[U-Boot] UDP packet sender
Hi, I would like to implement a new command and submit it to the mailing list. The command will have the following format: udpsend <destination/broadcast ip> <destination port> <source port> <text to send>
udpsend 255.255.255.255 4040 0 hello world
If source port is 0, a random port will be used (11000 + (get_timer(0) % 4096))
Where do I have to place my code : cmd or net directory ? For me cmd will be the better directory to keep it away from all more complex stuff like DHCP, TFTP, ...
Thank you for these informations. Regards, Gaëtan.
Ping ?
Hi.
<text to send>
Ping ?
You should write directly to network u-boot maintainer and add list to CC.
Joe Hershberger joe.hershberger@ni.com
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Gaëtan,
I'd like to understand the purpose / use-case for this command? Maybe there is a more appropriate way to solve the problem you have instead.
That's probably true. cmd/ would be the appropriate place.
-Joe
Hi Joe,
On 01/22/2018 11:46 PM, Joe Hershberger wrote:
Hi Gaëtan,
I want to send the current progression of an update script. As the board has no display/leds, the only way to get update progression is to broadcast UDP packet that a PC software will monitor. U-Boot will load/source a script from an ext4 partition. This script will load a rootfs image from update partition of an eMMC splitted into 10M chunks that will be written to an other partition of the eMMC. This is for update on site (by customer).
This UDP command will also be used in a closed production LAN to send Unique ID of the CPU (secret) and the MAC address to the monitoring production (burning) software that will feed a database to be able to generate license keys linked to hardware and print a label with the product name and the MAC address.
Maybe there is already existing command that I can use from a U-Boot script ?
-Joe
Regards, Gaëtan
On Mon, Jan 22, 2018 at 5:28 PM, Gaëtan Carlier gcembed@gmail.com wrote:
Hi Joe,
Hi Gaëtan,
I think this is commonly done by enabling netconsole and controlling / monitoring progress based on console output sent over UDP.
Cheers, -Joe
-Joe
Regards, Gaëtan
Hi Joe,
Hi Gaëtan,
a) I can/want not enable netconsole when the product is on the network of the customer. b) Once on customer LAN, everything is DHCP. c) I don't want to increase load of CPU because updating software on customer's computer has to decode all UDP frames sent by U-Boot while 10% of UDP are really needed (several boards can be on the same network).
Cheers, -Joe
-Joe
Regards, Gaëtan
Regards, Gaëtan.
Hi Joe,
Hi Gaëtan,
If you want to add this, add it as a command in cmd/netcat.c and use the same semantics as netcat as much as possible. Since there is no pipe support in U-Boot's shell, the data to send will have to be a parameter. Best to make it something that does not collide with netcat.
In netcat, you specify a "-u" switch to enable UDP, so your command would require that switch (so TCP could be added later).
So that means your invocation should be "nc -u -p <srcport> <host> <dstport> -- Text to send"
Cheers, -Joe
-Joe
Regards, Gaëtan
Regards, Gaëtan.
Hi Joe,
Hi Joe,
Hi Gaëtan,
Thank you for these informations. I will do that.
Cheers, -Joe
-Joe
Regards, Gaëtan
Regards, Gaëtan.
Regards, Gaëtan.
Gaëtan Carlier
Joe Hershberger
Lukasz Majewski
