[U-Boot] [PATCH] powerpc/85xx: Cleanup some QE related defines
Move some processor specific QE defines into config_mpc85xx.h and use QE_MURAM_SIZE to cleanup some ifdef mess in the QE immap struct.
Also fixed up some comment style issues in immap_qe.h
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/include/asm/config_mpc85xx.h | 6 ++ arch/powerpc/include/asm/immap_qe.h | 98 +++++++++-------------------- 2 files changed, 37 insertions(+), 67 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index bef88ce..4e7c179 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -67,11 +67,17 @@ #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 10 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define QE_MURAM_SIZE 0x10000UL +#define MAX_QE_RISC 2 +#define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_MPC8569) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 10 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define QE_MURAM_SIZE 0x20000UL +#define MAX_QE_RISC 4 +#define QE_NUM_OF_SNUM 46
#elif defined(CONFIG_MPC8572) #define CONFIG_MAX_CPUS 2 diff --git a/arch/powerpc/include/asm/immap_qe.h b/arch/powerpc/include/asm/immap_qe.h index 531cfc8..9be9dca 100644 --- a/arch/powerpc/include/asm/immap_qe.h +++ b/arch/powerpc/include/asm/immap_qe.h @@ -3,7 +3,7 @@ * The Internal Memory Map for devices with QE on them. This * is the superset of all QE devices (8360, etc.). * - * Copyright (c) 2006-2009 Freescale Semiconductor, Inc. + * Copyright (c) 2006-2009, 2011 Freescale Semiconductor, Inc. * Author: Shlomi Gridih gridish@freescale.com * * This program is free software; you can redistribute it and/or modify it @@ -15,8 +15,19 @@ #ifndef __IMMAP_QE_H__ #define __IMMAP_QE_H__
-/* QE I-RAM -*/ +#ifdef CONFIG_MPC83xx +#if defined(CONFIG_MPC8360) +#define QE_MURAM_SIZE 0xc000UL +#define MAX_QE_RISC 2 +#define QE_NUM_OF_SNUM 28 +#elif defined(CONFIG_MPC832x) +#define QE_MURAM_SIZE 0x4000UL +#define MAX_QE_RISC 1 +#define QE_NUM_OF_SNUM 28 +#endif +#endif + +/* QE I-RAM */ typedef struct qe_iram { u32 iadd; /* I-RAM Address Register */ u32 idata; /* I-RAM Data Register */ @@ -25,8 +36,7 @@ typedef struct qe_iram { u8 res1[0x70]; } __attribute__ ((packed)) qe_iram_t;
-/* QE Interrupt Controller -*/ +/* QE Interrupt Controller */ typedef struct qe_ic { u32 qicr; u32 qivec; @@ -49,8 +59,7 @@ typedef struct qe_ic { u8 res3[0x1C]; } __attribute__ ((packed)) qe_ic_t;
-/* Communications Processor -*/ +/* Communications Processor */ typedef struct cp_qe { u32 cecr; /* QE command register */ u32 ceccr; /* QE controller configuration register */ @@ -87,8 +96,7 @@ typedef struct cp_qe { u8 res13[0x280]; } __attribute__ ((packed)) cp_qe_t;
-/* QE Multiplexer -*/ +/* QE Multiplexer */ typedef struct qe_mux { u32 cmxgcr; /* CMX general clock route register */ u32 cmxsi1cr_l; /* CMX SI1 clock route low register */ @@ -102,8 +110,7 @@ typedef struct qe_mux { u8 res0[0x1C]; } __attribute__ ((packed)) qe_mux_t;
-/* QE Timers -*/ +/* QE Timers */ typedef struct qe_timers { u8 gtcfr1; /* Timer 1 2 global configuration register */ u8 res0[0x3]; @@ -133,8 +140,7 @@ typedef struct qe_timers { u8 res2[0x46]; } __attribute__ ((packed)) qe_timers_t;
-/* BRG -*/ +/* BRG */ typedef struct qe_brg { u32 brgc1; /* BRG1 configuration register */ u32 brgc2; /* BRG2 configuration register */ @@ -155,8 +161,7 @@ typedef struct qe_brg { u8 res0[0x40]; } __attribute__ ((packed)) qe_brg_t;
-/* SPI -*/ +/* SPI */ typedef struct spi { u8 res0[0x20]; u32 spmode; /* SPI mode register */ @@ -174,8 +179,7 @@ typedef struct spi { u8 res7[0x8]; } __attribute__ ((packed)) spi_t;
-/* SI -*/ +/* SI */ typedef struct si1 { u16 siamr1; /* SI1 TDMA mode register */ u16 sibmr1; /* SI1 TDMB mode register */ @@ -222,16 +226,14 @@ typedef struct si1 { u8 res9[0xBB]; } __attribute__ ((packed)) si1_t;
-/* SI Routing Tables -*/ +/* SI Routing Tables */ typedef struct sir { u8 tx[0x400]; u8 rx[0x400]; u8 res0[0x800]; } __attribute__ ((packed)) sir_t;
-/* USB Controller. -*/ +/* USB Controller. */ typedef struct usb_ctlr { u8 usb_usmod; u8 usb_usadr; @@ -253,8 +255,7 @@ typedef struct usb_ctlr { u8 res6[0x22]; } __attribute__ ((packed)) usb_t;
-/* MCC -*/ +/* MCC */ typedef struct mcc { u32 mcce; /* MCC event register */ u32 mccm; /* MCC mask register */ @@ -263,8 +264,7 @@ typedef struct mcc { u8 res0[0xF0]; } __attribute__ ((packed)) mcc_t;
-/* QE UCC Slow -*/ +/* QE UCC Slow */ typedef struct ucc_slow { u32 gumr_l; /* UCCx general mode register (low) */ u32 gumr_h; /* UCCx general mode register (high) */ @@ -368,8 +368,7 @@ typedef struct ucc_ethernet { u8 res5[0x200 - 0x1c4]; } __attribute__ ((packed)) uec_t;
-/* QE UCC Fast -*/ +/* QE UCC Fast */ typedef struct ucc_fast { u32 gumr; /* UCCx general mode register */ u32 upsmr; /* UCCx protocol-specific mode register */ @@ -403,8 +402,7 @@ typedef struct ucc_fast { uec_t ucc_eth; } __attribute__ ((packed)) ucc_fast_t;
-/* QE UCC -*/ +/* QE UCC */ typedef struct ucc_common { u8 res1[0x90]; u8 guemr; @@ -419,8 +417,7 @@ typedef struct ucc { }; } __attribute__ ((packed)) ucc_t;
-/* MultiPHY UTOPIA POS Controllers (UPC) -*/ +/* MultiPHY UTOPIA POS Controllers (UPC) */ typedef struct upc { u32 upgcr; /* UTOPIA/POS general configuration register */ u32 uplpa; /* UTOPIA/POS last PHY address */ @@ -476,8 +473,7 @@ typedef struct upc { u8 res2[0x150]; } __attribute__ ((packed)) upc_t;
-/* SDMA -*/ +/* SDMA */ typedef struct sdma { u32 sdsr; /* Serial DMA status register */ u32 sdmr; /* Serial DMA mode register */ @@ -497,8 +493,7 @@ typedef struct sdma { u8 res2[0x38]; } __attribute__ ((packed)) sdma_t;
-/* Debug Space -*/ +/* Debug Space */ typedef struct dbg { u32 bpdcr; /* Breakpoint debug command register */ u32 bpdsr; /* Breakpoint debug status register */ @@ -582,40 +577,9 @@ typedef struct qe_immap { u8 res14[0x300]; u8 res15[0x3A00]; u8 res16[0x8000]; /* 0x108000 - 0x110000 */ -#if defined(CONFIG_MPC8568) - u8 muram[0x10000]; /* 0x1_0000 - 0x2_0000 Multi-user RAM */ - u8 res17[0x20000]; /* 0x2_0000 - 0x4_0000 */ -#elif defined(CONFIG_MPC8569) - u8 muram[0x20000]; /* 0x1_0000 - 0x3_0000 Multi-user RAM */ - u8 res17[0x10000]; /* 0x3_0000 - 0x4_0000 */ -#else - u8 muram[0xC000]; /* 0x110000 - 0x11C000 Multi-user RAM */ - u8 res17[0x24000]; /* 0x11C000 - 0x140000 */ - u8 res18[0xC0000]; /* 0x140000 - 0x200000 */ -#endif + u8 muram[QE_MURAM_SIZE]; } __attribute__ ((packed)) qe_map_t;
extern qe_map_t *qe_immr;
-#if defined(CONFIG_MPC8568) -#define QE_MURAM_SIZE 0x10000UL -#elif defined(CONFIG_MPC8569) -#define QE_MURAM_SIZE 0x20000UL -#elif defined(CONFIG_MPC8360) -#define QE_MURAM_SIZE 0xc000UL -#elif defined(CONFIG_MPC832x) -#define QE_MURAM_SIZE 0x4000UL -#endif - -#if defined(CONFIG_MPC8323) -#define MAX_QE_RISC 1 -#define QE_NUM_OF_SNUM 28 -#elif defined(CONFIG_MPC8569) -#define MAX_QE_RISC 4 -#define QE_NUM_OF_SNUM 46 -#else -#define MAX_QE_RISC 2 -#define QE_NUM_OF_SNUM 28 -#endif - #endif /* __IMMAP_QE_H__ */
applied to 85xx next
- k
Kumar Gala
