[U-Boot] [PATCH v2] Cosmetic: Fix a number of typos, no functional changes.
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
ok, here's version two ...
diff --git a/Makefile b/Makefile index 1365db6..f55f8c0 100644 --- a/Makefile +++ b/Makefile @@ -45,13 +45,13 @@ endif
######################################################################### # -# U-boot build supports producing a object files to the separate external +# U-boot build supports generating object files in a separate external # directory. Two use cases are supported: # # 1) Add O= to the make command line # 'make O=/tmp/build all' # -# 2) Set environement variable BUILD_DIR to point to the desired location +# 2) Set environment variable BUILD_DIR to point to the desired location # 'export BUILD_DIR=/tmp/build' # 'make' # @@ -59,7 +59,7 @@ endif # 'export BUILD_DIR=/tmp/build' # './MAKEALL' # -# Command line 'O=' setting overrides BUILD_DIR environent variable. +# Command line 'O=' setting overrides BUILD_DIR environment variable. # # When none of the above methods is used the local build is performed and # the object files are placed in the source directory. diff --git a/README b/README index ccd47fa..13e3ac0 100644 --- a/README +++ b/README @@ -3360,7 +3360,7 @@ Configuration Settings: the Linux kernel; all data that must be processed by the Linux kernel (bd_info, boot arguments, FDT blob if used) must be put below this limit, unless "bootm_low" - enviroment variable is defined and non-zero. In such case + environment variable is defined and non-zero. In such case all data for the Linux kernel must be between "bootm_low" and "bootm_low" + CONFIG_SYS_BOOTMAPSZ. The environment variable "bootm_mapsize" will override the value of @@ -3473,7 +3473,7 @@ Configuration Settings:
- CONFIG_ENV_FLAGS_LIST_DEFAULT - CONFIG_ENV_FLAGS_LIST_STATIC - Enable validation of the values given to enviroment variables when + Enable validation of the values given to environment variables when calling env set. Variables can be restricted to only decimal, hexadecimal, or boolean. If CONFIG_CMD_NET is also defined, the variables can also be restricted to IP address or MAC address. diff --git a/arch/arm/cpu/arm926ejs/at91/eflash.c b/arch/arm/cpu/arm926ejs/at91/eflash.c index 3e21cdb..3f39264 100644 --- a/arch/arm/cpu/arm926ejs/at91/eflash.c +++ b/arch/arm/cpu/arm926ejs/at91/eflash.c @@ -28,7 +28,7 @@ * by u-Boot commands. * * Note: Redundant environment will not work in this flash since - * it does use partial page writes. Make sure the environent spans + * it does use partial page writes. Make sure the environment spans * whole pages! */
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c index cde3172..d4711c0 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c @@ -302,7 +302,7 @@ int arch_cpu_init(void) /* * Configures the I/O voltage of the pads connected to Egigabit * Ethernet interface to 1.8V - * By defult it is set to 3.3V + * By default it is set to 3.3V */ reg = readl(KW_REG_MPP_OUT_DRV_REG); reg |= (1 << 7); diff --git a/board/RPXlite_dw/README b/board/RPXlite_dw/README index 14296b2..9e2d0f4 100644 --- a/board/RPXlite_dw/README +++ b/board/RPXlite_dw/README @@ -87,9 +87,9 @@ u-boot>
-A word on the U-Boot enviroment variable setting and usage : +A word on the U-Boot environment variable setting and usage :
-In the beginning, you could just need very simple defult environment variable setting, +In the beginning, you could just need very simple default environment variable setting, like[include/configs/RPXlite.h] :
#define CONFIG_BOOTCOMMAND \ diff --git a/board/freescale/mx28evk/README b/board/freescale/mx28evk/README index 524f3fc..0389a1d 100644 --- a/board/freescale/mx28evk/README +++ b/board/freescale/mx28evk/README @@ -29,11 +29,11 @@ Environment Storage
There are two targets for mx28evk:
-"make mx28evk_config" - store enviroment variables into MMC +"make mx28evk_config" - store environment variables into MMC
or
-"make mx28evk_nand_config" - store enviroment variables into NAND flash +"make mx28evk_nand_config" - store environment variables into NAND flash
Choose the target accordingly.
diff --git a/board/sbc8349/README b/board/sbc8349/README index 2c35919..e2d60cc 100644 --- a/board/sbc8349/README +++ b/board/sbc8349/README @@ -50,7 +50,7 @@ is a summary of that information: trying to preserve your old environment settings and user flash). - Set the start address of the erase/flash process to FF80_0000 - Set the target RAM required to 64kB. - - Select sectors for erasing (see note on enviroment below) + - Select sectors for erasing (see note on environment below) - Select Erase and Reprogram.
Note that some versions of the register files used with Workbench diff --git a/common/image.c b/common/image.c index 2c88091..802a79e 100644 --- a/common/image.c +++ b/common/image.c @@ -965,7 +965,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, * @initrd_end: pointer to a ulong variable, will hold final init ramdisk * end address (after possible relocation) * - * boot_ramdisk_high() takes a relocation hint from "initrd_high" environement + * boot_ramdisk_high() takes a relocation hint from "initrd_high" environment * variable and if requested ramdisk data is moved to a specified location. * * Initrd_start and initrd_end are set to final (after relocation) ramdisk diff --git a/doc/README.hwconfig b/doc/README.hwconfig index cf54965..b6ddb43 100644 --- a/doc/README.hwconfig +++ b/doc/README.hwconfig @@ -18,7 +18,7 @@ Current implementation details/limitations: U-Boot. But I haven't bothered yet.
2. Since we don't implement a hwconfig command, i.e. we're working - with the environement directly, there is no way to tell that + with the environment directly, there is no way to tell that toggling a particular option will need a reboot to take effect. So, for now it's advised to always reboot the target after modifying the hwconfig variable. diff --git a/drivers/net/phy/smsc.c b/drivers/net/phy/smsc.c index 5936f9b..60ed92d 100644 --- a/drivers/net/phy/smsc.c +++ b/drivers/net/phy/smsc.c @@ -7,7 +7,7 @@ * Copyright 2010-2011 Freescale Semiconductor, Inc. * author Andy Fleming * - * Some code get from linux kenrel + * Some code copied from linux kernel * Copyright (c) 2006 Herbert Valerio Riedel hvr@gnu.org */ #include <miiphy.h> diff --git a/examples/standalone/README.smc91111_eeprom b/examples/standalone/README.smc91111_eeprom index 28e7e69..a2d52e7 100644 --- a/examples/standalone/README.smc91111_eeprom +++ b/examples/standalone/README.smc91111_eeprom @@ -154,10 +154,10 @@ The MAC address can be stored in four locations:
-Boot environmental variable in Flash <- can not change, without re-flashing U-boot. -U-Boot environental variable <- can not change, without +U-Boot environmental variable <- can not change, without resetting board/U-Boot -LAN91C111 Registers <- volitle -LAN91C111 EEPROM <- Non Volitle +LAN91C111 Registers <- volatile +LAN91C111 EEPROM <- Non-volatile
If you have not activated the network, and do not have a hardcoded or pre-assigned MAC address in U-boot, the environmental variables diff --git a/include/common.h b/include/common.h index 8addf43..6aa2398 100644 --- a/include/common.h +++ b/include/common.h @@ -383,7 +383,7 @@ int setenv_hex(const char *varname, ulong value); /** * setenv_addr - Set an environment variable to an address in hex * - * @varname: Environmet variable to set + * @varname: Environment variable to set * @addr: Value to set it to * @return 0 if ok, 1 on error */ diff --git a/include/configs/eXalion.h b/include/configs/eXalion.h index c2d04a2..7321b60 100644 --- a/include/configs/eXalion.h +++ b/include/configs/eXalion.h @@ -119,7 +119,7 @@
#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* Size of one Flash sector */ -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE /* Use one Flash sector for enviroment */ +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE /* Use one Flash sector for environment */ #define CONFIG_ENV_ADDR 0xFFFC0000 #define CONFIG_ENV_OFFSET 0 /* starting right at the beginning */
diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h index d63d0c4..0feef1e 100644 --- a/include/configs/sacsng.h +++ b/include/configs/sacsng.h @@ -305,7 +305,7 @@ #define CONFIG_ENV_IN_OWN_SECT 1
/* Define this to contain any number of null terminated strings that - * will be part of the default enviroment compiled into the boot image. + * will be part of the default environment compiled into the boot image. */ #define CONFIG_EXTRA_ENV_SETTINGS \ "quiet=0\0" \ diff --git a/lib/hashtable.c b/lib/hashtable.c index 644330a..c5a2b08 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -817,7 +817,7 @@ int himport_r(struct hsearch_data *htab, * size of 8 per entry (= safety factor of ~5) should provide enough * safety margin for any existing environment definitions and still * allow for more than enough dynamic additions. Note that the - * "size" argument is supposed to give the maximum enviroment size + * "size" argument is supposed to give the maximum environment size * (CONFIG_ENV_SIZE). This heuristics will result in * unreasonably large numbers (and thus memory footprint) for * big flash environments (>8,000 entries for 64 KB diff --git a/post/board/lwmon5/sysmon.c b/post/board/lwmon5/sysmon.c index da37d66..cca1a26 100644 --- a/post/board/lwmon5/sysmon.c +++ b/post/board/lwmon5/sysmon.c @@ -22,7 +22,7 @@ * * LCD backlight is not enabled if temperature values are not within * allowed ranges (-30 .. + 80). The brightness of backlite can be - * controlled by setting "brightness" enviroment variable. Default value is 50% + * controlled by setting "brightness" environment variable. Default value is 50% * * See the list of all parameters in the sysmon_table below */
Robert P. J. Day
