[U-Boot] Pull request: BCM ARM changes
The following changes since commit 97276a91db8e98f081a40ddf9dc8f81d4032a756:
Prepare v2019.04-rc1 (2019-02-07 21:32:19 -0500)
https://github.com/mbgg/u-boot.git tags/2019.01-next
for you to fetch changes up to 7e2ae620e15ef578b8f2812ec21ec07fae6c1e2f:
rpi: add Compute Module 3+ (2019-02-15 12:49:13 +0100)
---------------------------------------------------------------- - add compute module 3+ - fix 64 bit warning in bmp command
---------------------------------------------------------------- Adam Heinrich (1): cmd: bmp: Make integer-to-pointer cast platform, independent
Jonathan Gray (1): rpi: add Compute Module 3+
board/raspberrypi/rpi/rpi.c | 5 +++++ cmd/bmp.c | 2 +- 2 files changed, 6 insertions(+), 1 deletion(-)
Matthias Brugger
