[PATCH] arch: arm: dts: k3-am625-sk: Update timings node name for panel-lvds
Update the name of timing parameter node to panel-timing from panel-timngs.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- arch/arm/dts/k3-am625-sk.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts index 73dec8781c..a87b48bfed 100644 --- a/arch/arm/dts/k3-am625-sk.dts +++ b/arch/arm/dts/k3-am625-sk.dts @@ -168,7 +168,7 @@ width-mm = <217>; height-mm = <136>; data-mapping = "vesa-24"; - panel-timings { + panel-timing { bootph-pre-ram; clock-frequency = <150274>; hactive = <1920>;
panel-timings {
First, what tree is this against? Second, you know this needs to go to the linux dts file, first. Thanks.
Hi Tom,
panel-timings {
Yes I understand this should first go to linux dts. Please ignore this patch, once we have dss node in linux dts, I will send the pathces.
Thanks, Nikhil
Nikhil M Jain
