[U-Boot] [PATCH] mach-omap2: Cleanup secure boot media generation
Currently all secure media types of SPL are generated for all platforms, all platforms do not need all types, only generate the media types valid for each platform.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/mach-omap2/config.mk | 38 ++++++++++++++++++++++++++++---------- 1 file changed, 28 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-omap2/config.mk b/arch/arm/mach-omap2/config.mk index 20b555357a..af455366ed 100644 --- a/arch/arm/mach-omap2/config.mk +++ b/arch/arm/mach-omap2/config.mk @@ -6,34 +6,52 @@ include $(srctree)/arch/arm/mach-omap2/config_secure.mk
ifdef CONFIG_SPL_BUILD -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) +ifeq ($(CONFIG_TI_SECURE_DEVICE),y) # Refer to README.ti-secure for more info +# On DRA7xx/AM57xx: +# +# For booting spl from SD/MMC/eMMC use +# u-boot-spl_HS_MLO # -# For booting from SPI use -# u-boot-spl_HS_SPI_X-LOADER to program flash +# For booting spl over UART or USB use +# u-boot-spl_HS_ULO # +# For booting spl from QSPI or NOR use +# u-boot-spl_HS_X-LOADER +ifeq ($(CONFIG_OMAP54XX),y) +ALL-y += u-boot-spl_HS_MLO +ALL-y += u-boot-spl_HS_ULO +ALL-y += u-boot-spl_HS_X-LOADER +endif # On AM43XX: # +# For booting spl from SPI flash use +# u-boot-spl_HS_SPI_X-LOADER +# # For booting spl from all other media use # u-boot-spl_HS_ISSW -# +ifeq ($(CONFIG_AM43XX),y) +ALL-y += u-boot-spl_HS_SPI_X-LOADER +ALL-y += u-boot-spl_HS_ISSW +endif # On AM33XX: # -# For booting spl from NAND flash use +# For booting spl from SPI flash use +# u-boot-spl_HS_SPI_X-LOADER +# +# For booting spl from NAND flash or raw SD/MMC/eMMC use # u-boot-spl_HS_X-LOADER # -# For booting spl from SD/MMC/eMMC media use +# For booting spl from a filesystem on SD/MMC/eMMC use # u-boot-spl_HS_MLO # # For booting spl over UART, USB, or Ethernet use # u-boot-spl_HS_2ND -# -# Refer to README.ti-secure for more info -# -ALL-y += u-boot-spl_HS_ISSW +ifeq ($(CONFIG_AM33XX),y) ALL-y += u-boot-spl_HS_SPI_X-LOADER ALL-y += u-boot-spl_HS_X-LOADER ALL-y += u-boot-spl_HS_MLO ALL-y += u-boot-spl_HS_2ND +endif else ALL-y += MLO ifeq ($(CONFIG_AM33XX),y)
This fixed the build error on am57xx_hs_evm_defconfig.
Tested-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Lokesh Vutla lokeshvutla@ti.com
Andrew F. Davis
Lokesh Vutla
