[PATCH 0/7] arm: mvebu: Support for 98DX25xx/98DX35xx (AlleyCat5)
These patches are based on Marvell's bootloader for the AlleyCat5/5X which was based on u-boot 2018.03. I've split that code into consumable chunks and dropped as much unnecessary stuff as I can. I've also tried to sync the device trees as much as possible with the support that will land in Linux 6.0 although there are still some differences
Chris Packham (7): net: mvneta: Add support for AlleyCat5 usb: ehci: ehci-marvell: Support for marvell,ac5-ehci pinctrl: mvebu: Add AlleyCat5 support misc: mvebu: Add sample at reset driver arm: mvebu: Support for 98DX25xx/98DX35xx SoC arm: mvebu: Add RD-AC5X board tools: kwboot: Add knowledge of Marvell's TIM
arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx25xx.dtsi | 292 +++++++++++++++++++++ arch/arm/dts/ac5-98dx35xx-rd.dts | 155 +++++++++++ arch/arm/dts/ac5-98dx35xx.dtsi | 17 ++ arch/arm/mach-mvebu/Kconfig | 14 +- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/alleycat5/Makefile | 9 + arch/arm/mach-mvebu/alleycat5/clock.c | 49 ++++ arch/arm/mach-mvebu/alleycat5/cpu.c | 129 +++++++++ arch/arm/mach-mvebu/alleycat5/soc.c | 229 ++++++++++++++++ arch/arm/mach-mvebu/arm64-common.c | 15 ++ arch/arm/mach-mvebu/include/mach/clock.h | 11 + arch/arm/mach-mvebu/include/mach/cpu.h | 4 + arch/arm/mach-mvebu/include/mach/soc.h | 4 + board/Marvell/mvebu_alleycat-5/MAINTAINERS | 6 + board/Marvell/mvebu_alleycat-5/Makefile | 3 + board/Marvell/mvebu_alleycat-5/board.c | 35 +++ configs/mvebu_ac5_rd_defconfig | 89 +++++++ drivers/misc/Kconfig | 6 + drivers/misc/Makefile | 1 + drivers/misc/mvebu_sar/Makefile | 4 + drivers/misc/mvebu_sar/ac5_sar.c | 119 +++++++++ drivers/misc/mvebu_sar/sar-uclass.c | 146 +++++++++++ drivers/net/Kconfig | 2 +- drivers/net/mvneta.c | 66 ++++- drivers/pinctrl/mvebu/Kconfig | 2 +- drivers/usb/host/Kconfig | 1 + drivers/usb/host/ehci-marvell.c | 57 +++- include/configs/mvebu_alleycat-5.h | 92 +++++++ include/dm/uclass-id.h | 1 + include/fdtdec.h | 4 + include/mvebu/mvebu_chip_sar.h | 73 ++++++ include/mvebu/sar.h | 57 ++++ include/mvebu/var.h | 28 ++ include/sar-uclass.h | 23 ++ lib/fdtdec.c | 6 +- tools/kwbimage.h | 29 ++ tools/kwboot.c | 3 + 38 files changed, 1767 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx25xx.dtsi create mode 100644 arch/arm/dts/ac5-98dx35xx-rd.dts create mode 100644 arch/arm/dts/ac5-98dx35xx.dtsi create mode 100644 arch/arm/mach-mvebu/alleycat5/Makefile create mode 100644 arch/arm/mach-mvebu/alleycat5/clock.c create mode 100644 arch/arm/mach-mvebu/alleycat5/cpu.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.c create mode 100644 arch/arm/mach-mvebu/include/mach/clock.h create mode 100644 board/Marvell/mvebu_alleycat-5/MAINTAINERS create mode 100644 board/Marvell/mvebu_alleycat-5/Makefile create mode 100644 board/Marvell/mvebu_alleycat-5/board.c create mode 100644 configs/mvebu_ac5_rd_defconfig create mode 100644 drivers/misc/mvebu_sar/Makefile create mode 100644 drivers/misc/mvebu_sar/ac5_sar.c create mode 100644 drivers/misc/mvebu_sar/sar-uclass.c create mode 100644 include/configs/mvebu_alleycat-5.h create mode 100644 include/mvebu/mvebu_chip_sar.h create mode 100644 include/mvebu/sar.h create mode 100644 include/mvebu/var.h create mode 100644 include/sar-uclass.h
Add support for the AlleyCat5 SoC. This lacks the mbus from the other users of the mvneta.c driver so a new compatible string is needed to allow for a different window configuration.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
drivers/net/Kconfig | 2 +- drivers/net/mvneta.c | 66 ++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 64 insertions(+), 4 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6bbbadc5ee..8df3dce6df 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -448,7 +448,7 @@ config MVGBE
config MVNETA bool "Marvell Armada XP/385/3700 network interface support" - depends on ARMADA_XP || ARMADA_38X || ARMADA_3700 + depends on ARMADA_XP || ARMADA_38X || ARMADA_3700 || ALLEYCAT_5 select PHYLIB select DM_MDIO help diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index d2c42c4396..07919d6d35 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -91,6 +91,8 @@ DECLARE_GLOBAL_DATA_PTR; #define MVNETA_WIN_SIZE_MASK (0xffff0000) #define MVNETA_BASE_ADDR_ENABLE 0x2290 #define MVNETA_BASE_ADDR_ENABLE_BIT 0x1 +#define MVNETA_AC5_CNM_DDR_TARGET 0x2 +#define MVNETA_AC5_CNM_DDR_ATTR 0xb #define MVNETA_PORT_ACCESS_PROTECT 0x2294 #define MVNETA_PORT_ACCESS_PROTECT_WIN0_RW 0x3 #define MVNETA_PORT_CONFIG 0x2400 @@ -282,6 +284,8 @@ struct mvneta_port { struct gpio_desc phy_reset_gpio; struct gpio_desc sfp_tx_disable_gpio; #endif + + uintptr_t dma_base; /* base address for DMA address decoding */ };
/* The mvneta_tx_desc and mvneta_rx_desc structures describe the @@ -513,10 +517,19 @@ static void mvneta_rxq_desc_num_update(struct mvneta_port *pp, static struct mvneta_rx_desc * mvneta_rxq_next_desc_get(struct mvneta_rx_queue *rxq) { + struct mvneta_rx_desc *curr; int rx_desc = rxq->next_desc_to_proc;
+ /* validate RX descriptor */ + curr = rxq->descs + rx_desc; + if (curr->data_size == 0) { + /* do it to read real descriptor next time */ + DSB; + return NULL; + } + rxq->next_desc_to_proc = MVNETA_QUEUE_NEXT_DESC(rxq, rx_desc); - return rxq->descs + rx_desc; + return curr; }
/* Tx descriptors helper methods */ @@ -1343,6 +1356,29 @@ static void mvneta_conf_mbus_windows(struct mvneta_port *pp) mvreg_write(pp, MVNETA_BASE_ADDR_ENABLE, win_enable); }
+static void mvneta_conf_ac5_cnm_xbar_windows(struct mvneta_port *pp) +{ + int i; + + /* Clear all windows */ + for (i = 0; i < 6; i++) { + mvreg_write(pp, MVNETA_WIN_BASE(i), 0); + mvreg_write(pp, MVNETA_WIN_SIZE(i), 0); + + if (i < 4) + mvreg_write(pp, MVNETA_WIN_REMAP(i), 0); + } + + /* + * Setup window #0 base 0x0 to target XBAR port 2 (AMB2), attribute 0xb, size 4GB + * AMB2 address decoder remaps 0x0 to DDR 64 bit base address + */ + mvreg_write(pp, MVNETA_WIN_BASE(0), + (MVNETA_AC5_CNM_DDR_ATTR << 8) | MVNETA_AC5_CNM_DDR_TARGET); + mvreg_write(pp, MVNETA_WIN_SIZE(0), 0xffff0000); + mvreg_write(pp, MVNETA_BASE_ADDR_ENABLE, 0x3e); +} + /* Power up the port */ static int mvneta_port_power_up(struct mvneta_port *pp, int phy_mode) { @@ -1508,11 +1544,15 @@ static int mvneta_recv(struct udevice *dev, int flags, uchar **packetp) */ rx_desc = mvneta_rxq_next_desc_get(rxq);
+ if (!rx_desc) + return 0; + rx_status = rx_desc->status; if (!mvneta_rxq_desc_is_first_last(rx_status) || (rx_status & MVNETA_RXD_ERR_SUMMARY)) { mvneta_rx_error(pp, rx_desc); - /* leave the descriptor untouched */ + /* invalidate the descriptor */ + rx_desc->data_size = 0; return -EIO; }
@@ -1525,13 +1565,15 @@ static int mvneta_recv(struct udevice *dev, int flags, uchar **packetp) * No cache invalidation needed here, since the rx_buffer's are * located in a uncached memory region */ - *packetp = data; + *packetp = data + pp->dma_base;
/* * Only mark one descriptor as free * since only one was processed */ mvneta_rxq_desc_num_update(pp, rxq, 1, 1); + /* invalidate the descriptor */ + rx_desc->data_size = 0; }
return rx_bytes; @@ -1544,6 +1586,11 @@ static int mvneta_probe(struct udevice *dev) struct ofnode_phandle_args sfp_args; #endif void *bd_space; + void *blob = (void *)gd->fdt_blob; + int node = dev_of_offset(dev); + const int *cell; + int len; +
/* * Allocate buffer area for descs and rx_buffers. This is only @@ -1577,9 +1624,21 @@ static int mvneta_probe(struct udevice *dev) /* Configure MBUS address windows */ if (device_is_compatible(dev, "marvell,armada-3700-neta")) mvneta_bypass_mbus_windows(pp); + else if (device_is_compatible(dev, "marvell,armada-ac5-neta")) + mvneta_conf_ac5_cnm_xbar_windows(pp); else mvneta_conf_mbus_windows(pp);
+ /* fetch dma ranges property */ + cell = fdt_getprop(blob, node, "dma-ranges", &len); + if (cell && len >= 4 * sizeof(int)) { + /* RAZA - TODO do that in loop by address-cells size */ + pp->dma_base = fdt32_to_cpu(cell[1]); + pp->dma_base = (pp->dma_base << 32) | fdt32_to_cpu(cell[2]); + } else { + pp->dma_base = 0; + } + #if CONFIG_IS_ENABLED(DM_GPIO) if (!dev_read_phandle_with_args(dev, "sfp", NULL, 0, 0, &sfp_args) && ofnode_is_enabled(sfp_args.node)) @@ -1620,6 +1679,7 @@ static const struct eth_ops mvneta_ops = {
static const struct udevice_id mvneta_ids[] = { { .compatible = "marvell,armada-370-neta" }, + { .compatible = "marvell,armada-ac5-neta" }, { .compatible = "marvell,armada-xp-neta" }, { .compatible = "marvell,armada-3700-neta" }, { }
Unlike the other 64-bit mvebu SoCs the AlleyCat5 uses the older ehci block from the 32-bit SoCs. Adapt the ehci-marvell.c driver to cope with the fact that the ac5 does not have the mbus infrastructure the 32-bit SoCs have and ensure USB_EHCI_IS_TDI is selected.
drivers/usb/host/Kconfig | 1 + drivers/usb/host/ehci-marvell.c | 57 +++++++++++++++++++++++++++------ 2 files changed, 48 insertions(+), 10 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index a0f48f09a7..628078f495 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -178,6 +178,7 @@ config USB_EHCI_MARVELL depends on ARCH_MVEBU || ARCH_KIRKWOOD || ARCH_ORION5X default y select USB_EHCI_IS_TDI if !ARM64 + select USB_EHCI_IS_TDI if ALLEYCAT_5 ---help--- Enables support for the on-chip EHCI controller on MVEBU SoCs.
diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index b7e60c690a..7d859b9cce 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -48,12 +48,17 @@ struct ehci_mvebu_priv { fdt_addr_t hcd_base; };
+#define USB_TO_DRAM_TARGET_ID 0x2 +#define USB_TO_DRAM_ATTR_ID 0x0 +#define USB_DRAM_BASE 0x00000000 +#define USB_DRAM_SIZE 0xfff /* don't overrun u-boot source (was 0xffff) */ + /* * Once all the older Marvell SoC's (Orion, Kirkwood) are converted * to the common mvebu archticture including the mbus setup, this * will be the only function needed to configure the access windows */ -static void usb_brg_adrdec_setup(void *base) +static void usb_brg_adrdec_setup(struct udevice *dev, void *base) { const struct mbus_dram_target_info *dram; int i; @@ -65,16 +70,34 @@ static void usb_brg_adrdec_setup(void *base) writel(0, base + USB_WINDOW_BASE(i)); }
- for (i = 0; i < dram->num_cs; i++) { - const struct mbus_dram_window *cs = dram->cs + i; + if (device_is_compatible(dev, "marvell,ac5-ehci")) { + /* + * use decoding window to map dram address seen by usb to 0x0 + */
/* Write size, attributes and target id to control register */ - writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | - (dram->mbus_dram_target_id << 4) | 1, - base + USB_WINDOW_CTRL(i)); + writel((USB_DRAM_SIZE << 16) | (USB_TO_DRAM_ATTR_ID << 8) | + (USB_TO_DRAM_TARGET_ID << 4) | 1, + base + USB_WINDOW_CTRL(0));
/* Write base address to base register */ - writel(cs->base, base + USB_WINDOW_BASE(i)); + writel(USB_DRAM_BASE, base + USB_WINDOW_BASE(0)); + + debug("## AC5 decoding windows, ctrl[%p]=0x%x, base[%p]=0x%x\n", + base + USB_WINDOW_CTRL(0), readl(base + USB_WINDOW_CTRL(0)), + base + USB_WINDOW_BASE(0), readl(base + USB_WINDOW_BASE(0))); + } else { + for (i = 0; i < dram->num_cs; i++) { + const struct mbus_dram_window *cs = dram->cs + i; + + /* Write size, attributes and target id to control register */ + writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | + (dram->mbus_dram_target_id << 4) | 1, + base + USB_WINDOW_CTRL(i)); + + /* Write base address to base register */ + writel(cs->base, base + USB_WINDOW_BASE(i)); + } } }
@@ -126,15 +149,28 @@ static int ehci_mvebu_probe(struct udevice *dev) if (device_is_compatible(dev, "marvell,armada-3700-ehci")) marvell_ehci_ops.powerup_fixup = marvell_ehci_powerup_fixup; else - usb_brg_adrdec_setup((void *)priv->hcd_base); + usb_brg_adrdec_setup(dev, (void *)priv->hcd_base);
hccr = (struct ehci_hccr *)(priv->hcd_base + 0x100); hcor = (struct ehci_hcor *) ((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
debug("ehci-marvell: init hccr %lx and hcor %lx hc_length %ld\n", - (uintptr_t)hccr, (uintptr_t)hcor, - (uintptr_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + (uintptr_t)hccr, (uintptr_t)hcor, + (uintptr_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + +#define PHY_CALIB_OFFSET 0x808 + /* + * Trigger calibration during each usb start/reset: + * BIT 13 to 0, and then to 1 + */ + if (device_is_compatible(dev, "marvell,ac5-ehci")) { + void *phy_calib_reg = (void *)(priv->hcd_base + PHY_CALIB_OFFSET); + u32 val = readl(phy_calib_reg) & (~BIT(13)); + + writel(val, phy_calib_reg); + writel(val | BIT(13), phy_calib_reg); + }
return ehci_register(dev, hccr, hcor, &marvell_ehci_ops, 0, USB_INIT_HOST); @@ -143,6 +179,7 @@ static int ehci_mvebu_probe(struct udevice *dev) static const struct udevice_id ehci_usb_ids[] = { { .compatible = "marvell,orion-ehci", }, { .compatible = "marvell,armada-3700-ehci", }, + { .compatible = "marvell,ac5-ehci", }, { } };
This uses the same IP block as the Armada-8K SoCs.
drivers/pinctrl/mvebu/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/mvebu/Kconfig b/drivers/pinctrl/mvebu/Kconfig index 574fb4dfb0..7c51d138c8 100644 --- a/drivers/pinctrl/mvebu/Kconfig +++ b/drivers/pinctrl/mvebu/Kconfig @@ -15,7 +15,7 @@ config PINCTRL_ARMADA_37XX Marvell's Armada-37xx SoC.
config PINCTRL_ARMADA_8K - depends on ARMADA_8K && PINCTRL_FULL + depends on (ARMADA_8K || ALLEYCAT_5) && PINCTRL_FULL bool "Armada 7k/8k pin control driver" help Support pin multiplexing and pin configuration control on
Add a new UCLASS_SAR, the generic SAR code and an Alleycat5 driver. This has been adapted from the Marvell SDK but only the AC5 driver has been brought through (other drivers exist for the ap806, ap807 and cp110 IP blocks).
drivers/misc/Kconfig | 6 ++ drivers/misc/Makefile | 1 + drivers/misc/mvebu_sar/Makefile | 4 + drivers/misc/mvebu_sar/ac5_sar.c | 119 +++++++++++++++++++++++ drivers/misc/mvebu_sar/sar-uclass.c | 146 ++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/fdtdec.h | 4 + include/mvebu/mvebu_chip_sar.h | 73 ++++++++++++++ include/mvebu/sar.h | 57 +++++++++++ include/mvebu/var.h | 28 ++++++ include/sar-uclass.h | 23 +++++ lib/fdtdec.c | 6 +- 12 files changed, 467 insertions(+), 1 deletion(-) create mode 100644 drivers/misc/mvebu_sar/Makefile create mode 100644 drivers/misc/mvebu_sar/ac5_sar.c create mode 100644 drivers/misc/mvebu_sar/sar-uclass.c create mode 100644 include/mvebu/mvebu_chip_sar.h create mode 100644 include/mvebu/sar.h create mode 100644 include/mvebu/var.h create mode 100644 include/sar-uclass.h
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index a6da6e215d..4e99ef29d9 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -645,4 +645,10 @@ config SL28CPLD the base driver which provides common access methods for the sub-drivers.
+config MVEBU_SAR + bool "MVEBU SAR driver" + depends on ARCH_MVEBU + help + Support MVEBU SAR driver + endmenu diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index d494639cd9..3cf976edd8 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -62,6 +62,7 @@ obj-$(CONFIG_NUVOTON_NCT6102D) += nuvoton_nct6102d.o obj-$(CONFIG_P2SB) += p2sb-uclass.o obj-$(CONFIG_PCA9551_LED) += pca9551_led.o obj-$(CONFIG_$(SPL_)PWRSEQ) += pwrseq-uclass.o +obj-$(CONFIG_MVEBU_SAR) += mvebu_sar/ ifdef CONFIG_QFW obj-y += qfw.o obj-$(CONFIG_QFW_PIO) += qfw_pio.o diff --git a/drivers/misc/mvebu_sar/Makefile b/drivers/misc/mvebu_sar/Makefile new file mode 100644 index 0000000000..6f339fb7b4 --- /dev/null +++ b/drivers/misc/mvebu_sar/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_MVEBU_SAR) += sar-uclass.o +obj-$(CONFIG_ALLEYCAT_5) += ac5_sar.o diff --git a/drivers/misc/mvebu_sar/ac5_sar.c b/drivers/misc/mvebu_sar/ac5_sar.c new file mode 100644 index 0000000000..67b2110bc8 --- /dev/null +++ b/drivers/misc/mvebu_sar/ac5_sar.c @@ -0,0 +1,119 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <fdtdec.h> +#include <mvebu/mvebu_chip_sar.h> +#include <dm.h> + +#include <sar-uclass.h> + +#define MHz 1000000 + +#define BIT_VAL(b) ((1ULL << ((b) + 1)) - 1) +#define BIT_RANGE(Bl, Bh) (BIT_VAL(Bh) - BIT_VAL((Bl) - 1)) + +#define PLL_MAX_CHOICE 4 + +#define CPU_TYPE_AC5 0 +#define CPU_TYPE_AC5x 1 +#define CPU_TYPE_LAST 2 + +static const u32 pll_freq_tbl[CPU_TYPE_LAST][SAR_AP_FABRIC_FREQ + 1][PLL_MAX_CHOICE] = { + [CPU_TYPE_AC5] = { + [SAR_CPU_FREQ] = { + 800 * MHz, 1200 * MHz, 1400 * MHz, 1000 * MHz + }, + [SAR_DDR_FREQ] = { + 1200 * MHz, 800 * MHz, 0, 0 + }, + [SAR_AP_FABRIC_FREQ] = { + 396 * MHz, 290 * MHz, 197 * MHz, 0 + }, + }, + [CPU_TYPE_AC5x] = { + [SAR_CPU_FREQ] = { + 800 * MHz, 1200 * MHz, 1500 * MHz, 1600 * MHz + }, + [SAR_DDR_FREQ] = { + 1200 * MHz, 800 * MHz, 0, 0 + }, + [SAR_AP_FABRIC_FREQ] = { + 0, 0, 0, 0 + } + } +}; + +static const u32 soc_sar_masks_tbl[CPU_TYPE_LAST][SAR_AP_FABRIC_FREQ + 1] = { + [CPU_TYPE_AC5] = { + [SAR_CPU_FREQ] = BIT_RANGE(18, 20), + [SAR_DDR_FREQ] = BIT_RANGE(16, 17), + [SAR_AP_FABRIC_FREQ] = BIT_RANGE(22, 23), + }, + [CPU_TYPE_AC5x] = { + [SAR_CPU_FREQ] = BIT_RANGE(8, 10), + [SAR_DDR_FREQ] = BIT_RANGE(6, 7), + [SAR_AP_FABRIC_FREQ] = 1, + }, +}; + +static int ac5_sar_value_get(struct udevice *dev, enum mvebu_sar_opts sar_opt, + struct sar_val *val) +{ + u32 *pSarBase = (u32 *)(((struct dm_sar_pdata *)dev_get_priv(dev))->sar_base); + u32 sar_reg_val = readl(pSarBase); + u32 mask; + unsigned char choice; + int cpu_type = ((readl(0x7f90004c) & 0xFF000) >> 12) == 0x98 ? CPU_TYPE_AC5x : CPU_TYPE_AC5; + + if (sar_opt > SAR_AP_FABRIC_FREQ) { + pr_err("AC5-SAR: Unsupported SAR option %d.\n", sar_opt); + return -EINVAL; + } + + mask = soc_sar_masks_tbl[cpu_type][sar_opt]; + /* The choice within the bits allocated for a specific PLL */ + choice = (sar_reg_val & mask) >> (__builtin_ffs(mask) - 1); + + val->freq = pll_freq_tbl[cpu_type][sar_opt][choice]; + return 0; +} + +static int ac5_sar_init(struct udevice *dev) +{ + int ret, i; + + u32 sar_list[] = { + SAR_CPU_FREQ, + SAR_DDR_FREQ, + SAR_AP_FABRIC_FREQ + }; + + for (i = 0; i < ARRAY_SIZE(sar_list); i++) { + ret = mvebu_sar_id_register(dev, sar_list[i]); + if (ret) { + pr_err("Failed to register SAR %d, for AC5\n", + sar_list[i]); + return ret; + } + } + + return 0; +} + +static const struct sar_ops ac5_sar_ops = { + .sar_init_func = ac5_sar_init, + .sar_value_get_func = ac5_sar_value_get, + .sar_dump_func = NULL, +}; + +U_BOOT_DRIVER(ac5_sar) = { + .name = "ac5_sar", + .id = UCLASS_SAR, + .priv_auto = sizeof(struct dm_sar_pdata), + .ops = &ac5_sar_ops, +}; diff --git a/drivers/misc/mvebu_sar/sar-uclass.c b/drivers/misc/mvebu_sar/sar-uclass.c new file mode 100644 index 0000000000..d9cb019d5d --- /dev/null +++ b/drivers/misc/mvebu_sar/sar-uclass.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <fdtdec.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <sar-uclass.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define SAR_MAX_CHIP 4 + +UCLASS_DRIVER(sar) = { + .name = "sar", + .id = UCLASS_SAR, +}; + +struct udevice *__section(".data") soc_sar_info[SAR_MAX_IDX]; + +int mvebu_sar_id_register(struct udevice *dev, u32 sar_id) +{ + if (soc_sar_info[sar_id]) { + pr_err("sar %d was already registered.\n", sar_id); + return -EBUSY; + } + soc_sar_info[sar_id] = dev; + + return 0; +} + +/* find all drivers for sar device and initialize each driver */ +int mvebu_sar_init(void) +{ + int ret, i; + int node, chip_count, sar_list[SAR_MAX_CHIP]; + const void *blob = gd->fdt_blob; + struct udevice *sar_chip[SAR_MAX_CHIP]; + struct dm_sar_pdata *priv; + const struct sar_ops *ops; + struct udevice *parent; + struct driver_info sar_drivers[SAR_MAX_CHIP]; + void *sar_base = NULL; + const char *sar_driver, *sar_name; + + chip_count = fdtdec_find_aliases_for_id(blob, "sar-reg", + COMPAT_MVEBU_SAR_REG_COMMON, + sar_list, SAR_MAX_CHIP); + + if (chip_count <= 0) { + pr_err("Cannot find sample-at-reset dt entry (%d).\n", + chip_count); + return -ENODEV; + } + uclass_get_device_by_name(UCLASS_ROOT, "root_driver", &parent); + memset(soc_sar_info, 0, sizeof(soc_sar_info)); + + for (i = 0; i < chip_count ; i++) { + node = sar_list[i]; + if (node <= 0) + continue; + + /* Skip if Node is disabled */ + if (!fdtdec_get_is_enabled(blob, node)) + continue; + /* Binding stage */ + sar_driver = fdt_getprop(blob, node, "sar-driver", NULL); + sar_drivers[i].name = sar_driver; + ret = device_bind_by_name(parent, false, + &sar_drivers[i], &sar_chip[i]); + + if (!sar_chip[i]) { + pr_err("SAR driver binding failed\n"); + return 0; + } + + /* fetch driver info from device-tree */ + sar_base = (void *)fdtdec_get_addr_size_auto_noparent(blob, + node, "reg", 0, NULL, true); + if (!sar_base) { + pr_err("SAR address isn't found in the device-tree\n"); + return 0; + } + sar_name = fdt_getprop(blob, node, "sar-name", NULL); + /* Initialize driver priv struct */ + device_probe(sar_chip[i]); + priv = dev_get_priv(sar_chip[i]); + priv->sar_base = sar_base; + priv->sar_name = sar_name; + ops = device_get_ops(sar_chip[i]); + if (!ops->sar_init_func) + return -EINVAL; + + ret = ops->sar_init_func(sar_chip[i]); + if (ret) { + pr_err("sar_init failed (%d).\n", ret); + return ret; + } + } + + return 0; +} + +int mvebu_sar_value_get(enum mvebu_sar_opts opt, struct sar_val *val) +{ + const struct sar_ops *ops; + + if (soc_sar_info[opt]) { + ops = device_get_ops(soc_sar_info[opt]); + return ops->sar_value_get_func(soc_sar_info[opt], opt, val); + } + + pr_err("SAR - No chip registered on sar %d.\n", opt); + return -ENODEV; +} + +char *mvebu_sar_bootsrc_to_name(enum mvebu_bootsrc_type src) +{ + switch (src) { + case(BOOTSRC_NAND): + return "nand"; + case(BOOTSRC_SPI): + case(BOOTSRC_AP_SPI): + return "spi"; + case(BOOTSRC_SD_EMMC): + case(BOOTSRC_AP_SD_EMMC): + return "mmc"; + case(BOOTSRC_NOR): + return "nor"; + default: + return "unknown"; + } +} + +void mvebu_sar_dump(struct udevice *dev) +{ + const struct sar_ops *ops; + + ops = device_get_ops(dev); + + ops->sar_dump_func(dev); +} diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..2213e76d38 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -107,6 +107,7 @@ enum uclass_id { UCLASS_RESET, /* Reset controller device */ UCLASS_RNG, /* Random Number Generator */ UCLASS_RTC, /* Real time clock device */ + UCLASS_SAR, /* Reset Sample Configuration */ UCLASS_SCMI_AGENT, /* Interface with an SCMI server */ UCLASS_SCSI, /* SCSI device */ UCLASS_SERIAL, /* Serial UART */ diff --git a/include/fdtdec.h b/include/fdtdec.h index 12355afd7f..d8923ba443 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -199,6 +199,10 @@ enum fdt_compat_id { COMPAT_ALTERA_SOCFPGA_FPGA0, /* SOCFPGA FPGA manager */ COMPAT_ALTERA_SOCFPGA_NOC, /* SOCFPGA Arria 10 NOC */ COMPAT_ALTERA_SOCFPGA_CLK_INIT, /* SOCFPGA Arria 10 clk init */ + COMPAT_MVEBU_SAR, /* Marvell Sampled-at-Reset */ + COMPAT_MVEBU_SAR_REG_COMMON, /* Marvell Sampled-at-Reset Common */ + COMPAT_MVEBU_SAR_REG_AP806, /* Marvell Sampled-at-Reset for ap806/ap807 */ + COMPAT_MVEBU_SAR_REG_CP110, /* Marvell Sampled-at-Reset for cp110 */
COMPAT_COUNT, }; diff --git a/include/mvebu/mvebu_chip_sar.h b/include/mvebu/mvebu_chip_sar.h new file mode 100644 index 0000000000..4781aa06c4 --- /dev/null +++ b/include/mvebu/mvebu_chip_sar.h @@ -0,0 +1,73 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef _MVEBU_CHIP_SAR_H_ +#define _MVEBU_CHIP_SAR_H_ + +#include <asm/types.h> + +struct udevice; + +/* + * List of boot source options. + * Return value for each of the options: + * - SAR_CPU_FREQ: Frequency (Hz) + * - SAR_DDR_FREQ: Frequency (Hz) + * - SAR_AP_FABRIC_FREQ: Frequency (Hz) + * - SAR_CP_FABRIC_FREQ: Frequency (Hz) + * - SAR_BOOT_SRC: Boot source type (see mvebu_bootsrc_type) + */ +enum mvebu_sar_opts { + SAR_CPU_FREQ = 0, + SAR_DDR_FREQ, + SAR_AP_FABRIC_FREQ, + SAR_CP_FABRIC_FREQ, + SAR_CP0_PCIE0_CLK, + SAR_CP0_PCIE1_CLK, + SAR_CP1_PCIE0_CLK, + SAR_CP1_PCIE1_CLK, + SAR_BOOT_SRC, + SAR_MAX_IDX +}; + +enum mvebu_bootsrc_type { + BOOTSRC_NAND, + BOOTSRC_SPI, + BOOTSRC_AP_SPI, + BOOTSRC_SD_EMMC, + BOOTSRC_AP_SD_EMMC, + BOOTSRC_NOR, + BOOTSRC_MAX_IDX +}; + +/* + * sample-at-reset information + * raw_sar_val: Raw value out of the sample-at-reset register. + * This is hw dependent and should not be used for comparison + * purposes (useful for debug, or verbose information). + * bootsrc (SAR_BOOT_SRC): + * type: Boot source interface type. + * index: When applicable, indicates the interface index (e.g. SPI #1, + * NAND #0). + * freq: Frequency in Hz. + */ +struct sar_val { + u32 raw_sar_val; + union { + struct { + enum mvebu_bootsrc_type type; + int index; + } bootsrc; + u32 freq; + u32 clk_direction; /* input = 0 */ + }; +}; + +int mvebu_sar_init(void); +int mvebu_sar_value_get(enum mvebu_sar_opts opt, struct sar_val *val); +void mvebu_sar_dump(struct udevice *dev); +char *mvebu_sar_bootsrc_to_name(enum mvebu_bootsrc_type src); + +#endif /* _MVEBU_CHIP_SAR_H_ */ diff --git a/include/mvebu/sar.h b/include/mvebu/sar.h new file mode 100644 index 0000000000..bd0837d6a3 --- /dev/null +++ b/include/mvebu/sar.h @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef _SAR_H_ +#define _SAR_H_ + +#include <linux/compiler.h> +#include <mvebu/var.h> + +#define MAX_SAR_CHIPS 4 +#define MAX_SAR 8 + +enum sar_variables { + CPUS_NUM_SAR = 0, + CPU0_ENDIANESS_SAR, + FREQ_SAR, + CPU_FREQ_SAR, + FAB_REQ_SAR, + BOOT_SRC_SAR, + BOOT_WIDTH_SAR, + PEX_MODE_SAR, + L2_SIZE_SAR, + DRAM_ECC_SAR, + DRAM_BUS_WIDTH_SAR, +}; + +struct sar_var { + u8 start_bit; + u8 bit_length; + u8 option_cnt; + u8 active; + bool swap_bit; + char *desc; + char *key; + struct var_opts option_desc[MAX_VAR_OPTIONS]; +}; + +struct sar_data { + u32 chip_addr[MAX_SAR_CHIPS]; + u8 chip_count; + u8 bit_width; + struct sar_var sar_lookup[MAX_SAR]; +}; + +int sar_read_all(void); +int sar_default_key(const char *key); +int sar_default_all(void); +int sar_write_key(const char *key, int val); +int sar_print_key(const char *key); +void sar_list_keys(void); +int sar_list_key_opts(const char *key); +int sar_is_available(void); +void sar_init(void); + +#endif /* _SAR_H_ */ diff --git a/include/mvebu/var.h b/include/mvebu/var.h new file mode 100644 index 0000000000..6bd315c841 --- /dev/null +++ b/include/mvebu/var.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef _VAR_H_ +#define _VAR_H_ + +#include <linux/compiler.h> + +#define INVALID_KEY 0xFF +#define MAX_VAR_OPTIONS 10 + +#define VAR_IS_DEFAULT 0x1 +#define VAR_IS_LAST 0x2 + +struct var_opts { + u8 value; + char *desc; + u8 flags; +}; + +struct var_desc { + char *key; + char *description; +}; + +#endif /* _VAR_H_ */ diff --git a/include/sar-uclass.h b/include/sar-uclass.h new file mode 100644 index 0000000000..8b9cc08847 --- /dev/null +++ b/include/sar-uclass.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <mvebu/mvebu_chip_sar.h> + +struct udevice; + +struct sar_ops { + int (*sar_init_func)(struct udevice *dev); + int (*sar_dump_func)(struct udevice *dev); + int (*sar_value_get_func)(struct udevice *dev, enum mvebu_sar_opts sar, + struct sar_val *val); + int (*sar_bootsrc_get)(struct udevice *dev, u32 *idx); +}; + +struct dm_sar_pdata { + void __iomem *sar_base; + const char *sar_name; +}; + +int mvebu_sar_id_register(struct udevice *dev, u32 sar_id); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 96b6b71a60..26e5c82bcd 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -74,7 +74,11 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(ALTERA_SOCFPGA_F2SDR2, "altr,socfpga-fpga2sdram2-bridge"), COMPAT(ALTERA_SOCFPGA_FPGA0, "altr,socfpga-a10-fpga-mgr"), COMPAT(ALTERA_SOCFPGA_NOC, "altr,socfpga-a10-noc"), - COMPAT(ALTERA_SOCFPGA_CLK_INIT, "altr,socfpga-a10-clk-init") + COMPAT(ALTERA_SOCFPGA_CLK_INIT, "altr,socfpga-a10-clk-init"), + COMPAT(MVEBU_SAR, "marvell,sample-at-reset"), + COMPAT(MVEBU_SAR_REG_COMMON, "marvell,sample-at-reset-common"), + COMPAT(MVEBU_SAR_REG_AP806, "marvell,sample-at-reset-ap806"), + COMPAT(MVEBU_SAR_REG_CP110, "marvell,sample-at-reset-cp110"), };
static const char *const fdt_src_name[] = {
Add support for the Allecat5/Alleycat5X SoC. These are L3 switches with an integrated CPU (referred to as the CnM block in Marvell's documentation). These have dual ARMv8.2 CPUs (Cortex-A55). This support has been ported from Marvell's SDK which is based on a much older version of U-Boot.
arch/arm/dts/ac5-98dx25xx.dtsi | 292 +++++++++++++++++++++++ arch/arm/dts/ac5-98dx35xx.dtsi | 17 ++ arch/arm/mach-mvebu/Kconfig | 5 + arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/alleycat5/Makefile | 9 + arch/arm/mach-mvebu/alleycat5/clock.c | 49 ++++ arch/arm/mach-mvebu/alleycat5/cpu.c | 129 ++++++++++ arch/arm/mach-mvebu/alleycat5/soc.c | 229 ++++++++++++++++++ arch/arm/mach-mvebu/arm64-common.c | 15 ++ arch/arm/mach-mvebu/include/mach/clock.h | 11 + arch/arm/mach-mvebu/include/mach/cpu.h | 4 + arch/arm/mach-mvebu/include/mach/soc.h | 4 + 12 files changed, 765 insertions(+) create mode 100644 arch/arm/dts/ac5-98dx25xx.dtsi create mode 100644 arch/arm/dts/ac5-98dx35xx.dtsi create mode 100644 arch/arm/mach-mvebu/alleycat5/Makefile create mode 100644 arch/arm/mach-mvebu/alleycat5/clock.c create mode 100644 arch/arm/mach-mvebu/alleycat5/cpu.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.c create mode 100644 arch/arm/mach-mvebu/include/mach/clock.h
diff --git a/arch/arm/dts/ac5-98dx25xx.dtsi b/arch/arm/dts/ac5-98dx25xx.dtsi new file mode 100644 index 0000000000..c31d2f08cf --- /dev/null +++ b/arch/arm/dts/ac5-98dx25xx.dtsi @@ -0,0 +1,292 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For AC5. + * + * Copyright (C) 2021 Marvell + * Copyright (C) 2022 Allied Telesis Labs + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + model = "Marvell AC5 SoC"; + compatible = "marvell,ac5"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a55"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a55"; + reg = <0x0 0x100>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + l2: l2-cache { + compatible = "cache"; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <GIC_PPI 12 IRQ_TYPE_LEVEL_HIGH>; + }; + + config-space { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "simple-bus"; + + sar-reg { + compatible = "marvell,sample-at-reset-common"; + sar-driver = "ac5_sar"; + sar-name = "ac5_sar"; + status = "okay"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + internal-regs@7f000000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + /* 16M internal register @ 0x7f00_0000 */ + ranges = <0x0 0x0 0x7f000000 0x1000000>; + dma-coherent; + + uart0: serial@12000 { + compatible = "snps,dw-apb-uart"; + reg = <0x12000 0x100>; + reg-shift = <2>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "okay"; + }; + + uart1: serial@12100 { + compatible = "snps,dw-apb-uart"; + reg = <0x12100 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + uart2: serial@12200 { + compatible = "snps,dw-apb-uart"; + reg = <0x12200 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + uart3: serial@12300 { + compatible = "snps,dw-apb-uart"; + reg = <0x12300 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + mdio: mdio@22004 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "marvell,orion-mdio"; + reg = <0x22004 0x4>; + clocks = <&cnm_clock>; + }; + + i2c0: i2c@11000 { + compatible = "marvell,mv78230-i2c"; + reg = <0x11000 0x20>; + #address-cells = <1>; + #size-cells = <0>; + + clocks = <&cnm_clock>; + clock-names = "core"; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency=<100000>; + status = "disabled"; + }; + + i2c1: i2c@11100 { + compatible = "marvell,mv78230-i2c"; + reg = <0x11100 0x20>; + #address-cells = <1>; + #size-cells = <0>; + + clocks = <&cnm_clock>; + clock-names = "core"; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency=<100000>; + status = "disabled"; + }; + + gpio0: gpio@18100 { + compatible = "marvell,orion-gpio"; + reg = <0x18100 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + status = "okay"; + }; + + gpio1: gpio@18140 { + reg = <0x18140 0x40>; + compatible = "marvell,orion-gpio"; + ngpios = <14>; + gpio-controller; + #gpio-cells = <2>; + status = "okay"; + }; + }; + + /* + * Dedicated section for devices behind 32bit controllers so we + * can configure specific DMA mapping for them + */ + behind-32bit-controller@7f000000 { + compatible = "simple-bus"; + #address-cells = <0x2>; + #size-cells = <0x2>; + ranges = <0x0 0x0 0x0 0x7f000000 0x0 0x1000000>; + /* Host phy ram starts at 0x200M */ + dma-ranges = <0x0 0x0 0x2 0x0 0x1 0x0>; + dma-coherent; + + eth0: ethernet@20000 { + compatible = "marvell,armada-ac5-neta"; + reg = <0x0 0x20000 0x0 0x4000>; + dma-ranges = <0 2 0 0x40000000>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cnm_clock>; + phy-mode = "sgmii"; + status = "disabled"; + }; + + eth1: ethernet@24000 { + compatible = "marvell,armada-ac5-neta"; + reg = <0x0 0x24000 0x0 0x4000>; + dma-ranges = <0 2 0 0x40000000>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cnm_clock>; + phy-mode = "sgmii"; + status = "disabled"; + }; + + usb0: usb@80000 { + compatible = "marvell,ac5-ehci"; + reg = <0x0 0x80000 0x0 0x500>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + usb1: usb@a0000 { + compatible = "marvell,ac5-ehci"; + reg = <0x0 0xa0000 0x0 0x500>; + interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + }; + + pinctrl0: pinctrl@80020100 { + compatible = "marvell,mvebu-pinctrl"; + reg = <0 0x80020100 0 0x20>; + pin-count = <46>; + max-func = <0xf>; + status = "okay"; + }; + + spi0: spi@805a0000 { + compatible = "marvell,armada-3700-spi"; + reg = <0x0 0x805a0000 0x0 0x50>; + #address-cells = <0x1>; + #size-cells = <0x0>; + clocks = <&spi_clock>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + num-cs = <1>; + status = "disabled"; + }; + + spi1: spi@805a8000 { + compatible = "marvell,armada-3700-spi"; + reg = <0x0 0x805a8000 0x0 0x50>; + #address-cells = <0x1>; + #size-cells = <0x0>; + clocks = <&spi_clock>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + num-cs = <1>; + status = "disabled"; + }; + + gic: interrupt-controller@80600000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x80600000 0x0 0x10000>, /* GICD */ + <0x0 0x80660000 0x0 0x40000>; /* GICR */ + interrupts = <GIC_PPI 6 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + clocks { + cnm_clock: cnm-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <328000000>; + }; + + spi_clock: spi-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + }; + }; +}; diff --git a/arch/arm/dts/ac5-98dx35xx.dtsi b/arch/arm/dts/ac5-98dx35xx.dtsi new file mode 100644 index 0000000000..2ab72f854b --- /dev/null +++ b/arch/arm/dts/ac5-98dx35xx.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For AC5X. + * + * Copyright (C) 2022 Allied Telesis Labs + */ + +#include "ac5-98dx25xx.dtsi" + +/ { + model = "Marvell AC5X SoC"; + compatible = "marvell,ac5x", "marvell,ac5"; +}; + +&cnm_clock { + clock-frequency = <325000000>; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index a81b8e2b0d..400a308985 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -49,6 +49,11 @@ config ARMADA_8K bool select ARM64
+config ALLEYCAT_5 + bool + select ARM64 + select HAVE_MVEBU_EFUSE + # Armada PLL frequency (used for NAND clock generation) config SYS_MVEBU_PLL_CLOCK int diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 103e64cf20..f7d7f5f8ef 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -6,6 +6,7 @@ ifdef CONFIG_ARM64
obj-$(CONFIG_ARMADA_3700) += armada3700/ obj-$(CONFIG_ARMADA_8K) += armada8k/ +obj-$(CONFIG_ALLEYCAT_5) += alleycat5/ obj-y += arm64-common.o
else # CONFIG_ARM64 diff --git a/arch/arm/mach-mvebu/alleycat5/Makefile b/arch/arm/mach-mvebu/alleycat5/Makefile new file mode 100644 index 0000000000..43b8b70c84 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2016 Stefan Roese sr@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = cpu.o +obj-y += soc.o +obj-y += clock.o diff --git a/arch/arm/mach-mvebu/alleycat5/clock.c b/arch/arm/mach-mvebu/alleycat5/clock.c new file mode 100644 index 0000000000..83c01daa2d --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/clock.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <mach/clock.h> +#include <mvebu/mvebu_chip_sar.h> + +#define CONFIG_MSS_FREQUENCY (200 * 1000000) + +static u32 soc_ring_clk_get(void) +{ + struct sar_val sar; + + mvebu_sar_value_get(SAR_AP_FABRIC_FREQ, &sar); + return sar.freq; +} + +static u32 soc_mss_clk_get(void) +{ + return CONFIG_MSS_FREQUENCY; +} + +static u32 soc_cpu_clk_get(void) +{ + struct sar_val sar; + + mvebu_sar_value_get(SAR_CPU_FREQ, &sar); + return sar.freq; +} + +static u32 soc_ddr_clk_get(void) +{ + struct sar_val sar; + + mvebu_sar_value_get(SAR_DDR_FREQ, &sar); + return sar.freq; +} + +void soc_print_clock_info(void) +{ + char buf[32]; + + printf("Clock: CPU %4s MHz\n", strmhz(buf, soc_cpu_clk_get())); + printf("\tDDR %4s MHz\n", strmhz(buf, soc_ddr_clk_get())); + printf("\tFABRIC %4s MHz\n", strmhz(buf, soc_ring_clk_get())); + printf("\tMSS %4s MHz\n", strmhz(buf, soc_mss_clk_get())); +} diff --git a/arch/arm/mach-mvebu/alleycat5/cpu.c b/arch/arm/mach-mvebu/alleycat5/cpu.c new file mode 100644 index 0000000000..4ff95e8399 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/cpu.c @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <linux/libfdt.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/arch/cpu.h> +#include <linux/sizes.h> +#include <asm/arch/soc.h> +#include <asm/armv8/mmu.h> +#include <mach/clock.h> +#include <mach/soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define RAM_SIZE SZ_1G + +static struct mm_region ac5_mem_map[] = { + { + /* RAM */ + .phys = CONFIG_SYS_SDRAM_BASE, + .virt = CONFIG_SYS_SDRAM_BASE, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, + { + /* MMIO regions */ + .phys = 0x00000000, + .virt = 0xa0000000, + .size = 0x100000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + /* MMIO regions */ + .phys = 0x100000, + .virt = 0x100000, + .size = 0x3ff00000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + /* MMIO regions */ + .phys = 0x7F000000, + .virt = 0x7F000000, + .size = 0x21000000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + 0, + } +}; + +struct mm_region *mem_map = ac5_mem_map; + +void reset_cpu(void) +{ +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + soc_print_device_info(); + soc_print_clock_info(); + + return 0; +} +#endif + +int alleycat5_dram_init(void) +{ +#define SCRATCH_PAD_REG 0x80010018 + int ret; + + /* override DDR_FW size if DTS is set with size */ + ret = fdtdec_setup_mem_size_base(); + if (ret == -EINVAL) + gd->ram_size = readl(SCRATCH_PAD_REG) * 4ULL; + + /* if DRAM size == 0, print error message */ + if (gd->ram_size == 0) { + pr_err("DRAM size not initialized - check DRAM configuration\n"); + printf("\n Using temporary DRAM size of 512MB.\n\n"); + gd->ram_size = SZ_512M; + } + + ac5_mem_map[0].size = gd->ram_size; + + return 0; +} + +int alleycat5_dram_init_banksize(void) +{ + /* + * Config single DRAM bank + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int timer_init(void) +{ + return 0; +} + +/* + * get_ref_clk + * + * return: reference clock in MHz + */ +u32 get_ref_clk(void) +{ + return 25; +} diff --git a/arch/arm/mach-mvebu/alleycat5/soc.c b/arch/arm/mach-mvebu/alleycat5/soc.c new file mode 100644 index 0000000000..f388d4ee40 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/soc.c @@ -0,0 +1,229 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <asm/arch-armada8k/cache_llc.h> +#include <asm/io.h> +#include <asm/arch/soc.h> +#include <mvebu/mvebu_chip_sar.h> +#include <dm/device.h> + +#define DEVICE_ID_REG 0x7F90004C +#define DEVICE_ID_MASK 0xffff0 +#define REV_ID_MASK 0xf +#define DEVICE_ID_OFFSET 4 +#define REV_ID_OFFSET 0 + +#define AP_DEV_ID_STATUS_REG (SOC_REGS_PHY_BASE + 0x6F8240) +#define JTAG_DEV_ID_STATUS_REG (SOC_REGS_PHY_BASE + 0x6F8244) +#define AP_DEV_ID_STATUS_MASK 0xfff +#define AP_DEV_REV_ID_STATUS_MASK 0xf0000000 +#define SW_REV_STATUS_OFFSET 16 +#define AP_REV_STATUS_OFFSET 28 +#define SW_REV_STATUS_MASK 0xf + +#define DEVICE_ID_SUB_REV (MVEBU_REGISTER(0x2400230)) +#define DEVICE_ID_SUB_REV_OFFSET 7 +#define DEVICE_ID_SUB_REV_MASK (0xffff << DEVICE_ID_SUB_REV_OFFSET) + +#define NF_CLOCK_SEL_MASK 0x1 +#define SOC_MUX_NAND_EN_MASK 0x1 +#define CLOCK_1Mhz 1000000 +#define AC5X_DEV_ID 0x9800 + +struct soc_info { + u32 dev_id; + u32 rev_id; + char *soc_name; +}; + +static struct soc_info soc_info_table[] = { + /* Two reserved entries for unidentified devices - don't change */ + { 0xB4FF, 0x0, "Unidentified Alleycat5"}, + { 0x98FF, 0x0, "Unidentified Alleycat5x"}, + + { 0xB400, 0x2, "Alleycat5-plus 98DX2538-A2"}, + { 0xB401, 0x2, "Alleycat5-plus 98DX2535-A2"}, + { 0xB402, 0x2, "Alleycat5-plus 98DX2532-A2"}, + { 0xB403, 0x2, "Alleycat5-plus 98DX2531-A2"}, + { 0xB408, 0x2, "Alleycat5 98DX2528-A2"}, + { 0xB409, 0x2, "Alleycat5 98DX2525-A2"}, + { 0xB40A, 0x2, "Alleycat5 98DX2522-A2"}, + { 0xB40B, 0x2, "Alleycat5 98DX2521-A2"}, + { 0xB410, 0x2, "Alleycat5-lite 98DX2518-A2"}, + { 0xB411, 0x2, "Alleycat5-lite 98DX2515-A2"}, + { 0xB412, 0x2, "Alleycat5-lite 98DX2512-A2"}, + { 0xB413, 0x2, "Alleycat5-lite 98DX2511-A2"}, + + { 0xB400, 0x1, "Alleycat5-plus 98DX2538-A1"}, + { 0xB401, 0x1, "Alleycat5-plus 98DX2535-A1"}, + { 0xB402, 0x1, "Alleycat5-plus 98DX2532-A1"}, + { 0xB403, 0x1, "Alleycat5-plus 98DX2531-A1"}, + { 0xB408, 0x1, "Alleycat5 98DX2528-A1"}, + { 0xB409, 0x1, "Alleycat5 98DX2525-A1"}, + { 0xB40A, 0x1, "Alleycat5 98DX2522-A1"}, + { 0xB40B, 0x1, "Alleycat5 98DX2521-A1"}, + { 0xB410, 0x1, "Alleycat5-lite 98DX2518-A1"}, + { 0xB411, 0x1, "Alleycat5-lite 98DX2515-A1"}, + { 0xB412, 0x1, "Alleycat5-lite 98DX2512-A1"}, + { 0xB413, 0x1, "Alleycat5-lite 98DX2511-A1"}, + { 0x9800, 0x1, "Alleycat5X 98DX3500M-A1"}, + { 0x9806, 0x1, "Alleycat5X 98DX3501M-A1"}, + { 0x9801, 0x1, "Alleycat5X 98DX3510M-A1"}, + { 0x9802, 0x1, "Alleycat5X 98DX3520M-A1"}, + { 0x9803, 0x1, "Alleycat5X 98DX3530M-A1"}, + { 0x9804, 0x1, "Alleycat5X 98DX3540M-A1"}, + { 0x9805, 0x1, "Alleycat5X 98DX3550M-A1"}, + { 0x9820, 0x1, "Alleycat5X 98DX3500-A1"}, + { 0x9826, 0x1, "Alleycat5X 98DX3501-A1"}, + { 0x9821, 0x1, "Alleycat5X 98DX3510-A1"}, + { 0x9861, 0x1, "Alleycat5X 98DX3510H-A1"}, + { 0x9841, 0x1, "Alleycat5X 98DX3510MH-A1"}, + { 0x9822, 0x1, "Alleycat5X 98DX3520-A1"}, + { 0x9823, 0x1, "Alleycat5X 98DX3530-A1"}, + { 0x9863, 0x1, "Alleycat5X 98DX3530H-A1"}, + { 0x9824, 0x1, "Alleycat5X 98DX3540-A1"}, + { 0x9825, 0x1, "Alleycat5X 98DX3550-A1"}, + + { 0xB400, 0x0, "Alleycat5-plus 98DX2538-A0"}, + { 0xB401, 0x0, "Alleycat5-plus 98DX2535-A0"}, + { 0xB402, 0x0, "Alleycat5-plus 98DX2532-A0"}, + { 0xB403, 0x0, "Alleycat5-plus 98DX2531-A0"}, + { 0xB408, 0x0, "Alleycat5 98DX2528-A0"}, + { 0xB409, 0x0, "Alleycat5 98DX2525-A0"}, + { 0xB40A, 0x0, "Alleycat5 98DX2522-A0"}, + { 0xB40B, 0x0, "Alleycat5 98DX2521-A0"}, + { 0xB410, 0x0, "Alleycat5-lite 98DX2518-A0"}, + { 0xB411, 0x0, "Alleycat5-lite 98DX2515-A0"}, + { 0xB412, 0x0, "Alleycat5-lite 98DX2512-A0"}, + { 0xB413, 0x0, "Alleycat5-lite 98DX2511-A0"}, + { 0x9800, 0x0, "Alleycat5X 98DX3500M-A0"}, + { 0x9806, 0x0, "Alleycat5X 98DX3501M-A0"}, + { 0x9801, 0x0, "Alleycat5X 98DX3510M-A0"}, + { 0x9802, 0x0, "Alleycat5X 98DX3520M-A0"}, + { 0x9803, 0x0, "Alleycat5X 98DX3530M-A0"}, + { 0x9804, 0x0, "Alleycat5X 98DX3540M-A0"}, + { 0x9805, 0x0, "Alleycat5X 98DX3550M-A0"}, + { 0x9820, 0x0, "Alleycat5X 98DX3500-A0"}, + { 0x9826, 0x0, "Alleycat5X 98DX3501-A0"}, + { 0x9821, 0x0, "Alleycat5X 98DX3510-A0"}, + { 0x9861, 0x0, "Alleycat5X 98DX3510H-A0"}, + { 0x9841, 0x0, "Alleycat5X 98DX3510MH-A0"}, + { 0x9822, 0x0, "Alleycat5X 98DX3520-A0"}, + { 0x9823, 0x0, "Alleycat5X 98DX3530-A0"}, + { 0x9863, 0x0, "Alleycat5X 98DX3530H-A0"}, + { 0x9824, 0x0, "Alleycat5X 98DX3540-A0"}, + { 0x9825, 0x0, "Alleycat5X 98DX3550-A0"}, +}; + +static int get_soc_type_rev(u32 *type, u32 *rev) +{ + *type = (readl(DEVICE_ID_REG) & DEVICE_ID_MASK) >> DEVICE_ID_OFFSET; + *rev = (readl(DEVICE_ID_REG) & REV_ID_MASK) >> REV_ID_OFFSET; + + return 0; +} + +static int get_soc_table_index(u32 *index) +{ + u32 soc_type; + u32 rev, i, ret = 1; + + *index = 0; + get_soc_type_rev(&soc_type, &rev); + + for (i = 0; i < ARRAY_SIZE(soc_info_table) && ret != 0; i++) { + if (soc_type != soc_info_table[i].dev_id || + rev != soc_info_table[i].rev_id) + continue; + + *index = i; + ret = 0; + } + + if (ret && ((soc_type & 0xFF00) == AC5X_DEV_ID)) + *index = 1; + + return ret; +} + +static int get_soc_name(char **soc_name) +{ + u32 index; + + get_soc_table_index(&index); + *soc_name = soc_info_table[index].soc_name; + + return 0; +} + +/* Print device's SoC name and AP & CP information */ +void soc_print_device_info(void) +{ + char *soc_name = NULL; + + get_soc_name(&soc_name); + + printf("SoC: %s\n", soc_name); +} + +/* Return NAND clock in Hz */ +u32 mvebu_get_nand_clock(void) +{ + return 200 * 1000000; +} + +int soc_early_init_f(void) +{ +#ifdef CONFIG_MVEBU_SAR +/* Sample at reset register init */ + mvebu_sar_init(); +#endif + return 0; +} + +/* + * Override of __weak int mach_cpu_init(void) : + * SoC/machine dependent CPU setup + */ +int mach_cpu_init(void) +{ + u32 phy_i; + u64 newVal, phyBase = 0x7F080800; + + /* Init USB PHY */ +#define USB_STEPPING 0x20000 +#define WRITE_MASK(addr, mask, val) \ + { newVal = (readl(addr) & (~(mask))) | val;\ + writel(newVal, addr); } + + for (phy_i = 0; phy_i < 2; phy_i++, phyBase += USB_STEPPING) { + WRITE_MASK(phyBase + 0x4, 0x3, 0x2); + WRITE_MASK(phyBase + 0xC, 0x3000000, 0x2000000); + WRITE_MASK(phyBase + 0x1C, 0x3, 0x2); + WRITE_MASK(phyBase + 0x0, 0x1FF007F, 0x600005); + WRITE_MASK(phyBase + 0xC, 0x000F000, 0x0002000); + /* Calibration Threshold Setting = 4*/ + WRITE_MASK(phyBase + 0x8, 0x700, 0x400) + WRITE_MASK(phyBase + 0x14, 0x000000F, 0x000000a); + /* Change AMP to 4*/ + WRITE_MASK(phyBase + 0xC, 0x3700000, 0x3400000); + WRITE_MASK(phyBase + 0x4, 0x3, 0x3); + /* Impedance calibration triggering is performed by USB probe */ + } + + return 0; +} + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + u32 type, rev; + + get_soc_type_rev(&type, &rev); + + return 0; +} +#endif diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index 238edbe6ba..c9b6f16c63 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -53,6 +53,8 @@ __weak int dram_init_banksize(void) return a8k_dram_init_banksize(); else if (CONFIG_IS_ENABLED(ARMADA_3700)) return a3700_dram_init_banksize(); + else if (CONFIG_IS_ENABLED(ALLEYCAT_5)) + return alleycat5_dram_init_banksize(); else return fdtdec_setup_memory_banksize(); } @@ -68,6 +70,9 @@ __weak int dram_init(void) if (CONFIG_IS_ENABLED(ARMADA_3700)) return a3700_dram_init();
+ if (CONFIG_IS_ENABLED(ALLEYCAT_5)) + return alleycat5_dram_init(); + if (fdtdec_setup_mem_size_base() != 0) return -EINVAL;
@@ -100,6 +105,16 @@ int arch_early_init_r(void) break; }
+ i = 0; + while (1) { + /* Call the pinctrl code via the PINCTRL uclass driver */ + ret = uclass_get_device(UCLASS_PINCTRL, i++, &dev); + + /* We're done, once no further CP110 device is found */ + if (ret) + break; + } + /* Cause the SATA device to do its early init */ uclass_first_device(UCLASS_AHCI, &dev);
diff --git a/arch/arm/mach-mvebu/include/mach/clock.h b/arch/arm/mach-mvebu/include/mach/clock.h new file mode 100644 index 0000000000..93d965ad5a --- /dev/null +++ b/arch/arm/mach-mvebu/include/mach/clock.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef _MVEBU_CLOCK_H_ +#define _MVEBU_CLOCK_H_ + +void soc_print_clock_info(void); + +#endif /* _MVEBU_CLOCK_H_ */ diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index b127fce865..c17c2440f1 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -174,6 +174,10 @@ int a3700_dram_init_banksize(void); /* A3700 PCIe regions fixer for device tree */ int a3700_fdt_fix_pcie_regions(void *blob);
+/* Alleycat5 dram functions */ +int alleycat5_dram_init(void); +int alleycat5_dram_init_banksize(void); + /* * get_ref_clk * diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 3b9618852c..b9312e37dc 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -212,4 +212,8 @@ #define CONFIG_SYS_TCLK 250000000 /* 250MHz */ #endif
+#ifndef __ASSEMBLY__ +void soc_print_device_info(void); +int soc_early_init_f(void); +#endif /* __ASSEMBLY__ */ #endif /* _MVEBU_SOC_H */
The RD-AC5X-32G16HVG6HLG-A0 development board main components and features include: * Main 12V/54V power supply * 270 Gbps throughput packet processor on the main board * DDR4: * SR1: 2GB DDR4 2400MT/S(1GB x 2 pcs ) with ECC(1GB x 1 pcs) * SR2: 4GB DDR4 2400MT/S(2GB x 2 pcs ) with ECC(2GB x 1 pcs) * PCB co-layout with 4GB device to support 8GB (Dual CS) requirement * 16GB eMMC (Samsung KLMAG1JETD-B041006) * 16MB SPI NOR(GD25Q127C) * 32 x 1000 Base-T interfaces * 16 x 2500 Base-T interfaces * SR1: 88E2540*4 * SR2: 88E2580*1+88E2540*2 * Six (6) x 25G Base-R SFP28 interfaces * One (1) x RJ-45 console connector, interfacing to the on board UART * One (1) x USB Type-A connector, interfacing to the USB 2.0 port (0) * One (1) x USB Type-mini B connector, interfacing to the USB 2.0 port (1) * One (1) x RJ-45 1G Base-T Management port, interfacing to the host port (shared with PCIe) Connected to 88E1512 Gigabit Ethernet Phy * One (1) x Oculink port, interfacing to the PCIe port for external CPU connection * POE 802.3AT support on Port 1 ~ Port 32, 802.3BT support on Port 33 ~ Port 48 (Microsemi PD69208T4, PD69208M or TI TPS2388,TPS23881 solution) * POE total power budget 780W * LED interfaces per network port/POE * LED interfaces (common) showing system status * PTP TC mode Supported (Reserved M.2 connector to support BC mode)
arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx35xx-rd.dts | 155 +++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 9 +- board/Marvell/mvebu_alleycat-5/MAINTAINERS | 6 + board/Marvell/mvebu_alleycat-5/Makefile | 3 + board/Marvell/mvebu_alleycat-5/board.c | 35 +++++ configs/mvebu_ac5_rd_defconfig | 89 ++++++++++++ include/configs/mvebu_alleycat-5.h | 92 ++++++++++++ 8 files changed, 390 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx35xx-rd.dts create mode 100644 board/Marvell/mvebu_alleycat-5/MAINTAINERS create mode 100644 board/Marvell/mvebu_alleycat-5/Makefile create mode 100644 board/Marvell/mvebu_alleycat-5/board.c create mode 100644 configs/mvebu_ac5_rd_defconfig create mode 100644 include/configs/mvebu_alleycat-5.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7330121dba..a334596ada 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -274,7 +274,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ cn9132-db-A.dtb \ cn9132-db-B.dtb \ cn9130-crb-A.dtb \ - cn9130-crb-B.dtb + cn9130-crb-B.dtb \ + ac5-98dx35xx-rd.dtb endif
dtb-$(CONFIG_ARCH_SYNQUACER) += synquacer-sc2a11-developerbox.dtb diff --git a/arch/arm/dts/ac5-98dx35xx-rd.dts b/arch/arm/dts/ac5-98dx35xx-rd.dts new file mode 100644 index 0000000000..94eadd6f71 --- /dev/null +++ b/arch/arm/dts/ac5-98dx35xx-rd.dts @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For RD-AC5X. + * + * Copyright (C) 2021 Marvell + * Copyright (C) 2022 Allied Telesis Labs + */ +/* + * Device Tree file for Marvell Alleycat 5X development board + * This board file supports the B configuration of the board + */ + +/dts-v1/; + +#include "ac5-98dx35xx.dtsi" + +/ { + model = "Marvell RD-AC5X Board"; + compatible = "marvell,rd-ac5x", "marvell,ac5x", "marvell,ac5"; + + aliases { + serial0 = &uart0; + spiflash0 = &spiflash0; + gpio0 = &gpio0; + gpio1 = &gpio1; + ethernet0 = ð0; + ethernet1 = ð1; + spi0 = &spi0; + i2c0 = &i2c0; + i2c1 = &i2c1; + usb0 = &usb0; + usb1 = &usb1; + pinctrl0 = &pinctrl0; + sar-reg0 = "/config-space/sar-reg"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x2 0x00000000 0x0 0x40000000>; + }; + + usb1phy: usb-phy { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + config-space { + sar-reg { + reg = <0x944F8204 0x1>; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&mdio { + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +ð0 { + status = "okay"; + phy-handle = <&phy0>; +}; + +/* USB0 is a host USB */ +&usb0 { + status = "okay"; +}; + +/* USB1 is a peripheral USB */ +&usb1 { + status = "okay"; + phys = <&usb1phy>; + phy-names = "usb-phy"; + dr_mode = "peripheral"; +}; + +&spi0 { + status = "okay"; + + spiflash0: flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + spi-rx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + reg = <0>; + + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "spi_flash_part0"; + reg = <0x0 0x800000>; + }; + + parition@1 { + label = "spi_flash_part1"; + reg = <0x800000 0x700000>; + }; + + parition@2 { + label = "spi_flash_part2"; + reg = <0xF00000 0x100000>; + }; + }; +}; + +&pinctrl0 { + /* + * MPP Bus: MPP# mode# + * eMMC [0-11] 0x1 + * SPI[0] [12-17] 0x1 + * TSEN_INT [18] 0x1 + * DEV_INIT [19] 0x1 + * SPI[1] [20-23] 0x3 + * UART[1] [24-25] 0x3 + * I2C[0] [26-27] 0x1 + * XSMI[0] [28-29] 0x1 // SCH use SMI[0], reversed due to CPSS problem + * SMI[1] [30-31] 0x2 // SCH use XSMI[1], reversed due to CPSS problem + * UART[0] [32-33] 0x1 + * OOB_SMI [34-35] 0x1 + * PTP_CLK0_OUT [36] 0x1 + * PTP_PULSE_OUT [37] 0x1 + * RCVR_CLK_OUT [38] 0x1 + * GPIO(in/out) [39] 0x0 + * GPIO(in/out) [40] 0x0 + * PTP_REF_CLK [41] 0x1 + * PTP_CLK0 [42] 0x1 + * LED0_CLK [43] 0x1 + * LED0_STB [44] 0x1 + * LED0_DATA [45] 0x1 + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 1 1 1 1 1 1 1 1 1 + 3 3 3 3 3 3 1 1 1 1 + 2 2 1 1 1 1 1 1 1 0 + 0 1 1 1 1 1 >; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 400a308985..d27c45d58f 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -98,7 +98,7 @@ config CUSTOMER_BOARD_SUPPORT bool
choice - prompt "Armada XP/375/38x/3700/7K/8K board select" + prompt "Armada XP/375/38x/3700/7K/8K/Alleycat-5 board select" optional
config TARGET_CLEARFOG @@ -150,6 +150,10 @@ config TARGET_MVEBU_ARMADA_8K select BOARD_LATE_INIT imply SCSI
+config TARGET_MVEBU_ALLEYCAT5 + bool "Support AlleyCat 5 platforms" + select ALLEYCAT_5 + config TARGET_OCTEONTX2_CN913x bool "Support CN913x platforms" select ARMADA_8K @@ -258,6 +262,7 @@ config SYS_BOARD default "x530" if TARGET_X530 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 + default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG @@ -278,6 +283,7 @@ config SYS_CONFIG_NAME default "x530" if TARGET_X530 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 + default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP @@ -297,6 +303,7 @@ config SYS_VENDOR default "gdsys" if TARGET_CONTROLCENTERDC default "alliedtelesis" if TARGET_X530 default "mikrotik" if TARGET_CRS3XX_98DX3236 + default "Marvell" if TARGET_MVEBU_ALLEYCAT5
config SYS_SOC default "mvebu" diff --git a/board/Marvell/mvebu_alleycat-5/MAINTAINERS b/board/Marvell/mvebu_alleycat-5/MAINTAINERS new file mode 100644 index 0000000000..480c07c5f0 --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/MAINTAINERS @@ -0,0 +1,6 @@ +RD-AC5X BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/Marvell/mvebu_alleycat-5/ +F: include/configs/mvebu_alleycat-5.h +F: configs/mvebu_ac5_rd_defconfig diff --git a/board/Marvell/mvebu_alleycat-5/Makefile b/board/Marvell/mvebu_alleycat-5/Makefile new file mode 100644 index 0000000000..29254b4d64 --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y := board.o diff --git a/board/Marvell/mvebu_alleycat-5/board.c b/board/Marvell/mvebu_alleycat-5/board.c new file mode 100644 index 0000000000..3303d3c2c9 --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/board.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +__weak int soc_early_init_f(void) +{ + return 0; +} + +int board_early_init_f(void) +{ + soc_early_init_f(); + + return 0; +} + +int board_early_init_r(void) +{ + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + +int board_late_init(void) +{ + return 0; +} diff --git a/configs/mvebu_ac5_rd_defconfig b/configs/mvebu_ac5_rd_defconfig new file mode 100644 index 0000000000..bfc0cd6ba9 --- /dev/null +++ b/configs/mvebu_ac5_rd_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x200000000 +CONFIG_SYS_MALLOC_LEN=0x900000 +CONFIG_TARGET_MVEBU_ALLEYCAT5=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0x7f012000 +CONFIG_DEBUG_UART_CLOCK=325000000 +CONFIG_SYS_LOAD_ADDR=0x202000000 +CONFIG_DEBUG_UART=y +CONFIG_SYS_MEMTEST_START=0x200800000 +CONFIG_SYS_MEMTEST_END=0x200ffffff +CONFIG_DISTRO_DEFAULTS=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x200FF0000 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_BOOTDELAY=-1 +CONFIG_BOOTCOMMAND="run get_images; run set_bootargs; booti $kernel_addr $ramfs_addr $fdt_addr" +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_UBI=y +CONFIG_MAC_PARTITION=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_MVEBU_SAR=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_E1000=y +CONFIG_MVNETA=y +CONFIG_MVMDIO=y +CONFIG_PCI=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y diff --git a/include/configs/mvebu_alleycat-5.h b/include/configs/mvebu_alleycat-5.h new file mode 100644 index 0000000000..a9dbbf1858 --- /dev/null +++ b/include/configs/mvebu_alleycat-5.h @@ -0,0 +1,92 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Marvell International Ltd + */ + +#ifndef _CONFIG_MVEBU_ALLEYCAY_5_H +#define _CONFIG_MVEBU_ALLEYCAY_5_H + +#include <asm/arch/soc.h> + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* additions for new ARM relocation support */ +#define CONFIG_SYS_SDRAM_BASE 0x200000000 + +/* auto boot */ +#define CONFIG_PREBOOT + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400, 460800, 921600 } + +/* Default Env vars */ +#define CONFIG_IPADDR 0.0.0.0 /* In order to cause an error */ +#define CONFIG_SERVERIP 0.0.0.0 /* In order to cause an error */ +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_GATEWAYIP 0.0.0.0 +#define CONFIG_ETHPRIME "eth0" +#define CONFIG_ROOTPATH "/srv/nfs/" /* Default Dir for NFS */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#define CONFIG_EXTRA_ENV_SETTINGS "bootcmd=run get_images; " \ + "run set_bootargs; " \ + "booti $kernel_addr_r " \ + "$ramdisk_addr_r " \ + "$fdt_addr_r\0" \ + "extra_params=pci=pcie_bus_safe\0" \ + "kernel_addr_r=0x202000000\0" \ + "initrd_addr=0x206000000\0" \ + "initrd_size=0x2000000\0" \ + "fdt_addr_r=0x201000000\0" \ + "loadaddr=0x202000000\0" \ + "hostname=marvell\0" \ + "ramdisk_addr_r=0x206000000\0" \ + "ramfs_name=-\0" \ + "cpuidle=cpuidle.off=1\0" \ + "fdt_name=fdt.dtb\0" \ + "netdev=eth0\0" \ + "ethaddr=00:51:82:11:22:00\0" \ + "eth1addr=00:51:82:11:22:01\0" \ + "image_name=Image\0" \ + "get_ramfs=if test "${ramfs_name}"" \ + " != "-"; then setenv " \ + "ramdisk_addr_r 0x8000000; " \ + "tftpboot $ramdisk_addr_r " \ + "$ramfs_name; else setenv " \ + "ramdisk_addr_r -;fi\0" \ + "get_images=tftpboot $kernel_addr_r " \ + "$image_name; tftpboot " \ + "$fdt_addr_r $fdt_name; " \ + "run get_ramfs\0" \ + "console=" "console=ttyS0,115200 "\ + "earlycon=uart8250,mmio32,0xf0512000\0"\ + "root=root=/dev/nfs rw\0" \ + "set_bootargs=setenv bootargs $console"\ + " $root ip=$ipaddr:$serverip:" \ + "$gatewayip:$netmask:$hostname"\ + ":$netdev:none nfsroot="\ + "$serverip:$rootpath,tcp,v3 " \ + "$extra_params " \ + "$cpuidle" + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_SYS_TCLK 325000000 + +/* tbd #define CONFIG_BOARD_EARLY_INIT_R */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_USE_FLASH_BBT + +#define CONFIG_USB_MAX_CONTROLLER_COUNT (3 + 3) + +/* MTD support */ +#define CONFIG_MTD_DEVICE + +#endif /* _CONFIG_MVEBU_ALLEYCAY_5_H */
On Friday 16 September 2022 16:54:22 Chris Packham wrote:
+&spi0 {
- status = "okay";
- spiflash0: flash@0 {
reg = <0>;
#size-cells = <1>;
partition@0 {
I guess such label is useless. There is something stored, so it would be a wise idea to put there correct label. I do not know how it is on this platform, but on A3720 at offset 0 is "firmware", which consist of CM3 part, A53 part and U-Boot. It is not even U-Boot itself.
parition@1 {
parition@2 {
"$fdt_addr_r\0" \
"ramfs_name=-\0" \
"netdev=eth0\0" \
"get_ramfs=if test \"${ramfs_name}\"" \
" != \"-\"; then setenv " \
"run get_ramfs\0" \
"$extra_params " \
"$cpuidle"
This is hard to read, where is the variable name, where there is its value, etc...
And it would be better to use distroboot instead of manually written boot script.
+&spi0 {
status = "okay";
reg = <0>;
#size-cells = <1>;
partition@0 {
These are the names from the Linux SDK for the board. The first part will be the bootloader (mvddr+atf+u-boot). Somewhere in there is also the u-boot environment. I'm tempted just to drop the partitions altogether, they don't do anything useful for u-boot.
parition@1 {
parition@2 {
NFS */
"$fdt_addr_r\0" \
"ramfs_name=-\0" \
"netdev=eth0\0" \
"run get_ramfs\0" \
"$extra_params " \
"$cpuidle"
Yep I'll try to clean that up. Again this is straight from the older SDK so it'snot follow current best practice.
Marvell's proprietary TIM (trusted image) is used on the Armada-3700 and AlledCat5/5X (and possibly others). It has a whole host of features that work to implement a version of secure boot.
Kwboot's interest in this format is simply to detect that the image is one of these and not attempt to patch it (the images will work over UART boot as-is). This is done by checking for a specific magic value ("TIMH") in the first 32bits of the image.
Signed-off-by: Chris Packham judge.packham@gmail.com --- It might be possible to make the check more robust by validating more of the image. There is a checksum field that might be useful for this purpose. I haven't done this as I couldn't figure out Marvell's validation of this field.
tools/kwbimage.h | 29 +++++++++++++++++++++++++++++ tools/kwboot.c | 3 +++ 2 files changed, 32 insertions(+)
diff --git a/tools/kwbimage.h b/tools/kwbimage.h index 505522332b..8aab26952a 100644 --- a/tools/kwbimage.h +++ b/tools/kwbimage.h @@ -224,6 +224,28 @@ struct register_set_hdr_v1 { #define OPT_HDR_V1_BINARY_TYPE 0x2 #define OPT_HDR_V1_REGISTER_TYPE 0x3
+/* TIM (trusted image), Armada 3700, AlleyCat5 */ +struct tim_block_hdr { + uint32_t signature_id; + uint16_t opcode; + uint16_t blocksize; +} __packed; + +struct tim_hdr { + struct tim_block_hdr hdr; + uint32_t trusted; + uint32_t signed_tim_size; + uint32_t unsigned_tim_size; + uint32_t unique_id; + uint64_t loadaddr; + uint32_t flags; + uint32_t software_prot_version; + uint32_t num_blocks; + uint32_t checksum; +} __packed; + +#define TIM_HDR_SIGNATURE 0x54494d48 /* "TIMH" */ + /* * Byte 8 of the image header contains the version number. In the v0 * header, byte 8 was reserved, and always set to 0. In the v1 header, @@ -270,6 +292,13 @@ static inline size_t kwbheader_size_for_csum(const void *header) return kwbheader_size(header); }
+static inline bool kwbimage_is_tim(void *img) +{ + const struct tim_hdr *hdr = img; + + return le32_to_cpu(hdr->hdr.signature_id) == TIM_HDR_SIGNATURE; +} + static inline struct ext_hdr_v0 *ext_hdr_v0_first(void *img) { struct main_hdr_v0 *mhdr; diff --git a/tools/kwboot.c b/tools/kwboot.c index da4fe32da2..a9b3d0fd04 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -1869,6 +1869,9 @@ kwboot_img_patch(void *img, size_t *size, int baudrate) if (*size < sizeof(struct main_hdr_v1)) goto err;
+ if (kwbimage_is_tim(img)) + return 0; + image_ver = kwbimage_version(img); if (image_ver != 0 && image_ver != 1) { fprintf(stderr, "Invalid image header version\n");
Hello! I think it does not make sense to hack kwboot to skip validation of kwbimage format when ad-hoc TIM header is detected. kwboot has now lot of features which requires and expects valid kwbimage format and is now written to work specially with 32-bit mvebu ARM BootROMs.
TIM and kwbimage are totally different formats and it really does not make sense to starting rewriting kwboot to support also other format. Instead it would be better to write other dedicated tool for it.
For example, there is already tool mox-imager [1], which despite its name supports all A3720 BootROMS and mvebu64boot [2] which supports A70x0, A80x0 and CN9130 BootROMS.
[1] - https://gitlab.nic.cz/turris/mox-imager [2] - https://github.com/pali/mvebu64boot
- uint32_t signature_id;
- uint16_t opcode;
- uint16_t blocksize;
+} __packed;
+struct tim_hdr {
- struct tim_block_hdr hdr;
- uint32_t trusted;
- uint32_t signed_tim_size;
- uint32_t unsigned_tim_size;
- uint32_t unique_id;
- uint64_t loadaddr;
- uint32_t flags;
- uint32_t software_prot_version;
- uint32_t num_blocks;
- uint32_t checksum;
+} __packed;
- Byte 8 of the image header contains the version number. In the v0
- header, byte 8 was reserved, and always set to 0. In the v1 header,
- const struct tim_hdr *hdr = img;
- return le32_to_cpu(hdr->hdr.signature_id) == TIM_HDR_SIGNATURE;
- if (kwbimage_is_tim(img))
- image_ver = kwbimage_version(img); if (image_ver != 0 && image_ver != 1) { fprintf(stderr, "Invalid image header version\n");
-- 2.37.3
Yeah I tend to agree.
Mvebu64boot would fit better since this is a 64 bit Marveel SoC but again I'd have to teach it about TIM. One reason I went with kwboot (aside from not knowing anything else existed) was that the hand off between the uart boot sequence and the xmodem was awkward with the "official" methods (2 different transfer with 2 different protocols).
I do wonder if the boot seqence and xmodem stuff could be abstracted out to something that could be reused by other tools.
I the short term at least I'll drop this out of the series.
uint16_t opcode;
uint16_t blocksize;
+} __packed;
+struct tim_hdr {
uint32_t trusted;
uint32_t unique_id;
uint64_t loadaddr;
uint32_t flags;
uint32_t checksum;
+} __packed;
void *header)
baudrate)
-- 2.37.3
mox-imager already implements generating and parsing TIM images as this is used on A3720. But for UART booting is used custom WTPTP protocol, not variant of xmodem.
uint16_t opcode;
uint16_t blocksize;
+} __packed;
+struct tim_hdr {
uint32_t trusted;
uint32_t unique_id;
uint64_t loadaddr;
uint32_t flags;
uint32_t checksum;
+} __packed;
void *header)
baudrate)
-- 2.37.3
In the past I was thinking about it... but I come to the conclusion that it is easier to write specific tools which implements communication with just one BootROM. Trying to write one universal thing just opens a lot of issues and at the end it would do same thing like if you implement N independent applications and then additional "launcher" application which starts the correct one.
It looks like that most Marvell SoCs use xmodem protocol. Except 3720 which uses WTPTP. But as I figured out, every SoC use slightly modified protocol based on xmodem. So well, in theory "sx" would work. But if you want to have other features (like progress bar or bootrom output or speed change) then all this is bootrom specific and has to be implemented directly into xmodem state machine. So either you provide N xmodem implementations or try to create something "hookable" and since beginning I have feeling that "hooks" would just introduce new bugs and make it harder to debug.
kwboot is currently in the state that it supports kwbimage v0 and kwbimage v1 formats, which IIRC covers all 32-bit widely used SoCs from kirkwood, dove, armada and switches which integrates those CPUs, and probably also avanta. At lot of stages it expects valid kwbimage and that is why there is validation at the beginning. It injects 32-bit ARM binary code for changing UART speed and requires above SoC (as it touches internal registers, which are same on all those mentioned). It also contains workarounds for bugs in Armada 385 BootROMs.
I really think that kwboot is now in state when it is not easily possible to extend it for different platform without lot of energy and extra testing that it does not break something existing.
Hi Pali,
Having looked more into mox-imager (and WtpDownloader) I've realised that the AlleyCat5 uses something called "TIM" but it's different to the format used by Armada-3700. I suspect what I'm actually dealing with is a TIMv0 that pre-dates the version used by Armada-3700. All the more reason to do something new instead of trying to shoe-horn it into one of the existing places. I'll probably end up making a fork of your mvebu64boot and adapting it (mox-imager just does too much).
Hello! If that AC5 TIM format is different than A3720 TIM then it really makes sense to create a new tool. Forking mvebu64boot into completely new project seems like the easiest way how to achieve working tool without being afraid to break existing support.
Anyway, is not there any Marvell tool for this AC5 TIM format? Like A3720 TBB or WtpDownloader?
Nope the only official support is send the boot pattern using ascii/raw then send the image using xmodem. Which is what led to me looking for an alternative that can actually tell when the SoC has detected the pattern and hand off to the xmodem download. Supporting the signed images would be a bonus but not for my immediate need for recovering from bad bootloaders.
Chris Packham
Pali Rohár
