[U-Boot] Commit at91: Choose environment variables location within make config target
Hello Nicholas,
The commit mentioned in the subject cause these error messages here during make at91sam9261ek_config:
These are my steps: $ export BUILD_DIR=/tmp/build $ rm -rf /tmp/build $ make at91sam9261ek_config /bin/bash: line 7: /tmp/build/include/config.h: No such file or directory ... with environment variable in SPI DATAFLASH CS0 Configuring for at91sam9261ek board...
Is this what you had in mind? Or is this something that you need to fix...
Kind Regards,
Remy
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/Makefile b/Makefile index 2ac8141..0e31697 100644 --- a/Makefile +++ b/Makefile @@ -2586,6 +2586,7 @@ at91sam9260ek_nandflash_config \ at91sam9260ek_dataflash_cs0_config \ at91sam9260ek_dataflash_cs1_config \ at91sam9260ek_config : unconfig + @mkdir -p $(obj)include @if [ "$(findstring _nandflash,$@)" ] ; then \ echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ $(XECHO) "... with environment variable in NAND FLASH" ; \ @@ -2602,6 +2603,7 @@ at91sam9261ek_nandflash_config \ at91sam9261ek_dataflash_cs0_config \ at91sam9261ek_dataflash_cs3_config \ at91sam9261ek_config : unconfig + @mkdir -p $(obj)include @if [ "$(findstring _nandflash,$@)" ] ; then \ echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ $(XECHO) "... with environment variable in NAND FLASH" ; \ @@ -2618,6 +2620,7 @@ at91sam9263ek_nandflash_config \ at91sam9263ek_dataflash_config \ at91sam9263ek_dataflash_cs0_config \ at91sam9263ek_config : unconfig + @mkdir -p $(obj)include @if [ "$(findstring _nandflash,$@)" ] ; then \ echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ $(XECHO) "... with environment variable in NAND FLASH" ; \ @@ -2631,6 +2634,7 @@ at91sam9rlek_nandflash_config \ at91sam9rlek_dataflash_config \ at91sam9rlek_dataflash_cs0_config \ at91sam9rlek_config : unconfig + @mkdir -p $(obj)include @if [ "$(findstring _nandflash,$@)" ] ; then \ echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ $(XECHO) "... with environment variable in NAND FLASH" ; \
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1228948562-12728-1-git-send-email-plagnioj@jcrosoft.com you wrote:
- @mkdir -p $(obj)include
What has the Makefile changes to do with chsoing the environment variables location?
Please chose a better subject.
Remy Bohmer
