[U-Boot] [PATCH v1] imx: remove SATA boot mode for i.MX 6UL and 6ULL
The NXP i.MX 6UL and 6ULL do not support SATA and have no SATA boot mode, hence remove it from the boot device detecion. This fixes a build error introduced with 3bd1642d4d50 ("imx: fix USB boot mode detection for i.MX 6UL and 6ULL")
Fixes: 3bd1642d4d50 ("imx: fix USB boot mode detection for i.MX 6UL and 6ULL") Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
arch/arm/mach-imx/spl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index bcd1033fdb..3853e7739d 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -45,8 +45,10 @@ u32 spl_boot_device(void) case IMX6_BMODE_RESERVED: return BOOT_DEVICE_BOARD; /* SATA: See 8.5.4, Table 8-20 */ +#if !defined(CONFIG_MX6UL) && !defined(CONFIG_MX6ULL) case IMX6_BMODE_SATA: return BOOT_DEVICE_SATA; +#endif /* Serial ROM: See 8.5.5.1, Table 8-22 */ case IMX6_BMODE_SERIAL_ROM: /* BOOT_CFG4[2:0] */
Hi Stefan,
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
On Tue, Aug 29, 2017 at 10:16 PM, Stefano Babic sbabic@denx.de wrote:
Hi Stefan,
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Jagan Teki
Stefan Agner
Stefano Babic
