[U-Boot] [PATCH v2 1/2] dtoc: Support multiple compatible strings in a node
Sometimes a node will have multiple compatible strings. Drivers may use one or the other so the best approach seems to be to #define them to be equivalent.
Update dtoc to support this.
Changes in v2: - Put the #defines in the header file - Add the required dtd_ prefix to the #defines
doc/driver-model/of-plat.txt | 5 +++++ tools/dtoc/dtoc.py | 28 +++++++++++++++++++++------- 2 files changed, 26 insertions(+), 7 deletions(-)
diff --git a/doc/driver-model/of-plat.txt b/doc/driver-model/of-plat.txt index 0063bfe510..3ed8c759d6 100644 --- a/doc/driver-model/of-plat.txt +++ b/doc/driver-model/of-plat.txt @@ -156,6 +156,11 @@ This avoids the code overhead of converting the device tree data to platform data in the driver. The ofdata_to_platdata() method should therefore do nothing in such a driver.
+Where a node has multiple compatible strings, a #define is used to make them +equivalent, e.g.: + +#define dtd_rockchip_rk3299_dw_mshc dtd_rockchip_rk3288_dw_mshc +
Converting of-platdata to a useful form --------------------------------------- diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/dtoc.py index 08e35f148c..c0ab13ad34 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/dtoc.py @@ -88,6 +88,7 @@ class DtbPlatdata: self._phandle_node = {} self._outfile = None self._lines = [] + self._aliases = {}
def SetupOutput(self, fname): """Set up the output destination @@ -159,9 +160,10 @@ class DtbPlatdata: C identifier for the first compatible string """ compat = node.props['compatible'].value + aliases = [] if type(compat) == list: - compat = compat[0] - return Conv_name_to_c(compat) + compat, aliases = compat[0], compat[1:] + return Conv_name_to_c(compat), [Conv_name_to_c(a) for a in aliases]
def ScanDtb(self): """Scan the device tree to obtain a tree of notes and properties @@ -239,7 +241,7 @@ class DtbPlatdata: """ structs = {} for node in self._valid_nodes: - node_name = self.GetCompatName(node) + node_name, _ = self.GetCompatName(node) fields = {}
# Get a list of all the valid properties in this node. @@ -263,12 +265,17 @@ class DtbPlatdata:
upto = 0 for node in self._valid_nodes: - node_name = self.GetCompatName(node) + node_name, _ = self.GetCompatName(node) struct = structs[node_name] for name, prop in node.props.items(): if name not in PROP_IGNORE_LIST and name[0] != '#': prop.Widen(struct[name]) upto += 1 + + struct_name, aliases = self.GetCompatName(node) + for alias in aliases: + self._aliases[alias] = struct_name + return structs
def ScanPhandles(self): @@ -327,13 +334,17 @@ class DtbPlatdata: self.Out(';\n') self.Out('};\n')
+ for alias, struct_name in self._aliases.iteritems(): + self.Out('#define %s%s %s%s\n'% (STRUCT_PREFIX, alias, + STRUCT_PREFIX, struct_name)) + def OutputNode(self, node): """Output the C code for a node
Args: node: node to output """ - struct_name = self.GetCompatName(node) + struct_name, _ = self.GetCompatName(node) var_name = Conv_name_to_c(node.name) self.Buf('static struct %s%s %s%s = {\n' % (STRUCT_PREFIX, struct_name, VAL_PREFIX, var_name)) @@ -384,8 +395,11 @@ class DtbPlatdata: """Generate device defintions for the platform data
This writes out C platform data initialisation data and - U_BOOT_DEVICE() declarations for each valid node. See the - documentation in README.of-plat for more information. + U_BOOT_DEVICE() declarations for each valid node. Where a node has + multiple compatible strings, a #define is used to make them equivalent. + + See the documentation in doc/driver-model/of-plat.txt for more + information. """ self.Out('#include <common.h>\n') self.Out('#include <dm.h>\n')
This patch is just for testing.
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 5 ++++- configs/firefly-rk3399_defconfig | 1 + 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 7f1fc50f38..2ee4bd6872 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -260,6 +260,7 @@ };
sdmmc: dwmmc@fe320000 { + u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>; @@ -272,7 +273,9 @@ power-domains = <&power RK3399_PD_SD>; resets = <&cru SRST_SDMMC>; reset-names = "reset"; - status = "disabled"; + status = "okay"; + bus-width = <8>; + clock-freq-min-max = <0 0>; };
sdhci: sdhci@fe330000 { diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 0a4d005975..d6fae3a02d 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -63,3 +63,4 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y CONFIG_USE_TINY_PRINTF=y CONFIG_ERRNO_STR=y +CONFIG_MMC_DW_ROCKCHIP=y
Hi Simon,
This patch works on firefly-rk3399 board,
Tested-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
self._aliases = {} def SetupOutput(self, fname): """Set up the output destination
compat = compat[0]
return Conv_name_to_c(compat), [Conv_name_to_c(a) for a in aliases] def ScanDtb(self): """Scan the device tree to obtain a tree of notes and properties
node_name, _ = self.GetCompatName(node) fields = {} # Get a list of all the valid properties in this node.
return structs def ScanPhandles(self):
def OutputNode(self, node): """Output the C code for a node Args: node: node to output """
Hi Simon,
Thanks, - Kever
Changes in v2:
Applied to u-boot-dm, thanks!
Kever Yang
sjg@google.com
