[U-Boot] [PATCH] arm: socfpga: Assure ISWGRP 0 and 1 are inited
This fix makes sure that the ISWGRP0 and ISWGRP1 registers are correctly inited. In case those registers are not initialized, it is not possible to access the registers synthesised in the FPGA through the bridges. Any such access produces data abort.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/reset_manager.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index 1186358..b6beaa2 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -7,13 +7,16 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/reset_manager.h> #include <asm/arch/fpga_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h>
DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) @@ -97,6 +100,9 @@ void socfpga_bridges_reset(int enable) /* brdmodrst */ writel(0xffffffff, &reset_manager_base->brg_mod_reset); } else { + writel(0, &sysmgr_regs->iswgrp_handoff[0]); + writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); + /* Check signal from FPGA. */ if (!fpgamgr_test_fpga_ready()) { /* FPGA not ready, do nothing. */
Since this fixes an actual issue, applied.
Best regards, Marek Vasut
