[U-Boot] [PATCH 02/11] x86: bios: Synchronize stack between real and protected mode
PCI option rom may use different SS during its execution, so it is not safe to assume esp pointed to the same location in the protected mode.
Signed-off-by: Jian Luo jian.luo4@boschrexroth.de Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/lib/bios_asm.S | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/x86/lib/bios_asm.S b/arch/x86/lib/bios_asm.S index 4faa70e..a29fe0e 100644 --- a/arch/x86/lib/bios_asm.S +++ b/arch/x86/lib/bios_asm.S @@ -246,6 +246,8 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.) push %fs push %gs
+ movw %ss, %cs:__realmode_ss + /* Clear DF to not break ABI assumptions */ cld
@@ -258,12 +260,22 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.)
enter_protected_mode
+ movzwl %cs:__realmode_ss, %ecx + shll $4, %ecx + addl %ecx, %esp + /* Call the C interrupt handler */ movl $interrupt_handler, %eax call *%eax
+ movzwl %cs:__realmode_ss, %ecx + shll $4, %ecx + subl %ecx, %esp + enter_real_mode
+ movw %cs:__realmode_ss, %ss + /* * Restore all registers, including those manipulated by the C * handler @@ -276,6 +288,9 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.) popal iret
+__realmode_ss = PTR_TO_REAL_MODE(.) + .word 0 + .globl asm_realmode_code_size asm_realmode_code_size: .long . - asm_realmode_code
Please can you add a comment here for the next person who changes this, about what is going on? It looks like it is saving and restoring the real mode SS register?
shll $4, %ecx
addl %ecx, %esp
shll $4, %ecx
subl %ecx, %esp
enter_real_mode
.word 0
asm_realmode_code_size: .long . - asm_realmode_code -- 1.8.2.1
Hi Simon,
Will add a comment in v2.
shll $4, %ecx
addl %ecx, %esp
shll $4, %ecx
subl %ecx, %esp
enter_real_mode
.word 0
Regards, Bin
Bin Meng
