Re: [U-Boot-Users] [PATCH] Change env_get_char from a global function ptr to a function.
In message <024e01c89742$e48d4b80$ada7e280$@Tjernlund@transmode.se> you wrote:
Did you try this one or did du skip it this release?
Unfortunately this doesn't apply any more:
Applying Change env_get_char from a global function ptr to a function. error: patch failed: common/cmd_bootm.c:1150 error: common/cmd_bootm.c: patch does not apply error: patch failed: common/fdt_support.c:225 error: common/fdt_support.c: patch does not apply error: patch failed: common/ft_build.c:396 error: common/ft_build.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merged common/cmd_bootm.c CONFLICT (content): Merge conflict in common/cmd_bootm.c Auto-merged common/cmd_nvedit.c Auto-merged common/fdt_support.c CONFLICT (content): Merge conflict in common/fdt_support.c Auto-merged common/ft_build.c CONFLICT (content): Merge conflict in common/ft_build.c Auto-merged include/common.h Failed to merge in the changes. Patch failed at 0001.
Could you please update and resubmit? Thanks in advance.
OK, here it is.
From 96fdcd78686c22aa6be56575c9f37d1943c91222 Mon Sep 17 00:00:00 2001
From: Joakim Tjernlund Joakim.Tjernlund@transmode.se Date: Mon, 14 Apr 2008 22:59:00 +0200 Subject: [PATCH] Change env_get_char from a global function ptr to a function.
This avoids an early global data reference. --- api/api.c | 1 - common/cmd_nvedit.c | 3 --- common/env_common.c | 19 +++++++++++++------ common/env_eeprom.c | 1 - common/env_nvram.c | 1 - common/ft_build.c | 2 -- include/common.h | 1 + 7 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/api/api.c b/api/api.c index 0598d90..c1b2b60 100644 --- a/api/api.c +++ b/api/api.c @@ -40,7 +40,6 @@
/* U-Boot routines needed */ extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -extern uchar (*env_get_char)(int); extern uchar *env_get_addr(int);
/***************************************************************************** diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index cab727f..dc05f68 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -68,9 +68,6 @@ DECLARE_GLOBAL_DATA_PTR; /************************************************************************ ************************************************************************/
-/* Function that returns a character from the environment */ -extern uchar (*env_get_char)(int); - /* Function that returns a pointer to a value from the environment */ /* (Only memory version supported / needed). */ extern uchar *env_get_addr(int); diff --git a/common/env_common.c b/common/env_common.c index a494812..f366fdb 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -50,7 +50,6 @@ extern void env_relocate_spec (void); extern uchar env_get_char_spec(int);
static uchar env_get_char_init (int index); -uchar (*env_get_char)(int) = env_get_char_init;
/************************************************************************ * Default settings to be used when no valid environment is found @@ -182,6 +181,19 @@ uchar env_get_char_memory (int index) } #endif
+uchar env_get_char (int index) +{ + uchar c; + + /* if relocated to RAM */ + if (gd->flags & GD_FLG_RELOC) + c = env_get_char_memory(index); + else + c = env_get_char_init(index); + + return (c); +} + uchar *env_get_addr (int index) { if (gd->env_valid) { @@ -215,11 +227,6 @@ void env_relocate (void) DEBUGF ("%s[%d] malloced ENV at %p\n", __FUNCTION__,__LINE__,env_ptr); #endif
- /* - * After relocation to RAM, we can always use the "memory" functions - */ - env_get_char = env_get_char_memory; - if (gd->env_valid == 0) { #if defined(CONFIG_GTH) || defined(CFG_ENV_IS_NOWHERE) /* Environment not changable */ puts ("Using default environment\n\n"); diff --git a/common/env_eeprom.c b/common/env_eeprom.c index 2adc129..fae87ca 100644 --- a/common/env_eeprom.c +++ b/common/env_eeprom.c @@ -38,7 +38,6 @@ env_t *env_ptr = NULL;
char * env_name_spec = "EEPROM";
-extern uchar (*env_get_char)(int); extern uchar env_get_char_memory (int index);
diff --git a/common/env_nvram.c b/common/env_nvram.c index 7c18896..bfc8d02 100644 --- a/common/env_nvram.c +++ b/common/env_nvram.c @@ -63,7 +63,6 @@ char * env_name_spec = "NVRAM"; extern uchar default_environment[]; extern int default_environment_size;
#ifdef CONFIG_AMIGAONEG3SE diff --git a/common/ft_build.c b/common/ft_build.c index 0e5699a..0b6c2b7 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -396,8 +396,6 @@ void *ft_get_prop(void *bphp, const char *propname, int *szp)
-/* Function that returns a character from the environment */ -extern uchar(*env_get_char) (int);
void ft_setup(void *blob, bd_t * bd, ulong initrd_start, ulong initrd_end) { diff --git a/include/common.h b/include/common.h index 39bcd30..8630780 100644 --- a/include/common.h +++ b/include/common.h @@ -229,6 +229,7 @@ extern ulong load_addr; /* Default Load Address */ /* common/cmd_nvedit.c */ int env_init (void); void env_relocate (void); +uchar env_get_char (int); int envmatch (uchar *, int); char *getenv (char *); int getenv_r (char *name, char *buf, unsigned len);
In message 1208206910.5911.20.camel@gentoo-jocke.transmode.se you wrote: ...
OK, here it is.
Thanks, applied.
Joakim Tjernlund
