[PATCH] arm64: mvebu: handle non-zero base address for RAM
board_get_usable_ram_top() conflated the RAM size with the top address of RAM. On systems where RAM starts at address 0 these numbers are the same so it went unnoticed. Update board_get_usable_ram_top() to take CONFIG_SYS_SDRAM_BASE into account when determining the top address.
Signed-off-by: Chris Packham judge.packham@gmail.com --- I've got a 64-bit mvebu SoC/board that I plan on submitting in a few weeks. One of the gotchas with this board is that the physical address of the RAM starts at 0x2_00000000 (there's some seemingly unmovable I/O occupying the lower addresses).
This was one of the earlier issues I hit with porting. I figured it was independent enough that I could send it out while I'm still working on the rest of the series.
arch/arm/mach-mvebu/arm64-common.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index 5357aa554db4..238edbe6ba56 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -28,14 +28,13 @@ DECLARE_GLOBAL_DATA_PTR; * Currently only 2GiB are mapped for system memory. This is what * we pass to the U-Boot subsystem here. */ -#define USABLE_RAM_SIZE 0x80000000 +#define USABLE_RAM_SIZE 0x80000000ULL
ulong board_get_usable_ram_top(ulong total_size) { - if (gd->ram_size > USABLE_RAM_SIZE) - return USABLE_RAM_SIZE; + unsigned long top = CONFIG_SYS_SDRAM_BASE + min(gd->ram_size, USABLE_RAM_SIZE);
- return gd->ram_size; + return (gd->ram_top > top) ? top : gd->ram_top; }
- Currently only 2GiB are mapped for system memory. This is what
- we pass to the U-Boot subsystem here.
- unsigned long top = CONFIG_SYS_SDRAM_BASE + min(gd->ram_size, USABLE_RAM_SIZE);
- return (gd->ram_top > top) ? top : gd->ram_top; }
Thanks, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan Roese
Chris Packham
Stefan Roese
