[PULL] u-boot-sh/master-779h0-r2
The following changes since commit d7aaaf4223d0a2f9f8c9eed47d7431860b3116d8:
Merge tag 'u-boot-dfu-20240209' of https://source.denx.de/u-boot/custodians/u-boot-dfu (2024-02-09 09:00:42 -0500)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master-779h0-r2
for you to fetch changes up to 53066deccbedf02439309b0d4aca9f0be853a8da:
ARM: renesas: Add Renesas R8A779H0 V4M Gray Hawk board code (2024-02-10 17:08:06 +0100)
---------------------------------------------------------------- Duy Nguyen (2): dt-bindings: clock: Add R8A779H0 V4M CPG Core Clock Definitions dt-bindings: power: Add R8A779H0 V4M SYSC power domain definitions
Hai Pham (8): clk: renesas: Add R8A779H0 V4M clock tables pinctrl: renesas: Add R8A779H0 V4M PFC tables ARM: renesas: Add R8A779H0 V4M Kconfig entry and PRR ID mtd: spi: renesas: Add R8A779H0 V4M support ARM: dts: renesas: Add Renesas R8A779H0 V4M SoC support ARM: dts: renesas: Add Renesas R8A779H0 V4M DT extras ARM: dts: renesas: Add Renesas Gray Hawk boards support ARM: renesas: Add Renesas R8A779H0 V4M Gray Hawk board code
Marek Vasut (1): clk: renesas: Implement R8A779H0 V4M PLL7 support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/r8a779h0-gray-hawk-cpu.dtsi | 166 + arch/arm/dts/r8a779h0-gray-hawk-csi-dsi.dtsi | 15 + arch/arm/dts/r8a779h0-gray-hawk-ethernet.dtsi | 15 + arch/arm/dts/r8a779h0-gray-hawk-u-boot.dts | 42 + arch/arm/dts/r8a779h0-gray-hawk.dts | 25 + arch/arm/dts/r8a779h0-u-boot.dtsi | 27 + arch/arm/dts/r8a779h0.dtsi | 460 +++ arch/arm/mach-rmobile/Kconfig.rcar4 | 13 + arch/arm/mach-rmobile/cpu_info.c | 1 + arch/arm/mach-rmobile/include/mach/rmobile.h | 1 + board/renesas/grayhawk/Kconfig | 15 + board/renesas/grayhawk/MAINTAINERS | 5 + board/renesas/grayhawk/Makefile | 9 + board/renesas/grayhawk/grayhawk.c | 66 + configs/r8a779h0_grayhawk_defconfig | 75 + drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 6 + drivers/clk/renesas/r8a779h0-cpg-mssr.c | 293 ++ drivers/clk/renesas/rcar-gen3-cpg.h | 3 + drivers/pinctrl/renesas/Kconfig | 6 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a779h0.c | 3969 ++++++++++++++++++++ drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + drivers/spi/renesas_rpc_spi.c | 3 +- include/configs/grayhawk.h | 14 + .../dt-bindings/clock/renesas,r8a779h0-cpg-mssr.h | 96 + include/dt-bindings/power/renesas,r8a779h0-sysc.h | 49 + 30 files changed, 5395 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/r8a779h0-gray-hawk-cpu.dtsi create mode 100644 arch/arm/dts/r8a779h0-gray-hawk-csi-dsi.dtsi create mode 100644 arch/arm/dts/r8a779h0-gray-hawk-ethernet.dtsi create mode 100644 arch/arm/dts/r8a779h0-gray-hawk-u-boot.dts create mode 100644 arch/arm/dts/r8a779h0-gray-hawk.dts create mode 100644 arch/arm/dts/r8a779h0-u-boot.dtsi create mode 100644 arch/arm/dts/r8a779h0.dtsi create mode 100644 board/renesas/grayhawk/Kconfig create mode 100644 board/renesas/grayhawk/MAINTAINERS create mode 100644 board/renesas/grayhawk/Makefile create mode 100644 board/renesas/grayhawk/grayhawk.c create mode 100644 configs/r8a779h0_grayhawk_defconfig create mode 100644 drivers/clk/renesas/r8a779h0-cpg-mssr.c create mode 100644 drivers/pinctrl/renesas/pfc-r8a779h0.c create mode 100644 include/configs/grayhawk.h create mode 100644 include/dt-bindings/clock/renesas,r8a779h0-cpg-mssr.h create mode 100644 include/dt-bindings/power/renesas,r8a779h0-sysc.h
