U-Boot FIT Signature Verification
Hi there,
Does U-boot take into account certificate expiration date when verifying signed images in FIT? In other words, is date stored along with the public key in DTB file?
Cheers, Andy
On 9/11/20 7:26 PM, Andrii Voloshyn wrote:
Hi there,
Cheers, Andy
Hello Philippe,
looking at padding_pkcs_15_verify() in lib/rsa/rsa-verify.c I cannot find a comparison of the date on which an image was signed with the expiry date of the certificate. Shouldn't there be a check? Or did I simply look into the wrong function?
Best regards
Heinrich
Hi there,
Cheers, Andy
Hello Philippe,
I think Simon is the right person to answer this question, but
as far as I know, we don't have any device tree property for the expiration date of a public key. See doc/uImage.FIT/signature.txt.
-Takahiro Akashi
Best regards
Heinrich
Hi there,
Cheers, Andy
Hello Philippe,
Yes, the problem starts with mkimage not writing the dates available in the X509 certificate into the device tree.
The dates are accessible via the X509_get0_notBefore() and X509_get0_notAfter() functions of the OpenSSL library.
Takahiro, could you, please, also look at the UEFI secure boot implementation in U-Boot. EDK2 validates the dates via the embedded OpenSSL library in CryptoPkg/Library/OpensslLib/openssl/crypto/x509/x509_vfy.c, function verify_chain(). We should not do less.
Best regards
Heinrich
On Wed, 2020-09-16 at 13:14 +0200, Heinrich Schuchardt wrote:
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
Hi there,
Cheers, Andy
Hello Philippe,
Does that mean that verified boot stops/fails when the date expires ? How do you guarantee that the device has the correct time ?
Jocke
Hi there,
Cheers, Andy
Hello Philippe,
Jocke
We talking of the validity time range of the public key and the date of signature of the intermediate certificates and the loaded image. No RTC time is involved.
Best regards
Heinrich
Hi there,
Cheers, Andy
Hello Philippe,
Jocke
OK, but still: will an invalid time range then stop booting ?
On 9/11/20 7:26 PM, Andrii Voloshyn wrote: > Hi there, > > Does U-boot take into account certificate expiration date when verifying signed images in FIT? In other words, is date stored along with the public key in DTB file? > > Cheers, > Andy >
Hello Philippe,
Jocke
If you use a certificate that is valid until 2019 to sign an image or an intermediate certificate in 2020, the image must not be loaded.
Best regards
Heinrich
On Wed, Sep 16, 2020 at 01:19:03AM +0200, Heinrich Schuchardt wrote: > On 9/11/20 7:26 PM, Andrii Voloshyn wrote: >> Hi there, >> >> Does U-boot take into account certificate expiration date when verifying signed images in FIT? In other words, is date stored along with the public key in DTB file? >> >> Cheers, >> Andy >> > > Hello Philippe, > > looking at padding_pkcs_15_verify() in lib/rsa/rsa-verify.c I cannot > find a comparison of the date on which an image was signed with the > expiry date of the certificate. Shouldn't there be a check? Or did I > simply look into the wrong function?
Jocke
Right. And to be clear, the case of using a valid until 2021 cert to sign everything in 2020 will be seen as valid in 2022.
Jocke
Well, I'm not confident that pckcs7_verify_one() does this. (Probably not.)
-Takahiro Akashi
Best regards
Heinrich
Hi there,
Cheers, Andy
Hello Philippe,
Good point. Reither had a similar comment.
For trusted timestamps, we need to support RFC3161 timestamp protocol when signing an image. During the image verification, the "signed" timestamp of the image will also be verified with a certificate in "dbt" database.
Well, this is in UEFI world, not FIT signature verification.
(I have a prototype of timestamp revocation implementation as part of UEFI secure boot on U-Boot, but never made it public yet.)
-Takahiro Akashi
Jocke
Hi there,
Cheers, Andy
Hello Philippe,
Yes, we do the check. See pkcs7_verify_one() in lib/crypto/pkcs7_verify.c.
-Takahiro Akashi
Best regards
Heinrich
Hi Heinrich,
Hi there,
Cheers, Andy
Hello Philippe,
This function only check the padding using the algorithm pkcs-1.5 as defined here : https://tools.ietf.org/html/rfc3447#section-9.2 It doesn't check the certificate validity.
I don't remember to have see a date checked in the signature process. If all informations are (or may be) available at runtime, we may add it.
Best regards
Heinrich
Best regards, Philippe
participants (7)
AKASHI Takahiro
Andrii Voloshyn
Joakim Tjernlund
Philippe REYNES
takahiro.akashi@linaro.org
