[PATCH 0/3] arm: mvebu: Add support for programming LD eFuse on Armada 385
This patch series add support for programming LD eFuse on Armada 385. I tested it on Turris Omnia board.
Armada 385 LD1 eFuse is for General Purpose Data and is already mapped to U-Boot fuse word 65.
Pali Rohár (3): arm: mvebu: Add support for programming LD0 and LD1 eFuse arm: mvebu: Add support for specifying VHV_Enable GPIO arm: mvebu: turris_omnia: Specify VHV gpio for eFUSE programming
arch/arm/mach-mvebu/Kconfig | 15 +++++ arch/arm/mach-mvebu/efuse.c | 83 +++++++++++++++++++++++- arch/arm/mach-mvebu/include/mach/efuse.h | 4 ++ configs/turris_omnia_defconfig | 2 + 4 files changed, 102 insertions(+), 2 deletions(-)
This patch implements LD eFuse programming support. Armada 385 contains two LD eFuse lines, each is 256 bit long with one additional lock bit. LD 0 line is mapped to U-Boot fuse bank 64 and LD 1 line to fuse bank 65. U-Boot 32-bit fuse words 0-8 are mapped to LD eFuse line bits 0-255. U-Boot fuse word 9 is mapped to LD eFuse line lock bit.
So to program LD 1 General Purpose Data line, use U-Boot fuse command:
=> fuse prog -y 65 0 0x76543210 => fuse prog -y 65 1 0xfedcba98 => fuse prog -y 65 2 0x76543210 => fuse prog -y 65 3 0xfedcba98 => fuse prog -y 65 4 0x76543210 => fuse prog -y 65 5 0xfedcba98 => fuse prog -y 65 6 0x76543210 => fuse prog -y 65 7 0xfedcba98 => fuse prog -y 65 8 0x1
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/efuse.c | 43 ++++++++++++++++++++++++ arch/arm/mach-mvebu/include/mach/efuse.h | 4 +++ 2 files changed, 47 insertions(+)
diff --git a/arch/arm/mach-mvebu/efuse.c b/arch/arm/mach-mvebu/efuse.c index 80318c339eb7..4b0433782171 100644 --- a/arch/arm/mach-mvebu/efuse.c +++ b/arch/arm/mach-mvebu/efuse.c @@ -132,6 +132,46 @@ static int prog_efuse(int nr, struct efuse_val *new_val, u32 mask0, u32 mask1) return res; }
+int mvebu_prog_ld_efuse(int ld1, u32 word, u32 val) +{ + int i, res; + u32 line[EFUSE_LD_WORDS]; + + res = mvebu_efuse_init_hw(); + if (res) + return res; + + mvebu_read_ld_efuse(ld1, line); + + /* check if lock bit is already programmed */ + if (line[EFUSE_LD_WORDS - 1]) + return -EPERM; + + /* check if word is valid */ + if (word >= EFUSE_LD_WORDS) + return -EINVAL; + + /* check if there is some bit for programming */ + if (val == (line[word] & val)) + return 0; + + enable_efuse_program(); + + mvebu_read_ld_efuse(ld1, line); + line[word] |= val; + + for (i = 0; i < EFUSE_LD_WORDS; i++) { + writel(line[i], ld_efuses + i); + mdelay(1); + } + + mdelay(5); + + disable_efuse_program(); + + return 0; +} + int mvebu_efuse_init_hw(void) { int ret; @@ -254,6 +294,9 @@ int fuse_prog(u32 bank, u32 word, u32 val) { int res = 0;
+ if (bank == EFUSE_LD0_LINE || bank == EFUSE_LD1_LINE) + return mvebu_prog_ld_efuse(bank == EFUSE_LD1_LINE, word, val); + /* * NOTE: Fuse line should be written as whole. * So how can we do that with this API? diff --git a/arch/arm/mach-mvebu/include/mach/efuse.h b/arch/arm/mach-mvebu/include/mach/efuse.h index 122e735f2fc7..b125c30beb8c 100644 --- a/arch/arm/mach-mvebu/include/mach/efuse.h +++ b/arch/arm/mach-mvebu/include/mach/efuse.h @@ -70,4 +70,8 @@ int mvebu_write_efuse(int nr, struct efuse_val *val);
int mvebu_lock_efuse(int nr);
+void mvebu_read_ld_efuse(int ld1, u32 *line); + +int mvebu_prog_ld_efuse(int ld1, u32 word, u32 val); + #endif
VHV_Enable GPIO is required to enable during eFuse programming on Armada SoCs not from 3700 family. Add support for enabling and disabling VHV pin via GPIO during eFuse programming, when specified.
All details are in Marvell AN-389: ARMADA VHV Power document (Doc. No. MV-S302545-00 Rev. C, August 2, 2016).
Note that due to HW Errata 3.6 eFuse erroneous burning (Ref #: HWE-3718342) VHV power must be disabled while core voltage is off to prevent erroneous eFuse programming.
This is specified in Marvell ARMADA 380/385/388 Functional Errata, Guidelines, and Restrictions document (Doc. No. MV-S501377-00 Rev. D, December 1, 2016).
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/Kconfig | 15 +++++++++++++ arch/arm/mach-mvebu/efuse.c | 42 ++++++++++++++++++++++++++++++++++--- 2 files changed, 54 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index a81b8e2b0df2..d41a0a087bd1 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -347,6 +347,21 @@ config MVEBU_EFUSE_FAKE from a memory block. This is can be used for testing prog scripts.
+config MVEBU_EFUSE_VHV_GPIO + string "VHV_Enable GPIO name for eFuse programming" + depends on MVEBU_EFUSE && !ARMADA_3700 + help + The eFuse programing (burning) phase requires supplying 1.8V to the + device on the VHV power pin, while for normal operation the VHV power + rail must be left unconnected. See Marvell AN-389: ARMADA VHV Power + document (Doc. No. MV-S302545-00 Rev. C, August 2, 2016) for details. + . + This specify VHV_Enable GPIO name used in U-Boot for enabling VHV power. + +config MVEBU_EFUSE_VHV_GPIO_ACTIVE_LOW + bool "VHV_Enable GPIO is Active Low" + depends on MVEBU_EFUSE_VHV_GPIO != "" + config SECURED_MODE_IMAGE bool "Build image for trusted boot" default false diff --git a/arch/arm/mach-mvebu/efuse.c b/arch/arm/mach-mvebu/efuse.c index 4b0433782171..be5dc0e07d9b 100644 --- a/arch/arm/mach-mvebu/efuse.c +++ b/arch/arm/mach-mvebu/efuse.c @@ -10,6 +10,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/efuse.h> #include <asm/arch/soc.h> +#include <asm/gpio.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/mbus.h> @@ -56,17 +57,48 @@ static struct mvebu_hd_efuse *get_efuse_line(int nr) return efuses + nr; }
-static void enable_efuse_program(void) +#ifndef DRY_RUN +static int vhv_gpio; +#endif + +static int enable_efuse_program(void) { #ifndef DRY_RUN + if (CONFIG_MVEBU_EFUSE_VHV_GPIO[0]) { + if (gpio_lookup_name(CONFIG_MVEBU_EFUSE_VHV_GPIO, NULL, NULL, &vhv_gpio)) { + printf("Error: VHV gpio lookup failed\n"); + return -EOPNOTSUPP; + } + if (gpio_request(vhv_gpio, CONFIG_MVEBU_EFUSE_VHV_GPIO)) { + printf("Error: VHV gpio request failed\n"); + return -EOPNOTSUPP; + } + if (gpio_direction_output(vhv_gpio, + IS_ENABLED(CONFIG_MVEBU_EFUSE_VHV_GPIO_ACTIVE_LOW) ? 0 : 1)) { + printf("Error: VHV gpio enable failed\n"); + return -EINVAL; + } + mdelay(5); /* Wait for the VHV power to stabilize */ + } + setbits_le32(MVEBU_EFUSE_CONTROL, MVEBU_EFUSE_CTRL_PROGRAM_ENABLE); #endif + + return 0; }
static void disable_efuse_program(void) { #ifndef DRY_RUN clrbits_le32(MVEBU_EFUSE_CONTROL, MVEBU_EFUSE_CTRL_PROGRAM_ENABLE); + + if (CONFIG_MVEBU_EFUSE_VHV_GPIO[0]) { + if (gpio_direction_output(vhv_gpio, + IS_ENABLED(CONFIG_MVEBU_EFUSE_VHV_GPIO_ACTIVE_LOW) ? 1 : 0)) + printf("Error: VHV gpio disable failed\n"); + gpio_free(vhv_gpio); + vhv_gpio = 0; + } #endif }
@@ -123,7 +155,9 @@ static int prog_efuse(int nr, struct efuse_val *new_val, u32 mask0, u32 mask1) if (!new_val->dwords.d[0] && !new_val->dwords.d[1] && (mask0 | mask1)) return 0;
- enable_efuse_program(); + res = enable_efuse_program(); + if (res) + return res;
res = do_prog_efuse(efuse, new_val, mask0, mask1);
@@ -155,7 +189,9 @@ int mvebu_prog_ld_efuse(int ld1, u32 word, u32 val) if (val == (line[word] & val)) return 0;
mvebu_read_ld_efuse(ld1, line); line[word] |= val;
VHV gpio is connected to MCU and only on updated board design. Without it eFUSE programming does not work. Omnia MCU driver exports this GPIO to U-Boot under name mcu_56 and only when it is supported by MCU. So U-Boot fuse command refuse eFUSE programming on older board design when VHV gpio is not available.
We tested that Armada 385 without connected VHV gpio can do eFUSE programming but only for some bits and only sometimes - it is unstable. And better to be disabled on older board design without VHV gpio support.
Signed-off-by: Pali Rohár pali@kernel.org --- configs/turris_omnia_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index ba635feb44b2..01dee5472200 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -10,6 +10,8 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_TURRIS_OMNIA=y CONFIG_DDR_RESET_ON_TRAINING_FAILURE=y CONFIG_MVEBU_EFUSE=y +CONFIG_MVEBU_EFUSE_VHV_GPIO="mcu_56" +CONFIG_MVEBU_EFUSE_VHV_GPIO_ACTIVE_LOW=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0xF0000 CONFIG_ENV_SECT_SIZE=0x10000
Pali Rohár
