[U-Boot-Users] [PATCH] Support for new board, gth2
* Patch by Thomas Lange Aug 11 2005 - Add support for gth2 board
Changes to common files: * common/cmd_ide.c Swap input data if GTH2 and Big endian
* cpu/mips/au1x00_serial.c Call GTH2 log functions. Make sure watchdog is kicked
* cpu/mips/cpu.c If gth2, hang during reset until hardware watchdog kicks in
* include/asm-mips/au1x00.h Add GPIO definitions
/Thomas
In message 42FB8730.1060809@corelatus.se you wrote:
- Patch by Thomas Lange Aug 11 2005
Partially applied. The following parts were rejected and should be re-submitted after cleanup:
cpu/mips/au1x00_serial.c:
* No board specific code should be necessary here. * No watchdog reset should ever be needed in serial_tstc()
cpu/mips/cpu.c:
All other parts applied, thanks.
Thomas Lange
