[U-Boot] [PATCH] arm, davinci: Fix setting of the SDRAM configuration register
da850_ddr_setup() expects the BOOTUNLOCK bit to be set in #define CONFIG_SYS_DA850_DDR2_SDBCR ... in include/configs/*.h If BOOTUNLOCK is not set in this define, several configuration bits will not be writeable and the code will not work.
Since the BOOTUNLOCK and TIMUNLOCK bits are not configuration options but access control bits, this patch changes the code to work irrespective of the value of these bits in CONFIG_SYS_DA850_DDR2_SDBCR.
Signed-off-by: Christian Riesch christian.riesch@omicron.at Cc: Heiko Schocher hs@denx.de Cc: Paulraj Sandeep s-paulraj@ti.com ---
This patch applies on top of these two patches: [PATCH v3 1/2] arm, davinci: Rename AM1808 lowlevel functions to DA850 [PATCH v3 2/2] arm, davinci: Remove the duplication of LPSC functions in da850_lowlevel.c
Best regards, Christian
arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 25 +++++++++++++++++----- 1 files changed, 19 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c index 490ef8f..6f72491 100644 --- a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c +++ b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c @@ -184,18 +184,31 @@ int da850_ddr_setup(unsigned int freq) clrbits_le32(&davinci_syscfg1_regs->ddr_slew, (1 << DDR_SLEW_CMOSEN_BIT));
+ /* + * SDRAM Configuration Register (SDCR): + * First set the BOOTUNLOCK bit to make configuration bits + * writeable. + */ setbits_le32(&dv_ddr2_regs_ctrl->sdbcr, DV_DDR_BOOTUNLOCK);
- writel((CONFIG_SYS_DA850_DDR2_SDBCR & ~0xf0000000) | - (readl(&dv_ddr2_regs_ctrl->sdbcr) & 0xf0000000), /*rsv Bytes*/ - &dv_ddr2_regs_ctrl->sdbcr); - writel(CONFIG_SYS_DA850_DDR2_SDBCR2, &dv_ddr2_regs_ctrl->sdbcr2); + /* + * Write the new value of these bits and clear BOOTUNLOCK. + * At the same time, set the TIMUNLOCK bit to allow changing + * the timing registers + */ + tmp = CONFIG_SYS_DA850_DDR2_SDBCR; + tmp &= ~(0x1 << DV_DDR_SDCR_BOOTUNLOCK_SHIFT); + tmp |= (0x1 << DV_DDR_SDCR_TIMUNLOCK_SHIFT); + writel(tmp, &dv_ddr2_regs_ctrl->sdbcr);
+ /* write memory configuration and timing */ + writel(CONFIG_SYS_DA850_DDR2_SDBCR2, &dv_ddr2_regs_ctrl->sdbcr2); writel(CONFIG_SYS_DA850_DDR2_SDTIMR, &dv_ddr2_regs_ctrl->sdtimr); writel(CONFIG_SYS_DA850_DDR2_SDTIMR2, &dv_ddr2_regs_ctrl->sdtimr2);
- clrbits_le32(&dv_ddr2_regs_ctrl->sdbcr, - (1 << DV_DDR_SDCR_TIMUNLOCK_SHIFT)); + /* clear the TIMUNLOCK bit and write the value of the CL field */ + tmp &= ~(0x1 << DV_DDR_SDCR_TIMUNLOCK_SHIFT); + writel(tmp, &dv_ddr2_regs_ctrl->sdbcr);
/* * LPMODEN and MCLKSTOPEN must be set!
Changes for v2: - Removed trailing whitespaces
diff --git a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c index 490ef8f..6f72491 100644 --- a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c +++ b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c @@ -184,19 +184,31 @@ int da850_ddr_setup(unsigned int freq) clrbits_le32(&davinci_syscfg1_regs->ddr_slew, (1 << DDR_SLEW_CMOSEN_BIT));
da850_ddr_setup() expects the BOOTUNLOCK bit to be set in If BOOTUNLOCK is not set in this define, several configuration bits will not be writeable and the code will not work.
Signed-off-by: Christian Riesch christian.riesch@omicron.at Cc: Heiko Schocher hs@denx.de Cc: Paulraj Sandeep s-paulraj@ti.com --- This patch applies on top of these two patches: [PATCH v3 1/2] arm, davinci: Rename AM1808 lowlevel functions to DA850 [PATCH v3 2/2] arm, davinci: Remove the duplication of LPSC functions in da850_lowlevel.c
Changes for v3: - v2 was broken and did not apply, sorry for that!
diff --git a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c index 490ef8f..327ff97 100644 --- a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c +++ b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c @@ -184,18 +184,31 @@ int da850_ddr_setup(unsigned int freq) clrbits_le32(&davinci_syscfg1_regs->ddr_slew, (1 << DDR_SLEW_CMOSEN_BIT));
Hello Christian,
Thanks! Tested on the enbw_cmc board, so:
Tested-by: Heiko Schocher hs@denx.de
bye, Heiko
Christian Riesch
Heiko Schocher
