len = (unsigned)(this.val); + op &= 15; /* number of extra bits */ + if (op) { + if (bits < op) { + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + } + len += (unsigned)hold & ((1U << op) - 1); + hold >>= op; + bits -= op; + } + Tracevv((stderr, "inflate: length %u\n", len)); + if (bits < 15) { + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + } + this = dcode[hold & dmask]; + dodist: + op = (unsigned)(this.bits); + hold >>= op; + bits -= op; + op = (unsigned)(this.op); + if (op & 16) { /* distance base */ + dist = (unsigned)(this.val); + op &= 15; /* number of extra bits */ + if (bits < op) { + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + if (bits < op) { + hold += (unsigned long)(PUP(in)) << bits; + bits += 8; + } + } + dist += (unsigned)hold & ((1U << op) - 1); +#ifdef INFLATE_STRICT + if (dist > dmax) { + strm->msg = (char *)"invalid distance too far back"; + state->mode = BAD; + break; + } +#endif + hold >>= op; + bits -= op; + Tracevv((stderr, "inflate: distance %u\n", dist)); + op = (unsigned)(out - beg); /* max distance in output */ + if (dist > op) { /* see if copy from window */ + op = dist - op; /* distance back in window */ + if (op > whave) { + strm->msg = (char *)"invalid distance too far back"; + state->mode = BAD; + break; + } + from = window - OFF; + if (write == 0) { /* very common case */ + from += wsize - op; + if (op < len) { /* some from window */ + len -= op; + do { + PUP(out) = PUP(from); + } while (--op); + from = out - dist; /* rest from output */ + } + } + else if (write < op) { /* wrap around window */ + from += wsize + write - op; + op -= write; + if (op < len) { /* some from end of window */ + len -= op; + do { + PUP(out) = PUP(from); + } while (--op); + from = window - OFF; + if (write < len) { /* some from start of window */ + op = write; + len -= op; + do { + PUP(out) = PUP(from); + } while (--op); + from = out - dist; /* rest from output */ + } + } + } + else { /* contiguous in window */ + from += write - op; + if (op < len) { /* some from window */ + len -= op; + do { + PUP(out) = PUP(from); + } while (--op); + from = out - dist; /* rest from output */ + } + } + while (len > 2) { + PUP(out) = PUP(from); + PUP(out) = PUP(from); + PUP(out) = PUP(from); + len -= 3; + } + if (len) { + PUP(out) = PUP(from); + if (len > 1) + PUP(out) = PUP(from); + } + } + else { + from = out - dist; /* copy direct from output */ + do { /* minimum length is three */ + PUP(out) = PUP(from); + PUP(out) = PUP(from); + PUP(out) = PUP(from); + len -= 3; + } while (len > 2); + if (len) { + PUP(out) = PUP(from); + if (len > 1) + PUP(out) = PUP(from); + } + } + } + else if ((op & 64) == 0) { /* 2nd level distance code */ + this = dcode[this.val + (hold & ((1U << op) - 1))]; + goto dodist; + } + else { + strm->msg = (char *)"invalid distance code"; + state->mode = BAD; + break; + } + } + else if ((op & 64) == 0) { /* 2nd level length code */ + this = lcode[this.val + (hold & ((1U << op) - 1))]; + goto dolen; + } + else if (op & 32) { /* end-of-block */ + Tracevv((stderr, "inflate: end of block\n")); + state->mode = TYPE; + break; + } + else { + strm->msg = (char *)"invalid literal/length code"; + state->mode = BAD; + break; + } + } while (in < last && out < end); + + /* return unused bytes (on entry, bits < 8, so in won't go too far back) */ + len = bits >> 3; + in -= len; + bits -= len << 3; + hold &= (1U << bits) - 1; + + /* update state and return */ + strm->next_in = in + OFF; + strm->next_out = out + OFF; + strm->avail_in = (unsigned)(in < last ? 5 + (last - in) : 5 - (in - last)); + strm->avail_out = (unsigned)(out < end ? + 257 + (end - out) : 257 - (out - end)); + state->hold = hold; + state->bits = bits; + return; }
-#undef NEEDBYTE -#undef NEXTBYTE - -/*+++++*/ -/* infutil.h -- types and macros common to blocks and codes - * Copyright (C) 1995 Mark Adler - * For conditions of distribution and use, see copyright notice in zlib.h - */ - -/* WARNING: this file should *not* be used by applications. It is - part of the implementation of the compression library and is - subject to change. Applications should only use zlib.h. - */ - -/* inflate blocks semi-private state */ -struct inflate_blocks_state { - - /* mode */ - enum { - TYPE, /* get type bits (3, including end bit) */ - LENS, /* get lengths for stored */ - STORED, /* processing stored block */ - TABLE, /* get table lengths */ - BTREE, /* get bit lengths tree for a dynamic block */ - DTREE, /* get length, distance trees for a dynamic block */ - CODES, /* processing fixed or dynamic block */ - DRY, /* output remaining window bytes */ - DONEB, /* finished last block, done */ - BADB} /* got a data error--stuck here */ - mode; /* current inflate_block mode */ - - /* mode dependent information */ - union { - uInt left; /* if STORED, bytes left to copy */ - struct { - uInt table; /* table lengths (14 bits) */ - uInt index; /* index into blens (or border) */ - uIntf *blens; /* bit lengths of codes */ - uInt bb; /* bit length tree depth */ - inflate_huft *tb; /* bit length decoding tree */ - int nblens; /* # elements allocated at blens */ - } trees; /* if DTREE, decoding info for trees */ - struct { - inflate_huft *tl, *td; /* trees to free */ - inflate_codes_statef - *codes; - } decode; /* if CODES, current state */ - } sub; /* submode */ - uInt last; /* true if this block is the last block */ - - /* mode independent information */ - uInt bitk; /* bits in bit buffer */ - uLong bitb; /* bit buffer */ - Bytef *window; /* sliding window */ - Bytef *end; /* one byte after sliding window */ - Bytef *read; /* window read pointer */ - Bytef *write; /* window write pointer */ - check_func checkfn; /* check function */ - uLong check; /* check on output */ - -}; - - -/* defines for inflate input/output */ -/* update pointers and return */ -#define UPDBITS {s->bitb=b;s->bitk=k;} -#define UPDIN {z->avail_in=n;z->total_in+=p-z->next_in;z->next_in=p;} -#define UPDOUT {s->write=q;} -#define UPDATE {UPDBITS UPDIN UPDOUT} -#define LEAVE {UPDATE return inflate_flush(s,z,r);} -/* get bytes and bits */ -#define LOADIN {p=z->next_in;n=z->avail_in;b=s->bitb;k=s->bitk;} -#define NEEDBYTE {if(n)r=Z_OK;else LEAVE} -#define NEXTBYTE (n--,*p++) -#define NEEDBITS(j) {while(k<(j)){NEEDBYTE;b|=((uLong)NEXTBYTE)<<k;k+=8;}} -#define DUMPBITS(j) {b>>=(j);k-=(j);} -/* output bytes */ -#define WAVAIL (q<s->read?s->read-q-1:s->end-q) -#define LOADOUT {q=s->write;m=WAVAIL;} -#define WRAP {if(q==s->end&&s->read!=s->window){q=s->window;m=WAVAIL;}} -#define FLUSH {UPDOUT r=inflate_flush(s,z,r); LOADOUT} -#define NEEDOUT {if(m==0){WRAP if(m==0){FLUSH WRAP if(m==0) LEAVE}}r=Z_OK;} -#define OUTBYTE(a) {*q++=(Byte)(a);m--;} -/* load local pointers */ -#define LOAD {LOADIN LOADOUT} - /* - * The IBM 150 firmware munges the data right after _etext[]. This - * protects it. -- Cort + inflate_fast() speedups that turned out slower (on a PowerPC G3 750CXe): + - Using bit fields for code structure + - Different op definition to avoid & for extra bits (do & for table bits) + - Three separate decoding do-loops for direct, window, and write == 0 + - Special case for distance > 1 copies to do overlapped load and store copy + - Explicit branch predictions (based on measured branch probabilities) + - Deferring match copy and interspersed it with decoding subsequent codes + - Swapping literal/length else + - Swapping window/direct else + - Larger unrolled copy loops (three is about right) + - Moving len -= 3 statement into middle of loop */ -#if 0 -local uInt protect_mask[] = {0, 0, 0, 0, 0, 0, 0, 0, 0 ,0 ,0 ,0}; -#endif -/* And'ing with mask[n] masks the lower n bits */ -local uInt inflate_mask[] = { - 0x0000, - 0x0001, 0x0003, 0x0007, 0x000f, 0x001f, 0x003f, 0x007f, 0x00ff, - 0x01ff, 0x03ff, 0x07ff, 0x0fff, 0x1fff, 0x3fff, 0x7fff, 0xffff -}; - -/* copy as much as possible from the sliding window to the output area */ -local int inflate_flush OF(( - inflate_blocks_statef *, - z_stream *, - int));
/*+++++*/ -/* inffast.h -- header to use inffast.c - * Copyright (C) 1995 Mark Adler +/* inftrees.c -- generate Huffman trees for efficient decoding + * Copyright (C) 1995-2005 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
-/* WARNING: this file should *not* be used by applications. It is - part of the implementation of the compression library and is - subject to change. Applications should only use zlib.h. - */ - -local int inflate_fast OF(( - uInt, - uInt, - inflate_huft *, - inflate_huft *, - inflate_blocks_statef *, - z_stream *)); - - -/*+++++*/ -/* infblock.c -- interpret and process block types to last block - * Copyright (C) 1995 Mark Adler - * For conditions of distribution and use, see copyright notice in zlib.h +#define MAXBITS 15 +/* + If you use the zlib library in a product, an acknowledgment is welcome + in the documentation of your product. If for some reason you cannot + include such an acknowledgment, I would appreciate that you keep this + copyright string in the executable of your product. */
-/* Table for deflate from PKZIP's appnote.txt. */ -local uInt border[] = { /* Order of the bit length code lengths */ - 16, 17, 18, 0, 8, 7, 9, 6, 10, 5, 11, 4, 12, 3, 13, 2, 14, 1, 15}; - /* - Notes beyond the 1.93a appnote.txt: - - 1. Distance pointers never point before the beginning of the output - stream. - 2. Distance pointers can point back across blocks, up to 32k away. - 3. There is an implied maximum of 7 bits for the bit length table and - 15 bits for the actual data. - 4. If only one code exists, then it is encoded using one bit. (Zero - would be more efficient, but perhaps a little confusing.) If two - codes exist, they are coded using one bit each (0 and 1). - 5. There is no way of sending zero distance codes--a dummy must be - sent if there are none. (History: a pre 2.0 version of PKZIP would - store blocks with no distance codes, but this was discovered to be - too harsh a criterion.) Valid only for 1.93a. 2.04c does allow - zero distance codes, which is sent as one code of zero bits in - length. - 6. There are up to 286 literal/length codes. Code 256 represents the - end-of-block. Note however that the static length tree defines - 288 codes just to fill out the Huffman codes. Codes 286 and 287 - cannot be used though, since there is no length base or extra bits - defined for them. Similarily, there are up to 30 distance codes. - However, static trees define 32 codes (all 5 bits) to fill out the - Huffman codes, but the last two had better not show up in the data. - 7. Unzip can check dynamic Huffman blocks for complete code sets. - The exception is that a single code would not be complete (see #4). - 8. The five bits following the block type is really the number of - literal codes sent minus 257. - 9. Length codes 8,16,16 are interpreted as 13 length codes of 8 bits - (1+6+6). Therefore, to output three times the length, you output - three codes (1+1+1), whereas to output four times the same length, - you only need two codes (1+3). Hmm. - 10. In the tree reconstruction algorithm, Code = Code + Increment - only if BitLength(i) is not zero. (Pretty obvious.) - 11. Correction: 4 Bits: # of Bit Length codes - 4 (4 - 19) - 12. Note: length code 284 can represent 227-258, but length code 285 - really is 258. The last length deserves its own, short code - since it gets used a lot in very redundant files. The length - 258 is special since 258 - 3 (the min match length) is 255. - 13. The literal/length and distance code bit lengths are read as a - single stream of lengths. It is possible (and advantageous) for - a repeat code (16, 17, or 18) to go across the boundary between - the two sets of lengths. + Build a set of tables to decode the provided canonical Huffman code. + The code lengths are lens[0..codes-1]. The result starts at *table, + whose indices are 0..2^bits-1. work is a writable array of at least + lens shorts, which is used as a work area. type is the type of code + to be generated, CODES, LENS, or DISTS. On return, zero is success, + -1 is an invalid code, and +1 means that ENOUGH isn't enough. table + on return points to the next available entry's address. bits is the + requested root table index bits, and on return it is the actual root + table index bits. It will differ if the request is greater than the + longest code or if it is less than the shortest code. */ - - -local void inflate_blocks_reset(s, z, c) -inflate_blocks_statef *s; -z_stream *z; -uLongf *c; +int inflate_table(type, lens, codes, table, bits, work) +codetype type; +unsigned short FAR *lens; +unsigned codes; +code FAR * FAR *table; +unsigned FAR *bits; +unsigned short FAR *work; { - if (s->checkfn != Z_NULL) - *c = s->check; - if (s->mode == BTREE || s->mode == DTREE) - ZFREE(z, s->sub.trees.blens, s->sub.trees.nblens * sizeof(uInt)); - if (s->mode == CODES) - { - inflate_codes_free(s->sub.decode.codes, z); - inflate_trees_free(s->sub.decode.td, z); - inflate_trees_free(s->sub.decode.tl, z); - } - s->mode = TYPE; - s->bitk = 0; - s->bitb = 0; - s->read = s->write = s->window; - if (s->checkfn != Z_NULL) - s->check = (*s->checkfn)(0L, Z_NULL, 0); - if (z->outcb != Z_NULL) - (*z->outcb)(Z_NULL, 0); - Trace((stderr, "inflate: blocks reset\n")); -} - - -local inflate_blocks_statef *inflate_blocks_new(z, c, w) -z_stream *z; -check_func c; -uInt w; -{ - inflate_blocks_statef *s; - - if ((s = (inflate_blocks_statef *)ZALLOC - (z,1,sizeof(struct inflate_blocks_state))) == Z_NULL) - return s; - if ((s->window = (Bytef *)ZALLOC(z, 1, w)) == Z_NULL) - { - ZFREE(z, s, sizeof(struct inflate_blocks_state)); - return Z_NULL; - } - s->end = s->window + w; - s->checkfn = c; - s->mode = TYPE; - Trace((stderr, "inflate: blocks allocated\n")); - inflate_blocks_reset(s, z, &s->check); - return s; -} + unsigned len; /* a code's length in bits */ + unsigned sym; /* index of code symbols */ + unsigned min, max; /* minimum and maximum code lengths */ + unsigned root; /* number of index bits for root table */ + unsigned curr; /* number of index bits for current table */ + unsigned drop; /* code bits to drop for sub-table */ + int left; /* number of prefix codes available */ + unsigned used; /* code entries in table used */ + unsigned huff; /* Huffman code */ + unsigned incr; /* for incrementing code, index */ + unsigned fill; /* index for replicating entries */ + unsigned low; /* low bits for current root entry */ + unsigned mask; /* mask for low root bits */ + code this; /* table entry for duplication */ + code FAR *next; /* next available space in table */ + const unsigned short FAR *base; /* base value table to use */ + const unsigned short FAR *extra; /* extra bits table to use */ + int end; /* use base and extra for symbol > end */ + unsigned short count[MAXBITS+1]; /* number of codes of each length */ + unsigned short offs[MAXBITS+1]; /* offsets in table for each length */ + static const unsigned short lbase[31] = { /* Length codes 257..285 base */ + 3, 4, 5, 6, 7, 8, 9, 10, 11, 13, 15, 17, 19, 23, 27, 31, + 35, 43, 51, 59, 67, 83, 99, 115, 131, 163, 195, 227, 258, 0, 0}; + static const unsigned short lext[31] = { /* Length codes 257..285 extra */ + 16, 16, 16, 16, 16, 16, 16, 16, 17, 17, 17, 17, 18, 18, 18, 18, + 19, 19, 19, 19, 20, 20, 20, 20, 21, 21, 21, 21, 16, 201, 196}; + static const unsigned short dbase[32] = { /* Distance codes 0..29 base */ + 1, 2, 3, 4, 5, 7, 9, 13, 17, 25, 33, 49, 65, 97, 129, 193, + 257, 385, 513, 769, 1025, 1537, 2049, 3073, 4097, 6145, + 8193, 12289, 16385, 24577, 0, 0}; + static const unsigned short dext[32] = { /* Distance codes 0..29 extra */ + 16, 16, 16, 16, 17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, + 23, 23, 24, 24, 25, 25, 26, 26, 27, 27, + 28, 28, 29, 29, 64, 64}; + + /* + Process a set of code lengths to create a canonical Huffman code. The + code lengths are lens[0..codes-1]. Each length corresponds to the + symbols 0..codes-1. The Huffman code is generated by first sorting the + symbols by length from short to long, and retaining the symbol order + for codes with equal lengths. Then the code starts with all zero bits + for the first code of the shortest length, and the codes are integer + increments for the same length, and zeros are appended as the length + increases. For the deflate format, these bits are stored backwards + from their more natural integer increment ordering, and so when the + decoding tables are built in the large loop below, the integer codes + are incremented backwards. + + This routine assumes, but does not check, that all of the entries in + lens[] are in the range 0..MAXBITS. The caller must assure this. + 1..MAXBITS is interpreted as that code length. zero means that that + symbol does not occur in this code. + + The codes are sorted by computing a count of codes for each length, + creating from that a table of starting indices for each length in the + sorted table, and then entering the symbols in order in the sorted + table. The sorted table is work[], with that space being provided by + the caller. + + The length counts are used for other purposes as well, i.e. finding + the minimum and maximum length codes, determining if there are any + codes at all, checking for a valid set of lengths, and looking ahead + at length counts to determine sub-table sizes when building the + decoding tables. + */
+ /* accumulate lengths for codes (assumes lens[] all in 0..MAXBITS) */ + for (len = 0; len <= MAXBITS; len++) + count[len] = 0; + for (sym = 0; sym < codes; sym++) + count[lens[sym]]++; + + /* bound code lengths, force root to be within code lengths */ + root = *bits; + for (max = MAXBITS; max >= 1; max--) + if (count[max] != 0) break; + if (root > max) root = max; + if (max == 0) { /* no symbols to code at all */ + this.op = (unsigned char)64; /* invalid code marker */ + this.bits = (unsigned char)1; + this.val = (unsigned short)0; + *(*table)++ = this; /* make a table to force an error */ + *(*table)++ = this; + *bits = 1; + return 0; /* no symbols, but wait for decoding to report error */ + } + for (min = 1; min <= MAXBITS; min++) + if (count[min] != 0) break; + if (root < min) root = min; + + /* check for an over-subscribed or incomplete set of lengths */ + left = 1; + for (len = 1; len <= MAXBITS; len++) { + left <<= 1; + left -= count[len]; + if (left < 0) return -1; /* over-subscribed */ + } + if (left > 0 && (type == CODES || max != 1)) + return -1; /* incomplete set */ + + /* generate offsets into symbol table for each length for sorting */ + offs[1] = 0; + for (len = 1; len < MAXBITS; len++) + offs[len + 1] = offs[len] + count[len]; + + /* sort symbols by length, by symbol order within each length */ + for (sym = 0; sym < codes; sym++) + if (lens[sym] != 0) work[offs[lens[sym]]++] = (unsigned short)sym; + + /* + Create and fill in decoding tables. In this loop, the table being + filled is at next and has curr index bits. The code being used is huff + with length len. That code is converted to an index by dropping drop + bits off of the bottom. For codes where len is less than drop + curr, + those top drop + curr - len bits are incremented through all values to + fill the table with replicated entries. + + root is the number of index bits for the root table. When len exceeds + root, sub-tables are created pointed to by the root entry with an index + of the low root bits of huff. This is saved in low to check for when a + new sub-table should be started. drop is zero when the root table is + being filled, and drop is root when sub-tables are being filled. + + When a new sub-table is needed, it is necessary to look ahead in the + code lengths to determine what size sub-table is needed. The length + counts are used for this, and so count[] is decremented as codes are + entered in the tables. + + used keeps track of how many table entries have been allocated from the + provided *table space. It is checked when a LENS table is being made + against the space in *table, ENOUGH, minus the maximum space needed by + the worst case distance code, MAXD. This should never happen, but the + sufficiency of ENOUGH has not been proven exhaustively, hence the check. + This assumes that when type == LENS, bits == 9. + + sym increments through all symbols, and the loop terminates when + all codes of length max, i.e. all codes, have been processed. This + routine permits incomplete codes, so another loop after this one fills + in the rest of the decoding tables with invalid code markers. + */
-local int inflate_blocks(s, z, r) -inflate_blocks_statef *s; -z_stream *z; -int r; -{ - uInt t; /* temporary storage */ - uLong b; /* bit buffer */ - uInt k; /* bits in bit buffer */ - Bytef *p; /* input data pointer */ - uInt n; /* bytes available there */ - Bytef *q; /* output window write pointer */ - uInt m; /* bytes to end of window or read pointer */ - - /* copy input/output information to locals (UPDATE macro restores) */ - LOAD - - /* process input based on current state */ - while (1) switch (s->mode) - { - case TYPE: - NEEDBITS(3) - t = (uInt)b & 7; - s->last = t & 1; - switch (t >> 1) - { - case 0: /* stored */ - Trace((stderr, "inflate: stored block%s\n", - s->last ? " (last)" : "")); - DUMPBITS(3) - t = k & 7; /* go to byte boundary */ - DUMPBITS(t) - s->mode = LENS; /* get length of stored block */ - break; - case 1: /* fixed */ - Trace((stderr, "inflate: fixed codes block%s\n", - s->last ? " (last)" : "")); - { - uInt bl, bd; - inflate_huft *tl, *td; - - inflate_trees_fixed(&bl, &bd, &tl, &td); - s->sub.decode.codes = inflate_codes_new(bl, bd, tl, td, z); - if (s->sub.decode.codes == Z_NULL) - { - r = Z_MEM_ERROR; - LEAVE - } - s->sub.decode.tl = Z_NULL; /* don't try to free these */ - s->sub.decode.td = Z_NULL; - } - DUMPBITS(3) - s->mode = CODES; - break; - case 2: /* dynamic */ - Trace((stderr, "inflate: dynamic codes block%s\n", - s->last ? " (last)" : "")); - DUMPBITS(3) - s->mode = TABLE; - break; - case 3: /* illegal */ - DUMPBITS(3) - s->mode = BADB; - z->msg = "invalid block type"; - r = Z_DATA_ERROR; - LEAVE - } - break; - case LENS: - NEEDBITS(32) - if (((~b) >> 16) != (b & 0xffff)) - { - s->mode = BADB; - z->msg = "invalid stored block lengths"; - r = Z_DATA_ERROR; - LEAVE - } - s->sub.left = (uInt)b & 0xffff; - b = k = 0; /* dump bits */ - Tracev((stderr, "inflate: stored length %u\n", s->sub.left)); - s->mode = s->sub.left ? STORED : TYPE; - break; - case STORED: - if (n == 0) - LEAVE - NEEDOUT - t = s->sub.left; - if (t > n) t = n; - if (t > m) t = m; - zmemcpy(q, p, t); - p += t; n -= t; - q += t; m -= t; - if ((s->sub.left -= t) != 0) - break; - Tracev((stderr, "inflate: stored end, %lu total out\n", - z->total_out + (q >= s->read ? q - s->read : - (s->end - s->read) + (q - s->window)))); - s->mode = s->last ? DRY : TYPE; - break; - case TABLE: - NEEDBITS(14) - s->sub.trees.table = t = (uInt)b & 0x3fff; -#ifndef PKZIP_BUG_WORKAROUND - if ((t & 0x1f) > 29 || ((t >> 5) & 0x1f) > 29) - { - s->mode = BADB; - z->msg = "too many length or distance symbols"; - r = Z_DATA_ERROR; - LEAVE - } -#endif - t = 258 + (t & 0x1f) + ((t >> 5) & 0x1f); - if (t < 19) - t = 19; - if ((s->sub.trees.blens = (uIntf*)ZALLOC(z, t, sizeof(uInt))) == Z_NULL) - { - r = Z_MEM_ERROR; - LEAVE - } - s->sub.trees.nblens = t; - DUMPBITS(14) - s->sub.trees.index = 0; - Tracev((stderr, "inflate: table sizes ok\n")); - s->mode = BTREE; - case BTREE: - while (s->sub.trees.index < 4 + (s->sub.trees.table >> 10)) - { - NEEDBITS(3) - s->sub.trees.blens[border[s->sub.trees.index++]] = (uInt)b & 7; - DUMPBITS(3) - } - while (s->sub.trees.index < 19) - s->sub.trees.blens[border[s->sub.trees.index++]] = 0; - s->sub.trees.bb = 7; - t = inflate_trees_bits(s->sub.trees.blens, &s->sub.trees.bb, - &s->sub.trees.tb, z); - if (t != Z_OK) - { - r = t; - if (r == Z_DATA_ERROR) - s->mode = BADB; - LEAVE - } - s->sub.trees.index = 0; - Tracev((stderr, "inflate: bits tree ok\n")); - s->mode = DTREE; - case DTREE: - while (t = s->sub.trees.table, - s->sub.trees.index < 258 + (t & 0x1f) + ((t >> 5) & 0x1f)) - { - inflate_huft *h; - uInt i, j, c; - - t = s->sub.trees.bb; - NEEDBITS(t) - h = s->sub.trees.tb + ((uInt)b & inflate_mask[t]); - t = h->word.what.Bits; - c = h->more.Base; - if (c < 16) - { - DUMPBITS(t) - s->sub.trees.blens[s->sub.trees.index++] = c; - } - else /* c == 16..18 */ - { - i = c == 18 ? 7 : c - 14; - j = c == 18 ? 11 : 3; - NEEDBITS(t + i) - DUMPBITS(t) - j += (uInt)b & inflate_mask[i]; - DUMPBITS(i) - i = s->sub.trees.index; - t = s->sub.trees.table; - if (i + j > 258 + (t & 0x1f) + ((t >> 5) & 0x1f) || - (c == 16 && i < 1)) - { - s->mode = BADB; - z->msg = "invalid bit length repeat"; - r = Z_DATA_ERROR; - LEAVE - } - c = c == 16 ? s->sub.trees.blens[i - 1] : 0; - do { - s->sub.trees.blens[i++] = c; - } while (--j); - s->sub.trees.index = i; - } - } - inflate_trees_free(s->sub.trees.tb, z); - s->sub.trees.tb = Z_NULL; - { - uInt bl, bd; - inflate_huft *tl, *td; - inflate_codes_statef *c; - - bl = 9; /* must be <= 9 for lookahead assumptions */ - bd = 6; /* must be <= 9 for lookahead assumptions */ - t = s->sub.trees.table; - t = inflate_trees_dynamic(257 + (t & 0x1f), 1 + ((t >> 5) & 0x1f), - s->sub.trees.blens, &bl, &bd, &tl, &td, z); - if (t != Z_OK) - { - if (t == (uInt)Z_DATA_ERROR) - s->mode = BADB; - r = t; - LEAVE - } - Tracev((stderr, "inflate: trees ok\n")); - if ((c = inflate_codes_new(bl, bd, tl, td, z)) == Z_NULL) - { - inflate_trees_free(td, z); - inflate_trees_free(tl, z); - r = Z_MEM_ERROR; - LEAVE - } - ZFREE(z, s->sub.trees.blens, s->sub.trees.nblens * sizeof(uInt)); - s->sub.decode.codes = c; - s->sub.decode.tl = tl; - s->sub.decode.td = td; - } - s->mode = CODES; + /* set up for code type */ + switch (type) { case CODES: - UPDATE - if ((r = inflate_codes(s, z, r)) != Z_STREAM_END) - return inflate_flush(s, z, r); - r = Z_OK; - inflate_codes_free(s->sub.decode.codes, z); - inflate_trees_free(s->sub.decode.td, z); - inflate_trees_free(s->sub.decode.tl, z); - LOAD - Tracev((stderr, "inflate: codes end, %lu total out\n", - z->total_out + (q >= s->read ? q - s->read : - (s->end - s->read) + (q - s->window)))); - if (!s->last) - { - s->mode = TYPE; - break; - } - if (k > 7) /* return unused byte, if any */ - { - Assert(k < 16, "inflate_codes grabbed too many bytes") - k -= 8; - n++; - p--; /* can always return one */ - } - s->mode = DRY; - case DRY: - FLUSH - if (s->read != s->write) - LEAVE - s->mode = DONEB; - case DONEB: - r = Z_STREAM_END; - LEAVE - case BADB: - r = Z_DATA_ERROR; - LEAVE - default: - r = Z_STREAM_ERROR; - LEAVE - } -} - + base = extra = work; /* dummy value--not used */ + end = 19; + break; + case LENS: + base = lbase; + base -= 257; + extra = lext; + extra -= 257; + end = 256; + break; + default: /* DISTS */ + base = dbase; + extra = dext; + end = -1; + }
-local int inflate_blocks_free(s, z, c) -inflate_blocks_statef *s; -z_stream *z; -uLongf *c; -{ - inflate_blocks_reset(s, z, c); - ZFREE(z, s->window, s->end - s->window); - ZFREE(z, s, sizeof(struct inflate_blocks_state)); - Trace((stderr, "inflate: blocks freed\n")); - return Z_OK; -} + /* initialize state for loop */ + huff = 0; /* starting code */ + sym = 0; /* starting code symbol */ + len = min; /* starting code length */ + next = *table; /* current table to fill in */ + curr = root; /* current table index bits */ + drop = 0; /* current bits to drop from code for index */ + low = (unsigned)(-1); /* trigger new sub-table when len > root */ + used = 1U << root; /* use root table entries */ + mask = used - 1; /* mask for comparing low */ + + /* check available table space */ + if (type == LENS && used >= ENOUGH - MAXD) + return 1; + + /* process all codes and make table entries */ + for (;;) { + /* create table entry */ + this.bits = (unsigned char)(len - drop); + if ((int)(work[sym]) < end) { + this.op = (unsigned char)0; + this.val = work[sym]; + } + else if ((int)(work[sym]) > end) { + this.op = (unsigned char)(extra[work[sym]]); + this.val = base[work[sym]]; + } + else { + this.op = (unsigned char)(32 + 64); /* end of block */ + this.val = 0; + } + + /* replicate for those indices with low len bits equal to huff */ + incr = 1U << (len - drop); + fill = 1U << curr; + min = fill; /* save offset to next table */ + do { + fill -= incr; + next[(huff >> drop) + fill] = this; + } while (fill != 0); + + /* backwards increment the len-bit code huff */ + incr = 1U << (len - 1); + while (huff & incr) + incr >>= 1; + if (incr != 0) { + huff &= incr - 1; + huff += incr; + } + else + huff = 0; + + /* go to next symbol, update count, len */ + sym++; + if (--(count[len]) == 0) { + if (len == max) break; + len = lens[work[sym]]; + } + + /* create new sub-table if needed */ + if (len > root && (huff & mask) != low) { + /* if first time, transition to sub-tables */ + if (drop == 0) + drop = root; + + /* increment past last table */ + next += min; /* here min is 1 << curr */ + + /* determine length of next table */ + curr = len - drop; + left = (int)(1 << curr); + while (curr + drop < max) { + left -= count[curr + drop]; + if (left <= 0) break; + curr++; + left <<= 1; + } + + /* check for enough space */ + used += 1U << curr; + if (type == LENS && used >= ENOUGH - MAXD) + return 1; + + /* point entry in root table to sub-table */ + low = huff & mask; + (*table)[low].op = (unsigned char)curr; + (*table)[low].bits = (unsigned char)root; + (*table)[low].val = (unsigned short)(next - *table); + } + }
-/* - * This subroutine adds the data at next_in/avail_in to the output history - * without performing any output. The output buffer must be "caught up"; - * i.e. no pending output (hence s->read equals s->write), and the state must - * be BLOCKS (i.e. we should be willing to see the start of a series of - * BLOCKS). On exit, the output will also be caught up, and the checksum - * will have been updated if need be. - */ -local int inflate_addhistory(s, z) -inflate_blocks_statef *s; -z_stream *z; -{ - uLong b; /* bit buffer */ /* NOT USED HERE */ - uInt k; /* bits in bit buffer */ /* NOT USED HERE */ - uInt t; /* temporary storage */ - Bytef *p; /* input data pointer */ - uInt n; /* bytes available there */ - Bytef *q; /* output window write pointer */ - uInt m; /* bytes to end of window or read pointer */ - - if (s->read != s->write) - return Z_STREAM_ERROR; - if (s->mode != TYPE) - return Z_DATA_ERROR; - - /* we're ready to rock */ - LOAD - /* while there is input ready, copy to output buffer, moving - * pointers as needed. + /* + Fill in rest of table for incomplete codes. This loop is similar to the + loop above in incrementing huff for table indices. It is assumed that + len is equal to curr + drop, so there is no loop needed to increment + through high index bits. When the current sub-table is filled, the loop + drops back to the root table to fill in any remaining entries there. */ - while (n) { - t = n; /* how many to do */ - /* is there room until end of buffer? */ - if (t > m) t = m; - /* update check information */ - if (s->checkfn != Z_NULL) - s->check = (*s->checkfn)(s->check, q, t); - /* output callback */ - if (z->outcb != Z_NULL) - (*z->outcb)(q, t); - zmemcpy(q, p, t); - q += t; - p += t; - n -= t; - z->total_out += t; - s->read = q; /* drag read pointer forward */ -/* WRAP */ /* expand WRAP macro by hand to handle s->read */ - if (q == s->end) { - s->read = q = s->window; - m = WAVAIL; - } + this.op = (unsigned char)64; /* invalid code marker */ + this.bits = (unsigned char)(len - drop); + this.val = (unsigned short)0; + while (huff != 0) { + /* when done with sub-table, drop back to root table */ + if (drop != 0 && (huff & mask) != low) { + drop = 0; + len = root; + next = *table; + this.bits = (unsigned char)len; + } + + /* put invalid code marker in table */ + next[huff >> drop] = this; + + /* backwards increment the len-bit code huff */ + incr = 1U << (len - 1); + while (huff & incr) + incr >>= 1; + if (incr != 0) { + huff &= incr - 1; + huff += incr; + } + else + huff = 0; } - UPDATE - return Z_OK; -} -
-/* - * At the end of a Deflate-compressed PPP packet, we expect to have seen - * a `stored' block type value but not the (zero) length bytes. - */ -local int inflate_packet_flush(s) - inflate_blocks_statef *s; -{ - if (s->mode != LENS) - return Z_DATA_ERROR; - s->mode = TYPE; - return Z_OK; + /* set return parameters */ + *table += used; + *bits = root; + return 0; }
- /*+++++*/ -/* inftrees.c -- generate Huffman trees for efficient decoding - * Copyright (C) 1995 Mark Adler +/* inflate.c -- zlib decompression + * Copyright (C) 1995-2005 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */ +local void fixedtables OF((struct inflate_state FAR *state)); +local int updatewindow OF((z_streamp strm, unsigned out));
-/* simplify the use of the inflate_huft type with some defines */ -#define base more.Base -#define next more.Next -#define exop word.what.Exop -#define bits word.what.Bits - - -local int huft_build OF(( - uIntf *, /* code lengths in bits */ - uInt, /* number of codes */ - uInt, /* number of "simple" codes */ - uIntf *, /* list of base values for non-simple codes */ - uIntf *, /* list of extra bits for non-simple codes */ - inflate_huft * FAR*,/* result: starting table */ - uIntf *, /* maximum lookup bits (returns actual) */ - z_stream *)); /* for zalloc function */ - -local voidpf falloc OF(( - voidpf, /* opaque pointer (not used) */ - uInt, /* number of items */ - uInt)); /* size of item */ - -local void ffree OF(( - voidpf q, /* opaque pointer (not used) */ - voidpf p, /* what to free (not used) */ - uInt n)); /* number of bytes (not used) */ - -/* Tables for deflate from PKZIP's appnote.txt. */ -local uInt cplens[] = { /* Copy lengths for literal codes 257..285 */ - 3, 4, 5, 6, 7, 8, 9, 10, 11, 13, 15, 17, 19, 23, 27, 31, - 35, 43, 51, 59, 67, 83, 99, 115, 131, 163, 195, 227, 258, 0, 0}; - /* actually lengths - 2; also see note #13 above about 258 */ -local uInt cplext[] = { /* Extra bits for literal codes 257..285 */ - 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 2, 2, 2, 2, - 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 0, 192, 192}; /* 192==invalid */ -local uInt cpdist[] = { /* Copy offsets for distance codes 0..29 */ - 1, 2, 3, 4, 5, 7, 9, 13, 17, 25, 33, 49, 65, 97, 129, 193, - 257, 385, 513, 769, 1025, 1537, 2049, 3073, 4097, 6145, - 8193, 12289, 16385, 24577}; -local uInt cpdext[] = { /* Extra bits for distance codes */ - 0, 0, 0, 0, 1, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, - 7, 7, 8, 8, 9, 9, 10, 10, 11, 11, - 12, 12, 13, 13}; - -/* - Huffman code decoding is performed using a multi-level table lookup. - The fastest way to decode is to simply build a lookup table whose - size is determined by the longest code. However, the time it takes - to build this table can also be a factor if the data being decoded - is not very long. The most common codes are necessarily the - shortest codes, so those codes dominate the decoding time, and hence - the speed. The idea is you can have a shorter table that decodes the - shorter, more probable codes, and then point to subsidiary tables for - the longer codes. The time it costs to decode the longer codes is - then traded against the time it takes to make longer tables. - - This results of this trade are in the variables lbits and dbits - below. lbits is the number of bits the first level table for literal/ - length codes can decode in one step, and dbits is the same thing for - the distance codes. Subsequent tables are also less than or equal to - those sizes. These values may be adjusted either when all of the - codes are shorter than that, in which case the longest code length in - bits is used, or when the shortest code is *longer* than the requested - table size, in which case the length of the shortest code in bits is - used. - - There are two different values for the two tables, since they code a - different number of possibilities each. The literal/length table - codes 286 possible values, or in a flat code, a little over eight - bits. The distance table codes 30 possible values, or a little less - than five bits, flat. The optimum values for speed end up being - about one bit more than those, so lbits is 8+1 and dbits is 5+1. - The optimum values may differ though from machine to machine, and - possibly even between compilers. Your mileage may vary. - */ - - -/* If BMAX needs to be larger than 16, then h and x[] should be uLong. */ -#define BMAX 15 /* maximum bit length of any code */ -#define N_MAX 288 /* maximum number of codes in any set */ - -#ifdef DEBUG_ZLIB - uInt inflate_hufts; -#endif - -local int huft_build(b, n, s, d, e, t, m, zs) -uIntf *b; /* code lengths in bits (all assumed <= BMAX) */ -uInt n; /* number of codes (assumed <= N_MAX) */ -uInt s; /* number of simple-valued codes (0..s-1) */ -uIntf *d; /* list of base values for non-simple codes */ -uIntf *e; /* list of extra bits for non-simple codes */ -inflate_huft * FAR *t; /* result: starting table */ -uIntf *m; /* maximum lookup bits, returns actual */ -z_stream *zs; /* for zalloc function */ -/* Given a list of code lengths and a maximum table size, make a set of - tables to decode that set of codes. Return Z_OK on success, Z_BUF_ERROR - if the given code set is incomplete (the tables are still built in this - case), Z_DATA_ERROR if the input is invalid (all zero length codes or an - over-subscribed set of lengths), or Z_MEM_ERROR if not enough memory. */ +int ZEXPORT inflateReset(strm) +z_streamp strm; { - - uInt a; /* counter for codes of length k */ - uInt c[BMAX+1]; /* bit length count table */ - uInt f; /* i repeats in table every f entries */ - int g; /* maximum code length */ - int h; /* table level */ - register uInt i; /* counter, current code */ - register uInt j; /* counter */ - register int k; /* number of bits in current code */ - int l; /* bits per table (returned in m) */ - register uIntf *p; /* pointer into c[], b[], or v[] */ - inflate_huft *q; /* points to current table */ - struct inflate_huft_s r; /* table entry for structure assignment */ - inflate_huft *u[BMAX]; /* table stack */ - uInt v[N_MAX]; /* values in order of bit length */ - register int w; /* bits before this table == (l * h) */ - uInt x[BMAX+1]; /* bit offsets, then code stack */ - uIntf *xp; /* pointer into x */ - int y; /* number of dummy codes added */ - uInt z; /* number of entries in current table */ - - - /* Generate counts for each bit length */ - p = c; -#define C0 *p++ = 0; -#define C2 C0 C0 C0 C0 -#define C4 C2 C2 C2 C2 - C4 /* clear c[]--assume BMAX+1 is 16 */ - p = b; i = n; - do { - c[*p++]++; /* assume all entries <= BMAX */ - } while (--i); - if (c[0] == n) /* null input--all zero length codes */ - { - *t = (inflate_huft *)Z_NULL; - *m = 0; + struct inflate_state FAR *state; + + if (strm == Z_NULL || strm->state == Z_NULL) return Z_STREAM_ERROR; + state = (struct inflate_state FAR *)strm->state; + strm->total_in = strm->total_out = state->total = 0; + strm->msg = Z_NULL; + strm->adler = 1; /* to support ill-conceived Java test suite */ + state->mode = HEAD; + state->last = 0; + state->havedict = 0; + state->dmax = 32768U; + state->head = Z_NULL; + state->wsize = 0; + state->whave = 0; + state->write = 0; + state->hold = 0; + state->bits = 0; + state->lencode = state->distcode = state->next = state->codes; + Tracev((stderr, "inflate: reset\n")); return Z_OK; - } - - - /* Find minimum and maximum length, bound *m by those */ - l = *m; - for (j = 1; j <= BMAX; j++) - if (c[j]) - break; - k = j; /* minimum code length */ - if ((uInt)l < j) - l = j; - for (i = BMAX; i; i--) - if (c[i]) - break; - g = i; /* maximum code length */ - if ((uInt)l > i) - l = i; - *m = l; - - - /* Adjust last length count to fill out codes, if needed */ - for (y = 1 << j; j < i; j++, y <<= 1) - if ((y -= c[j]) < 0) - return Z_DATA_ERROR; - if ((y -= c[i]) < 0) - return Z_DATA_ERROR; - c[i] += y; - - - /* Generate starting offsets into the value table for each length */ - x[1] = j = 0; - p = c + 1; xp = x + 2; - while (--i) { /* note that i == g from above */ - *xp++ = (j += *p++); - } - - - /* Make a table of values in order of bit lengths */ - p = b; i = 0; - do { - if ((j = *p++) != 0) - v[x[j]++] = i; - } while (++i < n); - - - /* Generate the Huffman codes and for each, make the table entries */ - x[0] = i = 0; /* first Huffman code is zero */ - p = v; /* grab values in bit order */ - h = -1; /* no tables yet--level -1 */ - w = -l; /* bits decoded == (l * h) */ - u[0] = (inflate_huft *)Z_NULL; /* just to keep compilers happy */ - q = (inflate_huft *)Z_NULL; /* ditto */ - z = 0; /* ditto */ - - /* go through the bit lengths (k already is bits in shortest code) */ - for (; k <= g; k++) - { - a = c[k]; - while (a--) - { - /* here i is the Huffman code of length k bits for value *p */ - /* make tables up to required level */ - while (k > w + l) - { - h++; - w += l; /* previous table always l bits */ - - /* compute minimum size table less than or equal to l bits */ - z = (z = g - w) > (uInt)l ? l : z; /* table size upper limit */ - if ((f = 1 << (j = k - w)) > a + 1) /* try a k-w bit table */ - { /* too few codes for k-w bit table */ - f -= a + 1; /* deduct codes from patterns left */ - xp = c + k; - if (j < z) - while (++j < z) /* try smaller tables up to z bits */ - { - if ((f <<= 1) <= *++xp) - break; /* enough codes to use up j bits */ - f -= *xp; /* else deduct codes from patterns */ - } - } - z = 1 << j; /* table entries for j-bit table */ - - /* allocate and link in new table */ - if ((q = (inflate_huft *)ZALLOC - (zs,z + 1,sizeof(inflate_huft))) == Z_NULL) - { - if (h) - inflate_trees_free(u[0], zs); - return Z_MEM_ERROR; /* not enough memory */ - } - q->word.Nalloc = z + 1; -#ifdef DEBUG_ZLIB - inflate_hufts += z + 1; -#endif - *t = q + 1; /* link to list for huft_free() */ - *(t = &(q->next)) = Z_NULL; - u[h] = ++q; /* table starts after link */ - - /* connect to last table, if there is one */ - if (h) - { - x[h] = i; /* save pattern for backing up */ - r.bits = (Byte)l; /* bits to dump before this table */ - r.exop = (Byte)j; /* bits in this table */ - r.next = q; /* pointer to this table */ - j = i >> (w - l); /* (get around Turbo C bug) */ - u[h-1][j] = r; /* connect to last table */ - } - } - - /* set up table entry in r */ - r.bits = (Byte)(k - w); - if (p >= v + n) - r.exop = 128 + 64; /* out of values--invalid code */ - else if (*p < s) - { - r.exop = (Byte)(*p < 256 ? 0 : 32 + 64); /* 256 is end-of-block */ - r.base = *p++; /* simple code is just the value */ - } - else - { - r.exop = (Byte)e[*p - s] + 16 + 64; /* non-simple--look up in lists */ - r.base = d[*p++ - s]; - } - - /* fill code-like entries with r */ - f = 1 << (k - w); - for (j = i >> w; j < z; j += f) - q[j] = r; - - /* backwards increment the k-bit code i */ - for (j = 1 << (k - 1); i & j; j >>= 1) - i ^= j; - i ^= j; - - /* backup over finished tables */ - while ((i & ((1 << w) - 1)) != x[h]) - { - h--; /* don't need to update q */ - w -= l; - } - } - } - - - /* Return Z_BUF_ERROR if we were given an incomplete table */ - return y != 0 && g != 1 ? Z_BUF_ERROR : Z_OK; -} - - -local int inflate_trees_bits(c, bb, tb, z) -uIntf *c; /* 19 code lengths */ -uIntf *bb; /* bits tree desired/actual depth */ -inflate_huft * FAR *tb; /* bits tree result */ -z_stream *z; /* for zfree function */ -{ - int r; - - r = huft_build(c, 19, 19, (uIntf*)Z_NULL, (uIntf*)Z_NULL, tb, bb, z); - if (r == Z_DATA_ERROR) - z->msg = "oversubscribed dynamic bit lengths tree"; - else if (r == Z_BUF_ERROR) - { - inflate_trees_free(*tb, z); - z->msg = "incomplete dynamic bit lengths tree"; - r = Z_DATA_ERROR; - } - return r; }
- -local int inflate_trees_dynamic(nl, nd, c, bl, bd, tl, td, z) -uInt nl; /* number of literal/length codes */ -uInt nd; /* number of distance codes */ -uIntf *c; /* that many (total) code lengths */ -uIntf *bl; /* literal desired/actual bit depth */ -uIntf *bd; /* distance desired/actual bit depth */ -inflate_huft * FAR *tl; /* literal/length tree result */ -inflate_huft * FAR *td; /* distance tree result */ -z_stream *z; /* for zfree function */ +int ZEXPORT inflateInit2_(strm, windowBits, version, stream_size) +z_streamp strm; +int windowBits; +const char *version; +int stream_size; { - int r; - - /* build literal/length tree */ - if ((r = huft_build(c, nl, 257, cplens, cplext, tl, bl, z)) != Z_OK) - { - if (r == Z_DATA_ERROR) - z->msg = "oversubscribed literal/length tree"; - else if (r == Z_BUF_ERROR) - { - inflate_trees_free(*tl, z); - z->msg = "incomplete literal/length tree"; - r = Z_DATA_ERROR; + struct inflate_state FAR *state; + + if (version == Z_NULL || version[0] != ZLIB_VERSION[0] || + stream_size != (int)(sizeof(z_stream))) + return Z_VERSION_ERROR; + if (strm == Z_NULL) return Z_STREAM_ERROR; + strm->msg = Z_NULL; /* in case we return an error */ + if (strm->zalloc == (alloc_func)0) { + strm->zalloc = zcalloc; + strm->opaque = (voidpf)0; } - return r; - } - - /* build distance tree */ - if ((r = huft_build(c + nl, nd, 0, cpdist, cpdext, td, bd, z)) != Z_OK) - { - if (r == Z_DATA_ERROR) - z->msg = "oversubscribed literal/length tree"; - else if (r == Z_BUF_ERROR) { -#ifdef PKZIP_BUG_WORKAROUND - r = Z_OK; - } -#else - inflate_trees_free(*td, z); - z->msg = "incomplete literal/length tree"; - r = Z_DATA_ERROR; + if (strm->zfree == (free_func)0) strm->zfree = zcfree; + state = (struct inflate_state FAR *) + ZALLOC(strm, 1, sizeof(struct inflate_state)); + if (state == Z_NULL) return Z_MEM_ERROR; + Tracev((stderr, "inflate: allocated\n")); + strm->state = (struct internal_state FAR *)state; + if (windowBits < 0) { + state->wrap = 0; + windowBits = -windowBits; } - inflate_trees_free(*tl, z); - return r; + else { + state->wrap = (windowBits >> 4) + 1; +#ifdef GUNZIP + if (windowBits < 48) windowBits &= 15; #endif - } - - /* done */ - return Z_OK; -} - - -/* build fixed tables only once--keep them here */ -local int fixed_lock = 0; -local int fixed_built = 0; -#define FIXEDH 530 /* number of hufts used by fixed tables */ -local uInt fixed_left = FIXEDH; -local inflate_huft fixed_mem[FIXEDH]; -local uInt fixed_bl; -local uInt fixed_bd; -local inflate_huft *fixed_tl; -local inflate_huft *fixed_td; - - -local voidpf falloc(q, n, s) -voidpf q; /* opaque pointer (not used) */ -uInt n; /* number of items */ -uInt s; /* size of item */ -{ - Assert(s == sizeof(inflate_huft) && n <= fixed_left, - "inflate_trees falloc overflow"); - if (q) s++; /* to make some compilers happy */ - fixed_left -= n; - return (voidpf)(fixed_mem + fixed_left); -} - - -local void ffree(q, p, n) -voidpf q; -voidpf p; -uInt n; -{ - Assert(0, "inflate_trees ffree called!"); - if (q) q = p; /* to make some compilers happy */ + } + if (windowBits < 8 || windowBits > 15) { + ZFREE(strm, state); + strm->state = Z_NULL; + return Z_STREAM_ERROR; + } + state->wbits = (unsigned)windowBits; + state->window = Z_NULL; + return inflateReset(strm); }
- -local int inflate_trees_fixed(bl, bd, tl, td) -uIntf *bl; /* literal desired/actual bit depth */ -uIntf *bd; /* distance desired/actual bit depth */ -inflate_huft * FAR *tl; /* literal/length tree result */ -inflate_huft * FAR *td; /* distance tree result */ +int ZEXPORT inflateInit_(strm, version, stream_size) +z_streamp strm; +const char *version; +int stream_size; { - /* build fixed tables if not built already--lock out other instances */ - while (++fixed_lock > 1) - fixed_lock--; - if (!fixed_built) - { - int k; /* temporary variable */ - unsigned c[288]; /* length list for huft_build */ - z_stream z; /* for falloc function */ - - /* set up fake z_stream for memory routines */ - z.zalloc = falloc; - z.zfree = ffree; - z.opaque = Z_NULL; - - /* literal table */ - for (k = 0; k < 144; k++) - c[k] = 8; - for (; k < 256; k++) - c[k] = 9; - for (; k < 280; k++) - c[k] = 7; - for (; k < 288; k++) - c[k] = 8; - fixed_bl = 7; - huft_build(c, 288, 257, cplens, cplext, &fixed_tl, &fixed_bl, &z); - - /* distance table */ - for (k = 0; k < 30; k++) - c[k] = 5; - fixed_bd = 5; - huft_build(c, 30, 0, cpdist, cpdext, &fixed_td, &fixed_bd, &z); - - /* done */ - fixed_built = 1; - } - fixed_lock--; - *bl = fixed_bl; - *bd = fixed_bd; - *tl = fixed_tl; - *td = fixed_td; - return Z_OK; + return inflateInit2_(strm, DEF_WBITS, version, stream_size); }
- -local int inflate_trees_free(t, z) -inflate_huft *t; /* table to free */ -z_stream *z; /* for zfree function */ -/* Free the malloc'ed tables built by huft_build(), which makes a linked - list of the tables it made, with the links in a dummy first entry of - each table. */ +local void fixedtables(state) +struct inflate_state FAR *state; { - register inflate_huft *p, *q; - - /* Go through linked list, freeing from the malloced (t[-1]) address. */ - p = t; - while (p != Z_NULL) - { - q = (--p)->next; - ZFREE(z, p, p->word.Nalloc * sizeof(inflate_huft)); - p = q; - } - return Z_OK; + state->lencode = lenfix; + state->lenbits = 9; + state->distcode = distfix; + state->distbits = 5; }
-/*+++++*/ -/* infcodes.c -- process literals and length/distance pairs - * Copyright (C) 1995 Mark Adler - * For conditions of distribution and use, see copyright notice in zlib.h +/* + Update the window with the last wsize (normally 32K) bytes written before + returning. If window does not exist yet, create it. This is only called + when a window is already in use, or when output has been written during this + inflate call, but the end of the deflate stream has not been reached yet. + It is also called to create a window for dictionary data when a dictionary + is loaded. + + Providing output buffers larger than 32K to inflate() should provide a speed + advantage, since only the last 32K of output is copied to the sliding window + upon return from inflate(), and since all distances after the first 32K of + output will fall in the output data, making match copies simpler and faster. + The advantage may be dependent on the size of the processor's data caches. */ +local int updatewindow(strm, out) +z_streamp strm; +unsigned out; +{ + struct inflate_state FAR *state; + unsigned copy, dist;
-/* simplify the use of the inflate_huft type with some defines */ -#define base more.Base -#define next more.Next -#define exop word.what.Exop -#define bits word.what.Bits - -/* inflate codes private state */ -struct inflate_codes_state { - - /* mode */ - enum { /* waiting for "i:"=input, "o:"=output, "x:"=nothing */ - START, /* x: set up for LEN */ - LEN, /* i: get length/literal/eob next */ - LENEXT, /* i: getting length extra (have base) */ - DIST, /* i: get distance next */ - DISTEXT, /* i: getting distance extra */ - COPY, /* o: copying bytes in window, waiting for space */ - LIT, /* o: got literal, waiting for output space */ - WASH, /* o: got eob, possibly still output waiting */ - END, /* x: got eob and all data flushed */ - BADCODE} /* x: got error */ - mode; /* current inflate_codes mode */ - - /* mode dependent information */ - uInt len; - union { - struct { - inflate_huft *tree; /* pointer into tree */ - uInt need; /* bits needed */ - } code; /* if LEN or DIST, where in tree */ - uInt lit; /* if LIT, literal */ - struct { - uInt get; /* bits to get for extra */ - uInt dist; /* distance back to copy from */ - } copy; /* if EXT or COPY, where and how much */ - } sub; /* submode */ - - /* mode independent information */ - Byte lbits; /* ltree bits decoded per branch */ - Byte dbits; /* dtree bits decoder per branch */ - inflate_huft *ltree; /* literal/length/eob tree */ - inflate_huft *dtree; /* distance tree */ + state = (struct inflate_state FAR *)strm->state;
-}; + /* if it hasn't been done already, allocate space for the window */ + if (state->window == Z_NULL) { + state->window = (unsigned char FAR *) + ZALLOC(strm, 1U << state->wbits, + sizeof(unsigned char)); + if (state->window == Z_NULL) return 1; + }
+ /* if window not in use yet, initialize */ + if (state->wsize == 0) { + state->wsize = 1U << state->wbits; + state->write = 0; + state->whave = 0; + }
-local inflate_codes_statef *inflate_codes_new(bl, bd, tl, td, z) -uInt bl, bd; -inflate_huft *tl, *td; -z_stream *z; -{ - inflate_codes_statef *c; - - if ((c = (inflate_codes_statef *) - ZALLOC(z,1,sizeof(struct inflate_codes_state))) != Z_NULL) - { - c->mode = START; - c->lbits = (Byte)bl; - c->dbits = (Byte)bd; - c->ltree = tl; - c->dtree = td; - Tracev((stderr, "inflate: codes new\n")); - } - return c; + /* copy state->wsize or less output bytes into the circular window */ + copy = out - strm->avail_out; + if (copy >= state->wsize) { + zmemcpy(state->window, strm->next_out - state->wsize, state->wsize); + state->write = 0; + state->whave = state->wsize; + } + else { + dist = state->wsize - state->write; + if (dist > copy) dist = copy; + zmemcpy(state->window + state->write, strm->next_out - copy, dist); + copy -= dist; + if (copy) { + zmemcpy(state->window, strm->next_out - copy, copy); + state->write = copy; + state->whave = state->wsize; + } + else { + state->write += dist; + if (state->write == state->wsize) state->write = 0; + if (state->whave < state->wsize) state->whave += dist; + } + } + return 0; }
+/* Macros for inflate(): */ + +/* check function to use adler32() for zlib or crc32() for gzip */ +#define UPDATE(check, buf, len) \ + (state->flags ? crc32(check, buf, len) : adler32(check, buf, len)) + +/* check macros for header crc */ +#define CRC2(check, word) \ + do { \ + hbuf[0] = (unsigned char)(word); \ + hbuf[1] = (unsigned char)((word) >> 8); \ + check = crc32(check, hbuf, 2); \ + } while (0) + +#define CRC4(check, word) \ + do { \ + hbuf[0] = (unsigned char)(word); \ + hbuf[1] = (unsigned char)((word) >> 8); \ + hbuf[2] = (unsigned char)((word) >> 16); \ + hbuf[3] = (unsigned char)((word) >> 24); \ + check = crc32(check, hbuf, 4); \ + } while (0) + +/* Load registers with state in inflate() for speed */ +#define LOAD() \ + do { \ + put = strm->next_out; \ + left = strm->avail_out; \ + next = strm->next_in; \ + have = strm->avail_in; \ + hold = state->hold; \ + bits = state->bits; \ + } while (0) + +/* Restore state from registers in inflate() */ +#define RESTORE() \ + do { \ + strm->next_out = put; \ + strm->avail_out = left; \ + strm->next_in = next; \ + strm->avail_in = have; \ + state->hold = hold; \ + state->bits = bits; \ + } while (0) + +/* Clear the input bit accumulator */ +#define INITBITS() \ + do { \ + hold = 0; \ + bits = 0; \ + } while (0) + +/* Get a byte of input into the bit accumulator, or return from inflate() + if there is no input available. */ +#define PULLBYTE() \ + do { \ + if (have == 0) goto inf_leave; \ + have--; \ + hold += (unsigned long)(*next++) << bits; \ + bits += 8; \ + } while (0) + +/* Assure that there are at least n bits in the bit accumulator. If there is + not enough available input to do that, then return from inflate(). */ +#define NEEDBITS(n) \ + do { \ + while (bits < (unsigned)(n)) \ + PULLBYTE(); \ + } while (0) + +/* Return the low n bits of the bit accumulator (n < 16) */ +#define BITS(n) \ + ((unsigned)hold & ((1U << (n)) - 1)) + +/* Remove n bits from the bit accumulator */ +#define DROPBITS(n) \ + do { \ + hold >>= (n); \ + bits -= (unsigned)(n); \ + } while (0) + +/* Remove zero to seven bits as needed to go to a byte boundary */ +#define BYTEBITS() \ + do { \ + hold >>= bits & 7; \ + bits -= bits & 7; \ + } while (0) + +/* Reverse the bytes in a 32-bit value */ +#define REVERSE(q) \ + ((((q) >> 24) & 0xff) + (((q) >> 8) & 0xff00) + \ + (((q) & 0xff00) << 8) + (((q) & 0xff) << 24)) + +/* + inflate() uses a state machine to process as much input data and generate as + much output data as possible before returning. The state machine is + structured roughly as follows: + + for (;;) switch (state) { + ... + case STATEn: + if (not enough input data or output space to make progress) + return; + ... make progress ... + state = STATEm; + break; + ... + }
-local int inflate_codes(s, z, r) -inflate_blocks_statef *s; -z_stream *z; -int r; + so when inflate() is called again, the same case is attempted again, and + if the appropriate resources are provided, the machine proceeds to the + next state. The NEEDBITS() macro is usually the way the state evaluates + whether it can proceed or should return. NEEDBITS() does the return if + the requested bits are not available. The typical use of the BITS macros + is: + + NEEDBITS(n); + ... do something with BITS(n) ... + DROPBITS(n); + + where NEEDBITS(n) either returns from inflate() if there isn't enough + input left to load n bits into the accumulator, or it continues. BITS(n) + gives the low n bits in the accumulator. When done, DROPBITS(n) drops + the low n bits off the accumulator. INITBITS() clears the accumulator + and sets the number of available bits to zero. BYTEBITS() discards just + enough bits to put the accumulator on a byte boundary. After BYTEBITS() + and a NEEDBITS(8), then BITS(8) would return the next byte in the stream. + + NEEDBITS(n) uses PULLBYTE() to get an available byte of input, or to return + if there is no input available. The decoding of variable length codes uses + PULLBYTE() directly in order to pull just enough bytes to decode the next + code, and no more. + + Some states loop until they get enough input, making sure that enough + state information is maintained to continue the loop where it left off + if NEEDBITS() returns in the loop. For example, want, need, and keep + would all have to actually be part of the saved state in case NEEDBITS() + returns: + + case STATEw: + while (want < need) { + NEEDBITS(n); + keep[want++] = BITS(n); + DROPBITS(n); + } + state = STATEx; + case STATEx: + + As shown above, if the next state is also the next case, then the break + is omitted. + + A state may also return if there is not enough output space available to + complete that state. Those states are copying stored data, writing a + literal byte, and copying a matching string. + + When returning, a "goto inf_leave" is used to update the total counters, + update the check value, and determine whether any progress has been made + during that inflate() call in order to return the proper return code. + Progress is defined as a change in either strm->avail_in or strm->avail_out. + When there is a window, goto inf_leave will update the window with the last + output written. If a goto inf_leave occurs in the middle of decompression + and there is no window currently, goto inf_leave will create one and copy + output to the window for the next call of inflate(). + + In this implementation, the flush parameter of inflate() only affects the + return code (per zlib.h). inflate() always writes as much as possible to + strm->next_out, given the space available and the provided input--the effect + documented in zlib.h of Z_SYNC_FLUSH. Furthermore, inflate() always defers + the allocation of and copying into a sliding window until necessary, which + provides the effect documented in zlib.h for Z_FINISH when the entire input + stream available. So the only thing the flush parameter actually does is: + when flush is set to Z_FINISH, inflate() cannot return Z_OK. Instead it + will return Z_BUF_ERROR if it has not reached the end of the stream. + */ +int ZEXPORT inflate(strm, flush) +z_streamp strm; +int flush; { - uInt j; /* temporary storage */ - inflate_huft *t; /* temporary pointer */ - uInt e; /* extra bits or operation */ - uLong b; /* bit buffer */ - uInt k; /* bits in bit buffer */ - Bytef *p; /* input data pointer */ - uInt n; /* bytes available there */ - Bytef *q; /* output window write pointer */ - uInt m; /* bytes to end of window or read pointer */ - Bytef *f; /* pointer to copy strings from */ - inflate_codes_statef *c = s->sub.decode.codes; /* codes state */ - - /* copy input/output information to locals (UPDATE macro restores) */ - LOAD - - /* process input and output based on current state */ - while (1) switch (c->mode) - { /* waiting for "i:"=input, "o:"=output, "x:"=nothing */ - case START: /* x: set up for LEN */ -#ifndef SLOW - if (m >= 258 && n >= 10) - { - UPDATE - r = inflate_fast(c->lbits, c->dbits, c->ltree, c->dtree, s, z); - LOAD - if (r != Z_OK) - { - c->mode = r == Z_STREAM_END ? WASH : BADCODE; - break; - } - } -#endif /* !SLOW */ - c->sub.code.need = c->lbits; - c->sub.code.tree = c->ltree; - c->mode = LEN; - case LEN: /* i: get length/literal/eob next */ - j = c->sub.code.need; - NEEDBITS(j) - t = c->sub.code.tree + ((uInt)b & inflate_mask[j]); - DUMPBITS(t->bits) - e = (uInt)(t->exop); - if (e == 0) /* literal */ - { - c->sub.lit = t->base; - Tracevv((stderr, t->base >= 0x20 && t->base < 0x7f ? - "inflate: literal '%c'\n" : - "inflate: literal 0x%02x\n", t->base)); - c->mode = LIT; - break; - } - if (e & 16) /* length */ - { - c->sub.copy.get = e & 15; - c->len = t->base; - c->mode = LENEXT; - break; - } - if ((e & 64) == 0) /* next table */ - { - c->sub.code.need = e; - c->sub.code.tree = t->next; - break; - } - if (e & 32) /* end of block */ - { - Tracevv((stderr, "inflate: end of block\n")); - c->mode = WASH; - break; - } - c->mode = BADCODE; /* invalid code */ - z->msg = "invalid literal/length code"; - r = Z_DATA_ERROR; - LEAVE - case LENEXT: /* i: getting length extra (have base) */ - j = c->sub.copy.get; - NEEDBITS(j) - c->len += (uInt)b & inflate_mask[j]; - DUMPBITS(j) - c->sub.code.need = c->dbits; - c->sub.code.tree = c->dtree; - Tracevv((stderr, "inflate: length %u\n", c->len)); - c->mode = DIST; - case DIST: /* i: get distance next */ - j = c->sub.code.need; - NEEDBITS(j) - t = c->sub.code.tree + ((uInt)b & inflate_mask[j]); - DUMPBITS(t->bits) - e = (uInt)(t->exop); - if (e & 16) /* distance */ - { - c->sub.copy.get = e & 15; - c->sub.copy.dist = t->base; - c->mode = DISTEXT; - break; - } - if ((e & 64) == 0) /* next table */ - { - c->sub.code.need = e; - c->sub.code.tree = t->next; - break; - } - c->mode = BADCODE; /* invalid code */ - z->msg = "invalid distance code"; - r = Z_DATA_ERROR; - LEAVE - case DISTEXT: /* i: getting distance extra */ - j = c->sub.copy.get; - NEEDBITS(j) - c->sub.copy.dist += (uInt)b & inflate_mask[j]; - DUMPBITS(j) - Tracevv((stderr, "inflate: distance %u\n", c->sub.copy.dist)); - c->mode = COPY; - case COPY: /* o: copying bytes in window, waiting for space */ -#ifndef __TURBOC__ /* Turbo C bug for following expression */ - f = (uInt)(q - s->window) < c->sub.copy.dist ? - s->end - (c->sub.copy.dist - (q - s->window)) : - q - c->sub.copy.dist; + struct inflate_state FAR *state; + unsigned char FAR *next; /* next input */ + unsigned char FAR *put; /* next output */ + unsigned have, left; /* available input and output */ + unsigned long hold; /* bit buffer */ + unsigned bits; /* bits in bit buffer */ + unsigned in, out; /* save starting available input and output */ + unsigned copy; /* number of stored or match bytes to copy */ + unsigned char FAR *from; /* where to copy match bytes from */ + code this; /* current decoding table entry */ + code last; /* parent table entry */ + unsigned len; /* length to copy for repeats, bits to drop */ + int ret; /* return code */ +#ifdef GUNZIP + unsigned char hbuf[4]; /* buffer for gzip header crc calculation */ +#endif + static const unsigned short order[19] = /* permutation of code lengths */ + {16, 17, 18, 0, 8, 7, 9, 6, 10, 5, 11, 4, 12, 3, 13, 2, 14, 1, 15}; + + if (strm == Z_NULL || strm->state == Z_NULL || strm->next_out == Z_NULL || + (strm->next_in == Z_NULL && strm->avail_in != 0)) + return Z_STREAM_ERROR; + + state = (struct inflate_state FAR *)strm->state; + if (state->mode == TYPE) state->mode = TYPEDO; /* skip check */ + LOAD(); + in = have; + out = left; + ret = Z_OK; + for (;;) + switch (state->mode) { + case HEAD: + if (state->wrap == 0) { + state->mode = TYPEDO; + break; + } + NEEDBITS(16); +#ifdef GUNZIP + if ((state->wrap & 2) && hold == 0x8b1f) { /* gzip header */ + state->check = crc32(0L, Z_NULL, 0); + CRC2(state->check, hold); + INITBITS(); + state->mode = FLAGS; + break; + } + state->flags = 0; /* expect zlib header */ + if (state->head != Z_NULL) + state->head->done = -1; + if (!(state->wrap & 1) || /* check if zlib header allowed */ #else - f = q - c->sub.copy.dist; - if ((uInt)(q - s->window) < c->sub.copy.dist) - f = s->end - (c->sub.copy.dist - (q - s->window)); + if ( +#endif + ((BITS(8) << 8) + (hold >> 8)) % 31) { + strm->msg = (char *)"incorrect header check"; + state->mode = BAD; + break; + } + if (BITS(4) != Z_DEFLATED) { + strm->msg = (char *)"unknown compression method"; + state->mode = BAD; + break; + } + DROPBITS(4); + len = BITS(4) + 8; + if (len > state->wbits) { + strm->msg = (char *)"invalid window size"; + state->mode = BAD; + break; + } + state->dmax = 1U << len; + Tracev((stderr, "inflate: zlib header ok\n")); + strm->adler = state->check = adler32(0L, Z_NULL, 0); + state->mode = hold & 0x200 ? DICTID : TYPE; + INITBITS(); + break; +#ifdef GUNZIP + case FLAGS: + NEEDBITS(16); + state->flags = (int)(hold); + if ((state->flags & 0xff) != Z_DEFLATED) { + strm->msg = (char *)"unknown compression method"; + state->mode = BAD; + break; + } + if (state->flags & 0xe000) { + strm->msg = (char *)"unknown header flags set"; + state->mode = BAD; + break; + } + if (state->head != Z_NULL) + state->head->text = (int)((hold >> 8) & 1); + if (state->flags & 0x0200) CRC2(state->check, hold); + INITBITS(); + state->mode = TIME; + case TIME: + NEEDBITS(32); + if (state->head != Z_NULL) + state->head->time = hold; + if (state->flags & 0x0200) CRC4(state->check, hold); + INITBITS(); + state->mode = OS; + case OS: + NEEDBITS(16); + if (state->head != Z_NULL) { + state->head->xflags = (int)(hold & 0xff); + state->head->os = (int)(hold >> 8); + } + if (state->flags & 0x0200) CRC2(state->check, hold); + INITBITS(); + state->mode = EXLEN; + case EXLEN: + if (state->flags & 0x0400) { + NEEDBITS(16); + state->length = (unsigned)(hold); + if (state->head != Z_NULL) + state->head->extra_len = (unsigned)hold; + if (state->flags & 0x0200) CRC2(state->check, hold); + INITBITS(); + } + else if (state->head != Z_NULL) + state->head->extra = Z_NULL; + state->mode = EXTRA; + case EXTRA: + if (state->flags & 0x0400) { + copy = state->length; + if (copy > have) copy = have; + if (copy) { + if (state->head != Z_NULL && + state->head->extra != Z_NULL) { + len = state->head->extra_len - state->length; + zmemcpy(state->head->extra + len, next, + len + copy > state->head->extra_max ? + state->head->extra_max - len : copy); + } + if (state->flags & 0x0200) + state->check = crc32(state->check, next, copy); + have -= copy; + next += copy; + state->length -= copy; + } + if (state->length) goto inf_leave; + } + state->length = 0; + state->mode = NAME; + case NAME: + if (state->flags & 0x0800) { + if (have == 0) goto inf_leave; + copy = 0; + do { + len = (unsigned)(next[copy++]); + if (state->head != Z_NULL && + state->head->name != Z_NULL && + state->length < state->head->name_max) + state->head->name[state->length++] = len; + } while (len && copy < have); + if (state->flags & 0x0200) + state->check = crc32(state->check, next, copy); + have -= copy; + next += copy; + if (len) goto inf_leave; + } + else if (state->head != Z_NULL) + state->head->name = Z_NULL; + state->length = 0; + state->mode = COMMENT; + case COMMENT: + if (state->flags & 0x1000) { + if (have == 0) goto inf_leave; + copy = 0; + do { + len = (unsigned)(next[copy++]); + if (state->head != Z_NULL && + state->head->comment != Z_NULL && + state->length < state->head->comm_max) + state->head->comment[state->length++] = len; + } while (len && copy < have); + if (state->flags & 0x0200) + state->check = crc32(state->check, next, copy); + have -= copy; + next += copy; + if (len) goto inf_leave; + } + else if (state->head != Z_NULL) + state->head->comment = Z_NULL; + state->mode = HCRC; + case HCRC: + if (state->flags & 0x0200) { + NEEDBITS(16); + if (hold != (state->check & 0xffff)) { + strm->msg = (char *)"header crc mismatch"; + state->mode = BAD; + break; + } + INITBITS(); + } + if (state->head != Z_NULL) { + state->head->hcrc = (int)((state->flags >> 9) & 1); + state->head->done = 1; + } + strm->adler = state->check = crc32(0L, Z_NULL, 0); + state->mode = TYPE; + break; #endif - while (c->len) - { - NEEDOUT - OUTBYTE(*f++) - if (f == s->end) - f = s->window; - c->len--; - } - c->mode = START; - break; - case LIT: /* o: got literal, waiting for output space */ - NEEDOUT - OUTBYTE(c->sub.lit) - c->mode = START; - break; - case WASH: /* o: got eob, possibly more output */ - FLUSH - if (s->read != s->write) - LEAVE - c->mode = END; - case END: - r = Z_STREAM_END; - LEAVE - case BADCODE: /* x: got error */ - r = Z_DATA_ERROR; - LEAVE - default: - r = Z_STREAM_ERROR; - LEAVE - } + case DICTID: + NEEDBITS(32); + strm->adler = state->check = REVERSE(hold); + INITBITS(); + state->mode = DICT; + case DICT: + if (state->havedict == 0) { + RESTORE(); + return Z_NEED_DICT; + } + strm->adler = state->check = adler32(0L, Z_NULL, 0); + state->mode = TYPE; + case TYPE: + if (flush == Z_BLOCK) goto inf_leave; + case TYPEDO: + if (state->last) { + BYTEBITS(); + state->mode = CHECK; + break; + } + NEEDBITS(3); + state->last = BITS(1); + DROPBITS(1); + switch (BITS(2)) { + case 0: /* stored block */ + Tracev((stderr, "inflate: stored block%s\n", + state->last ? " (last)" : "")); + state->mode = STORED; + break; + case 1: /* fixed block */ + fixedtables(state); + Tracev((stderr, "inflate: fixed codes block%s\n", + state->last ? " (last)" : "")); + state->mode = LEN; /* decode codes */ + break; + case 2: /* dynamic block */ + Tracev((stderr, "inflate: dynamic codes block%s\n", + state->last ? " (last)" : "")); + state->mode = TABLE; + break; + case 3: + strm->msg = (char *)"invalid block type"; + state->mode = BAD; + } + DROPBITS(2); + break; + case STORED: + BYTEBITS(); /* go to byte boundary */ + NEEDBITS(32); + if ((hold & 0xffff) != ((hold >> 16) ^ 0xffff)) { + strm->msg = (char *)"invalid stored block lengths"; + state->mode = BAD; + break; + } + state->length = (unsigned)hold & 0xffff; + Tracev((stderr, "inflate: stored length %u\n", + state->length)); + INITBITS(); + state->mode = COPY; + case COPY: + copy = state->length; + if (copy) { + if (copy > have) copy = have; + if (copy > left) copy = left; + if (copy == 0) goto inf_leave; + zmemcpy(put, next, copy); + have -= copy; + next += copy; + left -= copy; + put += copy; + state->length -= copy; + break; + } + Tracev((stderr, "inflate: stored end\n")); + state->mode = TYPE; + break; + case TABLE: + NEEDBITS(14); + state->nlen = BITS(5) + 257; + DROPBITS(5); + state->ndist = BITS(5) + 1; + DROPBITS(5); + state->ncode = BITS(4) + 4; + DROPBITS(4); +#ifndef PKZIP_BUG_WORKAROUND + if (state->nlen > 286 || state->ndist > 30) { + strm->msg = (char *)"too many length or distance symbols"; + state->mode = BAD; + break; + } +#endif + Tracev((stderr, "inflate: table sizes ok\n")); + state->have = 0; + state->mode = LENLENS; + case LENLENS: + while (state->have < state->ncode) { + NEEDBITS(3); + state->lens[order[state->have++]] = (unsigned short)BITS(3); + DROPBITS(3); + } + while (state->have < 19) + state->lens[order[state->have++]] = 0; + state->next = state->codes; + state->lencode = (code const FAR *)(state->next); + state->lenbits = 7; + ret = inflate_table(CODES, state->lens, 19, &(state->next), + &(state->lenbits), state->work); + if (ret) { + strm->msg = (char *)"invalid code lengths set"; + state->mode = BAD; + break; + } + Tracev((stderr, "inflate: code lengths ok\n")); + state->have = 0; + state->mode = CODELENS; + case CODELENS: + while (state->have < state->nlen + state->ndist) { + for (;;) { + this = state->lencode[BITS(state->lenbits)]; + if ((unsigned)(this.bits) <= bits) break; + PULLBYTE(); + } + if (this.val < 16) { + NEEDBITS(this.bits); + DROPBITS(this.bits); + state->lens[state->have++] = this.val; + } + else { + if (this.val == 16) { + NEEDBITS(this.bits + 2); + DROPBITS(this.bits); + if (state->have == 0) { + strm->msg = (char *)"invalid bit length repeat"; + state->mode = BAD; + break; + } + len = state->lens[state->have - 1]; + copy = 3 + BITS(2); + DROPBITS(2); + } + else if (this.val == 17) { + NEEDBITS(this.bits + 3); + DROPBITS(this.bits); + len = 0; + copy = 3 + BITS(3); + DROPBITS(3); + } + else { + NEEDBITS(this.bits + 7); + DROPBITS(this.bits); + len = 0; + copy = 11 + BITS(7); + DROPBITS(7); + } + if (state->have + copy > state->nlen + state->ndist) { + strm->msg = (char *)"invalid bit length repeat"; + state->mode = BAD; + break; + } + while (copy--) + state->lens[state->have++] = (unsigned short)len; + } + } + + /* handle error breaks in while */ + if (state->mode == BAD) break; + + /* build code tables */ + state->next = state->codes; + state->lencode = (code const FAR *)(state->next); + state->lenbits = 9; + ret = inflate_table(LENS, state->lens, state->nlen, &(state->next), + &(state->lenbits), state->work); + if (ret) { + strm->msg = (char *)"invalid literal/lengths set"; + state->mode = BAD; + break; + } + state->distcode = (code const FAR *)(state->next); + state->distbits = 6; + ret = inflate_table(DISTS, state->lens + state->nlen, state->ndist, + &(state->next), &(state->distbits), state->work); + if (ret) { + strm->msg = (char *)"invalid distances set"; + state->mode = BAD; + break; + } + Tracev((stderr, "inflate: codes ok\n")); + state->mode = LEN; + case LEN: + if (have >= 6 && left >= 258) { + RESTORE(); + inflate_fast(strm, out); + LOAD(); + break; + } + for (;;) { + this = state->lencode[BITS(state->lenbits)]; + if ((unsigned)(this.bits) <= bits) break; + PULLBYTE(); + } + if (this.op && (this.op & 0xf0) == 0) { + last = this; + for (;;) { + this = state->lencode[last.val + + (BITS(last.bits + last.op) >> last.bits)]; + if ((unsigned)(last.bits + this.bits) <= bits) break; + PULLBYTE(); + } + DROPBITS(last.bits); + } + DROPBITS(this.bits); + state->length = (unsigned)this.val; + if ((int)(this.op) == 0) { + Tracevv((stderr, this.val >= 0x20 && this.val < 0x7f ? + "inflate: literal '%c'\n" : + "inflate: literal 0x%02x\n", this.val)); + state->mode = LIT; + break; + } + if (this.op & 32) { + Tracevv((stderr, "inflate: end of block\n")); + state->mode = TYPE; + break; + } + if (this.op & 64) { + strm->msg = (char *)"invalid literal/length code"; + state->mode = BAD; + break; + } + state->extra = (unsigned)(this.op) & 15; + state->mode = LENEXT; + case LENEXT: + if (state->extra) { + NEEDBITS(state->extra); + state->length += BITS(state->extra); + DROPBITS(state->extra); + } + Tracevv((stderr, "inflate: length %u\n", state->length)); + state->mode = DIST; + case DIST: + for (;;) { + this = state->distcode[BITS(state->distbits)]; + if ((unsigned)(this.bits) <= bits) break; + PULLBYTE(); + } + if ((this.op & 0xf0) == 0) { + last = this; + for (;;) { + this = state->distcode[last.val + + (BITS(last.bits + last.op) >> last.bits)]; + if ((unsigned)(last.bits + this.bits) <= bits) break; + PULLBYTE(); + } + DROPBITS(last.bits); + } + DROPBITS(this.bits); + if (this.op & 64) { + strm->msg = (char *)"invalid distance code"; + state->mode = BAD; + break; + } + state->offset = (unsigned)this.val; + state->extra = (unsigned)(this.op) & 15; + state->mode = DISTEXT; + case DISTEXT: + if (state->extra) { + NEEDBITS(state->extra); + state->offset += BITS(state->extra); + DROPBITS(state->extra); + } +#ifdef INFLATE_STRICT + if (state->offset > state->dmax) { + strm->msg = (char *)"invalid distance too far back"; + state->mode = BAD; + break; + } +#endif + if (state->offset > state->whave + out - left) { + strm->msg = (char *)"invalid distance too far back"; + state->mode = BAD; + break; + } + Tracevv((stderr, "inflate: distance %u\n", state->offset)); + state->mode = MATCH; + case MATCH: + if (left == 0) goto inf_leave; + copy = out - left; + if (state->offset > copy) { /* copy from window */ + copy = state->offset - copy; + if (copy > state->write) { + copy -= state->write; + from = state->window + (state->wsize - copy); + } + else + from = state->window + (state->write - copy); + if (copy > state->length) copy = state->length; + } + else { /* copy from output */ + from = put - state->offset; + copy = state->length; + } + if (copy > left) copy = left; + left -= copy; + state->length -= copy; + do { + *put++ = *from++; + } while (--copy); + if (state->length == 0) state->mode = LEN; + break; + case LIT: + if (left == 0) goto inf_leave; + *put++ = (unsigned char)(state->length); + left--; + state->mode = LEN; + break; + case CHECK: + if (state->wrap) { + NEEDBITS(32); + out -= left; + strm->total_out += out; + state->total += out; + if (out) + strm->adler = state->check = + UPDATE(state->check, put - out, out); + out = left; + if (( +#ifdef GUNZIP + state->flags ? hold : +#endif + REVERSE(hold)) != state->check) { + strm->msg = (char *)"incorrect data check"; + state->mode = BAD; + break; + } + INITBITS(); + Tracev((stderr, "inflate: check matches trailer\n")); + } +#ifdef GUNZIP + state->mode = LENGTH; + case LENGTH: + if (state->wrap && state->flags) { + NEEDBITS(32); + if (hold != (state->total & 0xffffffffUL)) { + strm->msg = (char *)"incorrect length check"; + state->mode = BAD; + break; + } + INITBITS(); + Tracev((stderr, "inflate: length matches trailer\n")); + } +#endif + state->mode = DONE; + case DONE: + ret = Z_STREAM_END; + goto inf_leave; + case BAD: + ret = Z_DATA_ERROR; + goto inf_leave; + case MEM: + return Z_MEM_ERROR; + case SYNC: + default: + return Z_STREAM_ERROR; + } + + /* + Return from inflate(), updating the total counts and the check value. + If there was no progress during the inflate() call, return a buffer + error. Call updatewindow() to create and/or update the window state. + Note: a memory error from inflate() is non-recoverable. + */ + inf_leave: + RESTORE(); + if (state->wsize || (state->mode < CHECK && out != strm->avail_out)) + if (updatewindow(strm, out)) { + state->mode = MEM; + return Z_MEM_ERROR; + } + in -= strm->avail_in; + out -= strm->avail_out; + strm->total_in += in; + strm->total_out += out; + state->total += out; + if (state->wrap && out) + strm->adler = state->check = + UPDATE(state->check, strm->next_out - out, out); + strm->data_type = state->bits + (state->last ? 64 : 0) + + (state->mode == TYPE ? 128 : 0); + if (((in == 0 && out == 0) || flush == Z_FINISH) && ret == Z_OK) + ret = Z_BUF_ERROR; + return ret; }
- -local void inflate_codes_free(c, z) -inflate_codes_statef *c; -z_stream *z; +int ZEXPORT inflateEnd(strm) +z_streamp strm; { - ZFREE(z, c, sizeof(struct inflate_codes_state)); - Tracev((stderr, "inflate: codes free\n")); + struct inflate_state FAR *state; + if (strm == Z_NULL || strm->state == Z_NULL || strm->zfree == (free_func)0) + return Z_STREAM_ERROR; + state = (struct inflate_state FAR *)strm->state; + if (state->window != Z_NULL) ZFREE(strm, state->window); + ZFREE(strm, strm->state); + strm->state = Z_NULL; + Tracev((stderr, "inflate: end\n")); + return Z_OK; }
/*+++++*/ -/* inflate_util.c -- data and routines common to blocks and codes - * Copyright (C) 1995 Mark Adler +/* zutil.c -- target dependent utility functions for the compression library + * Copyright (C) 1995-2005 Jean-loup Gailly. * For conditions of distribution and use, see copyright notice in zlib.h */
-/* copy as much as possible from the sliding window to the output area */ -local int inflate_flush(s, z, r) -inflate_blocks_statef *s; -z_stream *z; -int r; -{ - uInt n; - Bytef *p, *q; - - /* local copies of source and destination pointers */ - p = z->next_out; - q = s->read; - - /* compute number of bytes to copy as far as end of window */ - n = (uInt)((q <= s->write ? s->write : s->end) - q); - if (n > z->avail_out) n = z->avail_out; - if (n && r == Z_BUF_ERROR) r = Z_OK; - - /* update counters */ - z->avail_out -= n; - z->total_out += n; - - /* update check information */ - if (s->checkfn != Z_NULL) - s->check = (*s->checkfn)(s->check, q, n); - - /* output callback */ - if (z->outcb != Z_NULL) - (*z->outcb)(q, n); - - /* copy as far as end of window */ - zmemcpy(p, q, n); - p += n; - q += n; - - /* see if more to copy at beginning of window */ - if (q == s->end) - { - /* wrap pointers */ - q = s->window; - if (s->write == s->end) - s->write = s->window; - - /* compute bytes to copy */ - n = (uInt)(s->write - q); - if (n > z->avail_out) n = z->avail_out; - if (n && r == Z_BUF_ERROR) r = Z_OK; - - /* update counters */ - z->avail_out -= n; - z->total_out += n; - - /* update check information */ - if (s->checkfn != Z_NULL) - s->check = (*s->checkfn)(s->check, q, n); - - /* output callback */ - if (z->outcb != Z_NULL) - (*z->outcb)(q, n); - - /* copy */ - zmemcpy(p, q, n); - p += n; - q += n; - } - - /* update pointers */ - z->next_out = p; - s->read = q; - - /* done */ - return r; -} +/* @(#) $Id$ */
+#ifndef NO_DUMMY_DECL +struct internal_state {int dummy;}; /* for buggy compilers */ +#endif
-/*+++++*/ -/* inffast.c -- process literals and length/distance pairs fast - * Copyright (C) 1995 Mark Adler - * For conditions of distribution and use, see copyright notice in zlib.h - */ +const char * const z_errmsg[10] = { +"need dictionary", /* Z_NEED_DICT 2 */ +"stream end", /* Z_STREAM_END 1 */ +"", /* Z_OK 0 */ +"file error", /* Z_ERRNO (-1) */ +"stream error", /* Z_STREAM_ERROR (-2) */ +"data error", /* Z_DATA_ERROR (-3) */ +"insufficient memory", /* Z_MEM_ERROR (-4) */ +"buffer error", /* Z_BUF_ERROR (-5) */ +"incompatible version",/* Z_VERSION_ERROR (-6) */ +""};
-/* simplify the use of the inflate_huft type with some defines */ -#define base more.Base -#define next more.Next -#define exop word.what.Exop -#define bits word.what.Bits - -/* macros for bit input with no checking and for returning unused bytes */ -#define GRABBITS(j) {while(k<(j)){b|=((uLong)NEXTBYTE)<<k;k+=8;}} -#define UNGRAB {n+=(c=k>>3);p-=c;k&=7;} - -/* Called with number of bytes left to write in window at least 258 - (the maximum string length) and number of input bytes available - at least ten. The ten bytes are six bytes for the longest length/ - distance pair plus four bytes for overloading the bit buffer. */ - -local int inflate_fast(bl, bd, tl, td, s, z) -uInt bl, bd; -inflate_huft *tl, *td; -inflate_blocks_statef *s; -z_stream *z; +#ifdef DEBUG + +#ifndef verbose +#define verbose 0 +#endif +int z_verbose = verbose; + +void z_error (m) + char *m; { - inflate_huft *t; /* temporary pointer */ - uInt e; /* extra bits or operation */ - uLong b; /* bit buffer */ - uInt k; /* bits in bit buffer */ - Bytef *p; /* input data pointer */ - uInt n; /* bytes available there */ - Bytef *q; /* output window write pointer */ - uInt m; /* bytes to end of window or read pointer */ - uInt ml; /* mask for literal/length tree */ - uInt md; /* mask for distance tree */ - uInt c; /* bytes to copy */ - uInt d; /* distance back to copy from */ - Bytef *r; /* copy source pointer */ - - /* load input, output, bit values */ - LOAD - - /* initialize masks */ - ml = inflate_mask[bl]; - md = inflate_mask[bd]; - - /* do until not enough input or output space for fast loop */ - do { /* assume called with m >= 258 && n >= 10 */ - /* get literal/length code */ - GRABBITS(20) /* max bits for literal/length code */ - if ((e = (t = tl + ((uInt)b & ml))->exop) == 0) - { - DUMPBITS(t->bits) - Tracevv((stderr, t->base >= 0x20 && t->base < 0x7f ? - "inflate: * literal '%c'\n" : - "inflate: * literal 0x%02x\n", t->base)); - *q++ = (Byte)t->base; - m--; - continue; - } - do { - DUMPBITS(t->bits) - if (e & 16) - { - /* get extra bits for length */ - e &= 15; - c = t->base + ((uInt)b & inflate_mask[e]); - DUMPBITS(e) - Tracevv((stderr, "inflate: * length %u\n", c)); - - /* decode distance base of block to copy */ - GRABBITS(15); /* max bits for distance code */ - e = (t = td + ((uInt)b & md))->exop; - do { - DUMPBITS(t->bits) - if (e & 16) - { - /* get extra bits to add to distance base */ - e &= 15; - GRABBITS(e) /* get extra bits (up to 13) */ - d = t->base + ((uInt)b & inflate_mask[e]); - DUMPBITS(e) - Tracevv((stderr, "inflate: * distance %u\n", d)); - - /* do the copy */ - m -= c; - if ((uInt)(q - s->window) >= d) /* offset before dest */ - { /* just copy */ - r = q - d; - *q++ = *r++; c--; /* minimum count is three, */ - *q++ = *r++; c--; /* so unroll loop a little */ - } - else /* else offset after destination */ - { - e = d - (q - s->window); /* bytes from offset to end */ - r = s->end - e; /* pointer to offset */ - if (c > e) /* if source crosses, */ - { - c -= e; /* copy to end of window */ - do { - *q++ = *r++; - } while (--e); - r = s->window; /* copy rest from start of window */ - } - } - do { /* copy all or what's left */ - *q++ = *r++; - } while (--c); - break; - } - else if ((e & 64) == 0) - e = (t = t->next + ((uInt)b & inflate_mask[e]))->exop; - else - { - z->msg = "invalid distance code"; - UNGRAB - UPDATE - return Z_DATA_ERROR; - } - } while (1); - break; - } - if ((e & 64) == 0) - { - if ((e = (t = t->next + ((uInt)b & inflate_mask[e]))->exop) == 0) - { - DUMPBITS(t->bits) - Tracevv((stderr, t->base >= 0x20 && t->base < 0x7f ? - "inflate: * literal '%c'\n" : - "inflate: * literal 0x%02x\n", t->base)); - *q++ = (Byte)t->base; - m--; - break; - } - } - else if (e & 32) - { - Tracevv((stderr, "inflate: * end of block\n")); - UNGRAB - UPDATE - return Z_STREAM_END; - } - else - { - z->msg = "invalid literal/length code"; - UNGRAB - UPDATE - return Z_DATA_ERROR; - } - } while (1); - } while (m >= 258 && n >= 10); - - /* not enough input or output--restore pointers and return */ - UNGRAB - UPDATE - return Z_OK; + fprintf(stderr, "%s\n", m); + exit(1); } +#endif
- -/*+++++*/ -/* zutil.c -- target dependent utility functions for the compression library - * Copyright (C) 1995 Jean-loup Gailly. - * For conditions of distribution and use, see copyright notice in zlib.h +/* exported to allow conversion of error code to string for compress() and + * uncompress() */ +#ifndef MY_ZCALLOC /* Any system without a special alloc function */
-/* From: zutil.c,v 1.8 1995/05/03 17:27:12 jloup Exp */ - -char *zlib_version = ZLIB_VERSION; +#ifndef STDC +extern voidp malloc OF((uInt size)); +extern voidp calloc OF((uInt items, uInt size)); +extern void free OF((voidpf ptr)); +#endif
-char *z_errmsg[] = { -"stream end", /* Z_STREAM_END 1 */ -"", /* Z_OK 0 */ -"file error", /* Z_ERRNO (-1) */ -"stream error", /* Z_STREAM_ERROR (-2) */ -"data error", /* Z_DATA_ERROR (-3) */ -"insufficient memory", /* Z_MEM_ERROR (-4) */ -"buffer error", /* Z_BUF_ERROR (-5) */ -""}; +voidpf zcalloc (opaque, items, size) + voidpf opaque; + unsigned items; + unsigned size; +{ + if (opaque) + items += size - size; /* make compiler happy */ + return sizeof(uInt) > 2 ? (voidpf)malloc(items * size) : + (voidpf)calloc(items, size); +}
+void zcfree (opaque, ptr, nb) + voidpf opaque; + voidpf ptr; + unsigned nb; +{ + free(ptr); + if (opaque) + return; /* make compiler happy */ +}
+#endif /* MY_ZCALLOC */ /*+++++*/ /* adler32.c -- compute the Adler-32 checksum of a data stream - * Copyright (C) 1995 Mark Adler + * Copyright (C) 1995-2004 Mark Adler * For conditions of distribution and use, see copyright notice in zlib.h */
-/* From: adler32.c,v 1.6 1995/05/03 17:27:08 jloup Exp */ +/* @(#) $Id$ */
-#define BASE 65521L /* largest prime smaller than 65536 */ +#define BASE 65521UL /* largest prime smaller than 65536 */ #define NMAX 5552 /* NMAX is the largest n such that 255n(n+1)/2 + (n+1)(BASE-1) <= 2^32-1 */
-#define DO1(buf) {s1 += *buf++; s2 += s1;} -#define DO2(buf) DO1(buf); DO1(buf); -#define DO4(buf) DO2(buf); DO2(buf); -#define DO8(buf) DO4(buf); DO4(buf); -#define DO16(buf) DO8(buf); DO8(buf); +#define DO1(buf,i) {adler += (buf)[i]; sum2 += adler;} +#define DO2(buf,i) DO1(buf,i); DO1(buf,i+1); +#define DO4(buf,i) DO2(buf,i); DO2(buf,i+2); +#define DO8(buf,i) DO4(buf,i); DO4(buf,i+4); +#define DO16(buf) DO8(buf,0); DO8(buf,8); + +/* use NO_DIVIDE if your processor does not do division in hardware */ +#ifdef NO_DIVIDE +#define MOD(a) \ + do { \ + if (a >= (BASE << 16)) \ + a -= (BASE << 16); \ + if (a >= (BASE << 15)) \ + a -= (BASE << 15); \ + if (a >= (BASE << 14)) \ + a -= (BASE << 14); \ + if (a >= (BASE << 13)) \ + a -= (BASE << 13); \ + if (a >= (BASE << 12)) \ + a -= (BASE << 12); \ + if (a >= (BASE << 11)) \ + a -= (BASE << 11); \ + if (a >= (BASE << 10)) \ + a -= (BASE << 10); \ + if (a >= (BASE << 9)) \ + a -= (BASE << 9); \ + if (a >= (BASE << 8)) \ + a -= (BASE << 8); \ + if (a >= (BASE << 7)) \ + a -= (BASE << 7); \ + if (a >= (BASE << 6)) \ + a -= (BASE << 6); \ + if (a >= (BASE << 5)) \ + a -= (BASE << 5); \ + if (a >= (BASE << 4)) \ + a -= (BASE << 4); \ + if (a >= (BASE << 3)) \ + a -= (BASE << 3); \ + if (a >= (BASE << 2)) \ + a -= (BASE << 2); \ + if (a >= (BASE << 1)) \ + a -= (BASE << 1); \ + if (a >= BASE) \ + a -= BASE; \ + } while (0) +#define MOD4(a) \ + do { \ + if (a >= (BASE << 4)) \ + a -= (BASE << 4); \ + if (a >= (BASE << 3)) \ + a -= (BASE << 3); \ + if (a >= (BASE << 2)) \ + a -= (BASE << 2); \ + if (a >= (BASE << 1)) \ + a -= (BASE << 1); \ + if (a >= BASE) \ + a -= BASE; \ + } while (0) +#else +#define MOD(a) a %= BASE +#define MOD4(a) a %= BASE +#endif
/* ========================================================================= */ -uLong adler32(adler, buf, len) +uLong ZEXPORT adler32(adler, buf, len) uLong adler; - Bytef *buf; + const Bytef *buf; uInt len; { - unsigned long s1 = adler & 0xffff; - unsigned long s2 = (adler >> 16) & 0xffff; - int k; - - if (buf == Z_NULL) return 1L; - - while (len > 0) { - k = len < NMAX ? len : NMAX; - len -= k; - while (k >= 16) { - DO16(buf); - k -= 16; - } - if (k != 0) do { - DO1(buf); - } while (--k); - s1 %= BASE; - s2 %= BASE; + unsigned long sum2; + unsigned n; + + /* split Adler-32 into component sums */ + sum2 = (adler >> 16) & 0xffff; + adler &= 0xffff; + + /* in case user likes doing a byte at a time, keep it fast */ + if (len == 1) { + adler += buf[0]; + if (adler >= BASE) + adler -= BASE; + sum2 += adler; + if (sum2 >= BASE) + sum2 -= BASE; + return adler | (sum2 << 16); } - return (s2 << 16) | s1; + + /* initial Adler-32 value (deferred check for len == 1 speed) */ + if (buf == Z_NULL) + return 1L; + + /* in case short lengths are provided, keep it somewhat fast */ + if (len < 16) { + while (len--) { + adler += *buf++; + sum2 += adler; + } + if (adler >= BASE) + adler -= BASE; + MOD4(sum2); /* only added so many BASE's */ + return adler | (sum2 << 16); + } + + /* do length NMAX blocks -- requires just one modulo operation */ + while (len >= NMAX) { + len -= NMAX; + n = NMAX / 16; /* NMAX is divisible by 16 */ + do { + DO16(buf); /* 16 sums unrolled */ + buf += 16; + } while (--n); + MOD(adler); + MOD(sum2); + } + + /* do remaining bytes (less than NMAX, still just one modulo) */ + if (len) { /* avoid modulos if none remaining */ + while (len >= 16) { + len -= 16; + DO16(buf); + buf += 16; + } + while (len--) { + adler += *buf++; + sum2 += adler; + } + MOD(adler); + MOD(sum2); + } + + /* return recombined sums */ + return adler | (sum2 << 16); }
Dear Giuseppe CONDORELLI,
In message 1248339285-19580-1-git-send-email-giuseppe.condorelli@st.com you wrote:
This patch updates zlib to the latest stable version. Only relevant zlib parts were ported to u-boot tree, as already did for the current zlib (0.95). New zlib guarantees a faster inflate performances other then others improvements as explained at www.zlib.net
Signed-off-by: Giuseppe Condorelli giuseppe.condorelli@st.com Reviewed-by: Angelo Castello angelo.castello@st.com
include/u-boot/zlib.h | 718 ++++++--- lib_generic/zlib.c | 3931 +++++++++++++++++++++++++------------------------ 2 files changed, 2464 insertions(+), 2185 deletions(-)
Applied, thanks.
[This time it seems to compile without issues.]
Applied, thanks.
yesterday morning I could use the U-Boot git code to successfully decompress a gzip compressed image, using today's git checkout this does not work anymore:
## Booting kernel from Legacy Image at 00200000 ... Image Name: Linux-2.4.37.2-dbox2 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 748627 Bytes = 731.1 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... Error: inflate() returned -2 GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
Maybe the zlib update is responsible?
This is the newest commit from the U-Boot git checkout I used today:
commit 28958b8bea4c66629c5a22fd3c8b0d49df90383d Author: Wolfgang Denk wd@denx.de Date: Thu Jul 23 22:23:23 2009 +0200
Coding Style cleanup; update CHANGELOG. Signed-off-by: Wolfgang Denk wd@denx.de
Cheers, rhabarber1848
Yes, I'm just noticing the same behaviour:
## Booting kernel from Legacy Image at 00200000 ... Image Name: Linux-2.6.30 Created: 2009-06-30 7:45:03 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1350151 Bytes = 1.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00800000 Booting using the fdt blob at 0x800000 Uncompressing Kernel Image ... Error: inflate() returned -2 GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
I checked and verified that commit b201171f2b4d509f3ad510b214bee70ff902e3d6 [zlib: updated to v.1.2.3] is responsible for this.
So we should probably revert this patch for now. Wolfgang, what do you think?
Thanks.
Best regards, Stefan
Dear Stefan Roese,
I reverted the patch.
Giuseppe, please resubmit, but unly after *thorough* testing, please.
Hi All,
unfortunately currently I'm not able to reproduce this issue because boards I'm using are not ported to the best so far u-boot tree. However: - I worked with zlib-1.2.3 patch on my current u-boot version (1.3.1) without problem with sh boards. - This u-boot version is a little bit different about decompression, e.g. here we have gunzip inside cmd_bootm and in the bsf it is in a different file (gunzip.c) - Given this, I backported these into 1.3.1 and tested again, with success. I mean, I tested an old u-boot version with newest decompression code. I think it should be a good test, the one I modified is common code and should be self contained.
I'm wondering if something is going wrong only with PPC arch (errors are related to this arch), and in this case I cannot reproduce the issue at all. Please, is there somebody that can test this patch on a differen arch than PPC?
What's your thinking about?
Best regards and, please, let me know. Giuseppe Condorelli
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Friday, July 24, 2009 2:27 PM To: Stefan Roese Cc: u-boot@lists.denx.de; rhabarber1848@web.de; Giuseppe CONDORELLI Subject: Re: [U-Boot] [PATCH v3] zlib: updated to v.1.2.3
Dear Stefan Roese,
think?
Applied, thanks.
I'm seeing this, too. Reverting commits 28958b8b and b201171f2 makes uncompressing work again.
Kim
participants (5)
Giuseppe CONDORELLI
Kim Phillips
rhabarber1848
Stefan Roese
