[PATCH] binman: Don't change the descriptor in tests
At present testPackX86RomMeNoDesc removes the contents of the descriptor.bin file and testPackX86RomMeMissingDesc removes the file completely.
If a test that relies on this file happens to run after it is removed, it will not work. Since we have no control over the selecting of tests that run in parallel and series, we must avoid changing the files.
Update this tests to use separate files instead.
tools/binman/ftest.py | 8 +++---- tools/binman/test/163_x86_rom_me_empty.dts | 22 ++++++++++++++++++++ tools/binman/test/164_x86_rom_me_missing.dts | 22 ++++++++++++++++++++ 3 files changed, 47 insertions(+), 5 deletions(-) create mode 100644 tools/binman/test/163_x86_rom_me_empty.dts create mode 100644 tools/binman/test/164_x86_rom_me_missing.dts
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index ea72eff8c5..bf7f59fb84 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -940,9 +940,9 @@ class TestFunctional(unittest.TestCase): def testPackX86RomMeNoDesc(self): """Test that an invalid Intel descriptor entry is detected""" try: - TestFunctional._MakeInputFile('descriptor.bin', b'') + TestFunctional._MakeInputFile('descriptor-empty.bin', b'') with self.assertRaises(ValueError) as e: - self._DoTestFile('031_x86_rom_me.dts') + self._DoTestFile('163_x86_rom_me_empty.dts') self.assertIn("Node '/binman/intel-descriptor': Cannot find Intel Flash Descriptor (FD) signature", str(e.exception)) finally: @@ -3405,10 +3405,8 @@ class TestFunctional(unittest.TestCase):
def testPackX86RomMeMissingDesc(self): """Test that an missing Intel descriptor entry is allowed""" - pathname = os.path.join(self._indir, 'descriptor.bin') - os.remove(pathname) with test_util.capture_sys_output() as (stdout, stderr): - self._DoTestFile('031_x86_rom_me.dts', allow_missing=True) + self._DoTestFile('164_x86_rom_me_missing.dts', allow_missing=True) err = stderr.getvalue() self.assertRegex(err, "Image 'main-section'.*missing.*: intel-descriptor") diff --git a/tools/binman/test/163_x86_rom_me_empty.dts b/tools/binman/test/163_x86_rom_me_empty.dts new file mode 100644 index 0000000000..9349d2d724 --- /dev/null +++ b/tools/binman/test/163_x86_rom_me_empty.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-offset; + end-at-4gb; + size = <0x800000>; + intel-descriptor { + filename = "descriptor-empty.bin"; + }; + + intel-me { + filename = "me.bin"; + offset-unset; + }; + }; +}; diff --git a/tools/binman/test/164_x86_rom_me_missing.dts b/tools/binman/test/164_x86_rom_me_missing.dts new file mode 100644 index 0000000000..dce3be5e05 --- /dev/null +++ b/tools/binman/test/164_x86_rom_me_missing.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-offset; + end-at-4gb; + size = <0x800000>; + intel-descriptor { + filename = "descriptor-missing.bin"; + }; + + intel-me { + filename = "me.bin"; + offset-unset; + }; + }; +};
Applied to u-boot-dm.
