[U-Boot] [PATCH] mx5: soc.c: Fix Codyng Style
Do not declare extern in c files as pointed out by checkpatch.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx5/soc.c | 10 ++-------- arch/arm/include/asm/arch-mx5/sys_proto.h | 10 ++++++++++ 2 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index c6106d5..cf12ba8 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -26,6 +26,8 @@ #include <common.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + #include <asm/errno.h> #include <asm/io.h>
@@ -117,14 +119,6 @@ int print_cpuinfo(void) } #endif
-/* - * Initializes on-chip ethernet controllers. - * to override, implement board_eth_init() - */ -#if defined(CONFIG_FEC_MXC) -extern int fecmxc_initialize(bd_t *bis); -#endif - int cpu_eth_init(bd_t *bis) { int rc = -ENODEV; diff --git a/arch/arm/include/asm/arch-mx5/sys_proto.h b/arch/arm/include/asm/arch-mx5/sys_proto.h index ce63675..789558e 100644 --- a/arch/arm/include/asm/arch-mx5/sys_proto.h +++ b/arch/arm/include/asm/arch-mx5/sys_proto.h @@ -28,4 +28,14 @@ u32 get_cpu_rev(void); #define is_soc_rev(rev) ((get_cpu_rev() & 0xFF) - rev) void sdelay(unsigned long); void set_chipselect_size(int const); + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +#if defined(CONFIG_FEC_MXC) +int fecmxc_initialize(bd_t *bis); + +#endif + #endif
Fabio Estevam
