[U-Boot] [PATCH 1/9] mmc: tmio: sdhi: Track current tap number in private data
Retain the tap number from last calibration in private data. This will be later used for SCC error checking after each command.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 31 ++++++++++++++++--------------- drivers/mmc/tmio-common.h | 1 + 2 files changed, 17 insertions(+), 15 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 0cb65b480d..acc44e5b90 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -289,8 +289,7 @@ static unsigned int renesas_sdhi_compare_scc_data(struct tmio_sd_priv *priv) }
static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, - unsigned int tap_num, unsigned int taps, - unsigned int smpcmp) + unsigned int taps, unsigned int smpcmp) { unsigned long tap_cnt; /* counter of tuning success */ unsigned long tap_start;/* start position of tuning success */ @@ -307,14 +306,14 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, tmio_sd_writel(priv, 0, RENESAS_SDHI_SCC_RVSREQ);
/* Merge the results */ - for (i = 0; i < tap_num * 2; i++) { + for (i = 0; i < priv->tap_num * 2; i++) { if (!(taps & BIT(i))) { - taps &= ~BIT(i % tap_num); - taps &= ~BIT((i % tap_num) + tap_num); + taps &= ~BIT(i % priv->tap_num); + taps &= ~BIT((i % priv->tap_num) + priv->tap_num); } if (!(smpcmp & BIT(i))) { - smpcmp &= ~BIT(i % tap_num); - smpcmp &= ~BIT((i % tap_num) + tap_num); + smpcmp &= ~BIT(i % priv->tap_num); + smpcmp &= ~BIT((i % priv->tap_num) + priv->tap_num); } }
@@ -327,7 +326,7 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, ntap = 0; tap_start = 0; tap_end = 0; - for (i = 0; i < tap_num * 2; i++) { + for (i = 0; i < priv->tap_num * 2; i++) { if (taps & BIT(i)) ntap++; else { @@ -350,12 +349,12 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, * If all of the TAP is OK, the sampling clock position is selected by * identifying the change point of data. */ - if (tap_cnt == tap_num * 2) { + if (tap_cnt == priv->tap_num * 2) { match_cnt = 0; ntap = 0; tap_start = 0; tap_end = 0; - for (i = 0; i < tap_num * 2; i++) { + for (i = 0; i < priv->tap_num * 2; i++) { if (smpcmp & BIT(i)) ntap++; else { @@ -378,7 +377,7 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, select = true;
if (select) - priv->tap_set = ((tap_start + tap_end) / 2) % tap_num; + priv->tap_set = ((tap_start + tap_end) / 2) % priv->tap_num; else return -EIO;
@@ -419,15 +418,17 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode) /* Tuning is not supported */ goto out;
- if (tap_num * 2 >= sizeof(taps) * 8) { + priv->tap_num = tap_num; + + if (priv->tap_num * 2 >= sizeof(taps) * 8) { dev_err(dev, "Too many taps, skipping tuning. Please consider updating size of taps field of tmio_mmc_host\n"); goto out; }
/* Issue CMD19 twice for each tap */ - for (i = 0; i < 2 * tap_num; i++) { - renesas_sdhi_prepare_tuning(priv, i % tap_num); + for (i = 0; i < 2 * priv->tap_num; i++) { + renesas_sdhi_prepare_tuning(priv, i % priv->tap_num);
/* Force PIO for the tuning */ caps = priv->caps; @@ -447,7 +448,7 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode) mdelay(1); }
- ret = renesas_sdhi_select_tuning(priv, tap_num, taps, smpcmp); + ret = renesas_sdhi_select_tuning(priv, taps, smpcmp);
out: if (ret < 0) { diff --git a/drivers/mmc/tmio-common.h b/drivers/mmc/tmio-common.h index 51607de142..da89cc90c2 100644 --- a/drivers/mmc/tmio-common.h +++ b/drivers/mmc/tmio-common.h @@ -138,6 +138,7 @@ struct tmio_sd_priv { #endif #if CONFIG_IS_ENABLED(RENESAS_SDHI) u8 tap_set; + u8 tap_num; u8 nrtaps; bool needs_adjust_hs400; bool adjust_hs400_enable;
Retain the SMPCMP value from last calibration in private data. This will be later used for skipping bad taps.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 18 ++++++++++-------- drivers/mmc/tmio-common.h | 1 + 2 files changed, 11 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index acc44e5b90..2f34173d03 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -289,7 +289,7 @@ static unsigned int renesas_sdhi_compare_scc_data(struct tmio_sd_priv *priv) }
static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, - unsigned int taps, unsigned int smpcmp) + unsigned int taps) { unsigned long tap_cnt; /* counter of tuning success */ unsigned long tap_start;/* start position of tuning success */ @@ -311,9 +311,9 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, taps &= ~BIT(i % priv->tap_num); taps &= ~BIT((i % priv->tap_num) + priv->tap_num); } - if (!(smpcmp & BIT(i))) { - smpcmp &= ~BIT(i % priv->tap_num); - smpcmp &= ~BIT((i % priv->tap_num) + priv->tap_num); + if (!(priv->smpcmp & BIT(i))) { + priv->smpcmp &= ~BIT(i % priv->tap_num); + priv->smpcmp &= ~BIT((i % priv->tap_num) + priv->tap_num); } }
@@ -355,7 +355,7 @@ static int renesas_sdhi_select_tuning(struct tmio_sd_priv *priv, tap_start = 0; tap_end = 0; for (i = 0; i < priv->tap_num * 2; i++) { - if (smpcmp & BIT(i)) + if (priv->smpcmp & BIT(i)) ntap++; else { if (ntap > match_cnt) { @@ -398,7 +398,7 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode) struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct mmc *mmc = upriv->mmc; unsigned int tap_num; - unsigned int taps = 0, smpcmp = 0; + unsigned int taps = 0; int i, ret = 0; u32 caps;
@@ -426,6 +426,8 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode) goto out; }
+ priv->smpcmp = 0; + /* Issue CMD19 twice for each tap */ for (i = 0; i < 2 * priv->tap_num; i++) { renesas_sdhi_prepare_tuning(priv, i % priv->tap_num); @@ -443,12 +445,12 @@ int renesas_sdhi_execute_tuning(struct udevice *dev, uint opcode)
ret = renesas_sdhi_compare_scc_data(priv); if (ret == 0) - smpcmp |= BIT(i); + priv->smpcmp |= BIT(i);
mdelay(1); }
- ret = renesas_sdhi_select_tuning(priv, taps, smpcmp); + ret = renesas_sdhi_select_tuning(priv, taps);
out: if (ret < 0) { diff --git a/drivers/mmc/tmio-common.h b/drivers/mmc/tmio-common.h index da89cc90c2..79f51d21af 100644 --- a/drivers/mmc/tmio-common.h +++ b/drivers/mmc/tmio-common.h @@ -137,6 +137,7 @@ struct tmio_sd_priv { struct clk clk; #endif #if CONFIG_IS_ENABLED(RENESAS_SDHI) + unsigned int smpcmp; u8 tap_set; u8 tap_num; u8 nrtaps;
The M3W up to ES1.2 uses 4 tuning taps for HS400, make it so.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 2f34173d03..3f20a690a2 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -622,9 +622,12 @@ static void renesas_sdhi_filter_caps(struct udevice *dev) priv->adjust_hs400_calibrate = 0x2; }
- /* H3 ES2.0 uses 4 tuning taps */ - if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && - (rmobile_get_cpu_rev_integer() == 2)) + /* H3 ES1.x, ES2.0 and M3W ES1.0, ES1.1, ES1.2 uses 4 tuning taps */ + if (((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && + (rmobile_get_cpu_rev_integer() <= 2)) || + ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && + (rmobile_get_cpu_rev_integer() == 1) && + (rmobile_get_cpu_rev_fraction() <= 2))) priv->nrtaps = 4; else priv->nrtaps = 8;
Adjust the DT2FF offsets in HS400 according to latest information from the chip vendor.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 3f20a690a2..8c96e5c8a4 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -253,13 +253,13 @@ static int renesas_sdhi_hs400(struct udevice *dev) if (taps == 4) { tmio_sd_writel(priv, priv->tap_set >> 1, RENESAS_SDHI_SCC_TAPSET); + tmio_sd_writel(priv, hs400 ? 0x100 : 0x300, + RENESAS_SDHI_SCC_DT2FF); } else { tmio_sd_writel(priv, priv->tap_set, RENESAS_SDHI_SCC_TAPSET); + tmio_sd_writel(priv, 0x300, RENESAS_SDHI_SCC_DT2FF); }
- tmio_sd_writel(priv, hs400 ? 0x704 : 0x300, - RENESAS_SDHI_SCC_DT2FF); - reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_CKSEL); reg |= RENESAS_SDHI_SCC_CKSEL_DTSEL; tmio_sd_writel(priv, reg, RENESAS_SDHI_SCC_CKSEL);
Adjust the TMPPORT3 offsets according to the latest information from the chip vendor.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 8c96e5c8a4..79672653ff 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -604,22 +604,22 @@ static void renesas_sdhi_filter_caps(struct udevice *dev) (rmobile_get_cpu_rev_integer() == 1) && (rmobile_get_cpu_rev_fraction() > 2)) { priv->adjust_hs400_enable = true; - priv->adjust_hs400_offset = 0; + priv->adjust_hs400_offset = 3; priv->adjust_hs400_calibrate = 0x9; }
/* M3N can use HS400 with manual adjustment */ if (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77965) { priv->adjust_hs400_enable = true; - priv->adjust_hs400_offset = 0; + priv->adjust_hs400_offset = 3; priv->adjust_hs400_calibrate = 0x0; }
/* E3 can use HS400 with manual adjustment */ if (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77990) { priv->adjust_hs400_enable = true; - priv->adjust_hs400_offset = 0; - priv->adjust_hs400_calibrate = 0x2; + priv->adjust_hs400_offset = 3; + priv->adjust_hs400_calibrate = 0x4; }
Disable the auto-retuning in HS400 mode in favor of manual calibration.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 79672653ff..8c690a27b2 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -229,7 +229,9 @@ static int renesas_sdhi_hs400(struct udevice *dev) if (ret < 0) return ret;
- tmio_sd_writel(priv, 0, RENESAS_SDHI_SCC_RVSREQ); + reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_RVSCNTL); + reg &= ~RENESAS_SDHI_SCC_RVSCNTL_RVSEN; + tmio_sd_writel(priv, reg, RENESAS_SDHI_SCC_RVSCNTL);
reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_TMPPORT2); if (hs400) { @@ -264,10 +266,6 @@ static int renesas_sdhi_hs400(struct udevice *dev) reg |= RENESAS_SDHI_SCC_CKSEL_DTSEL; tmio_sd_writel(priv, reg, RENESAS_SDHI_SCC_CKSEL);
- reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_RVSCNTL); - reg |= RENESAS_SDHI_SCC_RVSCNTL_RVSEN; - tmio_sd_writel(priv, reg, RENESAS_SDHI_SCC_RVSCNTL); - /* Execute adjust hs400 offset after setting to HS400 mode */ if (hs400) priv->needs_adjust_hs400 = true;
Check SCC for errors after check command if applicable and optionally adjust the bus skew settings accordingly.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 85 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 85 insertions(+)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 8c690a27b2..dcc77dd86c 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -34,7 +34,12 @@ #define RENESAS_SDHI_SCC_RVSCNTL_RVSEN BIT(0) #define RENESAS_SDHI_SCC_RVSREQ 0x814 #define RENESAS_SDHI_SCC_RVSREQ_RVSERR BIT(2) +#define RENESAS_SDHI_SCC_RVSREQ_REQTAPUP BIT(1) +#define RENESAS_SDHI_SCC_RVSREQ_REQTAPDOWN BIT(0) #define RENESAS_SDHI_SCC_SMPCMP 0x818 +#define RENESAS_SDHI_SCC_SMPCMP_CMD_ERR (BIT(24) | BIT(8)) +#define RENESAS_SDHI_SCC_SMPCMP_CMD_REQUP BIT(24) +#define RENESAS_SDHI_SCC_SMPCMP_CMD_REQDOWN BIT(8) #define RENESAS_SDHI_SCC_TMPPORT2 0x81c #define RENESAS_SDHI_SCC_TMPPORT2_HS400EN BIT(31) #define RENESAS_SDHI_SCC_TMPPORT2_HS400OSEL BIT(4) @@ -87,6 +92,84 @@ static void sd_scc_tmpport_write32(struct tmio_sd_priv *priv, u32 addr, u32 val) tmio_sd_writel(priv, 0, RENESAS_SDHI_SCC_TMPPORT4); }
+static bool renesas_sdhi_check_scc_error(struct udevice *dev) +{ + struct tmio_sd_priv *priv = dev_get_priv(dev); + struct mmc *mmc = mmc_get_mmc_dev(dev); + unsigned long new_tap = priv->tap_set; + u32 reg, smpcmp; + + if ((priv->caps & TMIO_SD_CAP_RCAR_UHS) && + (mmc->selected_mode != UHS_SDR104) && + (mmc->selected_mode != MMC_HS_200) && + (mmc->selected_mode != MMC_HS_400) && + (priv->nrtaps != 4)) + return false; + + reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_RVSCNTL); + /* Handle automatic tuning correction */ + if (reg & RENESAS_SDHI_SCC_RVSCNTL_RVSEN) { + reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_RVSREQ); + if (reg & RENESAS_SDHI_SCC_RVSREQ_RVSERR) { + tmio_sd_writel(priv, 0, RENESAS_SDHI_SCC_RVSREQ); + return true; + } + + return false; + } + + /* Handle manual tuning correction */ + reg = tmio_sd_readl(priv, RENESAS_SDHI_SCC_RVSREQ); + if (!reg) /* No error */ + return false; + + tmio_sd_writel(priv, 0, RENESAS_SDHI_SCC_RVSREQ); + + if (mmc->selected_mode == MMC_HS_400) { + /* + * Correction Error Status contains CMD and DAT signal status. + * In HS400, DAT signal based on DS signal, not CLK. + * Therefore, use only CMD status. + */ + smpcmp = tmio_sd_readl(priv, RENESAS_SDHI_SCC_SMPCMP) & + RENESAS_SDHI_SCC_SMPCMP_CMD_ERR; + + switch (smpcmp) { + case 0: + return false; /* No error in CMD signal */ + case RENESAS_SDHI_SCC_SMPCMP_CMD_REQUP: + new_tap = (priv->tap_set + + priv->tap_num + 1) % priv->tap_num; + break; + case RENESAS_SDHI_SCC_SMPCMP_CMD_REQDOWN: + new_tap = (priv->tap_set + + priv->tap_num - 1) % priv->tap_num; + break; + default: + return true; /* Need re-tune */ + } + + priv->tap_set = new_tap; + } else { + if (reg & RENESAS_SDHI_SCC_RVSREQ_RVSERR) + return true; /* Need re-tune */ + else if (reg & RENESAS_SDHI_SCC_RVSREQ_REQTAPUP) + priv->tap_set = (priv->tap_set + + priv->tap_num + 1) % priv->tap_num; + else if (reg & RENESAS_SDHI_SCC_RVSREQ_REQTAPDOWN) + priv->tap_set = (priv->tap_set + + priv->tap_num - 1) % priv->tap_num; + else + return false; + } + + /* Set TAP position */ + tmio_sd_writel(priv, priv->tap_set >> ((priv->nrtaps == 4) ? 1 : 0), + RENESAS_SDHI_SCC_TAPSET); + + return false; +} + static void renesas_sdhi_adjust_hs400_mode_enable(struct tmio_sd_priv *priv) { u32 calib_code; @@ -536,6 +619,8 @@ static int renesas_sdhi_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, CONFIG_IS_ENABLED(MMC_HS400_SUPPORT) struct tmio_sd_priv *priv = dev_get_priv(dev);
+ renesas_sdhi_check_scc_error(dev); + if (cmd->cmdidx == MMC_CMD_SEND_STATUS) renesas_sdhi_adjust_hs400_mode_enable(priv); #endif
Some of the tuning taps produce suboptimal results. Add code which skips those "bad" taps.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 49 +++++++++++++++++++++++++++++++++++++- drivers/mmc/tmio-common.h | 1 + 2 files changed, 49 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index dcc77dd86c..087d8b47a8 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -97,6 +97,7 @@ static bool renesas_sdhi_check_scc_error(struct udevice *dev) struct tmio_sd_priv *priv = dev_get_priv(dev); struct mmc *mmc = mmc_get_mmc_dev(dev); unsigned long new_tap = priv->tap_set; + unsigned long error_tap = priv->tap_set; u32 reg, smpcmp;
if ((priv->caps & TMIO_SD_CAP_RCAR_UHS) && @@ -140,15 +141,32 @@ static bool renesas_sdhi_check_scc_error(struct udevice *dev) case RENESAS_SDHI_SCC_SMPCMP_CMD_REQUP: new_tap = (priv->tap_set + priv->tap_num + 1) % priv->tap_num; + error_tap = (priv->tap_set + + priv->tap_num - 1) % priv->tap_num; break; case RENESAS_SDHI_SCC_SMPCMP_CMD_REQDOWN: new_tap = (priv->tap_set + priv->tap_num - 1) % priv->tap_num; + error_tap = (priv->tap_set + + priv->tap_num + 1) % priv->tap_num; break; default: return true; /* Need re-tune */ }
+ if (priv->hs400_bad_tap & BIT(new_tap)) { + /* + * New tap is bad tap (cannot change). + * Compare with HS200 tuning result. + * In HS200 tuning, when smpcmp[error_tap] + * is OK, retune is executed. + */ + if (priv->smpcmp & BIT(error_tap)) + return true; /* Need retune */ + + return false; /* cannot change */ + } + priv->tap_set = new_tap; } else { if (reg & RENESAS_SDHI_SCC_RVSREQ_RVSERR) @@ -303,6 +321,7 @@ static int renesas_sdhi_hs400(struct udevice *dev) struct mmc *mmc = mmc_get_mmc_dev(dev); bool hs400 = (mmc->selected_mode == MMC_HS_400); int ret, taps = hs400 ? priv->nrtaps : 8; + unsigned long new_tap; u32 reg;
if (taps == 4) /* HS400 on 4tap SoC needs different clock */ @@ -335,6 +354,24 @@ static int renesas_sdhi_hs400(struct udevice *dev) RENESAS_SDHI_SCC_DTCNTL_TAPEN, RENESAS_SDHI_SCC_DTCNTL);
+ /* Avoid bad TAP */ + if (priv->hs400_bad_tap & BIT(priv->tap_set)) { + new_tap = (priv->tap_set + + priv->tap_num + 1) % priv->tap_num; + + if (priv->hs400_bad_tap & BIT(new_tap)) + new_tap = (priv->tap_set + + priv->tap_num - 1) % priv->tap_num; + + if (priv->hs400_bad_tap & BIT(new_tap)) { + new_tap = priv->tap_set; + debug("Three consecutive bad tap is prohibited\n"); + } + + priv->tap_set = new_tap; + tmio_sd_writel(priv, priv->tap_set, RENESAS_SDHI_SCC_TAPSET); + } + if (taps == 4) { tmio_sd_writel(priv, priv->tap_set >> 1, RENESAS_SDHI_SCC_TAPSET); @@ -682,13 +719,23 @@ static void renesas_sdhi_filter_caps(struct udevice *dev) (rmobile_get_cpu_rev_fraction() <= 2))) plat->cfg.host_caps &= ~MMC_MODE_HS400;
- /* M3W ES1.x for x>2 can use HS400 with manual adjustment */ + /* H3 ES2.0, ES3.0 and M3W ES1.2 and M3N bad taps */ + if (((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && + (rmobile_get_cpu_rev_integer() >= 2)) || + ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && + (rmobile_get_cpu_rev_integer() == 1) && + (rmobile_get_cpu_rev_fraction() == 2)) || + (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77965)) + priv->hs400_bad_tap = BIT(2) | BIT(3) | BIT(6) | BIT(7); + + /* M3W ES1.x for x>2 can use HS400 with manual adjustment and taps */ if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && (rmobile_get_cpu_rev_integer() == 1) && (rmobile_get_cpu_rev_fraction() > 2)) { priv->adjust_hs400_enable = true; priv->adjust_hs400_offset = 3; priv->adjust_hs400_calibrate = 0x9; + priv->hs400_bad_tap = BIT(1) | BIT(3) | BIT(5) | BIT(7); }
/* M3N can use HS400 with manual adjustment */ diff --git a/drivers/mmc/tmio-common.h b/drivers/mmc/tmio-common.h index 79f51d21af..f39118e337 100644 --- a/drivers/mmc/tmio-common.h +++ b/drivers/mmc/tmio-common.h @@ -145,6 +145,7 @@ struct tmio_sd_priv { bool adjust_hs400_enable; u8 adjust_hs400_offset; u8 adjust_hs400_calibrate; + u8 hs400_bad_tap; #endif ulong (*clk_get_rate)(struct tmio_sd_priv *); };
Instead of using single fixed value for the calibration offset, add tables which dynamically adjust this per calibration code from the SCC.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mmc/renesas-sdhi.c | 97 ++++++++++++++++++++++++++++++++------ drivers/mmc/tmio-common.h | 1 + 2 files changed, 83 insertions(+), 15 deletions(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 087d8b47a8..d47f24425b 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -63,6 +63,49 @@
#define RENESAS_SDHI_MAX_TAP 3
+#define CALIB_TABLE_MAX (RENESAS_SDHI_SCC_TMPPORT_CALIB_CODE_MASK + 1) + +static const u8 r8a7795_calib_table[2][CALIB_TABLE_MAX] = { + { 0, 0, 0, 0, 0, 1, 1, 2, 3, 4, 5, 5, 6, 6, 7, 11, + 15, 16, 16, 17, 17, 17, 17, 17, 18, 18, 18, 18, 19, 20, 21, 21 }, + { 3, 3, 4, 4, 5, 6, 6, 7, 8, 8, 9, 9, 10, 11, 12, 15, + 16, 16, 17, 17, 17, 17, 17, 18, 18, 18, 18, 19, 20, 21, 22, 22 } +}; + +static const u8 r8a7796_rev1_calib_table[2][CALIB_TABLE_MAX] = { + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 2, 3, 4, 9, + 15, 15, 15, 16, 16, 16, 16, 16, 17, 18, 19, 20, 21, 21, 22, 22 }, + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, + 2, 9, 16, 17, 17, 17, 18, 18, 18, 18, 19, 20, 21, 22, 23, 24} +}; + +static const u8 r8a7796_rev3_calib_table[2][CALIB_TABLE_MAX] = { + { 0, 0, 0, 0, 2, 3, 4, 4, 5, 6, 7, 7, 8, 9, 9, 10, + 11, 12, 13, 15, 16, 17, 17, 18, 19, 19, 20, 21, 21, 22, 23, 23 }, + { 1, 2, 2, 3, 4, 4, 5, 6, 6, 7, 8, 9, 9, 10, 11, 12, + 13, 14, 15, 16, 17, 17, 18, 19, 20, 20, 21, 22, 22, 23, 24, 24 } +}; + +static const u8 r8a77965_calib_table[2][CALIB_TABLE_MAX] = { + { 0, 1, 2, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15, + 16, 17, 18, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 29 }, + { 0, 1, 2, 2, 2, 3, 4, 5, 6, 7, 9, 10, 11, 12, 13, 15, + 16, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 31 } +}; + +static const u8 r8a77990_calib_table[2][CALIB_TABLE_MAX] = { + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, + { 0, 0, 1, 2, 3, 4, 4, 4, 4, 5, 5, 6, 7, 8, 10, 11, + 12, 13, 14, 16, 17, 18, 18, 18, 19, 19, 20, 24, 26, 26, 26, 26 } +}; + +static int rmobile_is_gen3_mmc0(struct tmio_sd_priv *priv) +{ + /* On R-Car Gen3, MMC0 is at 0xee140000 */ + return (uintptr_t)(priv->regbase) == 0xee140000; +} + static u32 sd_scc_tmpport_read32(struct tmio_sd_priv *priv, u32 addr) { /* read mode */ @@ -198,28 +241,30 @@ static void renesas_sdhi_adjust_hs400_mode_enable(struct tmio_sd_priv *priv) if (!priv->needs_adjust_hs400) return;
+ if (!priv->adjust_hs400_calib_table) + return; + /* * Enabled Manual adjust HS400 mode * * 1) Disabled Write Protect * W(addr=0x00, WP_DISABLE_CODE) - * 2) Read Calibration code and adjust - * R(addr=0x26) - adjust value - * 3) Enabled Manual Calibration + * + * 2) Read Calibration code + * read_value = R(addr=0x26) + * 3) Refer to calibration table + * Calibration code = table[read_value] + * 4) Enabled Manual Calibration * W(addr=0x22, manual mode | Calibration code) - * 4) Set Offset value to TMPPORT3 Reg + * 5) Set Offset value to TMPPORT3 Reg */ sd_scc_tmpport_write32(priv, 0x00, RENESAS_SDHI_SCC_TMPPORT_DISABLE_WP_CODE); calib_code = sd_scc_tmpport_read32(priv, 0x26); calib_code &= RENESAS_SDHI_SCC_TMPPORT_CALIB_CODE_MASK; - if (calib_code > priv->adjust_hs400_calibrate) - calib_code -= priv->adjust_hs400_calibrate; - else - calib_code = 0; sd_scc_tmpport_write32(priv, 0x22, RENESAS_SDHI_SCC_TMPPORT_MANUAL_MODE | - calib_code); + priv->adjust_hs400_calib_table[calib_code]); tmio_sd_writel(priv, priv->adjust_hs400_offset, RENESAS_SDHI_SCC_TMPPORT3);
@@ -711,12 +756,12 @@ static void renesas_sdhi_filter_caps(struct udevice *dev) if (!(priv->caps & TMIO_SD_CAP_RCAR_GEN3)) return;
- /* HS400 is not supported on H3 ES1.x and M3W ES1.0,ES1.1,ES1.2 */ + /* HS400 is not supported on H3 ES1.x and M3W ES1.0, ES1.1 */ if (((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && (rmobile_get_cpu_rev_integer() <= 1)) || ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && (rmobile_get_cpu_rev_integer() == 1) && - (rmobile_get_cpu_rev_fraction() <= 2))) + (rmobile_get_cpu_rev_fraction() < 2))) plat->cfg.host_caps &= ~MMC_MODE_HS400;
/* H3 ES2.0, ES3.0 and M3W ES1.2 and M3N bad taps */ @@ -728,28 +773,50 @@ static void renesas_sdhi_filter_caps(struct udevice *dev) (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77965)) priv->hs400_bad_tap = BIT(2) | BIT(3) | BIT(6) | BIT(7);
+ /* H3 ES3.0 can use HS400 with manual adjustment */ + if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && + (rmobile_get_cpu_rev_integer() >= 3)) { + priv->adjust_hs400_enable = true; + priv->adjust_hs400_offset = 0; + priv->adjust_hs400_calib_table = + r8a7795_calib_table[!rmobile_is_gen3_mmc0(priv)]; + } + + /* M3W ES1.2 can use HS400 with manual adjustment */ + if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && + (rmobile_get_cpu_rev_integer() == 1) && + (rmobile_get_cpu_rev_fraction() == 2)) { + priv->adjust_hs400_enable = true; + priv->adjust_hs400_offset = 3; + priv->adjust_hs400_calib_table = + r8a7796_rev1_calib_table[!rmobile_is_gen3_mmc0(priv)]; + } + /* M3W ES1.x for x>2 can use HS400 with manual adjustment and taps */ if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && (rmobile_get_cpu_rev_integer() == 1) && (rmobile_get_cpu_rev_fraction() > 2)) { priv->adjust_hs400_enable = true; - priv->adjust_hs400_offset = 3; - priv->adjust_hs400_calibrate = 0x9; + priv->adjust_hs400_offset = 0; priv->hs400_bad_tap = BIT(1) | BIT(3) | BIT(5) | BIT(7); + priv->adjust_hs400_calib_table = + r8a7796_rev3_calib_table[!rmobile_is_gen3_mmc0(priv)]; }
/* M3N can use HS400 with manual adjustment */ if (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77965) { priv->adjust_hs400_enable = true; priv->adjust_hs400_offset = 3; - priv->adjust_hs400_calibrate = 0x0; + priv->adjust_hs400_calib_table = + r8a77965_calib_table[!rmobile_is_gen3_mmc0(priv)]; }
/* E3 can use HS400 with manual adjustment */ if (rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A77990) { priv->adjust_hs400_enable = true; priv->adjust_hs400_offset = 3; - priv->adjust_hs400_calibrate = 0x4; + priv->adjust_hs400_calib_table = + r8a77990_calib_table[!rmobile_is_gen3_mmc0(priv)]; }
/* H3 ES1.x, ES2.0 and M3W ES1.0, ES1.1, ES1.2 uses 4 tuning taps */ diff --git a/drivers/mmc/tmio-common.h b/drivers/mmc/tmio-common.h index f39118e337..047458849b 100644 --- a/drivers/mmc/tmio-common.h +++ b/drivers/mmc/tmio-common.h @@ -146,6 +146,7 @@ struct tmio_sd_priv { u8 adjust_hs400_offset; u8 adjust_hs400_calibrate; u8 hs400_bad_tap; + const u8 *adjust_hs400_calib_table; #endif ulong (*clk_get_rate)(struct tmio_sd_priv *); };
Hi Marek,
Subject: [PATCH 9/9] mmc: tmio: sdhi: Add calibration tables
CI failed with your patchset, https://travis-ci.org/MrVan/u-boot/jobs/614839247 +==================================================== arm: + alt +drivers/mmc/renesas-sdhi.c: In function 'renesas_sdhi_filter_caps': +drivers/mmc/renesas-sdhi.c:782:4: error: 'r8a7795_calib_table' undeclared (first use in this function) + r8a7795_calib_table[!rmobile_is_gen3_mmc0(priv)]; + ^~~~~~~~~~~~~~~~~~~ +drivers/mmc/renesas-sdhi.c:782:4: note: each undeclared identifier is reported only once for each function it appears in +drivers/mmc/renesas-sdhi.c:782:25: error: implicit declaration of function 'rmobile_is_gen3_mmc0' [-Werror=implicit-function-declaration] + ^~~~~~~~~~~~~~~~~~~~ +drivers/mmc/renesas-sdhi.c:792:4: error: 'r8a7796_rev1_calib_table' undeclared (first use in this function); did you mean 'r8a7795_calib_table'? + r8a7796_rev1_calib_table[!rmobile_is_gen3_mmc0(priv)]; + ^~~~~~~~~~~~~~~~~~~~~~~~ + r8a7795_calib_table +drivers/mmc/renesas-sdhi.c:803:4: error: 'r8a7796_rev3_calib_table' undeclared (first use in this function); did you mean 'r8a7796_rev1_calib_table'? + r8a7796_rev3_calib_table[!rmobile_is_gen3_mmc0(priv)]; + r8a7796_rev1_calib_table +drivers/mmc/renesas-sdhi.c:811:4: error: 'r8a77965_calib_table' undeclared (first use in this function); did you mean 'r8a7795_calib_table'? + r8a77965_calib_table[!rmobile_is_gen3_mmc0(priv)]; + ^~~~~~~~~~~~~~~~~~~~
Please check,
Thanks, Peng.
- { 0, 0, 0, 0, 0, 1, 1, 2, 3, 4, 5, 5, 6, 6, 7, 11,
- { 3, 3, 4, 4, 5, 6, 6, 7, 8, 8, 9, 9, 10, 11, 12, 15,
16, 16, 17, 17, 17, 17, 17, 18, 18, 18, 18, 19, 20, 21, 22, 22 } };
- { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 2, 3, 4, 9,
- { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1,
2, 9, 16, 17, 17, 17, 18, 18, 18, 18, 19, 20, 21, 22, 23, 24} };
- { 0, 0, 0, 0, 2, 3, 4, 4, 5, 6, 7, 7, 8, 9, 9, 10,
- { 1, 2, 2, 3, 4, 4, 5, 6, 6, 7, 8, 9, 9, 10, 11, 12,
13, 14, 15, 16, 17, 17, 18, 19, 20, 20, 21, 22, 22, 23, 24, 24 } };
- { 0, 1, 2, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15,
- { 0, 1, 2, 2, 2, 3, 4, 5, 6, 7, 9, 10, 11, 12, 13, 15,
16, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 31 } };
- { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- { 0, 0, 1, 2, 3, 4, 4, 4, 4, 5, 5, 6, 7, 8, 10, 11,
12, 13, 14, 16, 17, 18, 18, 18, 19, 19, 20, 24, 26, 26, 26, 26 } };
+static int rmobile_is_gen3_mmc0(struct tmio_sd_priv *priv) {
- /* On R-Car Gen3, MMC0 is at 0xee140000 */
- return (uintptr_t)(priv->regbase) == 0xee140000; }
- if (!priv->adjust_hs400_calib_table)
return;
- Enabled Manual adjust HS400 mode
- Disabled Write Protect
- W(addr=0x00, WP_DISABLE_CODE)
- W(addr=0x22, manual mode | Calibration code)
*/ sd_scc_tmpport_write32(priv, 0x00, RENESAS_SDHI_SCC_TMPPORT_DISABLE_WP_CODE); calib_code = sd_scc_tmpport_read32(priv, 0x26); calib_code &= RENESAS_SDHI_SCC_TMPPORT_CALIB_CODE_MASK;* 5) Set Offset value to TMPPORT3 Reg
- else
sd_scc_tmpport_write32(priv, 0x22, RENESAS_SDHI_SCC_TMPPORT_MANUAL_MODE |calib_code = 0;
calib_code);
tmio_sd_writel(priv, priv->adjust_hs400_offset, RENESAS_SDHI_SCC_TMPPORT3);priv->adjust_hs400_calib_table[calib_code]);
- /* HS400 is not supported on H3 ES1.x and M3W ES1.0, ES1.1 */ if (((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7795) && (rmobile_get_cpu_rev_integer() <= 1)) || ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) && (rmobile_get_cpu_rev_integer() == 1) &&
- /* H3 ES3.0 can use HS400 with manual adjustment */
- /* M3W ES1.2 can use HS400 with manual adjustment */
- if ((rmobile_get_cpu_type() == RMOBILE_CPU_TYPE_R8A7796) &&
- /* M3W ES1.x for x>2 can use HS400 with manual adjustment and taps
- const u8 *adjust_hs400_calib_table;
#endif ulong (*clk_get_rate)(struct tmio_sd_priv *); }; -- 2.24.0.rc1
On 11/22/19 7:22 AM, Peng Fan wrote:
Hi Marek,
- r8a7795_calib_table[!rmobile_is_gen3_mmc0(priv)];
- r8a7796_rev1_calib_table[!rmobile_is_gen3_mmc0(priv)];
- r8a7796_rev3_calib_table[!rmobile_is_gen3_mmc0(priv)];
- r8a77965_calib_table[!rmobile_is_gen3_mmc0(priv)];
Please check,
Ah, I sent a V2.
Subject: [PATCH 1/9] mmc: tmio: sdhi: Track current tap number in private data
After CI https://travis-ci.org/MrVan/u-boot/builds/614839218 patchset will show in mmc/master.
Thanks, Peng.
- for (i = 0; i < priv->tap_num * 2; i++) { if (!(taps & BIT(i))) {
} if (!(smpcmp & BIT(i))) {taps &= ~BIT((i % priv->tap_num) + priv->tap_num);
} }smpcmp &= ~BIT((i % priv->tap_num) + priv->tap_num);
- for (i = 0; i < priv->tap_num * 2; i++) { if (taps & BIT(i)) ntap++; else {
- if (tap_cnt == priv->tap_num * 2) { match_cnt = 0; ntap = 0; tap_start = 0; tap_end = 0;
if (select)
else return -EIO;priv->tap_set = ((tap_start + tap_end) / 2) % priv->tap_num;
- priv->tap_num = tap_num;
- if (priv->tap_num * 2 >= sizeof(taps) * 8) { dev_err(dev, "Too many taps, skipping tuning. Please consider updating size
- u8 tap_num; u8 nrtaps; bool needs_adjust_hs400; bool adjust_hs400_enable;
-- 2.24.0.rc1
Peng Fan
