[U-Boot] [PATCH v2 0/3] env: add support to sunxi save env to spi
Changes since v1: - Rebase to current master - Added patches for testing with pine64-lts board
Oskari Lemmela (3): env: add support to sunxi save env to spi flash sunxi: Pine64-LTS: enable environment in spi flash arm: dts: sunxi: add spi0 alias
arch/arm/dts/sunxi-u-boot.dtsi | 1 + configs/pine64-lts_defconfig | 7 +++++++ env/Kconfig | 4 ++-- 3 files changed, 10 insertions(+), 2 deletions(-)
CONFIG_ENV_SECT_SIZE value is defined via Kconfig.
Signed-off-by: Oskari Lemmela oskari@lemmela.net Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com --- env/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 74db2f38cc..083de650ce 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -491,9 +491,9 @@ config ENV_SIZE
config ENV_SECT_SIZE hex "Environment Sector-Size" - depends on (!ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_OMAP2PLUS || ARCH_AT91) )|| ARCH_STM32MP + depends on (!ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_OMAP2PLUS || ARCH_AT91 || ARCH_SUNXI) )|| ARCH_STM32MP default 0x40000 if ARCH_ZYNQMP - default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 + default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 || ARCH_SUNXI help Size of the sector containing the environment.
enable config options for spi flash device and environment in spi flash.
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- configs/pine64-lts_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/pine64-lts_defconfig b/configs/pine64-lts_defconfig index 0da6b70ea8..34c38cf1fd 100644 --- a/configs/pine64-lts_defconfig +++ b/configs/pine64-lts_defconfig @@ -18,3 +18,10 @@ CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_SUNXI=y
First I am not sure if defining this unconditionally to put the environment in SPI flash is a good idea. People might expect to be able to (continue to) use an environment from the SD card if they just booted from one. Hence my efforts to allow to use the environment from the respective boot media: https://lists.denx.de/pipermail/u-boot/2019-June/372025.html
Secondly, this uses CONFIG_ENV_OFFSET to place the environment in SPI flash. For historical reasons this is 0x88000 for sunxi (old raw SD card offset), so 544KB. Which lets a saveenv overwrite the last part of U-Boot, if you have put it there.
So we should define this to something higher, I suggest just below 1MB, so 0xe0000. Actually I wonder why the default size is 128KB, when the typical environments are so much smaller. For my experiments I used 64KB at 0xf0000, which gives U-Boot more room to grow in the future.
Cheers, Andre.
Hi Andre,
Thanks for comments.
This patch was just for testing purposes. That is true current code picks SD card environment if it is able to load it and both (MMC and SPI) are enabled.
I read through that discussion around your environment patches. For fail-safe purposes it might be good idea to have at least Kconfig option to allow load working environment from different media if primary one fails.
That is true. Might be that default offset is fine for 32-bit systems which doesn't require ATF. I have used 0xE0000 in my defconfigs. So better defaults could be
default 0x88000 if (ARCH_SUNXI && !MACH_SUN50I) default 0xE0000 if ARCH_ZYNQ || (ARCH_SUNXI && MACH_SUN50I)
Or what you think?
Oskari
Cheers, Andre.
On Fri, 2 Aug 2019 10:47:10 +0300 Oskari Lemmelä oskari@lemmela.net wrote:
Hi Oskari,
Please mark patches accordingly if they are not meant for being merged. Although I am not sure why you posted it then in the first place?
Well, it does that, but uses the optional(!) eMMC device for that. If there is none, it will proceed with SPI Another reason to rework the env device selection and make more decisions at runtime.
Also it will overwrite a U-Boot copy on the SPI flash in the process.
Yeah, that was my plan, just didn't come around to it yet.
Something like this, though it should be (ARCH_SUNXI && ARM64), to also cover the H5, H6 and follow-up accidents from Allwinner. Amd it's a bit weird that this value is shared with the raw MMC offset, as SPI flash and MMC are quite different in terms of usage. So I think we should split these two at some point.
Cheers, Andre.
Or what you think?
Oskari
Cheers, Andre.
spi aliases are needed for spi flash devices.
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- arch/arm/dts/sunxi-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi index fdd4c80aa4..b6e075f785 100644 --- a/arch/arm/dts/sunxi-u-boot.dtsi +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -3,6 +3,7 @@ / { aliases { mmc1 = &mmc2; + spi0 = &spi0; };
binman {
André Przywara
Oskari Lemmela
Oskari Lemmelä
