[U-Boot] [PATCH v3 0/22] AHCI / SATA Improvements
This series contains a set of improvements for the SATA susbsystem, mostly targeted at solid-state drivers and improving start-up time.
The patches are tested on various x86 Chromebooks.
Changes in v3: - Remove use of DEFINE_PCI_DEVICE_TABLE suggested by siren checkpatch - Use struct pci_device_id properly - Add new patch to enable setenv_ulong/addr() for powerpc - Fix setenv operation to use correct function - Move missing #ifdef CONFIG_AHCI_SETFEATURES_XFER from later commit - Remove . from end of commit subject - Move #ifdef change into earlier commit - Add patch to support 64-bit LBA option when reading capacity - Add new patch to correct ide_read/write() function signatures
Changes in v2: - Use struct pci_device_id instead of defining new struct scsi_device - Squash in CONFIG_PCI patch - Set 'scsidevs' environment variable to number of SCSI disks
Gabe Black (3): ahci: Make sending the SETFEATURES_XFER command optional ahci: Make the AHCI code find the capacity of disks > 128 GB properly ahci: Support 64-bit LBA option when reading capacity
Hung-Te Lin (2): scsi: Add scsi_write to SCSI driver ahci: support scsi writing in AHCI driver
Marc Jones (2): ahci: Support spin-up and link-up separately ahci: Perform SATA flush after disk write.
Simon Glass (3): Support setenv_ulong() and setenv_addr() for powerpc ide: Correct function signatures for ide_read/write() x86: config: Enable AHCI support for coreboot
Stefan Reinauer (4): scsi: Add function and env var to report number of scsi drives ahci: Optimise AHCI controller reset and start-up ahci: Improve AHCI debugging ahci: cosmetics and cleanup
Taylor Hutt (4): ahci: Use sizeof(fis) instead of hardcoding '20' ahci: Fix 'Invaild' typo ahci: Use virt_to_phys() to denote physical addresses for DMA ahci: flush / invalidate dcache around SATA commands
Vadim Bendebury (2): ahci: Support splitting of read transactions into multiple chunks scsi: Provide support for a list of AHCI controllers.
Walter Murphy (2): ahci: Adjust SATA timeouts for hard disk (spinup delay & command timeout) ahci: Expand HDD Logical Block addressability up to 32 bits
README | 3 + common/cmd_ide.c | 27 +-- common/cmd_scsi.c | 255 ++++++++++++++++++++++++---- drivers/block/ahci.c | 401 +++++++++++++++++++++++++++++++++++--------- include/ahci.h | 1 + include/ata.h | 3 + include/common.h | 2 +- include/configs/coreboot.h | 22 +++ include/scsi.h | 4 + 9 files changed, 585 insertions(+), 133 deletions(-)
With an Intel AHCI controller, the driver does not operate properly if the requested amount of blocks to read exceeds 255.
It is probably possible to specify 0 as the block count and the driver will read 256 blocks, but it was decided to limit the number of blocks read at once to 128 (it should be a power of 2 for the optimal performance of solid state drives).
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/block/ahci.c | 98 +++++++++++++++++++++++++++++++++++--------------- 1 files changed, 69 insertions(+), 29 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 7b2ec50..d94da1f 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -42,6 +42,14 @@ hd_driveid_t *ataid[AHCI_MAX_PORTS];
#define writel_with_flush(a,b) do { writel(a,b); readl(b); } while (0)
+/* + * Some controllers limit number of blocks they can read at once. Contemporary + * SSD devices work much faster if the read size is aligned to a power of 2. + * Let's set default to 128 and allowing to be overwritten if needed. + */ +#ifndef MAX_SATA_BLOCKS_READ +#define MAX_SATA_BLOCKS_READ 0x80 +#endif
static inline u32 ahci_port_base(u32 base, u32 port) { @@ -88,6 +96,8 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) int i, j; volatile u8 *port_mmio;
+ debug("ahci_host_init: start\n"); + cap_save = readl(mmio + HOST_CAP); cap_save &= ((1 << 28) | (1 << 17)); cap_save |= (1 << 27); @@ -129,6 +139,9 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) debug("cap 0x%x port_map 0x%x n_ports %d\n", probe_ent->cap, probe_ent->port_map, probe_ent->n_ports);
+ if (probe_ent->n_ports > CONFIG_SYS_SCSI_MAX_SCSI_ID) + probe_ent->n_ports = CONFIG_SYS_SCSI_MAX_SCSI_ID; + for (i = 0; i < probe_ent->n_ports; i++) { probe_ent->port[i].port_mmio = ahci_port_base((u32) mmio, i); port_mmio = (u8 *) probe_ent->port[i].port_mmio; @@ -277,8 +290,8 @@ static int ahci_init_one(pci_dev_t pdev) probe_ent->pio_mask = 0x1f; probe_ent->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
- probe_ent->mmio_base = (u32)pci_map_bar(pdev, AHCI_PCI_BAR, - PCI_REGION_MEM); + pci_read_config_dword(pdev, PCI_BASE_ADDRESS_5, &probe_ent->mmio_base); + debug("ahci mmio_base=0x%08x\n", probe_ent->mmio_base);
/* Take from kernel: * JMicron-specific fixup: @@ -398,7 +411,7 @@ static int ahci_port_start(u8 port) * 32 bytes each in size */ pp->cmd_slot = (struct ahci_cmd_hdr *)mem; - debug("cmd_slot = %p\n", pp->cmd_slot); + debug("cmd_slot = 0x%x\n", (unsigned)pp->cmd_slot); mem += (AHCI_CMD_SLOT_SZ + 224);
/* @@ -561,42 +574,69 @@ static int ata_scsiop_inquiry(ccb *pccb) */ static int ata_scsiop_read10(ccb * pccb) { - u32 len = 0; + u32 lba = 0; + u16 blocks = 0; u8 fis[20]; + u8 *user_buffer = pccb->pdata; + u32 user_buffer_size = pccb->datalen;
- len = (((u32) pccb->cmd[7]) << 8) | ((u32) pccb->cmd[8]); + /* Retrieve the base LBA number from the ccb structure. */ + memcpy(&lba, pccb->cmd + 2, sizeof(lba)); + lba = be32_to_cpu(lba);
- /* For 10-byte and 16-byte SCSI R/W commands, transfer + /* + * And the number of blocks. + * + * For 10-byte and 16-byte SCSI R/W commands, transfer * length 0 means transfer 0 block of data. * However, for ATA R/W commands, sector count 0 means * 256 or 65536 sectors, not 0 sectors as in SCSI. * * WARNING: one or two older ATA drives treat 0 as 0... */ - if (!len) - return 0; + blocks = (((u16)pccb->cmd[7]) << 8) | ((u16) pccb->cmd[8]); + + debug("scsi_ahci: read %d blocks starting from lba 0x%x\n", + (unsigned)lba, blocks); + + /* Preset the FIS */ memset(fis, 0, 20); + fis[0] = 0x27; /* Host to device FIS. */ + fis[1] = 1 << 7; /* Command FIS. */ + fis[2] = ATA_CMD_RD_DMA; /* Command byte. */
- /* Construct the FIS */ - fis[0] = 0x27; /* Host to device FIS. */ - fis[1] = 1 << 7; /* Command FIS. */ - fis[2] = ATA_CMD_RD_DMA; /* Command byte. */ - - /* LBA address, only support LBA28 in this driver */ - fis[4] = pccb->cmd[5]; - fis[5] = pccb->cmd[4]; - fis[6] = pccb->cmd[3]; - fis[7] = (pccb->cmd[2] & 0x0f) | 0xe0; - - /* Sector Count */ - fis[12] = pccb->cmd[8]; - fis[13] = pccb->cmd[7]; - - /* Read from ahci */ - if (get_ahci_device_data(pccb->target, (u8 *) & fis, 20, - pccb->pdata, pccb->datalen)) { - debug("scsi_ahci: SCSI READ10 command failure.\n"); - return -EIO; + while (blocks) { + u16 now_blocks; /* number of blocks per iteration */ + u32 transfer_size; /* number of bytes per iteration */ + + now_blocks = min(MAX_SATA_BLOCKS_READ, blocks); + + transfer_size = ATA_BLOCKSIZE * now_blocks; + if (transfer_size > user_buffer_size) { + printf("scsi_ahci: Error: buffer too small.\n"); + return -EIO; + } + + /* LBA address, only support LBA28 in this driver */ + fis[4] = (lba >> 0) & 0xff; + fis[5] = (lba >> 8) & 0xff; + fis[6] = (lba >> 16) & 0xff; + fis[7] = ((lba >> 24) & 0xf) | 0xe0; + + /* Block (sector) count */ + fis[12] = (now_blocks >> 0) & 0xff; + fis[13] = (now_blocks >> 8) & 0xff; + + /* Read from ahci */ + if (get_ahci_device_data(pccb->target, (u8 *) &fis, sizeof(fis), + user_buffer, user_buffer_size)) { + debug("scsi_ahci: SCSI READ10 command failure.\n"); + return -EIO; + } + user_buffer += transfer_size; + user_buffer_size -= transfer_size; + blocks -= now_blocks; + lba += now_blocks; }
return 0; @@ -617,7 +657,7 @@ static int ata_scsiop_read_capacity10(ccb *pccb) return -EPERM; }
- cap = le32_to_cpu(ataid[pccb->target]->lba_capacity); + cap = be32_to_cpu(ataid[pccb->target]->lba_capacity); memcpy(pccb->pdata, &cap, sizeof(cap));
pccb->pdata[4] = pccb->pdata[5] = 0;
Many AHCI controllers are identical, the main (and often the only) difference being the PCI Vendor ID/Device ID combination reported by the device.
This change allows the config file to define a list of PCI vendor ID/device ID pairs. The driver would scan the list and initialize the first device it finds.
No actual multiple device list is introduced yet, this change just add the framework.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Taylor Hutt thutt@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Remove use of DEFINE_PCI_DEVICE_TABLE suggested by siren checkpatch - Use struct pci_device_id properly
common/cmd_scsi.c | 40 +++++++++++++++++++++++++++++++++++----- 1 files changed, 35 insertions(+), 5 deletions(-)
diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 22d0119..50eb239 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -34,6 +34,9 @@ #include <image.h> #include <pci.h>
+#ifdef CONFIG_SCSI_DEV_LIST +#define SCSI_DEV_LIST CONFIG_SCSI_DEV_LIST +#else #ifdef CONFIG_SCSI_SYM53C8XX #define SCSI_VEND_ID 0x1000 #ifndef CONFIG_SCSI_DEV_ID @@ -49,8 +52,12 @@ #elif !defined(CONFIG_SCSI_AHCI_PLAT) #error no scsi device defined #endif +#define SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} +#endif
- +#ifdef CONFIG_PCI +const struct pci_device_id scsi_device_list[] = { SCSI_DEV_LIST }; +#endif static ccb tempccb; /* temporary scsi command buffer */
static unsigned char tempbuff[512]; /* temporary data buffer */ @@ -178,15 +185,38 @@ removable: void scsi_init(void) { int busdevfunc; + int i; + /* + * Find a device from the list, this driver will support a single + * controller. + */ + for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { + /* get PCI Device ID */ + busdevfunc = pci_find_device(scsi_device_list[i].vendor, + scsi_device_list[i].device, + 0); + if (busdevfunc != -1) + break; + }
- busdevfunc=pci_find_device(SCSI_VEND_ID,SCSI_DEV_ID,0); /* get PCI Device ID */ - if(busdevfunc==-1) { - printf("Error SCSI Controller (%04X,%04X) not found\n",SCSI_VEND_ID,SCSI_DEV_ID); + if (busdevfunc == -1) { + printf("Error: SCSI Controller(s) "); + for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { + printf("%04X:%04X ", + scsi_device_list[i].vendor, + scsi_device_list[i].device); + } + printf("not found\n"); return; } #ifdef DEBUG else { - printf("SCSI Controller (%04X,%04X) found (%d:%d:%d)\n",SCSI_VEND_ID,SCSI_DEV_ID,(busdevfunc>>16)&0xFF,(busdevfunc>>11)&0x1F,(busdevfunc>>8)&0x7); + printf("SCSI Controller (%04X,%04X) found (%d:%d:%d)\n", + scsi_device_list[i].vendor, + scsi_device_list[i].device, + (busdevfunc >> 16) & 0xFF, + (busdevfunc >> 11) & 0x1F, + (busdevfunc >> 8) & 0x7); } #endif scsi_low_level_init(busdevfunc);
Implement write functionality in the scsi layer. A ''scsi write' command is also added to console for testing.
Signed-off-by: Hung-Te Lin hungte@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
common/cmd_scsi.c | 115 +++++++++++++++++++++++++++++++++++++++++++++++++--- 1 files changed, 108 insertions(+), 7 deletions(-)
diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 50eb239..31ea788 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -75,11 +75,15 @@ void scsi_setup_test_unit_ready(ccb * pccb); void scsi_setup_read_capacity(ccb * pccb); void scsi_setup_read6(ccb * pccb, unsigned long start, unsigned short blocks); void scsi_setup_read_ext(ccb * pccb, unsigned long start, unsigned short blocks); +static void scsi_setup_write_ext(ccb *pccb, unsigned long start, + unsigned short blocks); void scsi_setup_inquiry(ccb * pccb); void scsi_ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len);
-ulong scsi_read(int device, ulong blknr, ulong blkcnt, void *buffer); +static ulong scsi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer); +static ulong scsi_write(int device, ulong blknr, + lbaint_t blkcnt, const void *buffer);
/********************************************************************************* @@ -109,6 +113,7 @@ void scsi_scan(int mode) scsi_dev_desc[i].dev=i; scsi_dev_desc[i].part_type=PART_TYPE_UNKNOWN; scsi_dev_desc[i].block_read=scsi_read; + scsi_dev_desc[i].block_write = scsi_write; } scsi_max_devs=0; for(i=0;i<CONFIG_SYS_SCSI_MAX_SCSI_ID;i++) { @@ -335,6 +340,19 @@ int do_scsi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) n = scsi_read(scsi_curr_dev, blk, cnt, (ulong *)addr); printf ("%ld blocks read: %s\n",n,(n==cnt) ? "OK" : "ERROR"); return 0; + } else if (strcmp(argv[1], "write") == 0) { + ulong addr = simple_strtoul(argv[2], NULL, 16); + ulong blk = simple_strtoul(argv[3], NULL, 16); + ulong cnt = simple_strtoul(argv[4], NULL, 16); + ulong n; + printf("\nSCSI write: device %d block # %ld, " + "count %ld ... ", + scsi_curr_dev, blk, cnt); + n = scsi_write(scsi_curr_dev, blk, cnt, + (ulong *)addr); + printf("%ld blocks written: %s\n", n, + (n == cnt) ? "OK" : "ERROR"); + return 0; } } /* switch */ return CMD_RET_USAGE; @@ -346,9 +364,10 @@ int do_scsi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#define SCSI_MAX_READ_BLK 0xFFFF /* almost the maximum amount of the scsi_ext command.. */
-ulong scsi_read(int device, ulong blknr, ulong blkcnt, void *buffer) +static ulong scsi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) { - ulong start,blks, buf_addr; + lbaint_t start, blks; + uintptr_t buf_addr; unsigned short smallblks; ccb* pccb=(ccb *)&tempccb; device&=0xff; @@ -359,7 +378,9 @@ ulong scsi_read(int device, ulong blknr, ulong blkcnt, void *buffer) buf_addr=(unsigned long)buffer; start=blknr; blks=blkcnt; - debug ("\nscsi_read: dev %d startblk %lx, blccnt %lx buffer %lx\n",device,start,blks,(unsigned long)buffer); + debug("\nscsi_read: dev %d startblk " LBAF + ", blccnt " LBAF " buffer %lx\n", + device, start, blks, (unsigned long)buffer); do { pccb->pdata=(unsigned char *)buf_addr; if(blks>SCSI_MAX_READ_BLK) { @@ -376,7 +397,9 @@ ulong scsi_read(int device, ulong blknr, ulong blkcnt, void *buffer) start+=blks; blks=0; } - debug ("scsi_read_ext: startblk %lx, blccnt %x buffer %lx\n",start,smallblks,buf_addr); + debug("scsi_read_ext: startblk " LBAF + ", blccnt %x buffer %lx\n", + start, smallblks, buf_addr); if(scsi_exec(pccb)!=TRUE) { scsi_print_error(pccb); blkcnt-=blks; @@ -384,10 +407,65 @@ ulong scsi_read(int device, ulong blknr, ulong blkcnt, void *buffer) } buf_addr+=pccb->datalen; } while(blks!=0); - debug ("scsi_read_ext: end startblk %lx, blccnt %x buffer %lx\n",start,smallblks,buf_addr); + debug("scsi_read_ext: end startblk " LBAF + ", blccnt %x buffer %lx\n", start, smallblks, buf_addr); return(blkcnt); }
+/******************************************************************************* + * scsi_write + */ + +/* Almost the maximum amount of the scsi_ext command.. */ +#define SCSI_MAX_WRITE_BLK 0xFFFF + +static ulong scsi_write(int device, ulong blknr, + lbaint_t blkcnt, const void *buffer) +{ + lbaint_t start, blks; + uintptr_t buf_addr; + unsigned short smallblks; + ccb* pccb = (ccb *)&tempccb; + device &= 0xff; + /* Setup device + */ + pccb->target = scsi_dev_desc[device].target; + pccb->lun = scsi_dev_desc[device].lun; + buf_addr = (unsigned long)buffer; + start = blknr; + blks = blkcnt; + debug("\n%s: dev %d startblk " LBAF ", blccnt " LBAF " buffer %lx\n", + __func__, device, start, blks, (unsigned long)buffer); + do { + pccb->pdata = (unsigned char *)buf_addr; + if (blks > SCSI_MAX_WRITE_BLK) { + pccb->datalen = (scsi_dev_desc[device].blksz * + SCSI_MAX_WRITE_BLK); + smallblks = SCSI_MAX_WRITE_BLK; + scsi_setup_write_ext(pccb, start, smallblks); + start += SCSI_MAX_WRITE_BLK; + blks -= SCSI_MAX_WRITE_BLK; + } else { + pccb->datalen = scsi_dev_desc[device].blksz * blks; + smallblks = (unsigned short)blks; + scsi_setup_write_ext(pccb, start, smallblks); + start += blks; + blks = 0; + } + debug("%s: startblk " LBAF ", blccnt %x buffer %lx\n", + __func__, start, smallblks, buf_addr); + if (scsi_exec(pccb) != TRUE) { + scsi_print_error(pccb); + blkcnt -= blks; + break; + } + buf_addr += pccb->datalen; + } while (blks != 0); + debug("%s: end startblk " LBAF ", blccnt %x buffer %lx\n", + __func__, start, smallblks, buf_addr); + return blkcnt; +} + /* copy src to dest, skipping leading and trailing blanks * and null terminate the string */ @@ -481,6 +559,27 @@ void scsi_setup_read_ext(ccb * pccb, unsigned long start, unsigned short blocks) pccb->cmd[7],pccb->cmd[8]); }
+void scsi_setup_write_ext(ccb *pccb, unsigned long start, unsigned short blocks) +{ + pccb->cmd[0] = SCSI_WRITE10; + pccb->cmd[1] = pccb->lun << 5; + pccb->cmd[2] = ((unsigned char) (start>>24)) & 0xff; + pccb->cmd[3] = ((unsigned char) (start>>16)) & 0xff; + pccb->cmd[4] = ((unsigned char) (start>>8)) & 0xff; + pccb->cmd[5] = ((unsigned char) (start)) & 0xff; + pccb->cmd[6] = 0; + pccb->cmd[7] = ((unsigned char) (blocks>>8)) & 0xff; + pccb->cmd[8] = (unsigned char)blocks & 0xff; + pccb->cmd[9] = 0; + pccb->cmdlen = 10; + pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */ + debug("%s: cmd: %02X %02X startblk %02X%02X%02X%02X blccnt %02X%02X\n", + __func__, + pccb->cmd[0], pccb->cmd[1], + pccb->cmd[2], pccb->cmd[3], pccb->cmd[4], pccb->cmd[5], + pccb->cmd[7], pccb->cmd[8]); +} + void scsi_setup_read6(ccb * pccb, unsigned long start, unsigned short blocks) { pccb->cmd[0]=SCSI_READ6; @@ -522,7 +621,9 @@ U_BOOT_CMD( "scsi device [dev] - show or set current device\n" "scsi part [dev] - print partition table of one or all SCSI devices\n" "scsi read addr blk# cnt - read `cnt' blocks starting at block `blk#'\n" - " to memory address `addr'" + " to memory address `addr'\n" + "scsi write addr blk# cnt - write `cnt' blocks starting at block\n" + " `blk#' from memory address `addr'" );
U_BOOT_CMD(
This includes were outside an #ifdef CONFIG_PPC, but there is not reason to exclude powerpc from using them.
Move the declaration outside the #ifdef.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add new patch to enable setenv_ulong/addr() for powerpc
include/common.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/common.h b/include/common.h index b23e90b..12b3e03 100644 --- a/include/common.h +++ b/include/common.h @@ -345,9 +345,9 @@ int saveenv (void); int inline setenv (const char *, const char *); #else int setenv (const char *, const char *); +#endif /* CONFIG_PPC */ int setenv_ulong(const char *varname, ulong value); int setenv_addr(const char *varname, const void *addr); -#endif /* CONFIG_PPC */ #ifdef CONFIG_ARM # include <asm/mach-types.h> # include <asm/setup.h>
Add a new function to find out the number of available SCSI disks. Also set the 'scsidevs' environment variable after each scan.
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Fix setenv operation to use correct function
Changes in v2: - Set 'scsidevs' environment variable to number of SCSI disks
README | 3 +++ common/cmd_scsi.c | 8 ++++++++ include/scsi.h | 2 ++ 3 files changed, 13 insertions(+), 0 deletions(-)
diff --git a/README b/README index 69da2b8..801772c 100644 --- a/README +++ b/README @@ -1039,6 +1039,9 @@ The following options need to be configured: devices. CONFIG_SYS_SCSI_SYM53C8XX_CCF to fix clock timing (80Mhz)
+ The environment variable 'scsidevs' is set to the number of + SCSI devices found during the last scan. + - NETWORK Support (PCI): CONFIG_E1000 Support for Intel 8254x/8257x gigabit chips. diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 31ea788..9bd8ec9 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -184,6 +184,14 @@ removable: scsi_curr_dev=0; else scsi_curr_dev = -1; + + printf("Found %d device(s).\n", scsi_max_devs); + setenv_ulong("scsidevs", scsi_max_devs); +} + +int scsi_get_disk_count(void) +{ + return scsi_max_devs; }
#ifdef CONFIG_PCI diff --git a/include/scsi.h b/include/scsi.h index 89ae45f..9681d19 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -189,6 +189,8 @@ void scsi_low_level_init(int busdevfunc); void scsi_init(void); void scsi_scan(int mode);
+/** @return the number of scsi disks */ +int scsi_get_disk_count(void);
#define SCSI_IDENTIFY 0xC0 /* not used */
The existing code waits a whole second for the AHCI controller to reset. Instead, let's poll the status register to see if the reset has succeeded and return earlier if possible. This brings down the time for AHCI probing from 1s to 20ms.
drivers/block/ahci.c | 24 +++++++++++++++--------- 1 files changed, 15 insertions(+), 9 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index d94da1f..ad397dc 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -110,13 +110,15 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) /* reset must complete within 1 second, or * the hardware should be considered fried. */ - ssleep(1); - - tmp = readl(mmio + HOST_CTL); - if (tmp & HOST_RESET) { - debug("controller reset failed (0x%x)\n", tmp); - return -1; - } + i = 1000; + do { + udelay(1000); + tmp = readl(mmio + HOST_CTL); + if (!i--) { + debug("controller reset failed (0x%x)\n", tmp); + return -1; + } + } while (tmp & HOST_RESET);
writel_with_flush(HOST_AHCI_EN, mmio + HOST_CTL); writel(cap_save, mmio + HOST_CAP); @@ -164,13 +166,17 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(PORT_CMD_SPIN_UP, port_mmio + PORT_CMD);
j = 0; - while (j < 100) { - msleep(10); + while (j < 1000) { tmp = readl(port_mmio + PORT_SCR_STAT); if ((tmp & 0xf) == 0x3) break; + udelay(1000); j++; } + if (j == 1000) + debug("timeout.\n"); + else + debug("ok.\n");
tmp = readl(port_mmio + PORT_SCR_ERR); debug("PORT_SCR_ERR 0x%x\n", tmp);
- remove unused ssleep macro - add some useful debugging information
drivers/block/ahci.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index ad397dc..af31c97 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -68,7 +68,6 @@ static void ahci_setup_port(struct ahci_ioports *port, unsigned long base,
#define msleep(a) udelay(a * 1000) -#define ssleep(a) msleep(a * 1000)
static int waiting_for_cmd_completed(volatile u8 *offset, int timeout_msec, @@ -153,6 +152,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) tmp = readl(port_mmio + PORT_CMD); if (tmp & (PORT_CMD_LIST_ON | PORT_CMD_FIS_ON | PORT_CMD_FIS_RX | PORT_CMD_START)) { + debug("Port %d is active. Deactivating.\n", i); tmp &= ~(PORT_CMD_LIST_ON | PORT_CMD_FIS_ON | PORT_CMD_FIS_RX | PORT_CMD_START); writel_with_flush(tmp, port_mmio + PORT_CMD); @@ -163,6 +163,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) msleep(500); }
+ debug("Spinning up port %d... ", i); writel(PORT_CMD_SPIN_UP, port_mmio + PORT_CMD);
j = 0;
- print the correct speed - print all the AHCI capability flags (information taken from Linux kernel driver) - clean up some comments
For example, this might show the following string: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
Commit-Ready: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org Tested-by: Stefan Reinauer reinauer@chromium.org ---
drivers/block/ahci.c | 25 ++++++++++++++++++------- include/ahci.h | 1 + 2 files changed, 19 insertions(+), 7 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index af31c97..0a7ad81 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -194,7 +194,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) /* set irq mask (enables interrupts) */ writel(DEF_PORT_IRQ, port_mmio + PORT_IRQ_MASK);
- /*register linkup ports */ + /* register linkup ports */ tmp = readl(port_mmio + PORT_SCR_STAT); debug("Port %d status: 0x%x\n", i, tmp); if ((tmp & 0xf) == 0x03) @@ -222,12 +222,13 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) u16 cc; #endif volatile u8 *mmio = (volatile u8 *)probe_ent->mmio_base; - u32 vers, cap, impl, speed; + u32 vers, cap, cap2, impl, speed; const char *speed_s; const char *scc_s;
vers = readl(mmio + HOST_VERSION); cap = probe_ent->cap; + cap2 = readl(mmio + HOST_CAP2); impl = probe_ent->port_map;
speed = (cap >> 20) & 0xf; @@ -235,6 +236,8 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) speed_s = "1.5"; else if (speed == 2) speed_s = "3"; + else if (speed == 3) + speed_s = "6"; else speed_s = "?";
@@ -260,8 +263,9 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) ((cap >> 8) & 0x1f) + 1, (cap & 0x1f) + 1, speed_s, impl, scc_s);
printf("flags: " - "%s%s%s%s%s%s" - "%s%s%s%s%s%s%s\n", + "%s%s%s%s%s%s%s" + "%s%s%s%s%s%s%s" + "%s%s%s%s%s%s\n", cap & (1 << 31) ? "64bit " : "", cap & (1 << 30) ? "ncq " : "", cap & (1 << 28) ? "ilck " : "", @@ -272,9 +276,16 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) cap & (1 << 19) ? "nz " : "", cap & (1 << 18) ? "only " : "", cap & (1 << 17) ? "pmp " : "", + cap & (1 << 16) ? "fbss " : "", cap & (1 << 15) ? "pio " : "", cap & (1 << 14) ? "slum " : "", - cap & (1 << 13) ? "part " : ""); + cap & (1 << 13) ? "part " : "", + cap & (1 << 7) ? "ccc " : "", + cap & (1 << 6) ? "ems " : "", + cap & (1 << 5) ? "sxs " : "", + cap2 & (1 << 2) ? "apst " : "", + cap2 & (1 << 1) ? "nvmp " : "", + cap2 & (1 << 0) ? "boh " : ""); }
#ifndef CONFIG_SCSI_AHCI_PLAT @@ -369,7 +380,7 @@ static void ahci_set_feature(u8 port) u32 cmd_fis_len = 5; /* five dwords */ u8 fis[20];
- /*set feature */ + /* set feature */ memset(fis, 0, 20); fis[0] = 0x27; fis[1] = 1 << 7; @@ -383,7 +394,7 @@ static void ahci_set_feature(u8 port) readl(port_mmio + PORT_CMD_ISSUE);
if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, 150, 0x1)) { - printf("set feature error!\n"); + printf("set feature error on port %d!\n", port); } }
diff --git a/include/ahci.h b/include/ahci.h index c4fb9e7..babbdc6 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -51,6 +51,7 @@ #define HOST_IRQ_STAT 0x08 /* interrupt status */ #define HOST_PORTS_IMPL 0x0c /* bitmap of implemented ports */ #define HOST_VERSION 0x10 /* AHCI spec. version compliancy */ +#define HOST_CAP2 0x24 /* host capabilities, extended */
/* HOST_CTL bits */ #define HOST_RESET (1 << 0) /* reset controller; self-clear */
This command doesn't really do anything when talking to a SATA device, and sending it confuses some of them. This change makes sending the command optional, and defaults to not. The situations where it should be sent are not the common case.
With the standard SSD in the machine, here are some times with the option turned off: 1. 8277 2. 8273 3. 8050
And turned on: 1. 8303 2. 8155 3. 8276
Sending that command seems to have no meaningful effect on performance.
This fixes problems with an SSD marked Toshiba NV6424, Taiwan 11159AE P and TC58NVG5D2FTA10.
Signed-off-by: Gabe Black gabeblack@chromium.org Signed-off-by: Taylor Hutt thutt@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Move missing #ifdef CONFIG_AHCI_SETFEATURES_XFER from later commit
drivers/block/ahci.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 0a7ad81..2236321 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -373,6 +373,7 @@ static void ahci_fill_cmd_slot(struct ahci_ioports *pp, u32 opts) }
+#ifdef CONFIG_AHCI_SETFEATURES_XFER static void ahci_set_feature(u8 port) { struct ahci_ioports *pp = &(probe_ent->port[port]); @@ -397,6 +398,7 @@ static void ahci_set_feature(u8 port) printf("set feature error on port %d!\n", port); } } +#endif
static int ahci_port_start(u8 port) @@ -743,7 +745,9 @@ void scsi_low_level_init(int busdevfunc) printf("Can not start port %d\n", i); continue; } +#ifdef CONFIG_AHCI_SETFEATURES_XFER ahci_set_feature((u8) i); +#endif } } } @@ -784,7 +788,9 @@ int ahci_init(u32 base) printf("Can not start port %d\n", i); continue; } +#ifdef CONFIG_AHCI_SETFEATURES_XFER ahci_set_feature((u8) i); +#endif } } err_out:
The "scsi write" command requires support from underlying driver. This CL enables SCSI_WRITE10 in AHCI driver.
Tested in U-Boot console, try to i/o with sector #64: scsi read 1000 40 1 md.b 1000 200 # check if things are not 0xcc mw.b 1000 cc 200 # try to fill with 0xcc scsi write 1000 40 1 mw.b 1000 0 200 # fill with zero md.b 1000 200 # should be all 0 scsi read 1000 40 1 md.b 1000 200 # should be all 0xcc
Signed-off-by: Hung-Te Lin hungte@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Remove . from end of commit subject
drivers/block/ahci.c | 54 +++++++++++++++++++++++++++---------------------- 1 files changed, 30 insertions(+), 24 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 2236321..5092352 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -43,12 +43,13 @@ hd_driveid_t *ataid[AHCI_MAX_PORTS]; #define writel_with_flush(a,b) do { writel(a,b); readl(b); } while (0)
/* - * Some controllers limit number of blocks they can read at once. Contemporary - * SSD devices work much faster if the read size is aligned to a power of 2. - * Let's set default to 128 and allowing to be overwritten if needed. + * Some controllers limit number of blocks they can read/write at once. + * Contemporary SSD devices work much faster if the read/write size is aligned + * to a power of 2. Let's set default to 128 and allowing to be overwritten if + * needed. */ -#ifndef MAX_SATA_BLOCKS_READ -#define MAX_SATA_BLOCKS_READ 0x80 +#ifndef MAX_SATA_BLOCKS_READ_WRITE +#define MAX_SATA_BLOCKS_READ_WRITE 0x80 #endif
static inline u32 ahci_port_base(u32 base, u32 port) @@ -464,8 +465,8 @@ static int ahci_port_start(u8 port) }
-static int get_ahci_device_data(u8 port, u8 *fis, int fis_len, u8 *buf, - int buf_len) +static int ahci_device_data_io(u8 port, u8 *fis, int fis_len, u8 *buf, + int buf_len, u8 is_write) {
struct ahci_ioports *pp = &(probe_ent->port[port]); @@ -474,7 +475,7 @@ static int get_ahci_device_data(u8 port, u8 *fis, int fis_len, u8 *buf, u32 port_status; int sg_count;
- debug("Enter get_ahci_device_data: for port %d\n", port); + debug("Enter %s: for port %d\n", __func__, port);
if (port > probe_ent->n_ports) { printf("Invaild port number %d\n", port); @@ -490,7 +491,7 @@ static int get_ahci_device_data(u8 port, u8 *fis, int fis_len, u8 *buf, memcpy((unsigned char *)pp->cmd_tbl, fis, fis_len);
sg_count = ahci_fill_sg(port, buf, buf_len); - opts = (fis_len >> 2) | (sg_count << 16); + opts = (fis_len >> 2) | (sg_count << 16) | (is_write << 6); ahci_fill_cmd_slot(pp, opts);
writel_with_flush(1, port_mmio + PORT_CMD_ISSUE); @@ -499,8 +500,7 @@ static int get_ahci_device_data(u8 port, u8 *fis, int fis_len, u8 *buf, printf("timeout exit!\n"); return -1; } - debug("get_ahci_device_data: %d byte transferred.\n", - pp->cmd_slot->status); + debug("%s: %d byte transferred.\n", __func__, pp->cmd_slot->status);
return 0; } @@ -570,8 +570,8 @@ static int ata_scsiop_inquiry(ccb *pccb) if (!(tmpid = malloc(sizeof(hd_driveid_t)))) return -ENOMEM;
- if (get_ahci_device_data(port, (u8 *) & fis, 20, - tmpid, sizeof(hd_driveid_t))) { + if (ahci_device_data_io(port, (u8 *) &fis, 20, tmpid, + sizeof(hd_driveid_t), 0)) { debug("scsi_ahci: SCSI inquiry command failure.\n"); return -EIO; } @@ -590,9 +590,9 @@ static int ata_scsiop_inquiry(ccb *pccb)
/* - * SCSI READ10 command operation. + * SCSI READ10/WRITE10 command operation. */ -static int ata_scsiop_read10(ccb * pccb) +static int ata_scsiop_read_write(ccb *pccb, u8 is_write) { u32 lba = 0; u16 blocks = 0; @@ -616,20 +616,21 @@ static int ata_scsiop_read10(ccb * pccb) */ blocks = (((u16)pccb->cmd[7]) << 8) | ((u16) pccb->cmd[8]);
- debug("scsi_ahci: read %d blocks starting from lba 0x%x\n", - (unsigned)lba, blocks); + debug("scsi_ahci: %s %d blocks starting from lba 0x%x\n", + is_write ? "write" : "read", (unsigned)lba, blocks);
/* Preset the FIS */ memset(fis, 0, 20); fis[0] = 0x27; /* Host to device FIS. */ fis[1] = 1 << 7; /* Command FIS. */ - fis[2] = ATA_CMD_RD_DMA; /* Command byte. */ + /* Command byte (read/write). */ + fis[2] = is_write ? ATA_CMD_WR_DMA : ATA_CMD_RD_DMA;
while (blocks) { u16 now_blocks; /* number of blocks per iteration */ u32 transfer_size; /* number of bytes per iteration */
- now_blocks = min(MAX_SATA_BLOCKS_READ, blocks); + now_blocks = min(MAX_SATA_BLOCKS_READ_WRITE, blocks);
transfer_size = ATA_BLOCKSIZE * now_blocks; if (transfer_size > user_buffer_size) { @@ -647,10 +648,12 @@ static int ata_scsiop_read10(ccb * pccb) fis[12] = (now_blocks >> 0) & 0xff; fis[13] = (now_blocks >> 8) & 0xff;
- /* Read from ahci */ - if (get_ahci_device_data(pccb->target, (u8 *) &fis, sizeof(fis), - user_buffer, user_buffer_size)) { - debug("scsi_ahci: SCSI READ10 command failure.\n"); + /* Read/Write from ahci */ + if (ahci_device_data_io(pccb->target, (u8 *) &fis, sizeof(fis), + user_buffer, user_buffer_size, + is_write)) { + debug("scsi_ahci: SCSI %s10 command failure.\n", + is_write ? "WRITE" : "READ"); return -EIO; } user_buffer += transfer_size; @@ -703,7 +706,10 @@ int scsi_exec(ccb *pccb)
switch (pccb->cmd[0]) { case SCSI_READ10: - ret = ata_scsiop_read10(pccb); + ret = ata_scsiop_read_write(pccb, 0); + break; + case SCSI_WRITE10: + ret = ata_scsiop_read_write(pccb, 1); break; case SCSI_RD_CAPAC: ret = ata_scsiop_read_capacity10(pccb);
In the structure returned by the ATA identify device command, there are two fields which describe the device capacity. One is a 32 bit data type which reports the number of sectors as a 28 bit LBA, and the other is a 64 bit data type which is for a 48 bit LBA. If the device doesn't support 48 bit LBAs, the small value is the only value with the correct size. If it supports more, if the number of sectors is small enough to fit into 28 bits, both fields reflect the correct value. If it's too large, the smaller field has 28 bits of 1s, 0xfffffff, and the other field has the correct value.
The AHCI driver is implemented by attaching to the generic SCSI code and translating on the fly between SCSI binary data structures and AHCI data structures. It responds to requests to execute specific SCSI commands by executing the equivalent AHCI commands and then crafting a response which matches what a SCSI disk would send.
The AHCI driver now considers both fields and chooses the correct one when implementing both the SCSI READ CAPACITY (10) and READ CAPACITY (16) commands.
Signed-off-by: Gabe Black gabeblack@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/block/ahci.c | 55 +++++++++++++++++++++++++++++++++++++++++++++---- include/scsi.h | 2 + 2 files changed, 52 insertions(+), 5 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 5092352..c16e8ba 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -672,6 +672,7 @@ static int ata_scsiop_read_write(ccb *pccb, u8 is_write) static int ata_scsiop_read_capacity10(ccb *pccb) { u32 cap; + u32 block_size;
if (!ataid[pccb->target]) { printf("scsi_ahci: SCSI READ CAPACITY10 command failure. " @@ -680,12 +681,53 @@ static int ata_scsiop_read_capacity10(ccb *pccb) return -EPERM; }
- cap = be32_to_cpu(ataid[pccb->target]->lba_capacity); + cap = le32_to_cpu(ataid[pccb->target]->lba_capacity); + if (cap == 0xfffffff) { + unsigned short *cap48 = ataid[pccb->target]->lba48_capacity; + if (cap48[2] || cap48[3]) { + cap = 0xffffffff; + } else { + cap = (le16_to_cpu(cap48[1]) << 16) | + (le16_to_cpu(cap48[0])); + } + } + + cap = cpu_to_be32(cap); memcpy(pccb->pdata, &cap, sizeof(cap));
- pccb->pdata[4] = pccb->pdata[5] = 0; - pccb->pdata[6] = 512 >> 8; - pccb->pdata[7] = 512 & 0xff; + block_size = cpu_to_be32((u32)512); + memcpy(&pccb->pdata[4], &block_size, 4); + + return 0; +} + + +/* + * SCSI READ CAPACITY16 command operation. + */ +static int ata_scsiop_read_capacity16(ccb *pccb) +{ + u64 cap; + u64 block_size; + + if (!ataid[pccb->target]) { + printf("scsi_ahci: SCSI READ CAPACITY16 command failure. " + "\tNo ATA info!\n" + "\tPlease run SCSI commmand INQUIRY firstly!\n"); + return -EPERM; + } + + cap = le32_to_cpu(ataid[pccb->target]->lba_capacity); + if (cap == 0xfffffff) { + memcpy(&cap, ataid[pccb->target]->lba48_capacity, sizeof(cap)); + cap = le64_to_cpu(cap); + } + + cap = cpu_to_be64(cap); + memcpy(pccb->pdata, &cap, sizeof(cap)); + + block_size = cpu_to_be64((u64)512); + memcpy(&pccb->pdata[8], &block_size, 8);
return 0; } @@ -711,9 +753,12 @@ int scsi_exec(ccb *pccb) case SCSI_WRITE10: ret = ata_scsiop_read_write(pccb, 1); break; - case SCSI_RD_CAPAC: + case SCSI_RD_CAPAC10: ret = ata_scsiop_read_capacity10(pccb); break; + case SCSI_RD_CAPAC16: + ret = ata_scsiop_read_capacity16(pccb); + break; case SCSI_TST_U_RDY: ret = ata_scsiop_test_unit_ready(pccb); break; diff --git a/include/scsi.h b/include/scsi.h index 9681d19..9da764b 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -150,6 +150,8 @@ typedef struct SCSI_cmd_block{ #define SCSI_READ6 0x08 /* Read 6-byte (MANDATORY) */ #define SCSI_READ10 0x28 /* Read 10-byte (MANDATORY) */ #define SCSI_RD_CAPAC 0x25 /* Read Capacity (MANDATORY) */ +#define SCSI_RD_CAPAC10 SCSI_RD_CAPAC /* Read Capacity (10) */ +#define SCSI_RD_CAPAC16 0x9e /* Read Capacity (16) */ #define SCSI_RD_DEFECT 0x37 /* Read Defect Data (O) */ #define SCSI_READ_LONG 0x3E /* Read Long (O) */ #define SCSI_REASS_BLK 0x07 /* Reassign Blocks (O) */
This cleanup replaces the hardcoded use of '20', which represents the number of bytes in the FIS, with sizeof(fis).
drivers/block/ahci.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index c16e8ba..10fae88 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -383,14 +383,14 @@ static void ahci_set_feature(u8 port) u8 fis[20];
/* set feature */ - memset(fis, 0, 20); + memset(fis, 0, sizeof(fis)); fis[0] = 0x27; fis[1] = 1 << 7; fis[2] = ATA_CMD_SETF; fis[3] = SETFEATURES_XFER; fis[12] = __ilog2(probe_ent->udma_mask + 1) + 0x40 - 0x01;
- memcpy((unsigned char *)pp->cmd_tbl, fis, 20); + memcpy((unsigned char *)pp->cmd_tbl, fis, sizeof(fis)); ahci_fill_cmd_slot(pp, cmd_fis_len); writel(1, port_mmio + PORT_CMD_ISSUE); readl(port_mmio + PORT_CMD_ISSUE); @@ -559,7 +559,7 @@ static int ata_scsiop_inquiry(ccb *pccb) if (pccb->datalen <= 35) return 0;
- memset(fis, 0, 20); + memset(fis, 0, sizeof(fis)); /* Construct the FIS */ fis[0] = 0x27; /* Host to device FIS. */ fis[1] = 1 << 7; /* Command FIS. */ @@ -570,7 +570,7 @@ static int ata_scsiop_inquiry(ccb *pccb) if (!(tmpid = malloc(sizeof(hd_driveid_t)))) return -ENOMEM;
- if (ahci_device_data_io(port, (u8 *) &fis, 20, tmpid, + if (ahci_device_data_io(port, (u8 *) &fis, sizeof(fis), tmpid, sizeof(hd_driveid_t), 0)) { debug("scsi_ahci: SCSI inquiry command failure.\n"); return -EIO; @@ -620,7 +620,7 @@ static int ata_scsiop_read_write(ccb *pccb, u8 is_write) is_write ? "write" : "read", (unsigned)lba, blocks);
/* Preset the FIS */ - memset(fis, 0, 20); + memset(fis, 0, sizeof(fis)); fis[0] = 0x27; /* Host to device FIS. */ fis[1] = 1 << 7; /* Command FIS. */ /* Command byte (read/write). */
This fixes a spelling error in a message which can be output to the console.
Signed-off-by: Taylor Hutt thutt@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Move #ifdef change into earlier commit
drivers/block/ahci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 10fae88..20c5336 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -478,7 +478,7 @@ static int ahci_device_data_io(u8 port, u8 *fis, int fis_len, u8 *buf, debug("Enter %s: for port %d\n", __func__, port);
if (port > probe_ent->n_ports) { - printf("Invaild port number %d\n", port); + printf("Invalid port number %d\n", port); return -1; }
Capacity needs to allow for a 64-bit value.
Signed-off-by: Gabe Black gabeblack@google.com Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add patch to support 64-bit LBA option when reading capacity
common/cmd_scsi.c | 92 ++++++++++++++++++++++++++++++++++++++--------------- 1 files changed, 66 insertions(+), 26 deletions(-)
diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 9bd8ec9..266bfa6 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -72,7 +72,6 @@ static block_dev_desc_t scsi_dev_desc[CONFIG_SYS_SCSI_MAX_DEVICE]; * forward declerations of some Setup Routines */ void scsi_setup_test_unit_ready(ccb * pccb); -void scsi_setup_read_capacity(ccb * pccb); void scsi_setup_read6(ccb * pccb, unsigned long start, unsigned short blocks); void scsi_setup_read_ext(ccb * pccb, unsigned long start, unsigned short blocks); static void scsi_setup_write_ext(ccb *pccb, unsigned long start, @@ -81,6 +80,8 @@ void scsi_setup_inquiry(ccb * pccb); void scsi_ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len);
+static int scsi_read_capacity(ccb *pccb, lbaint_t *capacity, + unsigned long *blksz); static ulong scsi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer); static ulong scsi_write(int device, ulong blknr, lbaint_t blkcnt, const void *buffer); @@ -93,7 +94,8 @@ static ulong scsi_write(int device, ulong blknr, void scsi_scan(int mode) { unsigned char i,perq,modi,lun; - unsigned long capacity,blksz; + lbaint_t capacity; + unsigned long blksz; ccb* pccb=(ccb *)&tempccb;
if(mode==1) { @@ -158,16 +160,10 @@ void scsi_scan(int mode) scsi_print_error(pccb); continue; } - pccb->datalen=8; - scsi_setup_read_capacity(pccb); - if(scsi_exec(pccb)!=TRUE) { + if (scsi_read_capacity(pccb, &capacity, &blksz)) { scsi_print_error(pccb); continue; } - capacity=((unsigned long)tempbuff[0]<<24)|((unsigned long)tempbuff[1]<<16)| - ((unsigned long)tempbuff[2]<<8)|((unsigned long)tempbuff[3]); - blksz=((unsigned long)tempbuff[4]<<24)|((unsigned long)tempbuff[5]<<16)| - ((unsigned long)tempbuff[6]<<8)|((unsigned long)tempbuff[7]); scsi_dev_desc[scsi_max_devs].lba=capacity; scsi_dev_desc[scsi_max_devs].blksz=blksz; scsi_dev_desc[scsi_max_devs].type=perq; @@ -514,6 +510,67 @@ void scsi_trim_trail (unsigned char *str, unsigned int len) } }
+int scsi_read_capacity(ccb *pccb, lbaint_t *capacity, unsigned long *blksz) +{ + *capacity = 0; + + memset(pccb->cmd, 0, sizeof(pccb->cmd)); + pccb->cmd[0] = SCSI_RD_CAPAC10; + pccb->cmd[1] = pccb->lun << 5; + pccb->cmdlen = 10; + pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */ + + pccb->datalen = 8; + if (scsi_exec(pccb) != TRUE) + return 1; + + *capacity = ((lbaint_t)pccb->pdata[0] << 24) | + ((lbaint_t)pccb->pdata[1] << 16) | + ((lbaint_t)pccb->pdata[2] << 8) | + ((lbaint_t)pccb->pdata[3]); + + if (*capacity != 0xffffffff) { + /* Read capacity (10) was sufficient for this drive. */ + *blksz = ((unsigned long)pccb->pdata[4] << 24) | + ((unsigned long)pccb->pdata[5] << 16) | + ((unsigned long)pccb->pdata[6] << 8) | + ((unsigned long)pccb->pdata[7]); + return 0; + } + + /* Read capacity (10) was insufficient. Use read capacity (16). */ + + memset(pccb->cmd, 0, sizeof(pccb->cmd)); + pccb->cmd[0] = SCSI_RD_CAPAC16; + pccb->cmd[1] = 0x10; + pccb->cmdlen = 16; + pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */ + + pccb->datalen = 16; + if (scsi_exec(pccb) != TRUE) + return 1; + + *capacity = ((uint64_t)pccb->pdata[0] << 56) | + ((uint64_t)pccb->pdata[1] << 48) | + ((uint64_t)pccb->pdata[2] << 40) | + ((uint64_t)pccb->pdata[3] << 32) | + ((uint64_t)pccb->pdata[4] << 24) | + ((uint64_t)pccb->pdata[5] << 16) | + ((uint64_t)pccb->pdata[6] << 8) | + ((uint64_t)pccb->pdata[7]); + + *blksz = ((uint64_t)pccb->pdata[8] << 56) | + ((uint64_t)pccb->pdata[9] << 48) | + ((uint64_t)pccb->pdata[10] << 40) | + ((uint64_t)pccb->pdata[11] << 32) | + ((uint64_t)pccb->pdata[12] << 24) | + ((uint64_t)pccb->pdata[13] << 16) | + ((uint64_t)pccb->pdata[14] << 8) | + ((uint64_t)pccb->pdata[15]); + + return 0; +} +
/************************************************************************************ * Some setup (fill-in) routines @@ -530,23 +587,6 @@ void scsi_setup_test_unit_ready(ccb * pccb) pccb->msgout[0]=SCSI_IDENTIFY; /* NOT USED */ }
-void scsi_setup_read_capacity(ccb * pccb) -{ - pccb->cmd[0]=SCSI_RD_CAPAC; - pccb->cmd[1]=pccb->lun<<5; - pccb->cmd[2]=0; - pccb->cmd[3]=0; - pccb->cmd[4]=0; - pccb->cmd[5]=0; - pccb->cmd[6]=0; - pccb->cmd[7]=0; - pccb->cmd[8]=0; - pccb->cmd[9]=0; - pccb->cmdlen=10; - pccb->msgout[0]=SCSI_IDENTIFY; /* NOT USED */ - -} - void scsi_setup_read_ext(ccb * pccb, unsigned long start, unsigned short blocks) { pccb->cmd[0]=SCSI_READ10;
Update the assignment of various physical memory buffers used by the SATA controller to explicitly be denoted as physical addresses.
The memory is identity-mapped, so these function calls are a nop, but they provide good semantic documentation for any maintainers.
The return value of virt_to_phys() is 'unsigned long'. On machines where sizeof(unsigned long) != sizeof(pointer), a cast through (uintptr_t) is needed to appease the compiler due to the potential of losing the upper 32 bits of the address.
In compilation this scenario, a physical address could be 64-bits, yet the C pointer environment only allows 32-bit addresses; the constraint is that pointers cannot address more than 4Gb of memory and if virt_to_phys() ever returns an out-of-range value for the physical address, there are issues with emmory mapping which must be solved. However, since the memory is identify mappeed, there is no problem introducing the cast: the original pointer will reside in 32-bits, so the physical address will also be within in 32-bits.
drivers/block/ahci.c | 10 ++++++---- 1 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 20c5336..00de086 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -431,25 +431,27 @@ static int ahci_port_start(u8 port) * First item in chunk of DMA memory: 32-slot command table, * 32 bytes each in size */ - pp->cmd_slot = (struct ahci_cmd_hdr *)mem; + pp->cmd_slot = + (struct ahci_cmd_hdr *)(uintptr_t)virt_to_phys((void *)mem); debug("cmd_slot = 0x%x\n", (unsigned)pp->cmd_slot); mem += (AHCI_CMD_SLOT_SZ + 224);
/* * Second item: Received-FIS area */ - pp->rx_fis = mem; + pp->rx_fis = virt_to_phys((void *)mem); mem += AHCI_RX_FIS_SZ;
/* * Third item: data area for storing a single command * and its scatter-gather table */ - pp->cmd_tbl = mem; + pp->cmd_tbl = virt_to_phys((void *)mem); debug("cmd_tbl_dma = 0x%x\n", pp->cmd_tbl);
mem += AHCI_CMD_TBL_HDR; - pp->cmd_tbl_sg = (struct ahci_sg *)mem; + pp->cmd_tbl_sg = + (struct ahci_sg *)(uintptr_t)virt_to_phys((void *)mem);
writel_with_flush((u32) pp->cmd_slot, port_mmio + PORT_LST_ADDR);
Exynos5 automatically performs DMA when the SATA controller executes commands. This adds the necessary dcache-to-memory flush & invalidation calls to allow the DMA to properly function.
drivers/block/ahci.c | 39 +++++++++++++++++++++++++++++++++++++++ 1 files changed, 39 insertions(+), 0 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 00de086..a05d9cf 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -70,6 +70,39 @@ static void ahci_setup_port(struct ahci_ioports *port, unsigned long base,
+static void ahci_dcache_flush_range(unsigned begin, unsigned len) +{ + const unsigned long start = begin; + const unsigned long end = start + len; + + debug("%s: flush dcache: [%#lx, %#lx)\n", __func__, start, end); + flush_dcache_range(start, end); +} + +/* + * SATA controller DMAs to physical RAM. Ensure data from the + * controller is invalidated from dcache; next access comes from + * physical RAM. + */ +static void ahci_dcache_invalidate_range(unsigned begin, unsigned len) +{ + const unsigned long start = begin; + const unsigned long end = start + len; + + debug("%s: invalidate dcache: [%#lx, %#lx)\n", __func__, start, end); + invalidate_dcache_range(start, end); +} + +/* + * Ensure data for SATA controller is flushed out of dcache and + * written to physical memory. + */ +static void ahci_dcache_flush_sata_cmd(struct ahci_ioports *pp) +{ + ahci_dcache_flush_range((unsigned long)pp->cmd_slot, + AHCI_PORT_PRIV_DMA_SZ); +} + static int waiting_for_cmd_completed(volatile u8 *offset, int timeout_msec, u32 sign) @@ -392,6 +425,7 @@ static void ahci_set_feature(u8 port)
memcpy((unsigned char *)pp->cmd_tbl, fis, sizeof(fis)); ahci_fill_cmd_slot(pp, cmd_fis_len); + ahci_dcache_flush_sata_cmd(pp); writel(1, port_mmio + PORT_CMD_ISSUE); readl(port_mmio + PORT_CMD_ISSUE);
@@ -496,12 +530,17 @@ static int ahci_device_data_io(u8 port, u8 *fis, int fis_len, u8 *buf, opts = (fis_len >> 2) | (sg_count << 16) | (is_write << 6); ahci_fill_cmd_slot(pp, opts);
+ ahci_dcache_flush_sata_cmd(pp); + ahci_dcache_flush_range((unsigned)buf, (unsigned)buf_len); + writel_with_flush(1, port_mmio + PORT_CMD_ISSUE);
if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, 150, 0x1)) { printf("timeout exit!\n"); return -1; } + + ahci_dcache_invalidate_range((unsigned)buf, (unsigned)buf_len); debug("%s: %d byte transferred.\n", __func__, pp->cmd_slot->status);
Note: These are timeout values and not delay values, so the event being timed out will complete whenever it is actually ready, with a measurement granularity of 1 millisecond, up till the timeout value. Therefore, there is no effect on SSD booting.
The values were determined by instrumenting the code and measuring the actual time taken by several different models of HDD for each of the parameters and then adding 50% more for the spinup value and just doubling the command timeout value.
Signed-off-by: Walter Murphy wmurphy@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/block/ahci.c | 14 ++++++++++---- 1 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index a05d9cf..719574f 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -52,6 +52,10 @@ hd_driveid_t *ataid[AHCI_MAX_PORTS]; #define MAX_SATA_BLOCKS_READ_WRITE 0x80 #endif
+/* Maximum timeouts for each event */ +#define WAIT_MS_DATAIO 5000 +#define WAIT_MS_LINKUP 4 + static inline u32 ahci_port_base(u32 base, u32 port) { return base + 0x100 + (port * 0x80); @@ -201,14 +205,14 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(PORT_CMD_SPIN_UP, port_mmio + PORT_CMD);
j = 0; - while (j < 1000) { + while (j < WAIT_MS_LINKUP) { tmp = readl(port_mmio + PORT_SCR_STAT); if ((tmp & 0xf) == 0x3) break; udelay(1000); j++; } - if (j == 1000) + if (j == WAIT_MS_LINKUP) debug("timeout.\n"); else debug("ok.\n"); @@ -429,7 +433,8 @@ static void ahci_set_feature(u8 port) writel(1, port_mmio + PORT_CMD_ISSUE); readl(port_mmio + PORT_CMD_ISSUE);
- if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, 150, 0x1)) { + if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, + WAIT_MS_DATAIO, 0x1)) { printf("set feature error on port %d!\n", port); } } @@ -535,7 +540,8 @@ static int ahci_device_data_io(u8 port, u8 *fis, int fis_len, u8 *buf,
- if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, 150, 0x1)) { + if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, + WAIT_MS_DATAIO, 0x1)) { printf("timeout exit!\n"); return -1; }
Add HDD handling to the SSD-only AHCI driver, by separately dealing with spin-up and link-up.
Signed-off-by: Marc Jones marc.jones@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/block/ahci.c | 45 +++++++++++++++++++++++++++++++++++++++------ 1 files changed, 39 insertions(+), 6 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 719574f..19c5f13 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -53,6 +53,7 @@ hd_driveid_t *ataid[AHCI_MAX_PORTS]; #endif
/* Maximum timeouts for each event */ +#define WAIT_MS_SPINUP 10000 #define WAIT_MS_DATAIO 5000 #define WAIT_MS_LINKUP 4
@@ -129,7 +130,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) unsigned short vendor; #endif volatile u8 *mmio = (volatile u8 *)probe_ent->mmio_base; - u32 tmp, cap_save; + u32 tmp, cap_save, cmd; int i, j; volatile u8 *port_mmio;
@@ -137,7 +138,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent)
cap_save = readl(mmio + HOST_CAP); cap_save &= ((1 << 28) | (1 << 17)); - cap_save |= (1 << 27); + cap_save |= (1 << 27); /* Staggered Spin-up. Not needed. */
/* global controller reset */ tmp = readl(mmio + HOST_CTL); @@ -201,9 +202,18 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) msleep(500); }
- debug("Spinning up port %d... ", i); - writel(PORT_CMD_SPIN_UP, port_mmio + PORT_CMD); - + /* Add the spinup command to whatever mode bits may + * already be on in the command register. + */ + cmd = readl(port_mmio + PORT_CMD); + cmd |= PORT_CMD_FIS_RX; + cmd |= PORT_CMD_SPIN_UP; + writel_with_flush(cmd, port_mmio + PORT_CMD); + + /* Bring up SATA link. + * SATA link bringup time is usually less than 1 ms; only very + * rarely has it taken between 1-2 ms. Never seen it above 2 ms. + */ j = 0; while (j < WAIT_MS_LINKUP) { tmp = readl(port_mmio + PORT_SCR_STAT); @@ -212,7 +222,30 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) udelay(1000); j++; } - if (j == WAIT_MS_LINKUP) + if (j == WAIT_MS_LINKUP) { + printf("SATA link %d timeout.\n", i); + continue; + } else { + debug("SATA link ok.\n"); + } + + /* Clear error status */ + tmp = readl(port_mmio + PORT_SCR_ERR); + if (tmp) + writel(tmp, port_mmio + PORT_SCR_ERR); + + debug("Spinning up device on SATA port %d... ", i); + + j = 0; + while (j < WAIT_MS_SPINUP) { + tmp = readl(port_mmio + PORT_TFDATA); + if (!(tmp & (ATA_STAT_BUSY | ATA_STAT_DRQ))) + break; + udelay(1000); + j++; + } + printf("Target spinup took %d ms.\n", j); + if (j == WAIT_MS_SPINUP) debug("timeout.\n"); else debug("ok.\n");
Writes in u-boot are so rare, and the logic to know when is the last write and do a flush only there is sufficiently difficult. Just do a flush after every write. This incurs, usually, one extra flush when the rare writes do happen.
drivers/block/ahci.c | 52 +++++++++++++++++++++++++++++++++++++++++++++++++- include/ata.h | 3 ++ 2 files changed, 54 insertions(+), 1 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 19c5f13..963efec 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -37,6 +37,8 @@ #include <linux/ctype.h> #include <ahci.h>
+static int ata_io_flush(u8 port); + struct ahci_probe_ent *probe_ent = NULL; hd_driveid_t *ataid[AHCI_MAX_PORTS];
@@ -55,6 +57,7 @@ hd_driveid_t *ataid[AHCI_MAX_PORTS]; /* Maximum timeouts for each event */ #define WAIT_MS_SPINUP 10000 #define WAIT_MS_DATAIO 5000 +#define WAIT_MS_FLUSH 5000 #define WAIT_MS_LINKUP 4
static inline u32 ahci_port_base(u32 base, u32 port) @@ -267,7 +270,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent)
/* register linkup ports */ tmp = readl(port_mmio + PORT_SCR_STAT); - debug("Port %d status: 0x%x\n", i, tmp); + debug("SATA port %d status: 0x%x\n", i, tmp); if ((tmp & 0xf) == 0x03) probe_ent->link_port_map |= (0x01 << i); } @@ -736,6 +739,17 @@ static int ata_scsiop_read_write(ccb *pccb, u8 is_write) is_write ? "WRITE" : "READ"); return -EIO; } + + /* If this transaction is a write, do a following flush. + * Writes in u-boot are so rare, and the logic to know when is + * the last write and do a flush only there is sufficiently + * difficult. Just do a flush after every write. This incurs, + * usually, one extra flush when the rare writes do happen. + */ + if (is_write) { + if (-EIO == ata_io_flush(pccb->target)) + return -EIO; + } user_buffer += transfer_size; user_buffer_size -= transfer_size; blocks -= now_blocks; @@ -929,6 +943,42 @@ err_out: } #endif
+/* + * In the general case of generic rotating media it makes sense to have a + * flush capability. It probably even makes sense in the case of SSDs because + * one cannot always know for sure what kind of internal cache/flush mechanism + * is embodied therein. At first it was planned to invoke this after the last + * write to disk and before rebooting. In practice, knowing, a priori, which + * is the last write is difficult. Because writing to the disk in u-boot is + * very rare, this flush command will be invoked after every block write. + */ +static int ata_io_flush(u8 port) +{ + u8 fis[20]; + struct ahci_ioports *pp = &(probe_ent->port[port]); + volatile u8 *port_mmio = (volatile u8 *)pp->port_mmio; + u32 cmd_fis_len = 5; /* five dwords */ + + /* Preset the FIS */ + memset(fis, 0, 20); + fis[0] = 0x27; /* Host to device FIS. */ + fis[1] = 1 << 7; /* Command FIS. */ + fis[2] = ATA_CMD_FLUSH; + + memcpy((unsigned char *)pp->cmd_tbl, fis, 20); + ahci_fill_cmd_slot(pp, cmd_fis_len); + writel_with_flush(1, port_mmio + PORT_CMD_ISSUE); + + if (waiting_for_cmd_completed(port_mmio + PORT_CMD_ISSUE, + WAIT_MS_FLUSH, 0x1)) { + debug("scsi_ahci: flush command timeout on port %d.\n", port); + return -EIO; + } + + return 0; +} + + void scsi_bus_reset(void) { /*Not implement*/ diff --git a/include/ata.h b/include/ata.h index 3b2d737..a614724 100644 --- a/include/ata.h +++ b/include/ata.h @@ -114,6 +114,9 @@ #define ATA_CMD_WRITE_EXT 0x34 /* Write Sectores (with retries) with 48bit addressing */ #define ATA_CMD_VRFY_EXT 0x42 /* Read Verify (with retries) with 48bit addressing */
+#define ATA_CMD_FLUSH 0xE7 /* Flush drive cache */ +#define ATA_CMD_FLUSH_EXT 0xEA /* Flush drive cache, with 48bit addressing */ + /* * ATAPI Commands */
Currently, this driver uses a 28bit interface to AHCI, this limits the number of blocks addressable to 2^28, or the max disk size to 512(2^28) or about 137GB. This change allows supporting drives up to about 2TB.
Testing this is a bit difficult. There is test code that can be inserted into U-Boot that will write test patterns into certain unused blocks. These patterns can be manually checked using 'dd' after boot. Another way is to confirm the original error that exposed this bug is fixed. IOW: see if AU (Auto Update) will now work on the drive. Also, check that there are no warning messages from the 'cgpt' utility.
drivers/block/ahci.c | 12 ++++++++---- 1 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 963efec..8c785ae 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -707,7 +707,7 @@ static int ata_scsiop_read_write(ccb *pccb, u8 is_write) fis[0] = 0x27; /* Host to device FIS. */ fis[1] = 1 << 7; /* Command FIS. */ /* Command byte (read/write). */ - fis[2] = is_write ? ATA_CMD_WR_DMA : ATA_CMD_RD_DMA; + fis[2] = is_write ? ATA_CMD_WRITE_EXT : ATA_CMD_READ_EXT;
while (blocks) { u16 now_blocks; /* number of blocks per iteration */ @@ -721,11 +721,15 @@ static int ata_scsiop_read_write(ccb *pccb, u8 is_write) return -EIO; }
- /* LBA address, only support LBA28 in this driver */ + /* LBA48 SATA command but only use 32bit address range within + * that. The next smaller command range (28bit) is too small. + */ fis[4] = (lba >> 0) & 0xff; fis[5] = (lba >> 8) & 0xff; fis[6] = (lba >> 16) & 0xff; - fis[7] = ((lba >> 24) & 0xf) | 0xe0; + fis[7] = 1 << 6; /* device reg: set LBA mode */ + fis[8] = ((lba >> 24) & 0xff); + fis[3] = 0xe0; /* features */
/* Block (sector) count */ fis[12] = (now_blocks >> 0) & 0xff; @@ -963,7 +967,7 @@ static int ata_io_flush(u8 port) memset(fis, 0, 20); fis[0] = 0x27; /* Host to device FIS. */ fis[1] = 1 << 7; /* Command FIS. */ - fis[2] = ATA_CMD_FLUSH; + fis[2] = ATA_CMD_FLUSH_EXT;
memcpy((unsigned char *)pp->cmd_tbl, fis, 20); ahci_fill_cmd_slot(pp, cmd_fis_len);
The prototypes in the header were changed by commit 4ac8f8e0 but the functions no longer match. Correct this.
It seems odd that block devices take an lbaint_t for the block count, but an unsigned long for the blknr. Surely we should promote blknr to lbaint_t also?
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add new patch to correct ide_read/write() function signatures
common/cmd_ide.c | 27 +++++++++------------------ 1 files changed, 9 insertions(+), 18 deletions(-)
diff --git a/common/cmd_ide.c b/common/cmd_ide.c index d508e9f..0105bdb 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -96,7 +96,8 @@ static void ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len
#ifdef CONFIG_ATAPI static void atapi_inquiry(block_dev_desc_t *dev_desc); -ulong atapi_read (int device, lbaint_t blknr, ulong blkcnt, void *buffer); +static ulong atapi_read(int device, ulong blknr, lbaint_t blkcnt, + void *buffer); #endif
@@ -826,7 +827,7 @@ static void ide_ident(block_dev_desc_t *dev_desc)
-ulong ide_read(int device, lbaint_t blknr, ulong blkcnt, void *buffer) +ulong ide_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) { ulong n = 0; unsigned char c; @@ -840,7 +841,7 @@ ulong ide_read(int device, lbaint_t blknr, ulong blkcnt, void *buffer) lba48 = 1; } #endif - debug("ide_read dev %d start %lX, blocks %lX buffer at %lX\n", + debug("ide_read dev %d start %lX, blocks " LBAF " buffer at %lX\n", device, blknr, blkcnt, (ulong) buffer);
ide_led(DEVICE_LED(device), 1); /* LED on */ @@ -930,13 +931,8 @@ ulong ide_read(int device, lbaint_t blknr, ulong blkcnt, void *buffer)
if ((c & (ATA_STAT_DRQ | ATA_STAT_BUSY | ATA_STAT_ERR)) != ATA_STAT_DRQ) { -#if defined(CONFIG_SYS_64BIT_LBA) - printf("Error (no IRQ) dev %d blk %lld: status 0x%02x\n", + printf("Error (no IRQ) dev %d blk %ld: status %#02x\n", device, blknr, c); -#else - printf("Error (no IRQ) dev %d blk %ld: status 0x%02x\n", - device, (ulong) blknr, c); -#endif break; }
@@ -955,7 +951,7 @@ IDE_READ_E: /* ------------------------------------------------------------------------- */
-ulong ide_write(int device, lbaint_t blknr, ulong blkcnt, const void *buffer) +ulong ide_write(int device, ulong blknr, lbaint_t blkcnt, const void *buffer) { ulong n = 0; unsigned char c; @@ -1023,13 +1019,8 @@ ulong ide_write(int device, lbaint_t blknr, ulong blkcnt, const void *buffer)
if ((c & (ATA_STAT_DRQ | ATA_STAT_BUSY | ATA_STAT_ERR)) != ATA_STAT_DRQ) { -#if defined(CONFIG_SYS_64BIT_LBA) - printf("Error (no IRQ) dev %d blk %lld: status 0x%02x\n", + printf("Error (no IRQ) dev %d blk %ld: status %#02x\n", device, blknr, c); -#else - printf("Error (no IRQ) dev %d blk %ld: status 0x%02x\n", - device, (ulong) blknr, c); -#endif goto WR_OUT; }
@@ -1518,13 +1509,13 @@ static void atapi_inquiry(block_dev_desc_t *dev_desc) #define ATAPI_READ_BLOCK_SIZE 2048 /* assuming CD part */ #define ATAPI_READ_MAX_BLOCK (ATAPI_READ_MAX_BYTES/ATAPI_READ_BLOCK_SIZE)
-ulong atapi_read(int device, lbaint_t blknr, ulong blkcnt, void *buffer) +ulong atapi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) { ulong n = 0; unsigned char ccb[12]; /* Command descriptor block */ ulong cnt;
- debug("atapi_read dev %d start %lX, blocks %lX buffer at %lX\n", + debug("atapi_read dev %d start %lX, blocks " LBAF " buffer at %lX\n", device, blknr, blkcnt, (ulong) buffer);
do {
Oops, not sure how I missed that.
It's a bit odd, I agree but doc/driver-model/UDM-block.txt promises to correct this so I went first for consistency in all users.
Reviewed-by: Tom Rini trini@ti.com
Yes, it isn't any worse than it was.
Thanks, Simon
-- Tom
Enable AHCI driver for Intel SATA devices.
include/configs/coreboot.h | 22 ++++++++++++++++++++++ 1 files changed, 22 insertions(+), 0 deletions(-)
diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index 3df085b..cc95e2b 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -45,6 +45,28 @@ #undef CONFIG_WATCHDOG #undef CONFIG_HW_WATCHDOG
+/* SATA AHCI storage */ + +#define CONFIG_SCSI_AHCI + +#ifdef CONFIG_SCSI_AHCI +#define CONFIG_SYS_64BIT_LBA +#define CONFIG_SATA_INTEL 1 +#define CONFIG_SCSI_DEV_LIST {PCI_VENDOR_ID_INTEL, \ + PCI_DEVICE_ID_INTEL_NM10_AHCI}, \ + {PCI_VENDOR_ID_INTEL, \ + PCI_DEVICE_ID_INTEL_COUGARPOINT_AHCI_MOBILE}, \ + {PCI_VENDOR_ID_INTEL, \ + PCI_DEVICE_ID_INTEL_COUGARPOINT_AHCI_SERIES6}, \ + {PCI_VENDOR_ID_INTEL, \ + PCI_DEVICE_ID_INTEL_PANTHERPOINT_AHCI_MOBILE} + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 2 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#endif + /*----------------------------------------------------------------------- * Real Time Clock Configuration */
On Mon, Oct 29, 2012 at 08:23:43AM -0700, Simon Glass wrote:
This series contains a set of improvements for the SATA susbsystem, mostly targeted at solid-state drivers and improving start-up time.
The patches are tested on various x86 Chromebooks.
Changes in v3:
Changes in v2:
- Use struct pci_device_id instead of defining new struct scsi_device
- Squash in CONFIG_PCI patch
Gabe Black (3): ahci: Make sending the SETFEATURES_XFER command optional ahci: Make the AHCI code find the capacity of disks > 128 GB properly ahci: Support 64-bit LBA option when reading capacity
Hung-Te Lin (2): scsi: Add scsi_write to SCSI driver ahci: support scsi writing in AHCI driver
Marc Jones (2): ahci: Support spin-up and link-up separately ahci: Perform SATA flush after disk write.
Simon Glass (3): Support setenv_ulong() and setenv_addr() for powerpc ide: Correct function signatures for ide_read/write() x86: config: Enable AHCI support for coreboot
Stefan Reinauer (4): scsi: Add function and env var to report number of scsi drives ahci: Optimise AHCI controller reset and start-up ahci: Improve AHCI debugging ahci: cosmetics and cleanup
Taylor Hutt (4): ahci: Use sizeof(fis) instead of hardcoding '20' ahci: Fix 'Invaild' typo ahci: Use virt_to_phys() to denote physical addresses for DMA ahci: flush / invalidate dcache around SATA commands
Vadim Bendebury (2): ahci: Support splitting of read transactions into multiple chunks scsi: Provide support for a list of AHCI controllers.
Walter Murphy (2): ahci: Adjust SATA timeouts for hard disk (spinup delay & command timeout) ahci: Expand HDD Logical Block addressability up to 32 bits
README | 3 + common/cmd_ide.c | 27 +-- common/cmd_scsi.c | 255 ++++++++++++++++++++++++---- drivers/block/ahci.c | 401 +++++++++++++++++++++++++++++++++++--------- include/ahci.h | 1 + include/ata.h | 3 + include/common.h | 2 +- include/configs/coreboot.h | 22 +++ include/scsi.h | 4 + 9 files changed, 585 insertions(+), 133 deletions(-)
For the series, applied to u-boot/master, thanks!
