[U-Boot] [PATCH] Kconfig: update FASTBOOT_FLASH_MMC_DEV
handle FASTBOOT_FLASH_MMC_DEV default properly
Signed-off-by: Steve Rae steve.rae@raedomain.com --- I was hoping that the FASTBOOT_FLASH_MMC_DEV Kconfig option could be an integer (eg. 0, 1, or 2 etc.) or undefined (to signify that it is not being used). However, it seems that (Kconfig experts please!) this is not correct within Kconfig. Therefore, I have implemented "-1" to signify that it is not used. Is this the "best practice" for handling this scenario?
cmd/fastboot/Kconfig | 4 +++- common/Makefile | 4 +++- drivers/usb/gadget/f_fastboot.c | 12 ++++++++---- 3 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/cmd/fastboot/Kconfig b/cmd/fastboot/Kconfig index a93d1c0..fdd5475 100644 --- a/cmd/fastboot/Kconfig +++ b/cmd/fastboot/Kconfig @@ -50,10 +50,12 @@ config FASTBOOT_FLASH
config FASTBOOT_FLASH_MMC_DEV int "Define FASTBOOT MMC FLASH default device" + default -1 help The fastboot "flash" command requires additional information regarding the non-volatile storage device. Define this to - the eMMC device that fastboot should use to store the image. + the eMMC device that fastboot should use to store the image, + or define '-1' to disable storing to an eMMC device.
endif # USB_FUNCTION_FASTBOOT
diff --git a/common/Makefile b/common/Makefile index 21619b3..56e95b3 100644 --- a/common/Makefile +++ b/common/Makefile @@ -142,12 +142,14 @@ obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
-# This option is not just y/n - it can have a numeric value ifdef CONFIG_FASTBOOT_FLASH obj-y += image-sparse.o +# This option is not just y/n - it is a numeric value ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +ifneq ($(CONFIG_FASTBOOT_FLASH_MMC_DEV), -1) obj-y += fb_mmc.o endif +endif ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV obj-y += fb_nand.o endif diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 2160b1c..5df6b8b 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -21,7 +21,8 @@ #include <linux/compiler.h> #include <version.h> #include <g_dnl.h> -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#if defined(CONFIG_FASTBOOT_FLASH_MMC_DEV) && \ + (CONFIG_FASTBOOT_FLASH_MMC_DEV != -1) #include <fb_mmc.h> #endif #ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV @@ -594,7 +595,8 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) fb_response_str = response;
fastboot_fail("no flash device defined"); -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#if defined(CONFIG_FASTBOOT_FLASH_MMC_DEV) && \ + (CONFIG_FASTBOOT_FLASH_MMC_DEV != -1) fb_mmc_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, download_bytes); #endif @@ -610,7 +612,8 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) static void cb_oem(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#if defined(CONFIG_FASTBOOT_FLASH_MMC_DEV) && \ + (CONFIG_FASTBOOT_FLASH_MMC_DEV != -1) if (strncmp("format", cmd + 4, 6) == 0) { char cmdbuf[32]; sprintf(cmdbuf, "gpt write mmc %x $partitions", @@ -646,7 +649,8 @@ static void cb_erase(struct usb_ep *ep, struct usb_request *req) fb_response_str = response;
fastboot_fail("no flash device defined"); -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#if defined(CONFIG_FASTBOOT_FLASH_MMC_DEV) && \ + (CONFIG_FASTBOOT_FLASH_MMC_DEV != -1) fb_mmc_erase(cmd); #endif #ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV
usb_request *req)
fb_response_str = response; fastboot_fail("no flash device defined");
usb_request *req)
usb_request *req)
#endif
1.8.5
ping...
Hi Steve,
I think it might be better to have a bool option which enables/disables the feature, as well as what you have here. Then you don't need the -1 value.
Steve Rae
