[U-Boot] [PATCH 1/2] zynq-common: Define CONFIG_SYS_I2C_ZYNQ based on board config
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Enable CONFIG_SYS_I2C_ZYNQ only if it has either I2C0 or I2C1 enabled in a board config.This fixes the issue of i2c error during board init if board specific doesnt have either I2C0 or I2C1.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
include/configs/zynq-common.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index ca5ef0430234..2d98cd27a986 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -179,7 +179,10 @@ # define CONFIG_CMD_FS_GENERIC #endif
+#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) #define CONFIG_SYS_I2C_ZYNQ +#endif + /* I2C */ #if defined(CONFIG_SYS_I2C_ZYNQ) # define CONFIG_CMD_I2C
Add DTS for ep108 board.
arch/arm/dts/Makefile | 2 + arch/arm/dts/zynqmp-ep108-clk.dtsi | 119 +++++++ arch/arm/dts/zynqmp-ep108.dts | 174 ++++++++++ arch/arm/dts/zynqmp.dtsi | 668 +++++++++++++++++++++++++++++++++++++ 4 files changed, 963 insertions(+) create mode 100644 arch/arm/dts/zynqmp-ep108-clk.dtsi create mode 100644 arch/arm/dts/zynqmp-ep108.dts create mode 100644 arch/arm/dts/zynqmp.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ddc6a057d567..910648ca2dba 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -65,6 +65,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-zc770-xm011.dtb \ zynq-zc770-xm012.dtb \ zynq-zc770-xm013.dtb +dtb-$(CONFIG_ARCH_ZYNQMP) += \ + zynqmp-ep108.dtb dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-evm.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb
diff --git a/arch/arm/dts/zynqmp-ep108-clk.dtsi b/arch/arm/dts/zynqmp-ep108-clk.dtsi new file mode 100644 index 000000000000..f86452655391 --- /dev/null +++ b/arch/arm/dts/zynqmp-ep108-clk.dtsi @@ -0,0 +1,119 @@ +/* + * clock specification for Xilinx ZynqMP ep108 development board + * + * (C) Copyright 2015, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +&amba { + misc_clk: misc_clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + + i2c_clk: i2c_clk { + compatible = "fixed-clock"; + #clock-cells = <0x0>; + clock-frequency = <111111111>; + }; + + sata_clk: sata_clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <75000000>; + }; + + dp_aclk: clock0 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <50000000>; + clock-accuracy = <100>; + }; + + dp_aud_clk: clock1 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <22579200>; + clock-accuracy = <100>; + }; +}; + +&can0 { + clocks = <&misc_clk &misc_clk>; +}; + +&gem0 { + clocks = <&misc_clk>, <&misc_clk>, <&misc_clk>; +}; + +&gpio { + clocks = <&misc_clk>; +}; + +&i2c0 { + clocks = <&i2c_clk>; +}; + +&i2c1 { + clocks = <&i2c_clk>; +}; + +&qspi { + clocks = <&misc_clk &misc_clk>; +}; + +&sata { + clocks = <&sata_clk>; +}; + +&sdhci0 { + clocks = <&misc_clk>, <&misc_clk>; +}; + +&sdhci1 { + clocks = <&misc_clk>, <&misc_clk>; +}; + +&spi0 { + clocks = <&misc_clk &misc_clk>; +}; + +&spi1 { + clocks = <&misc_clk &misc_clk>; +}; + +&uart0 { + clocks = <&misc_clk &misc_clk>; +}; + +&usb0 { + clocks = <&misc_clk>, <&misc_clk>; +}; + +&usb1 { + clocks = <&misc_clk>, <&misc_clk>; +}; + +&watchdog0 { + clocks= <&misc_clk>; +}; + +&xilinx_drm { + clocks = <&misc_clk>; +}; + +&xlnx_dp { + clocks = <&dp_aclk>, <&dp_aud_clk>; +}; + +&xlnx_dp_snd_codec0 { + clocks = <&dp_aud_clk>; +}; + +&xlnx_dpdma { + clocks = <&misc_clk>; +}; diff --git a/arch/arm/dts/zynqmp-ep108.dts b/arch/arm/dts/zynqmp-ep108.dts new file mode 100644 index 000000000000..4481bd07c9e8 --- /dev/null +++ b/arch/arm/dts/zynqmp-ep108.dts @@ -0,0 +1,174 @@ +/* + * dts file for Xilinx ZynqMP ep108 development board + * + * (C) Copyright 2014 - 2015, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +/include/ "zynqmp.dtsi" +/include/ "zynqmp-ep108-clk.dtsi" + +/ { + model = "ZynqMP EP108"; + + aliases { + serial0 = &uart0; + spi0 = &qspi; + spi1 = &spi0; + spi2 = &spi1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0x0 0x0 0x40000000>; + }; +}; + +&can0 { + status = "okay"; +}; + +&gem0 { + status = "okay"; + phy-handle = <&phy0>; + phy-mode = "rgmii-id"; + phy0: phy@0{ + reg = <0>; + max-speed = <100>; + }; +}; + +&gpio { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + eeprom@54 { + compatible = "at,24c64"; + reg = <0x54>; + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + eeprom@55 { + compatible = "at,24c64"; + reg = <0x55>; + }; +}; + +&qspi { + status = "okay"; + flash@0 { + compatible = "n25q512a11"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <10000000>; + partition@qspi-fsbl-uboot { /* for testing purpose */ + label = "qspi-fsbl-uboot"; + reg = <0x0 0x100000>; + }; + partition@qspi-linux { /* for testing purpose */ + label = "qspi-linux"; + reg = <0x100000 0x500000>; + }; + partition@qspi-device-tree { /* for testing purpose */ + label = "qspi-device-tree"; + reg = <0x600000 0x20000>; + }; + partition@qspi-rootfs { /* for testing purpose */ + label = "qspi-rootfs"; + reg = <0x620000 0x5E0000>; + }; + }; +}; + +&sata { + status = "okay"; + ceva,broken-gen2; +}; + +&sdhci0 { + status = "okay"; +}; + +&sdhci1 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + num-cs = <1>; + spi0_flash0: spi0_flash0@0 { + compatible = "m25p80"; + #address-cells = <1>; + #size-cells = <1>; + spi-max-frequency = <50000000>; + reg = <0>; + + spi0_flash0@00000000 { + label = "spi0_flash0"; + reg = <0x0 0x100000>; + }; + }; +}; + +&spi1 { + status = "okay"; + num-cs = <1>; + spi1_flash0: spi1_flash0@0 { + compatible = "m25p80"; + #address-cells = <1>; + #size-cells = <1>; + spi-max-frequency = <50000000>; + reg = <0>; + + spi1_flash0@00000000 { + label = "spi1_flash0"; + reg = <0x0 0x100000>; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; + dr_mode = "peripheral"; + maximum-speed = "high-speed"; +}; + +&usb1 { + status = "okay"; + dr_mode = "host"; + maximum-speed = "high-speed"; +}; + +&watchdog0 { + status = "okay"; +}; + +&xlnx_dp { + xlnx,max-pclock-frequency = <200000>; +}; + +&xlnx_dpdma { + xlnx,axi-clock-freq = <200000000>; +}; diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi new file mode 100644 index 000000000000..24a34e6d85d2 --- /dev/null +++ b/arch/arm/dts/zynqmp.dtsi @@ -0,0 +1,668 @@ +/* + * dts file for Xilinx ZynqMP + * + * (C) Copyright 2014 - 2015, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/ { + compatible = "xlnx,zynqmp"; + #address-cells = <2>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x0>; + }; + + cpu@1 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x1>; + }; + + cpu@2 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x2>; + }; + + cpu@3 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x3>; + }; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <0 143 4>, + <0 144 4>, + <0 145 4>, + <0 146 4>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + firmware { + compatible = "xlnx,zynqmp-pm"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupt-parent = <&gic>; + interrupts = <1 13 0xf01>, + <1 14 0xf01>, + <1 11 0xf01>, + <1 10 0xf01>; + }; + + amba_apu: amba_apu { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <1>; + ranges; + + gic: interrupt-controller@f9010000 { + compatible = "arm,gic-400", "arm,cortex-a15-gic"; + #interrupt-cells = <3>; + reg = <0x0 0xf9010000 0x10000>, + <0x0 0xf902f000 0x2000>, + <0x0 0xf9040000 0x20000>, + <0x0 0xf906f000 0x2000>; + interrupt-controller; + interrupt-parent = <&gic>; + interrupts = <1 9 0xf04>; + }; + }; + + amba: amba { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <1>; + ranges; + + can0: can@ff060000 { + compatible = "xlnx,zynq-can-1.0"; + status = "disabled"; + clock-names = "can_clk", "pclk"; + reg = <0x0 0xff060000 0x1000>; + interrupts = <0 23 4>; + interrupt-parent = <&gic>; + tx-fifo-depth = <0x40>; + rx-fifo-depth = <0x40>; + }; + + can1: can@ff070000 { + compatible = "xlnx,zynq-can-1.0"; + status = "disabled"; + clock-names = "can_clk", "pclk"; + reg = <0x0 0xff070000 0x1000>; + interrupts = <0 24 4>; + interrupt-parent = <&gic>; + tx-fifo-depth = <0x40>; + rx-fifo-depth = <0x40>; + }; + + /* GDMA */ + fpd_dma_chan1: dma@fd500000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd500000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 124 4>; + xlnx,id = <0>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan2: dma@fd510000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd510000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 125 4>; + xlnx,id = <1>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan3: dma@fd520000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd520000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 126 4>; + xlnx,id = <2>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan4: dma@fd530000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd530000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 127 4>; + xlnx,id = <3>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan5: dma@fd540000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd540000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 128 4>; + xlnx,id = <4>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan6: dma@fd550000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd550000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 129 4>; + xlnx,id = <5>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan7: dma@fd560000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd560000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 130 4>; + xlnx,id = <6>; + xlnx,bus-width = <128>; + }; + + fpd_dma_chan8: dma@fd570000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xfd570000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 131 4>; + xlnx,id = <7>; + xlnx,bus-width = <128>; + }; + + gpu: gpu@fd4b0000 { + status = "disabled"; + compatible = "arm,mali-400", "arm,mali-utgard"; + reg = <0x0 0xfd4b0000 0x30000>; + interrupt-parent = <&gic>; + interrupts = <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>; + interrupt-names = "IRQGP", "IRQGPMMU", "IRQPP0", "IRQPPMMU0", "IRQPP1", "IRQPPMMU1"; + }; + + /* ADMA */ + lpd_dma_chan1: dma@ffa80000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffa80000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 77 4>; + xlnx,id = <0>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan2: dma@ffa90000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffa90000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 78 4>; + xlnx,id = <1>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan3: dma@ffaa0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffaa0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 79 4>; + xlnx,id = <2>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan4: dma@ffab0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffab0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 80 4>; + xlnx,id = <3>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan5: dma@ffac0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffac0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 81 4>; + xlnx,id = <4>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan6: dma@ffad0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffad0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 82 4>; + xlnx,id = <5>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan7: dma@ffae0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffae0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 83 4>; + xlnx,id = <6>; + xlnx,bus-width = <64>; + }; + + lpd_dma_chan8: dma@ffaf0000 { + status = "disabled"; + compatible = "xlnx,zynqmp-dma-1.0"; + reg = <0x0 0xffaf0000 0x1000>; + interrupt-parent = <&gic>; + interrupts = <0 84 4>; + xlnx,id = <7>; + xlnx,bus-width = <64>; + }; + + nand0: nand@ff100000 { + compatible = "arasan,nfc-v3p10"; + status = "disabled"; + reg = <0x0 0xff100000 0x1000>; + clock-names = "clk_sys", "clk_flash"; + interrupt-parent = <&gic>; + interrupts = <0 14 4>; + #address-cells = <2>; + #size-cells = <1>; + }; + + gem0: ethernet@ff0b0000 { + compatible = "cdns,gem"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 57 4>, <0 57 4>; + reg = <0x0 0xff0b0000 0x1000>; + clock-names = "pclk", "hclk", "tx_clk"; + #address-cells = <1>; + #size-cells = <0>; + jumbo-max-len = <10240>; + jumbo-supported; + }; + + gem1: ethernet@ff0c0000 { + compatible = "cdns,gem"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 59 4>, <0 59 4>; + reg = <0x0 0xff0c0000 0x1000>; + clock-names = "pclk", "hclk", "tx_clk"; + #address-cells = <1>; + #size-cells = <0>; + jumbo-max-len = <10240>; + jumbo-supported; + }; + + gem2: ethernet@ff0d0000 { + compatible = "cdns,gem"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 61 4>, <0 61 4>; + reg = <0x0 0xff0d0000 0x1000>; + clock-names = "pclk", "hclk", "tx_clk"; + #address-cells = <1>; + #size-cells = <0>; + jumbo-max-len = <10240>; + jumbo-supported; + }; + + gem3: ethernet@ff0e0000 { + compatible = "cdns,gem"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 63 4>, <0 63 4>; + reg = <0x0 0xff0e0000 0x1000>; + clock-names = "pclk", "hclk", "tx_clk"; + #address-cells = <1>; + #size-cells = <0>; + jumbo-max-len = <10240>; + jumbo-supported; + }; + + gpio: gpio@ff0a0000 { + compatible = "xlnx,zynqmp-gpio-1.0"; + status = "disabled"; + #gpio-cells = <0x2>; + interrupt-parent = <&gic>; + interrupts = <0 16 4>; + reg = <0x0 0xff0a0000 0x1000>; + }; + + i2c0: i2c@ff020000 { + compatible = "cdns,i2c-r1p10"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 17 4>; + reg = <0x0 0xff020000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@ff030000 { + compatible = "cdns,i2c-r1p10"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 18 4>; + reg = <0x0 0xff030000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + pcie: pcie@fd0e0000 { + compatible = "xlnx,nwl-pcie-2.11"; + status = "disabled"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + device_type = "pci"; + interrupt-parent = <&gic>; + interrupts = < 0 118 4>, + < 0 116 4>, + < 0 115 4>, /* MSI_1 [63...32] */ + < 0 114 4 >; /* MSI_0 [31...0] */ + interrupt-names = "misc", "intx", "msi_1", "msi_0"; + reg = <0x0 0xfd0e0000 0x1000>, + <0x0 0xfd480000 0x1000>, + <0x0 0xe0000000 0x1000000>; + reg-names = "breg", "pcireg", "cfg"; + ranges = <0x02000000 0x00000000 0xe1000000 0x00000000 0xe1000000 0 0x0f000000>; + }; + + qspi: spi@ff0f0000 { + compatible = "xlnx,zynqmp-qspi-1.0"; + status = "disabled"; + clock-names = "ref_clk", "pclk"; + interrupts = <0 15 4>; + interrupt-parent = <&gic>; + num-cs = <1>; + reg = <0x0 0xff0f0000 0x1000 0x0 0xc0000000 0x8000000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + rtc: rtc@ffa60000 { + compatible = "xlnx,zynqmp-rtc"; + status = "disabled"; + reg = <0x0 0xffa60000 0x100>; + interrupt-parent = <&gic>; + interrupts = <0 26 4>, <0 27 4>; + interrupt-names = "alarm", "sec"; + }; + + sata: ahci@fd0c0000 { + compatible = "ceva,ahci-1v84"; + status = "disabled"; + reg = <0x0 0xfd0c0000 0x2000>; + interrupt-parent = <&gic>; + interrupts = <0 133 4>; + }; + + sdhci0: sdhci@ff160000 { + compatible = "arasan,sdhci-8.9a"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 48 4>; + reg = <0x0 0xff160000 0x1000>; + clock-names = "clk_xin", "clk_ahb"; + }; + + sdhci1: sdhci@ff170000 { + compatible = "arasan,sdhci-8.9a"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 49 4>; + reg = <0x0 0xff170000 0x1000>; + clock-names = "clk_xin", "clk_ahb"; + }; + + smmu: smmu@fd800000 { + compatible = "arm,mmu-500"; + reg = <0x0 0xfd800000 0x20000>; + #global-interrupts = <1>; + interrupt-parent = <&gic>; + interrupts = <0 157 4>, + <0 157 4>, <0 157 4>, <0 157 4>, <0 157 4>, + <0 157 4>, <0 157 4>, <0 157 4>, <0 157 4>, + <0 157 4>, <0 157 4>, <0 157 4>, <0 157 4>, + <0 157 4>, <0 157 4>, <0 157 4>, <0 157 4>; + }; + + spi0: spi@ff040000 { + compatible = "cdns,spi-r1p6"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 19 4>; + reg = <0x0 0xff040000 0x1000>; + clock-names = "ref_clk", "pclk"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@ff050000 { + compatible = "cdns,spi-r1p6"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 20 4>; + reg = <0x0 0xff050000 0x1000>; + clock-names = "ref_clk", "pclk"; + #address-cells = <1>; + #size-cells = <0>; + }; + + ttc0: timer@ff110000 { + compatible = "cdns,ttc"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 36 4>, <0 37 4>, <0 38 4>; + reg = <0x0 0xff110000 0x1000>; + timer-width = <32>; + }; + + ttc1: timer@ff120000 { + compatible = "cdns,ttc"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 39 4>, <0 40 4>, <0 41 4>; + reg = <0x0 0xff120000 0x1000>; + timer-width = <32>; + }; + + ttc2: timer@ff130000 { + compatible = "cdns,ttc"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 42 4>, <0 43 4>, <0 44 4>; + reg = <0x0 0xff130000 0x1000>; + timer-width = <32>; + }; + + ttc3: timer@ff140000 { + compatible = "cdns,ttc"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 45 4>, <0 46 4>, <0 47 4>; + reg = <0x0 0xff140000 0x1000>; + timer-width = <32>; + }; + + uart0: serial@ff000000 { + compatible = "cdns,uart-r1p8"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 21 4>; + reg = <0x0 0xff000000 0x1000>; + clock-names = "uart_clk", "pclk"; + }; + + uart1: serial@ff010000 { + compatible = "cdns,uart-r1p8"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 22 4>; + reg = <0x0 0xff010000 0x1000>; + clock-names = "uart_clk", "pclk"; + }; + + usb0: usb@fe200000 { + compatible = "snps,dwc3"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 65 4>; + reg = <0x0 0xfe200000 0x40000>; + clock-names = "clk_xin", "clk_ahb"; + }; + + usb1: usb@fe300000 { + compatible = "snps,dwc3"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 70 4>; + reg = <0x0 0xfe300000 0x40000>; + clock-names = "clk_xin", "clk_ahb"; + }; + + watchdog0: watchdog@fd4d0000 { + compatible = "cdns,wdt-r1p2"; + status = "disabled"; + interrupt-parent = <&gic>; + interrupts = <0 52 1>; + reg = <0x0 0xfd4d0000 0x1000>; + timeout-sec = <10>; + }; + + xilinx_drm: xilinx_drm { + compatible = "xlnx,drm"; + status = "disabled"; + xlnx,encoder-slave = <&xlnx_dp>; + xlnx,connector-type = "DisplayPort"; + xlnx,dp-sub = <&xlnx_dp_sub>; + planes { + xlnx,pixel-format = "rgb565"; + plane0 { + dmas = <&xlnx_dpdma 3>; + dma-names = "dma"; + }; + plane1 { + dmas = <&xlnx_dpdma 0>; + dma-names = "dma"; + }; + }; + }; + + xlnx_dp: dp@43c00000 { + compatible = "xlnx,v-dp"; + status = "disabled"; + reg = <0x0 0xfd4a0000 0x1000>; + interrupts = <0 119 4>; + interrupt-parent = <&gic>; + clock-names = "aclk", "aud_clk"; + xlnx,dp-version = "v1.2"; + xlnx,max-lanes = <2>; + xlnx,max-link-rate = <540000>; + xlnx,max-bpc = <16>; + xlnx,enable-ycrcb; + xlnx,colormetry = "rgb"; + xlnx,bpc = <8>; + xlnx,audio-chan = <2>; + xlnx,dp-sub = <&xlnx_dp_sub>; + }; + + xlnx_dp_snd_card: dp_snd_card { + compatible = "xlnx,dp-snd-card"; + status = "disabled"; + xlnx,dp-snd-pcm = <&xlnx_dp_snd_pcm0>, <&xlnx_dp_snd_pcm1>; + xlnx,dp-snd-codec = <&xlnx_dp_snd_codec0>; + }; + + xlnx_dp_snd_codec0: dp_snd_codec0 { + compatible = "xlnx,dp-snd-codec"; + status = "disabled"; + clock-names = "aud_clk"; + }; + + xlnx_dp_snd_pcm0: dp_snd_pcm0 { + compatible = "xlnx,dp-snd-pcm"; + status = "disabled"; + dmas = <&xlnx_dpdma 4>; + dma-names = "tx"; + }; + + xlnx_dp_snd_pcm1: dp_snd_pcm1 { + compatible = "xlnx,dp-snd-pcm"; + status = "disabled"; + dmas = <&xlnx_dpdma 5>; + dma-names = "tx"; + }; + + xlnx_dp_sub: dp_sub@43c0a000 { + compatible = "xlnx,dp-sub"; + status = "disabled"; + reg = <0x0 0xfd4aa000 0x1000>, <0x0 0xfd4ab000 0x1000>, <0x0 0xfd4ac000 0x1000>; + reg-names = "blend", "av_buf", "aud"; + xlnx,output-fmt = "rgb"; + }; + + xlnx_dpdma: dma@fd4c0000 { + compatible = "xlnx,dpdma"; + status = "disabled"; + reg = <0x0 0xfd4c0000 0x1000>; + interrupts = <0 122 4>; + interrupt-parent = <&gic>; + clock-names = "axi_clk"; + dma-channels = <6>; + #dma-cells = <1>; + dma-video0channel@43c10000 { + compatible = "xlnx,video0"; + }; + dma-video1channel@43c10000 { + compatible = "xlnx,video1"; + }; + dma-video2channel@43c10000 { + compatible = "xlnx,video2"; + }; + dma-graphicschannel@43c10000 { + compatible = "xlnx,graphics"; + }; + dma-audio0channel@43c10000 { + compatible = "xlnx,audio0"; + }; + dma-audio1channel@43c10000 { + compatible = "xlnx,audio1"; + }; + }; + }; +};
Michal Simek
