[U-Boot] [PATCH 1/1] spi: tegra20: Add support for mode selection
Respect the mode passed in claim_bus call.
Signed-off-by: Mirza Krak mirza.krak@hostmobility.com --- drivers/spi/tegra20_slink.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index f6fb89b393f0..271e2adbb2e1 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -36,6 +36,11 @@ DECLARE_GLOBAL_DATA_PTR; #define SLINK_CMD_ENB (1 << 31) #define SLINK_CMD_GO (1 << 30) #define SLINK_CMD_M_S (1 << 28) +#define SLINK_CMD_IDLE_SCLK_DRIVE_LOW (0 << 24) +#define SLINK_CMD_IDLE_SCLK_DRIVE_HIGH (1 << 24) +#define SLINK_CMD_IDLE_SCLK_PULL_LOW (2 << 24) +#define SLINK_CMD_IDLE_SCLK_PULL_HIGH (3 << 24) +#define SLINK_CMD_IDLE_SCLK_MASK (3 << 24) #define SLINK_CMD_CK_SDA (1 << 21) #define SLINK_CMD_CS_POL (1 << 13) #define SLINK_CMD_CS_VAL (1 << 12) @@ -146,6 +151,7 @@ static int tegra30_spi_claim_bus(struct udevice *dev) struct udevice *bus = dev->parent; struct tegra30_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs; + unsigned int mode = priv->mode; u32 reg;
/* Change SPI clock to correct frequency, PLLP_OUT0 source */ @@ -161,6 +167,17 @@ static int tegra30_spi_claim_bus(struct udevice *dev) /* Set master mode and sw controlled CS */ reg = readl(®s->command); reg |= SLINK_CMD_M_S | SLINK_CMD_CS_SOFT; + + /* Set CPOL and CPHA */ + reg &= ~SLINK_CMD_IDLE_SCLK_MASK & ~SLINK_CMD_CK_SDA; + if (mode & SPI_CPHA) + reg |= SLINK_CMD_CK_SDA; + + if (mode & SPI_CPOL) + reg |= SLINK_CMD_IDLE_SCLK_DRIVE_HIGH; + else + reg |= SLINK_CMD_IDLE_SCLK_DRIVE_LOW; + writel(reg, ®s->command); debug("%s: COMMAND = %08x\n", __func__, readl(®s->command));
ping
2015-07-20 13:56 GMT+02:00 Mirza Krak mirza.krak@hostmobility.com:
unsigned int mode = priv->mode; u32 reg; /* Change SPI clock to correct frequency, PLLP_OUT0 source */
else
-- 2.1.0
I think we need to or CPOL and CPHA
what about this reg &= ~(SLINK_CMD_IDLE_SCLK_MASK | SLINK_CMD_CK_SDA);
else
-- 2.1.0
thanks!
2015-09-04 13:35 GMT+02:00 Jagan Teki jteki@openedev.com:
The end result should be the same as reg &= ~SLINK_CMD_IDLE_SCLK_MASK & ~SLINK_CMD_CK_SDA;
or am I wrong?
But I can agree that it is easier to read/follow your suggestion.
or am I wrong?
Yes, true.
Please make this change and send.
thanks!
Jagan Teki
Mirza Krak
