[RESEND PATCH 0/3] env: mmc: allow support of mmc_get_env_dev with OF_CONTROL
Hi Joe,
It is a resend of previous serie [1] after rebase.
This serie provides several corrections on ENV suport in MMC partition. No code modification on this RESEND, tested on STM32MP157C-EV1.
[1] http://patchwork.ozlabs.org/project/uboot/list/?series=165325
Regards
Patrick
Patrick Delaunay (3): env: mmc: allow support of mmc_get_env_dev with OF_CONTROL env: mmc: correct the offset returned by mmc_offset_try_partition env: mmc: add redundancy support in mmc_offset_try_partition
env/mmc.c | 26 ++++++++++++++++---------- 1 file changed, 16 insertions(+), 10 deletions(-)
Use the weak function mmc_get_env_dev in mmc_offset_try_partition function to allow dynamic selection of mmc device to use and no more use directly the define CONFIG_SYS_MMC_ENV_DEV.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
env/mmc.c | 18 ++++++++++++------ 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index a8b661db80..e67ef90bce 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -24,14 +24,25 @@
DECLARE_GLOBAL_DATA_PTR;
+#if !defined(CONFIG_SYS_MMC_ENV_DEV) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +__weak int mmc_get_env_dev(void) +{ + return CONFIG_SYS_MMC_ENV_DEV; +} + #if CONFIG_IS_ENABLED(OF_CONTROL) static inline int mmc_offset_try_partition(const char *str, s64 *val) { struct disk_partition info; struct blk_desc *desc; int len, i, ret; + char dev_str[4];
- ret = blk_get_device_by_str("mmc", STR(CONFIG_SYS_MMC_ENV_DEV), &desc); + snprintf(dev_str, sizeof(dev_str), "%d", mmc_get_env_dev()); + ret = blk_get_device_by_str("mmc", dev_str, &desc); if (ret < 0) return (ret);
@@ -114,11 +125,6 @@ __weak int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) return 0; }
-__weak int mmc_get_env_dev(void) -{ - return CONFIG_SYS_MMC_ENV_DEV; -} - #ifdef CONFIG_SYS_MMC_ENV_PART __weak uint mmc_get_env_part(struct mmc *mmc) {
The output of the function mmc_offset_try_partition must be a byte offset in mmc and not a multiple of blksz.
This function is used in mmc_offset(), called by mmc_get_env_addr() and the offset is used in write_env(), erase_env() and read_env().
In these function, blk_start = offset / mmc->read_bl_len or /write_bl_len so this offset is not a multiple of blksz.
env/mmc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index e67ef90bce..5de4a45817 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -56,10 +56,10 @@ static inline int mmc_offset_try_partition(const char *str, s64 *val) }
/* round up to info.blksz */ - len = (CONFIG_ENV_SIZE + info.blksz - 1) & ~(info.blksz - 1); + len = DIV_ROUND_UP(CONFIG_ENV_SIZE, info.blksz);
/* use the top of the partion for the environment */ - *val = (info.start + info.size - 1) - len / info.blksz; + *val = (info.start + info.size - len) * info.blksz;
return 0; }
Manage 2 copy at the end of the partition selected by config "u-boot,mmc-env-partition" to save the U-Boot environment, with CONFIG_ENV_SIZE and 2*CONFIG_ENV_SIZE offset.
This patch allows to support redundancy (CONFIG_ENV_OFFSET_REDUND).
env/mmc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index 5de4a45817..aca61b75e9 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -34,7 +34,7 @@ __weak int mmc_get_env_dev(void) }
#if CONFIG_IS_ENABLED(OF_CONTROL) -static inline int mmc_offset_try_partition(const char *str, s64 *val) +static inline int mmc_offset_try_partition(const char *str, int copy, s64 *val) { struct disk_partition info; struct blk_desc *desc; @@ -59,7 +59,7 @@ static inline int mmc_offset_try_partition(const char *str, s64 *val) len = DIV_ROUND_UP(CONFIG_ENV_SIZE, info.blksz);
/* use the top of the partion for the environment */ - *val = (info.start + info.size - len) * info.blksz; + *val = (info.start + info.size - (1 + copy) * len) * info.blksz;
return 0; } @@ -84,7 +84,7 @@ static inline s64 mmc_offset(int copy) str = fdtdec_get_config_string(gd->fdt_blob, dt_prop.partition); if (str) { /* try to place the environment at end of the partition */ - err = mmc_offset_try_partition(str, &val); + err = mmc_offset_try_partition(str, copy, &val); if (!err) return val; }
Patrick Delaunay
