[U-Boot-Users] [PATCH] Fixed pcnet io_base
Bus and phys address are not always the same
Signed-off-by: Vlad Lungu vlad@comsys.ro --- drivers/pcnet.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/drivers/pcnet.c b/drivers/pcnet.c index 2af0e8f..22edb48 100644 --- a/drivers/pcnet.c +++ b/drivers/pcnet.c @@ -196,6 +196,7 @@ int pcnet_initialize(bd_t *bis) * Setup the PCI device. */ pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, (unsigned int *)&dev->iobase); + dev->iobase=pci_io_to_phys(devbusfn,dev->iobase); dev->iobase &= ~0xf;
PCNET_DEBUG1("%s: devbusfn=0x%x iobase=0x%x: ",
Dear Ben,
this patch is still on my "open" list. Can you please review and apply if it makes sense to you? Thanks.
------- Forwarded Message
Date: Wed, 10 Oct 2007 23:02:09 +0300 From: Vlad Lungu vlad@comsys.ro To: u-boot-users@lists.sourceforge.net, wd@denx.de Subject: [PATCH] Fixed pcnet io_base
diff --git a/drivers/pcnet.c b/drivers/pcnet.c index 2af0e8f..22edb48 100644 --- a/drivers/pcnet.c +++ b/drivers/pcnet.c @@ -196,6 +196,7 @@ int pcnet_initialize(bd_t *bis) * Setup the PCI device. */ pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, (unsigned int *)&de v->iobase); + dev->iobase=pci_io_to_phys(devbusfn,dev->iobase); dev->iobase &= ~0xf;
Hi Wolfgang,
On Sun, Apr 20, 2008 at 2:36 AM, Wolfgang Denk wd@denx.de wrote:
Dear Ben,
This looks OK to me. Assuming that pci_io_to_phys() is defined on all relevant architectures, I have no objections. Unfortunately I can't run MAKEALL right now, so if it's not too much of a bother please pull directly. We can always pull it out if there's a problem, I guess.
regards, Ben
dev->iobase=pci_io_to_phys(devbusfn,dev->iobase); dev->iobase &= ~0xf; PCNET_DEBUG1("%s: devbusfn=0x%x iobase=0x%x: ",
-- 1.5.2.2
------- End of Forwarded Message
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Where a calculator on the ENIAC is equipped with 18,000 vacuum tubes and weighs 30 tons, computers in the future may have only 1,000 vacuum tubes and weigh only 1/2 tons. - Popular Mechanics, March 1949
In message f8328f7c0804200702x40841be6k286dd6e335440692@mail.gmail.com you wrote:
Applied, thanks.
Applied, thanks.
Ben Warren
Vlad Lungu
