[U-Boot] [PATCH 00/11] ARM: uniphier: UniPhier SoC code updates
- DDR PHY init code updates - Some bug fixes
Masahiro Yamada (11): ARM: uniphier: enable SSC for more PLLs for LD20 SoC ARM: uniphier: remove unused board attribute macros ARM: uniphier: update DRAM init code for LD20 SoC (3rd) ARM: uniphier: rename ddrphy-ld20-regs.h to ddruqphy-regs.h ARM: uniphier: fix DRAM init poll address for LD4, Pro4, sLD8 ARM: uniphier: enable clocks to MIO/STDMAC on LD11 if USB is enabled ARM: uniphier: do not run harmful code for USB boot mode of LD11 ES3 ARM: uniphier: rework existing DDR PHY code to reuse for LD11 SoC ARM: uniphier: refactor DDR PHY parameter dump command ARM: uniphier: support DDR PHY parameter dump command for LD11 ARM: uniphier: update DRAM init code for LD11 SoC
arch/arm/mach-uniphier/Kconfig | 3 +- arch/arm/mach-uniphier/clk/clk-ld11.c | 19 +- arch/arm/mach-uniphier/clk/dpll-ld20.c | 9 +- arch/arm/mach-uniphier/clk/pll-ld20.c | 15 +- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 236 +++++++----- arch/arm/mach-uniphier/dram/ddrphy-init.h | 17 + arch/arm/mach-uniphier/dram/ddrphy-ld4.c | 47 ++- arch/arm/mach-uniphier/dram/ddrphy-regs.h | 282 +++++++------- arch/arm/mach-uniphier/dram/ddrphy-training.c | 95 ++--- .../dram/{ddrphy-ld20-regs.h => ddruqphy-regs.h} | 7 +- arch/arm/mach-uniphier/dram/umc-ld11.c | 415 +++++++++++++++++++-- arch/arm/mach-uniphier/dram/umc-ld20.c | 113 ++++-- arch/arm/mach-uniphier/dram/umc-ld4.c | 4 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 4 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 4 +- arch/arm/mach-uniphier/init.h | 10 +- arch/arm/mach-uniphier/sc64-regs.h | 2 + 17 files changed, 867 insertions(+), 415 deletions(-) create mode 100644 arch/arm/mach-uniphier/dram/ddrphy-init.h rename arch/arm/mach-uniphier/dram/{ddrphy-ld20-regs.h => ddruqphy-regs.h} (96%)
For Electro-Magnetic Compatibility.
Set CPLL, SPLL2, MPLL, VPPLL, GPPLL, DPLL* to SSC rate 1 percent.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/clk/dpll-ld20.c | 9 +++------ arch/arm/mach-uniphier/clk/pll-ld20.c | 15 ++++++++------- 2 files changed, 11 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/dpll-ld20.c b/arch/arm/mach-uniphier/clk/dpll-ld20.c index 1132313..86e99c4 100644 --- a/arch/arm/mach-uniphier/clk/dpll-ld20.c +++ b/arch/arm/mach-uniphier/clk/dpll-ld20.c @@ -11,12 +11,9 @@
int uniphier_ld20_dpll_init(const struct uniphier_board_data *bd) { - unsigned int dpll_ssc_rate = UNIPHIER_BD_DPLL_SSC_GET_RATE(bd->flags); - unsigned int dram_freq = bd->dram_freq; - - uniphier_ld20_sscpll_init(SC_DPLL0CTRL, dram_freq, dpll_ssc_rate, 2); - uniphier_ld20_sscpll_init(SC_DPLL1CTRL, dram_freq, dpll_ssc_rate, 2); - uniphier_ld20_sscpll_init(SC_DPLL2CTRL, dram_freq, dpll_ssc_rate, 2); + uniphier_ld20_sscpll_init(SC_DPLL0CTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 2); + uniphier_ld20_sscpll_init(SC_DPLL1CTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 2); + uniphier_ld20_sscpll_init(SC_DPLL2CTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 2);
return 0; } diff --git a/arch/arm/mach-uniphier/clk/pll-ld20.c b/arch/arm/mach-uniphier/clk/pll-ld20.c index 5e545da..8ad6883 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-ld20.c @@ -13,8 +13,6 @@
int uniphier_ld20_pll_init(const struct uniphier_board_data *bd) { - unsigned int dpll_ssc_rate = UNIPHIER_BD_DPLL_SSC_GET_RATE(bd->flags); - uniphier_ld20_sscpll_init(SC_CPLLCTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 4); /* do nothing for SPLL */ uniphier_ld20_sscpll_init(SC_SPLL2CTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 4); @@ -24,11 +22,14 @@ int uniphier_ld20_pll_init(const struct uniphier_board_data *bd)
mdelay(1);
- if (dpll_ssc_rate > 0) { - uniphier_ld20_sscpll_ssc_en(SC_DPLL0CTRL); - uniphier_ld20_sscpll_ssc_en(SC_DPLL1CTRL); - uniphier_ld20_sscpll_ssc_en(SC_DPLL2CTRL); - } + uniphier_ld20_sscpll_ssc_en(SC_CPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_SPLL2CTRL); + uniphier_ld20_sscpll_ssc_en(SC_MPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_VPPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_GPPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_DPLL0CTRL); + uniphier_ld20_sscpll_ssc_en(SC_DPLL1CTRL); + uniphier_ld20_sscpll_ssc_en(SC_DPLL2CTRL);
uniphier_ld20_vpll27_init(SC_VPLL27FCTRL); uniphier_ld20_vpll27_init(SC_VPLL27ACTRL);
After SoC evaluation, they turned out unnecessary.
arch/arm/mach-uniphier/init.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 4e3bee1..361e024 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -24,9 +24,6 @@ struct uniphier_board_data { struct uniphier_dram_ch dram_ch[UNIPHIER_MAX_NR_DRAM_CH]; unsigned int flags;
-#define UNIPHIER_BD_DPLL_SSC_GET_RATE(f) (((f) >> 8) & 0x3) -#define UNIPHIER_BD_DPLL_SSC_RATE(r) (((r) & 0x3) << 8) - #define UNIPHIER_BD_DDR3PLUS BIT(2)
#define UNIPHIER_BD_BOARD_GET_TYPE(f) ((f) & 0x3)
- Constify UMC setting data arrays - Merge data arrays *_d0 and *_d1. - Add PHY parameters for LD20 C1 board
arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h | 1 + arch/arm/mach-uniphier/dram/umc-ld20.c | 111 +++++++++++++++++-------- arch/arm/mach-uniphier/init.h | 7 +- 3 files changed, 83 insertions(+), 36 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h b/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h index 0c11b65..268ba7f 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h +++ b/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h @@ -15,6 +15,7 @@ #define PHY_MAS_DLY_WIDTH 8
#define PHY_SCL_START (0x40 << (PHY_REG_SHIFT)) +#define PHY_SCL_START_GO_DONE BIT(28) #define PHY_SCL_DATA_0 (0x41 << (PHY_REG_SHIFT)) #define PHY_SCL_DATA_1 (0x42 << (PHY_REG_SHIFT)) #define PHY_SCL_LATENCY (0x43 << (PHY_REG_SHIFT)) diff --git a/arch/arm/mach-uniphier/dram/umc-ld20.c b/arch/arm/mach-uniphier/dram/umc-ld20.c index 4e1fbde..ea933fe 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld20.c +++ b/arch/arm/mach-uniphier/dram/umc-ld20.c @@ -1,7 +1,7 @@ /* * Copyright (C) 2016 Socionext Inc. * - * based on commit 9073035a9860f892f8d1345dfb0ea862b5021145 of Diag + * based on commit a7a36122aa072fe1bb06e02b73b3634b7a6c555a of Diag * * SPDX-License-Identifier: GPL-2.0+ */ @@ -33,6 +33,7 @@ enum dram_size { enum dram_board { /* board type */ DRAM_BOARD_LD20_REF, /* LD20 reference */ DRAM_BOARD_LD20_GLOBAL, /* LD20 TV */ + DRAM_BOARD_LD20_C1, /* LD20 TV C1 */ DRAM_BOARD_LD21_REF, /* LD21 reference */ DRAM_BOARD_LD21_GLOBAL, /* LD21 TV */ DRAM_BOARD_NR, @@ -42,6 +43,7 @@ enum dram_board { /* board type */ static const int ddrphy_adrctrl[DRAM_BOARD_NR][DRAM_CH_NR] = { {268 - 262, 268 - 263, 268 - 378}, /* LD20 reference */ {268 - 262, 268 - 263, 268 - 378}, /* LD20 TV */ + {268 - 262, 268 - 263, 268 - 378}, /* LD20 TV C1 */ {268 - 212, 268 - 268, /* No CH2 */}, /* LD21 reference */ {268 - 212, 268 - 268, /* No CH2 */}, /* LD21 TV */ }; @@ -49,6 +51,7 @@ static const int ddrphy_adrctrl[DRAM_BOARD_NR][DRAM_CH_NR] = { static const int ddrphy_dlltrimclk[DRAM_BOARD_NR][DRAM_CH_NR] = { {268, 268, 268}, /* LD20 reference */ {268, 268, 268}, /* LD20 TV */ + {189, 189, 189}, /* LD20 TV C1 */ {268, 268 + 252, /* No CH2 */}, /* LD21 reference */ {268, 268 + 202, /* No CH2 */}, /* LD21 TV */ }; @@ -56,6 +59,7 @@ static const int ddrphy_dlltrimclk[DRAM_BOARD_NR][DRAM_CH_NR] = { static const int ddrphy_dllrecalib[DRAM_BOARD_NR][DRAM_CH_NR] = { {268 - 378, 268 - 263, 268 - 378}, /* LD20 reference */ {268 - 378, 268 - 263, 268 - 378}, /* LD20 TV */ + {268 - 378, 268 - 263, 268 - 378}, /* LD20 TV C1 */ {268 - 212, 268 - 536, /* No CH2 */}, /* LD21 reference */ {268 - 212, 268 - 536, /* No CH2 */}, /* LD21 TV */ }; @@ -63,6 +67,7 @@ static const int ddrphy_dllrecalib[DRAM_BOARD_NR][DRAM_CH_NR] = { static const u32 ddrphy_phy_pad_ctrl[DRAM_BOARD_NR][DRAM_CH_NR] = { {0x50B840B1, 0x50B840B1, 0x50B840B1}, /* LD20 reference */ {0x50BB40B1, 0x50BB40B1, 0x50BB40B1}, /* LD20 TV */ + {0x50BB40B1, 0x50BB40B1, 0x50BB40B1}, /* LD20 TV C1 */ {0x50BB40B4, 0x50B840B1, /* No CH2 */}, /* LD21 reference */ {0x50BB40B4, 0x50B840B1, /* No CH2 */}, /* LD21 TV */ }; @@ -112,6 +117,26 @@ static const int ddrphy_op_dq_shift_val[DRAM_BOARD_NR][DRAM_CH_NR][32] = { 1, 1, 1, 0, 2, 2, 1, 2, }, }, + { /* LD20 TV C1 */ + { + 2, 1, 0, 1, 2, 1, 1, 1, + 2, 1, 1, 2, 1, 1, 1, 1, + 1, 2, 1, 1, 1, 2, 1, 1, + 2, 2, 0, 1, 1, 2, 2, 1, + }, + { + 1, 1, 0, 1, 2, 2, 1, 1, + 1, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 0, 0, 1, 1, 0, 0, + 0, 1, 1, 1, 2, 1, 2, 1, + }, + { + 2, 2, 0, 2, 1, 1, 2, 1, + 1, 1, 0, 1, 1, -1, 1, 1, + 2, 2, 2, 2, 1, 1, 1, 1, + 1, 1, 1, 0, 2, 2, 1, 2, + }, + }, { /* LD21 reference */ { 1, 1, 0, 1, 1, 1, 1, 1, @@ -183,6 +208,26 @@ static int ddrphy_ip_dq_shift_val[DRAM_BOARD_NR][DRAM_CH_NR][32] = { 2, 2, 2, 2, 1, 2, 2, 1, }, }, + { /* LD20 TV C1 */ + { + 3, 3, 3, 2, 3, 2, 0, 2, + 2, 3, 3, 1, 2, 2, 2, 2, + 2, 2, 2, 2, 0, 1, 1, 1, + 2, 2, 2, 2, 3, 0, 2, 2, + }, + { + 2, 2, 1, 1, -1, 1, 1, 1, + 2, 0, 2, 2, 2, 1, 0, 2, + 2, 1, 2, 1, 0, 1, 1, 1, + 2, 2, 2, 2, 2, 2, 2, 2, + }, + { + 2, 2, 3, 2, 1, 2, 2, 2, + 2, 3, 4, 2, 3, 4, 3, 3, + 2, 2, 1, 2, 1, 1, 1, 1, + 2, 2, 2, 2, 1, 2, 2, 1, + }, + }, { /* LD21 reference */ { 2, 2, 2, 2, 1, 2, 2, 2, @@ -387,7 +432,7 @@ static int ddrphy_training(void __iomem *phy_base, enum dram_board board, writel(0x00010000, phy_base + PHY_DLL_TRIM_2); writel(0x50000000, phy_base + PHY_SCL_START);
- while (readl(phy_base + PHY_SCL_START) & BIT(28)) + while (readl(phy_base + PHY_SCL_START) & PHY_SCL_START_GO_DONE) cpu_relax();
writel(0x00000000, phy_base + PHY_DISABLE_GATING_FOR_SCL); @@ -396,13 +441,13 @@ static int ddrphy_training(void __iomem *phy_base, enum dram_board board, writel(0xFBF8FFFF, phy_base + PHY_SCL_START_ADDR); writel(0x11000000, phy_base + PHY_SCL_START);
writel(0xFBF0FFFF, phy_base + PHY_SCL_START_ADDR); writel(0x30500000, phy_base + PHY_SCL_START);
writel(0x00000001, phy_base + PHY_DISABLE_GATING_FOR_SCL); @@ -411,12 +456,12 @@ static int ddrphy_training(void __iomem *phy_base, enum dram_board board, writel(0xf10e4a56, phy_base + PHY_SCL_DATA_1); writel(0x11000000, phy_base + PHY_SCL_START);
writel(0x34000000, phy_base + PHY_SCL_START);
writel(0x00000003, phy_base + PHY_DISABLE_GATING_FOR_SCL); @@ -445,45 +490,42 @@ static int ddrphy_training(void __iomem *phy_base, enum dram_board board, }
/* UMC */ -static u32 umc_initctla[DRAM_FREQ_NR] = {0x71016D11}; -static u32 umc_initctlb[DRAM_FREQ_NR] = {0x07E390AC}; -static u32 umc_initctlc[DRAM_FREQ_NR] = {0x00FF00FF}; -static u32 umc_drmmr0[DRAM_FREQ_NR] = {0x00000114}; -static u32 umc_drmmr2[DRAM_FREQ_NR] = {0x000002a0}; +static const u32 umc_initctla[DRAM_FREQ_NR] = {0x71016D11}; +static const u32 umc_initctlb[DRAM_FREQ_NR] = {0x07E390AC}; +static const u32 umc_initctlc[DRAM_FREQ_NR] = {0x00FF00FF}; +static const u32 umc_drmmr0[DRAM_FREQ_NR] = {0x00000114}; +static const u32 umc_drmmr2[DRAM_FREQ_NR] = {0x000002a0};
-static u32 umc_memconf0a[DRAM_FREQ_NR][DRAM_SZ_NR] = { +static const u32 umc_memconf0a[DRAM_FREQ_NR][DRAM_SZ_NR] = { /* 256MB 512MB */ {0x00000601, 0x00000801}, /* 1866 MHz */ };
-static u32 umc_memconf0b[DRAM_FREQ_NR][DRAM_SZ_NR] = { +static const u32 umc_memconf0b[DRAM_FREQ_NR][DRAM_SZ_NR] = { /* 256MB 512MB */ {0x00000120, 0x00000130}, /* 1866 MHz */ };
-static u32 umc_memconfch[DRAM_FREQ_NR][DRAM_SZ_NR] = { +static const u32 umc_memconfch[DRAM_FREQ_NR][DRAM_SZ_NR] = { /* 256MB 512MB */ {0x00033603, 0x00033803}, /* 1866 MHz */ };
-static u32 umc_cmdctla[DRAM_FREQ_NR] = {0x060D0D20}; -static u32 umc_cmdctlb[DRAM_FREQ_NR] = {0x2D211C08}; -static u32 umc_cmdctlc[DRAM_FREQ_NR] = {0x00150C04}; -static u32 umc_cmdctle[DRAM_FREQ_NR][DRAM_SZ_NR] = { +static const u32 umc_cmdctla[DRAM_FREQ_NR] = {0x060D0D20}; +static const u32 umc_cmdctlb[DRAM_FREQ_NR] = {0x2D211C08}; +static const u32 umc_cmdctlc[DRAM_FREQ_NR] = {0x00150C04}; +static const u32 umc_cmdctle[DRAM_FREQ_NR][DRAM_SZ_NR] = { /* 256MB 512MB */ {0x0049071D, 0x0078071D}, /* 1866 MHz */ };
-static u32 umc_rdatactl_d0[DRAM_FREQ_NR] = {0x00000610}; -static u32 umc_rdatactl_d1[DRAM_FREQ_NR] = {0x00000610}; -static u32 umc_wdatactl_d0[DRAM_FREQ_NR] = {0x00000204}; -static u32 umc_wdatactl_d1[DRAM_FREQ_NR] = {0x00000204}; -static u32 umc_odtctl_d0[DRAM_FREQ_NR] = {0x02000002}; -static u32 umc_odtctl_d1[DRAM_FREQ_NR] = {0x02000002}; -static u32 umc_dataset[DRAM_FREQ_NR] = {0x04000000}; +static const u32 umc_rdatactl[DRAM_FREQ_NR] = {0x00000610}; +static const u32 umc_wdatactl[DRAM_FREQ_NR] = {0x00000204}; +static const u32 umc_odtctl[DRAM_FREQ_NR] = {0x02000002}; +static const u32 umc_dataset[DRAM_FREQ_NR] = {0x04000000};
-static u32 umc_flowctla[DRAM_FREQ_NR] = {0x0081E01E}; -static u32 umc_directbusctrla[DRAM_CH_NR] = { +static const u32 umc_flowctla[DRAM_FREQ_NR] = {0x0081E01E}; +static const u32 umc_directbusctrla[DRAM_CH_NR] = { 0x00000000, 0x00000001, 0x00000001 };
@@ -546,13 +588,13 @@ static int umc_dc_init(void __iomem *dc_base, unsigned int freq, writel(umc_cmdctlc[freq_e], dc_base + UMC_CMDCTLC); writel(umc_cmdctle[freq_e][size_e], dc_base + UMC_CMDCTLE);
- writel(umc_rdatactl_d0[freq_e], dc_base + UMC_RDATACTL_D0); - writel(umc_rdatactl_d1[freq_e], dc_base + UMC_RDATACTL_D1); + writel(umc_rdatactl[freq_e], dc_base + UMC_RDATACTL_D0); + writel(umc_rdatactl[freq_e], dc_base + UMC_RDATACTL_D1);
- writel(umc_wdatactl_d0[freq_e], dc_base + UMC_WDATACTL_D0); - writel(umc_wdatactl_d1[freq_e], dc_base + UMC_WDATACTL_D1); - writel(umc_odtctl_d0[freq_e], dc_base + UMC_ODTCTL_D0); - writel(umc_odtctl_d1[freq_e], dc_base + UMC_ODTCTL_D1); + writel(umc_wdatactl[freq_e], dc_base + UMC_WDATACTL_D0); + writel(umc_wdatactl[freq_e], dc_base + UMC_WDATACTL_D1); + writel(umc_odtctl[freq_e], dc_base + UMC_ODTCTL_D0); + writel(umc_odtctl[freq_e], dc_base + UMC_ODTCTL_D1); writel(umc_dataset[freq_e], dc_base + UMC_DATASET);
writel(0x00400020, dc_base + UMC_DCCGCTL); @@ -644,6 +686,9 @@ int uniphier_ld20_umc_init(const struct uniphier_board_data *bd) case UNIPHIER_BD_BOARD_LD20_GLOBAL: board = DRAM_BOARD_LD20_GLOBAL; break; + case UNIPHIER_BD_BOARD_LD20_C1: + board = DRAM_BOARD_LD20_C1; + break; case UNIPHIER_BD_BOARD_LD21_REF: board = DRAM_BOARD_LD21_REF; break; diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 361e024..f3f9e54 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -26,11 +26,12 @@ struct uniphier_board_data {
-#define UNIPHIER_BD_BOARD_GET_TYPE(f) ((f) & 0x3) +#define UNIPHIER_BD_BOARD_GET_TYPE(f) ((f) & 0x7) #define UNIPHIER_BD_BOARD_LD20_REF 0 /* LD20 reference */ #define UNIPHIER_BD_BOARD_LD20_GLOBAL 1 /* LD20 TV Set */ -#define UNIPHIER_BD_BOARD_LD21_REF 2 /* LD21 reference */ -#define UNIPHIER_BD_BOARD_LD21_GLOBAL 3 /* LD21 TV Set */ +#define UNIPHIER_BD_BOARD_LD20_C1 2 /* LD20 TV Set C1 */ +#define UNIPHIER_BD_BOARD_LD21_REF 3 /* LD21 reference */ +#define UNIPHIER_BD_BOARD_LD21_GLOBAL 4 /* LD21 TV Set */ };
const struct uniphier_board_data *uniphier_get_board_param(void);
This PHY might be used for other SoCs in the future. Avoid including the SoC name in the header name.
arch/arm/mach-uniphier/dram/{ddrphy-ld20-regs.h => ddruqphy-regs.h} | 6 +++--- arch/arm/mach-uniphier/dram/umc-ld20.c | 2 +- 2 files changed, 4 insertions(+), 4 deletions(-) rename arch/arm/mach-uniphier/dram/{ddrphy-ld20-regs.h => ddruqphy-regs.h} (97%)
diff --git a/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h b/arch/arm/mach-uniphier/dram/ddruqphy-regs.h similarity index 97% rename from arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h rename to arch/arm/mach-uniphier/dram/ddruqphy-regs.h index 268ba7f..e496af5 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-ld20-regs.h +++ b/arch/arm/mach-uniphier/dram/ddruqphy-regs.h @@ -4,8 +4,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _DDRPHY_LD20_REGS_H -#define _DDRPHY_LD20_REGS_H +#ifndef _DDRUQPHY_REGS_H +#define _DDRUQPHY_REGS_H
#include <linux/bitops.h>
@@ -76,4 +76,4 @@ #define PHY_VREF_TRAINING (0x72 << (PHY_REG_SHIFT)) #define PHY_SCL_GATE_TIMING (0x78 << (PHY_REG_SHIFT))
-#endif /* _DDRPHY_LD20_REGS_H */ +#endif /* _DDRUQPHY_REGS_H */ diff --git a/arch/arm/mach-uniphier/dram/umc-ld20.c b/arch/arm/mach-uniphier/dram/umc-ld20.c index ea933fe..b8c0f59 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld20.c +++ b/arch/arm/mach-uniphier/dram/umc-ld20.c @@ -14,7 +14,7 @@ #include <asm/processor.h>
#include "../init.h" -#include "ddrphy-ld20-regs.h" +#include "ddruqphy-regs.h" #include "umc64-regs.h"
#define DRAM_CH_NR 3
The status register should be polled.
arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index 1ea6193..82ab63c 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -149,7 +149,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, int ret;
writel(UMC_INITSET_INIT1EN, dc_base + UMC_INITSET); - while (readl(dc_base + UMC_INITSET) & UMC_INITSTAT_INIT1ST) + while (readl(dc_base + UMC_INITSTAT) & UMC_INITSTAT_INIT1ST) cpu_relax();
writel(0x00000101, dc_base + UMC_DIOCTLA); diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index f6c2d7f..4a7aa78 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -137,7 +137,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, int phy, ret;
for (phy = 0; phy < nr_phy; phy++) { diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index 61b1dc1..568a007 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -152,7 +152,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, int ret;
At the moment, the clk driver is not clever enough to automatically enable parent clocks like Linux. Enable the STDMAC clock explicitly if USB is enabled.
arch/arm/mach-uniphier/clk/clk-ld11.c | 11 +++++++++++ arch/arm/mach-uniphier/sc64-regs.h | 2 ++ 2 files changed, 13 insertions(+)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld11.c b/arch/arm/mach-uniphier/clk/clk-ld11.c index 92a0733..ca8737d 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld11.c +++ b/arch/arm/mach-uniphier/clk/clk-ld11.c @@ -9,6 +9,7 @@ #include <linux/io.h>
#include "../init.h" +#include "../sc64-regs.h" #include "../sg-regs.h"
void uniphier_ld11_clk_init(void) @@ -25,4 +26,14 @@ void uniphier_ld11_clk_init(void) writel(3, SG_ETPHYPSHUT); writel(7, SG_ETPHYCNT); } + +#ifdef CONFIG_USB_EHCI + { + /* FIXME: the current clk driver can not handle parents */ + u32 tmp; + tmp = readl(SC_CLKCTRL4); + tmp |= SC_CLKCTRL4_MIO | SC_CLKCTRL4_STDMAC; + writel(tmp, SC_CLKCTRL4); + } +#endif } diff --git a/arch/arm/mach-uniphier/sc64-regs.h b/arch/arm/mach-uniphier/sc64-regs.h index b0a4281..d3aa185 100644 --- a/arch/arm/mach-uniphier/sc64-regs.h +++ b/arch/arm/mach-uniphier/sc64-regs.h @@ -52,6 +52,8 @@ #define SC_CLKCTRL (SC_BASE_ADDR | 0x2100) #define SC_CLKCTRL3 (SC_BASE_ADDR | 0x2108) #define SC_CLKCTRL4 (SC_BASE_ADDR | 0x210c) +#define SC_CLKCTRL4_MIO (1 << 10) +#define SC_CLKCTRL4_STDMAC (1 << 8) #define SC_CLKCTRL4_PERI (1 << 7) #define SC_CLKCTRL4_ETHER (1 << 6) #define SC_CLKCTRL4_NAND (1 << 0)
The USB boot without the stand-by MPU is available on ES3 or later of LD11 SoC, but the code in this if-conditional block must not be run when booting from USB. Check if the boot device is USB, and skip the code in the case.
arch/arm/mach-uniphier/clk/clk-ld11.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld11.c b/arch/arm/mach-uniphier/clk/clk-ld11.c index ca8737d..58069cb 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld11.c +++ b/arch/arm/mach-uniphier/clk/clk-ld11.c @@ -5,18 +5,20 @@ */
#include <common.h> +#include <spl.h> #include <linux/bitops.h> #include <linux/io.h>
+#include "../boot-mode/boot-device.h" #include "../init.h" #include "../sc64-regs.h" #include "../sg-regs.h"
void uniphier_ld11_clk_init(void) { - if (readl(SG_PINMON0) & BIT(27)) { - /* if booted without stand-by MPU */ - + /* if booted from a device other than USB, without stand-by MPU */ + if ((readl(SG_PINMON0) & BIT(27)) && + spl_boot_device_raw() != BOOT_DEVICE_USB) { writel(1, SG_ETPHYPSHUT); writel(1, SG_ETPHYCNT);
The DDR PHY register view of LD11 is slightly different from that of LD4/Pro4/sLD8, but it will be possible to share the register macros (and I want to re-use as much code as possible). Change the code in the more flexible form.
arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 142 +++++++------ arch/arm/mach-uniphier/dram/ddrphy-init.h | 20 ++ arch/arm/mach-uniphier/dram/ddrphy-ld4.c | 47 +++-- arch/arm/mach-uniphier/dram/ddrphy-regs.h | 280 ++++++++++++-------------- arch/arm/mach-uniphier/dram/ddrphy-training.c | 92 ++++----- arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- 8 files changed, 296 insertions(+), 291 deletions(-) create mode 100644 arch/arm/mach-uniphier/dram/ddrphy-init.h
diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c index 6ac261d..3dae129 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c @@ -11,6 +11,7 @@ #include <linux/sizes.h>
#include "../soc-info.h" +#include "ddrphy-init.h" #include "ddrphy-regs.h"
/* Select either decimal or hexadecimal */ @@ -40,38 +41,43 @@ static unsigned long uniphier_sld8_base[] = { 0 /* sentinel */ };
-static u32 read_bdl(struct ddrphy_datx8 __iomem *dx, int index) +static void print_bdl(void __iomem *reg, int n) { - return (readl(&dx->bdlr[index / 5]) >> (index % 5 * 6)) & 0x3f; + u32 val = readl(reg); + int i; + + for (i = 0; i < n; i++) + printf(FS PRINTF_FORMAT, (val >> i * 6) & 0x3f); }
static void dump_loop(unsigned long *base, - void (*callback)(struct ddrphy_datx8 __iomem *)) + void (*callback)(void __iomem *)) { - struct ddrphy __iomem *phy; + void __iomem *phy_base, *dx_base; int p, dx;
for (p = 0; *base; base++, p++) { - phy = ioremap(*base, SZ_4K); + phy_base = ioremap(*base, SZ_4K); + dx_base = phy_base + PHY_DX_BASE;
for (dx = 0; dx < NR_DATX8_PER_DDRPHY; dx++) { printf("PHY%dDX%d:", p, dx); - (*callback)(&phy->dx[dx]); + (*callback)(dx_base); + dx_base += PHY_DX_STRIDE; printf("\n"); }
- iounmap(phy); + iounmap(phy_base); } }
-static void __wbdl_dump(struct ddrphy_datx8 __iomem *dx) +static void __wbdl_dump(void __iomem *dx_base) { - int i; + print_bdl(dx_base + PHY_DX_BDLR0, 5); + print_bdl(dx_base + PHY_DX_BDLR1, 5);
- for (i = 0; i < 10; i++) - printf(FS PRINTF_FORMAT, read_bdl(dx, i)); - - printf(FS "(+" PRINTF_FORMAT ")", readl(&dx->lcdlr[1]) & 0xff); + printf(FS "(+" PRINTF_FORMAT ")", + readl(dx_base + PHY_DX_LCDLR1) & 0xff); }
static void wbdl_dump(unsigned long *base) @@ -82,14 +88,13 @@ static void wbdl_dump(unsigned long *base) dump_loop(base, &__wbdl_dump); }
-static void __rbdl_dump(struct ddrphy_datx8 __iomem *dx) +static void __rbdl_dump(void __iomem *dx_base) { - int i; - - for (i = 15; i < 24; i++) - printf(FS PRINTF_FORMAT, read_bdl(dx, i)); + print_bdl(dx_base + PHY_DX_BDLR3, 5); + print_bdl(dx_base + PHY_DX_BDLR4, 4);
- printf(FS "(+" PRINTF_FORMAT ")", (readl(&dx->lcdlr[1]) >> 8) & 0xff); + printf(FS "(+" PRINTF_FORMAT ")", + (readl(dx_base + PHY_DX_LCDLR1) >> 8) & 0xff); }
static void rbdl_dump(unsigned long *base) @@ -100,11 +105,11 @@ static void rbdl_dump(unsigned long *base) dump_loop(base, &__rbdl_dump); }
-static void __wld_dump(struct ddrphy_datx8 __iomem *dx) +static void __wld_dump(void __iomem *dx_base) { int rank; - u32 lcdlr0 = readl(&dx->lcdlr[0]); - u32 gtr = readl(&dx->gtr); + u32 lcdlr0 = readl(dx_base + PHY_DX_LCDLR0); + u32 gtr = readl(dx_base + PHY_DX_GTR);
for (rank = 0; rank < 4; rank++) { u32 wld = (lcdlr0 >> (8 * rank)) & 0xff; /* Delay */ @@ -123,11 +128,11 @@ static void wld_dump(unsigned long *base) dump_loop(base, &__wld_dump); }
-static void __dqsgd_dump(struct ddrphy_datx8 __iomem *dx) +static void __dqsgd_dump(void __iomem *dx_base) { int rank; - u32 lcdlr2 = readl(&dx->lcdlr[2]); - u32 gtr = readl(&dx->gtr); + u32 lcdlr2 = readl(dx_base + PHY_DX_LCDLR2); + u32 gtr = readl(dx_base + PHY_DX_GTR);
for (rank = 0; rank < 4; rank++) { u32 dqsgd = (lcdlr2 >> (8 * rank)) & 0xff; /* Delay */ @@ -145,10 +150,10 @@ static void dqsgd_dump(unsigned long *base) dump_loop(base, &__dqsgd_dump); }
-static void __mdl_dump(struct ddrphy_datx8 __iomem *dx) +static void __mdl_dump(void __iomem *dx_base) { int i; - u32 mdl = readl(&dx->mdlr); + u32 mdl = readl(dx_base + PHY_DX_MDLR); for (i = 0; i < 3; i++) printf(FS PRINTF_FORMAT, (mdl >> (8 * i)) & 0xff); } @@ -161,53 +166,62 @@ static void mdl_dump(unsigned long *base) dump_loop(base, &__mdl_dump); }
-#define REG_DUMP(x) \ - { u32 __iomem *p = &phy->x; printf("%3d: %-10s: %p : %08x\n", \ - p - (u32 *)phy, #x, p, readl(p)); } +#define REG_DUMP(x) \ + { int ofst = PHY_ ## x; void __iomem *reg = phy_base + ofst; \ + printf("%3d: %-10s: %p : %08x\n", \ + ofst >> PHY_REG_SHIFT, #x, reg, readl(reg)); } + +#define DX_REG_DUMP(dx, x) \ + { int ofst = PHY_DX_BASE + PHY_DX_STRIDE * (dx) + \ + PHY_DX_## x; \ + void __iomem *reg = phy_base + ofst; \ + printf("%3d: DX%d%-7s: %p : %08x\n", \ + ofst >> PHY_REG_SHIFT, (dx), #x, reg, readl(reg)); }
static void reg_dump(unsigned long *base) { - struct ddrphy __iomem *phy; - int p; + void __iomem *phy_base; + int p, dx;
printf("\n--- DDR PHY registers ---\n");
- printf("== PHY%d (base: %p) ==\n", p, phy); + printf("== PHY%d (base: %p) ==\n", p, phy_base); printf(" No: Name : Address : Data\n");
- REG_DUMP(ridr); - REG_DUMP(pir); - REG_DUMP(pgcr[0]); - REG_DUMP(pgcr[1]); - REG_DUMP(pgsr[0]); - REG_DUMP(pgsr[1]); - REG_DUMP(pllcr); - REG_DUMP(ptr[0]); - REG_DUMP(ptr[1]); - REG_DUMP(ptr[2]); - REG_DUMP(ptr[3]); - REG_DUMP(ptr[4]); - REG_DUMP(acmdlr); - REG_DUMP(acbdlr); - REG_DUMP(dxccr); - REG_DUMP(dsgcr); - REG_DUMP(dcr); - REG_DUMP(dtpr[0]); - REG_DUMP(dtpr[1]); - REG_DUMP(dtpr[2]); - REG_DUMP(mr0); - REG_DUMP(mr1); - REG_DUMP(mr2); - REG_DUMP(mr3); - REG_DUMP(dx[0].gcr); - REG_DUMP(dx[0].gtr); - REG_DUMP(dx[1].gcr); - REG_DUMP(dx[1].gtr); - - iounmap(phy); + REG_DUMP(RIDR); + REG_DUMP(PIR); + REG_DUMP(PGCR0); + REG_DUMP(PGCR1); + REG_DUMP(PGSR0); + REG_DUMP(PGSR1); + REG_DUMP(PLLCR); + REG_DUMP(PTR0); + REG_DUMP(PTR1); + REG_DUMP(PTR2); + REG_DUMP(PTR3); + REG_DUMP(PTR4); + REG_DUMP(ACMDLR); + REG_DUMP(ACBDLR); + REG_DUMP(DXCCR); + REG_DUMP(DSGCR); + REG_DUMP(DCR); + REG_DUMP(DTPR0); + REG_DUMP(DTPR1); + REG_DUMP(DTPR2); + REG_DUMP(MR0); + REG_DUMP(MR1); + REG_DUMP(MR2); + REG_DUMP(MR3); + + for (dx = 0; dx < NR_DATX8_PER_DDRPHY; dx++) { + DX_REG_DUMP(dx, GCR); + DX_REG_DUMP(dx, GTR); + } + + iounmap(phy_base); } }
diff --git a/arch/arm/mach-uniphier/dram/ddrphy-init.h b/arch/arm/mach-uniphier/dram/ddrphy-init.h new file mode 100644 index 0000000..3fc610b --- /dev/null +++ b/arch/arm/mach-uniphier/dram/ddrphy-init.h @@ -0,0 +1,20 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_DDRPHY_INIT_H +#define ARCH_DDRPHY_INTT_H + +#include <linux/compiler.h> +#include <linux/types.h> + +/* for LD4, Pro4, sLD8 */ +#define NR_DATX8_PER_DDRPHY 2 + +int uniphier_ld4_ddrphy_init(void __iomem *phy_base, int freq, bool ddr3plus); +void ddrphy_prepare_training(void __iomem *phy_base, int rank); +int ddrphy_training(void __iomem *phy_base); + +#endif /* ARCH_DDRPHY_INT_H */ diff --git a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c index c9e164f..040f342 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c @@ -6,9 +6,9 @@
#include <common.h> #include <linux/err.h> -#include <linux/types.h> #include <linux/io.h>
enum dram_freq { @@ -27,8 +27,7 @@ static u32 ddrphy_dtpr2[DRAM_FREQ_NR] = {0x5002c200, 0xa00214f8}; static u32 ddrphy_mr0[DRAM_FREQ_NR] = {0x00000b51, 0x00000d71}; static u32 ddrphy_mr2[DRAM_FREQ_NR] = {0x00000290, 0x00000298};
-int uniphier_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, - bool ddr3plus) +int uniphier_ld4_ddrphy_init(void __iomem *phy_base, int freq, bool ddr3plus) { enum dram_freq freq_e; u32 tmp; @@ -45,34 +44,34 @@ int uniphier_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, return -EINVAL; }
- writel(0x0300c473, &phy->pgcr[1]); - writel(ddrphy_ptr0[freq_e], &phy->ptr[0]); - writel(ddrphy_ptr1[freq_e], &phy->ptr[1]); - writel(0x00083DEF, &phy->ptr[2]); - writel(ddrphy_ptr3[freq_e], &phy->ptr[3]); - writel(ddrphy_ptr4[freq_e], &phy->ptr[4]); - writel(0xF004001A, &phy->dsgcr); + writel(0x0300c473, phy_base + PHY_PGCR1); + writel(ddrphy_ptr0[freq_e], phy_base + PHY_PTR0); + writel(ddrphy_ptr1[freq_e], phy_base + PHY_PTR1); + writel(0x00083DEF, phy_base + PHY_PTR2); + writel(ddrphy_ptr3[freq_e], phy_base + PHY_PTR3); + writel(ddrphy_ptr4[freq_e], phy_base + PHY_PTR4); + writel(0xF004001A, phy_base + PHY_DSGCR);
/* change the value of the on-die pull-up/pull-down registors */ - tmp = readl(&phy->dxccr); + tmp = readl(phy_base + PHY_DXCCR); tmp &= ~0x0ee0; - tmp |= DXCCR_DQSNRES_688_OHM | DXCCR_DQSRES_688_OHM; - writel(tmp, &phy->dxccr); + tmp |= PHY_DXCCR_DQSNRES_688_OHM | PHY_DXCCR_DQSRES_688_OHM; + writel(tmp, phy_base + PHY_DXCCR);
- writel(0x0000040B, &phy->dcr); - writel(ddrphy_dtpr0[freq_e], &phy->dtpr[0]); - writel(ddrphy_dtpr1[freq_e], &phy->dtpr[1]); - writel(ddrphy_dtpr2[freq_e], &phy->dtpr[2]); - writel(ddrphy_mr0[freq_e], &phy->mr0); - writel(0x00000006, &phy->mr1); - writel(ddrphy_mr2[freq_e], &phy->mr2); - writel(ddr3plus ? 0x00000800 : 0x00000000, &phy->mr3); + writel(0x0000040B, phy_base + PHY_DCR); + writel(ddrphy_dtpr0[freq_e], phy_base + PHY_DTPR0); + writel(ddrphy_dtpr1[freq_e], phy_base + PHY_DTPR1); + writel(ddrphy_dtpr2[freq_e], phy_base + PHY_DTPR2); + writel(ddrphy_mr0[freq_e], phy_base + PHY_MR0); + writel(0x00000006, phy_base + PHY_MR1); + writel(ddrphy_mr2[freq_e], phy_base + PHY_MR2); + writel(ddr3plus ? 0x00000800 : 0x00000000, phy_base + PHY_MR3);
- while (!(readl(&phy->pgsr[0]) & PGSR0_IDONE)) + while (!(readl(phy_base + PHY_PGSR0) & PHY_PGSR0_IDONE)) ;
- writel(0x0300C473, &phy->pgcr[1]); - writel(0x0000005D, &phy->zq[0].cr[1]); + writel(0x0300C473, phy_base + PHY_PGCR1); + writel(0x0000005D, phy_base + PHY_ZQ_BASE + PHY_ZQ_CR1);
return 0; } diff --git a/arch/arm/mach-uniphier/dram/ddrphy-regs.h b/arch/arm/mach-uniphier/dram/ddrphy-regs.h index a8fe6a0..13ce54c 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-regs.h +++ b/arch/arm/mach-uniphier/dram/ddrphy-regs.h @@ -9,160 +9,132 @@ #ifndef ARCH_DDRPHY_REGS_H #define ARCH_DDRPHY_REGS_H
-#include <linux/bitops.h> -#include <linux/compiler.h> -#include <linux/types.h> +#define PHY_REG_SHIFT 2
-#ifndef __ASSEMBLY__ - -struct ddrphy { - u32 ridr; /* Revision Identification Register */ - u32 pir; /* PHY Initialixation Register */ - u32 pgcr[2]; /* PHY General Configuration Register */ - u32 pgsr[2]; /* PHY General Status Register */ - u32 pllcr; /* PLL Control Register */ - u32 ptr[5]; /* PHY Timing Register */ - u32 acmdlr; /* AC Master Delay Line Register */ - u32 acbdlr; /* AC Bit Delay Line Register */ - u32 aciocr; /* AC I/O Configuration Register */ - u32 dxccr; /* DATX8 Common Configuration Register */ - u32 dsgcr; /* DDR System General Configuration Register */ - u32 dcr; /* DRAM Configuration Register */ - u32 dtpr[3]; /* DRAM Timing Parameters Register */ - u32 mr0; /* Mode Register 0 */ - u32 mr1; /* Mode Register 1 */ - u32 mr2; /* Mode Register 2 */ - u32 mr3; /* Mode Register 3 */ - u32 odtcr; /* ODT Configuration Register */ - u32 dtcr; /* Data Training Configuration Register */ - u32 dtar[4]; /* Data Training Address Register */ - u32 dtdr[2]; /* Data Training Data Register */ - u32 dtedr[2]; /* Data Training Eye Data Register */ - u32 pgcr2; /* PHY General Configuration Register 2 */ - u32 rsv0[8]; /* Reserved */ - u32 rdimmgcr[2]; /* RDIMM General Configuration Register */ - u32 rdimmcr0[2]; /* RDIMM Control Register */ - u32 dcuar; /* DCU Address Register */ - u32 dcudr; /* DCU Data Register */ - u32 dcurr; /* DCU Run Register */ - u32 dculr; /* DCU Loop Register */ - u32 dcugcr; /* DCU General Configuration Register */ - u32 dcutpr; /* DCU Timing Parameters Register */ - u32 dcusr[2]; /* DCU Status Register */ - u32 rsv1[8]; /* Reserved */ - u32 bistrr; /* BIST Run Register */ - u32 bistwcr; /* BIST Word Count Register */ - u32 bistmskr[3]; /* BIST Mask Register */ - u32 bistlsr; /* BIST LFSR Sed Register */ - u32 bistar[3]; /* BIST Address Register */ - u32 bistudpr; /* BIST User Data Pattern Register */ - u32 bistgsr; /* BIST General Status Register */ - u32 bistwer; /* BIST Word Error Register */ - u32 bistber[4]; /* BIST Bit Error Register */ - u32 bistwcsr; /* BIST Word Count Status Register */ - u32 bistfwr[3]; /* BIST Fail Word Register */ - u32 rsv2[10]; /* Reserved */ - u32 gpr[2]; /* General Purpose Register */ - struct ddrphy_zq { /* ZQ */ - u32 cr[2]; /* Impedance Control Register */ - u32 sr[2]; /* Impedance Status Register */ - } zq[4]; - struct ddrphy_datx8 { /* DATX8 */ - u32 gcr; /* General Configuration Register */ - u32 gsr[2]; /* General Status Register */ - u32 bdlr[5]; /* Bit Delay Line Register */ - u32 lcdlr[3]; /* Local Calibrated Delay Line Register */ - u32 mdlr; /* Master Delay Line Register */ - u32 gtr; /* General Timing Register */ - u32 gsr2; /* General Status Register 2 */ - u32 rsv[2]; /* Reserved */ - } dx[9]; -}; - -#endif /* __ASSEMBLY__ */ - -#define PIR_INIT BIT(0) /* Initialization Trigger */ -#define PIR_ZCAL BIT(1) /* Impedance Calibration */ -#define PIR_PLLINIT BIT(4) /* PLL Initialization */ -#define PIR_DCAL BIT(5) /* DDL Calibration */ -#define PIR_PHYRST BIT(6) /* PHY Reset */ -#define PIR_DRAMRST BIT(7) /* DRAM Reset */ -#define PIR_DRAMINIT BIT(8) /* DRAM Initialization */ -#define PIR_WL BIT(9) /* Write Leveling */ -#define PIR_QSGATE BIT(10) /* Read DQS Gate Training */ -#define PIR_WLADJ BIT(11) /* Write Leveling Adjust */ -#define PIR_RDDSKW BIT(12) /* Read Data Bit Deskew */ -#define PIR_WRDSKW BIT(13) /* Write Data Bit Deskew */ -#define PIR_RDEYE BIT(14) /* Read Data Eye Training */ -#define PIR_WREYE BIT(15) /* Write Data Eye Training */ -#define PIR_LOCKBYP BIT(28) /* PLL Lock Bypass */ -#define PIR_DCALBYP BIT(29) /* DDL Calibration Bypass */ -#define PIR_ZCALBYP BIT(30) /* Impedance Calib Bypass */ -#define PIR_INITBYP BIT(31) /* Initialization Bypass */ - -#define PGSR0_IDONE BIT(0) /* Initialization Done */ -#define PGSR0_PLDONE BIT(1) /* PLL Lock Done */ -#define PGSR0_DCDONE BIT(2) /* DDL Calibration Done */ -#define PGSR0_ZCDONE BIT(3) /* Impedance Calibration Done */ -#define PGSR0_DIDONE BIT(4) /* DRAM Initialization Done */ -#define PGSR0_WLDONE BIT(5) /* Write Leveling Done */ -#define PGSR0_QSGDONE BIT(6) /* DQS Gate Training Done */ -#define PGSR0_WLADONE BIT(7) /* Write Leveling Adjust Done */ -#define PGSR0_RDDONE BIT(8) /* Read Bit Deskew Done */ -#define PGSR0_WDDONE BIT(9) /* Write Bit Deskew Done */ -#define PGSR0_REDONE BIT(10) /* Read Eye Training Done */ -#define PGSR0_WEDONE BIT(11) /* Write Eye Training Done */ -#define PGSR0_IERR BIT(16) /* Initialization Error */ -#define PGSR0_PLERR BIT(17) /* PLL Lock Error */ -#define PGSR0_DCERR BIT(18) /* DDL Calibration Error */ -#define PGSR0_ZCERR BIT(19) /* Impedance Calib Error */ -#define PGSR0_DIERR BIT(20) /* DRAM Initialization Error */ -#define PGSR0_WLERR BIT(21) /* Write Leveling Error */ -#define PGSR0_QSGERR BIT(22) /* DQS Gate Training Error */ -#define PGSR0_WLAERR BIT(23) /* Write Leveling Adj Error */ -#define PGSR0_RDERR BIT(24) /* Read Bit Deskew Error */ -#define PGSR0_WDERR BIT(25) /* Write Bit Deskew Error */ -#define PGSR0_REERR BIT(26) /* Read Eye Training Error */ -#define PGSR0_WEERR BIT(27) /* Write Eye Training Error */ -#define PGSR0_DTERR_SHIFT 28 /* Data Training Error Status*/ -#define PGSR0_DTERR (7 << (PGSR0_DTERR_SHIFT)) -#define PGSR0_APLOCK BIT(31) /* AC PLL Lock */ - -#define DXCCR_DQSRES_OPEN (0 << 5) -#define DXCCR_DQSRES_688_OHM (1 << 5) -#define DXCCR_DQSRES_611_OHM (2 << 5) -#define DXCCR_DQSRES_550_OHM (3 << 5) -#define DXCCR_DQSRES_500_OHM (4 << 5) -#define DXCCR_DQSRES_458_OHM (5 << 5) -#define DXCCR_DQSRES_393_OHM (6 << 5) -#define DXCCR_DQSRES_344_OHM (7 << 5) - -#define DXCCR_DQSNRES_OPEN (0 << 9) -#define DXCCR_DQSNRES_688_OHM (1 << 9) -#define DXCCR_DQSNRES_611_OHM (2 << 9) -#define DXCCR_DQSNRES_550_OHM (3 << 9) -#define DXCCR_DQSNRES_500_OHM (4 << 9) -#define DXCCR_DQSNRES_458_OHM (5 << 9) -#define DXCCR_DQSNRES_393_OHM (6 << 9) -#define DXCCR_DQSNRES_344_OHM (7 << 9) - -#define DTCR_DTRANK_SHIFT 4 /* Data Training Rank */ -#define DTCR_DTRANK_MASK (0x3 << (DTCR_DTRANK_SHIFT)) -#define DTCR_DTMPR BIT(6) /* Data Training using MPR */ -#define DTCR_RANKEN_SHIFT 24 /* Rank Enable */ -#define DTCR_RANKEN_MASK (0xf << (DTCR_RANKEN_SHIFT)) - -#define DXGCR_WLRKEN_SHIFT 26 /* Write Level Rank Enable */ -#define DXGCR_WLRKEN_MASK (0xf << (DXGCR_WLRKEN_SHIFT)) - -/* SoC-specific parameters */ -#define NR_DATX8_PER_DDRPHY 2 - -#ifndef __ASSEMBLY__ -int uniphier_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, - bool ddr3plus); -void ddrphy_prepare_training(struct ddrphy __iomem *phy, int rank); -int ddrphy_training(struct ddrphy __iomem *phy); -#endif +#define PHY_RIDR (0x000 << PHY_REG_SHIFT) +#define PHY_PIR (0x001 << PHY_REG_SHIFT) +#define PHY_PIR_INIT BIT(0) /* Initialization Trigger */ +#define PHY_PIR_ZCAL BIT(1) /* Impedance Calibration */ +#define PHY_PIR_PLLINIT BIT(4) /* PLL Initialization */ +#define PHY_PIR_DCAL BIT(5) /* DDL Calibration */ +#define PHY_PIR_PHYRST BIT(6) /* PHY Reset */ +#define PHY_PIR_DRAMRST BIT(7) /* DRAM Reset */ +#define PHY_PIR_DRAMINIT BIT(8) /* DRAM Initialization */ +#define PHY_PIR_WL BIT(9) /* Write Leveling */ +#define PHY_PIR_QSGATE BIT(10) /* Read DQS Gate Training */ +#define PHY_PIR_WLADJ BIT(11) /* Write Leveling Adjust */ +#define PHY_PIR_RDDSKW BIT(12) /* Read Data Bit Deskew */ +#define PHY_PIR_WRDSKW BIT(13) /* Write Data Bit Deskew */ +#define PHY_PIR_RDEYE BIT(14) /* Read Data Eye Training */ +#define PHY_PIR_WREYE BIT(15) /* Write Data Eye Training */ +#define PHY_PIR_LOCKBYP BIT(28) /* PLL Lock Bypass */ +#define PHY_PIR_DCALBYP BIT(29) /* DDL Calibration Bypass */ +#define PHY_PIR_ZCALBYP BIT(30) /* Impedance Calib Bypass */ +#define PHY_PIR_INITBYP BIT(31) /* Initialization Bypass */ +#define PHY_PGCR0 (0x002 << PHY_REG_SHIFT) +#define PHY_PGCR1 (0x003 << PHY_REG_SHIFT) +#define PHY_PGSR0 (0x004 << PHY_REG_SHIFT) +#define PHY_PGSR0_IDONE BIT(0) /* Initialization Done */ +#define PHY_PGSR0_PLDONE BIT(1) /* PLL Lock Done */ +#define PHY_PGSR0_DCDONE BIT(2) /* DDL Calibration Done */ +#define PHY_PGSR0_ZCDONE BIT(3) /* Impedance Calibration Done */ +#define PHY_PGSR0_DIDONE BIT(4) /* DRAM Initialization Done */ +#define PHY_PGSR0_WLDONE BIT(5) /* Write Leveling Done */ +#define PHY_PGSR0_QSGDONE BIT(6) /* DQS Gate Training Done */ +#define PHY_PGSR0_WLADONE BIT(7) /* Write Leveling Adjust Done */ +#define PHY_PGSR0_RDDONE BIT(8) /* Read Bit Deskew Done */ +#define PHY_PGSR0_WDDONE BIT(9) /* Write Bit Deskew Done */ +#define PHY_PGSR0_REDONE BIT(10) /* Read Eye Training Done */ +#define PHY_PGSR0_WEDONE BIT(11) /* Write Eye Training Done */ +#define PHY_PGSR0_DIERR BIT(20) /* DRAM Initialization Error */ +#define PHY_PGSR0_WLERR BIT(21) /* Write Leveling Error */ +#define PHY_PGSR0_QSGERR BIT(22) /* DQS Gate Training Error */ +#define PHY_PGSR0_WLAERR BIT(23) /* Write Leveling Adj Error */ +#define PHY_PGSR0_RDERR BIT(24) /* Read Bit Deskew Error */ +#define PHY_PGSR0_WDERR BIT(25) /* Write Bit Deskew Error */ +#define PHY_PGSR0_REERR BIT(26) /* Read Eye Training Error */ +#define PHY_PGSR0_WEERR BIT(27) /* Write Eye Training Error */ +#define PHY_PGSR0_DTERR_SHIFT 28 /* Data Training Error Status*/ +#define PHY_PGSR0_DTERR (7 << (PHY_PGSR0_DTERR_SHIFT)) +#define PHY_PGSR1 (0x005 << PHY_REG_SHIFT) +#define PHY_PLLCR (0x006 << PHY_REG_SHIFT) +#define PHY_PTR0 (0x007 << PHY_REG_SHIFT) +#define PHY_PTR1 (0x008 << PHY_REG_SHIFT) +#define PHY_PTR2 (0x009 << PHY_REG_SHIFT) +#define PHY_PTR3 (0x00A << PHY_REG_SHIFT) +#define PHY_PTR4 (0x00B << PHY_REG_SHIFT) +#define PHY_ACMDLR (0x00C << PHY_REG_SHIFT) +#define PHY_ACBDLR (0x00D << PHY_REG_SHIFT) +#define PHY_ACIOCR (0x00E << PHY_REG_SHIFT) +#define PHY_DXCCR (0x00F << PHY_REG_SHIFT) +#define PHY_DXCCR_DQSRES_OPEN (0 << 5) +#define PHY_DXCCR_DQSRES_688_OHM (1 << 5) +#define PHY_DXCCR_DQSRES_611_OHM (2 << 5) +#define PHY_DXCCR_DQSRES_550_OHM (3 << 5) +#define PHY_DXCCR_DQSRES_500_OHM (4 << 5) +#define PHY_DXCCR_DQSRES_458_OHM (5 << 5) +#define PHY_DXCCR_DQSRES_393_OHM (6 << 5) +#define PHY_DXCCR_DQSRES_344_OHM (7 << 5) +#define PHY_DXCCR_DQSNRES_OPEN (0 << 9) +#define PHY_DXCCR_DQSNRES_688_OHM (1 << 9) +#define PHY_DXCCR_DQSNRES_611_OHM (2 << 9) +#define PHY_DXCCR_DQSNRES_550_OHM (3 << 9) +#define PHY_DXCCR_DQSNRES_500_OHM (4 << 9) +#define PHY_DXCCR_DQSNRES_458_OHM (5 << 9) +#define PHY_DXCCR_DQSNRES_393_OHM (6 << 9) +#define PHY_DXCCR_DQSNRES_344_OHM (7 << 9) +#define PHY_DSGCR (0x010 << PHY_REG_SHIFT) +#define PHY_DCR (0x011 << PHY_REG_SHIFT) +#define PHY_DTPR0 (0x012 << PHY_REG_SHIFT) +#define PHY_DTPR1 (0x013 << PHY_REG_SHIFT) +#define PHY_DTPR2 (0x014 << PHY_REG_SHIFT) +#define PHY_MR0 (0x015 << PHY_REG_SHIFT) +#define PHY_MR1 (0x016 << PHY_REG_SHIFT) +#define PHY_MR2 (0x017 << PHY_REG_SHIFT) +#define PHY_MR3 (0x018 << PHY_REG_SHIFT) +#define PHY_ODTCR (0x019 << PHY_REG_SHIFT) +#define PHY_DTCR (0x01A << PHY_REG_SHIFT) +#define PHY_DTCR_DTRANK_SHIFT 4 /* Data Training Rank */ +#define PHY_DTCR_DTRANK_MASK (0x3 << (PHY_DTCR_DTRANK_SHIFT)) +#define PHY_DTCR_DTMPR BIT(6) /* Data Training using MPR */ +#define PHY_DTCR_RANKEN_SHIFT 24 /* Rank Enable */ +#define PHY_DTCR_RANKEN_MASK (0xf << (PHY_DTCR_RANKEN_SHIFT)) +#define PHY_DTAR0 (0x01B << PHY_REG_SHIFT) +#define PHY_DTAR1 (0x01C << PHY_REG_SHIFT) +#define PHY_DTAR2 (0x01D << PHY_REG_SHIFT) +#define PHY_DTAR3 (0x01E << PHY_REG_SHIFT) +#define PHY_DTDR0 (0x01F << PHY_REG_SHIFT) +#define PHY_DTDR1 (0x020 << PHY_REG_SHIFT) +#define PHY_DTEDR0 (0x021 << PHY_REG_SHIFT) +#define PHY_DTEDR1 (0x022 << PHY_REG_SHIFT) +#define PHY_PGCR2 (0x023 << PHY_REG_SHIFT) +#define PHY_GPR0 (0x05E << PHY_REG_SHIFT) +#define PHY_GPR1 (0x05F << PHY_REG_SHIFT) +/* ZQ */ +#define PHY_ZQ_BASE (0x060 << PHY_REG_SHIFT) +#define PHY_ZQ_STRIDE (0x004 << PHY_REG_SHIFT) +#define PHY_ZQ_CR0 (0x000 << PHY_REG_SHIFT) +#define PHY_ZQ_CR1 (0x001 << PHY_REG_SHIFT) +#define PHY_ZQ_SR0 (0x002 << PHY_REG_SHIFT) +#define PHY_ZQ_SR1 (0x003 << PHY_REG_SHIFT) +/* DATX8 */ +#define PHY_DX_BASE (0x070 << PHY_REG_SHIFT) +#define PHY_DX_STRIDE (0x010 << PHY_REG_SHIFT) +#define PHY_DX_GCR (0x000 << PHY_REG_SHIFT) +#define PHY_DX_GCR_WLRKEN_SHIFT 26 /* Write Level Rank Enable */ +#define PHY_DX_GCR_WLRKEN_MASK (0xf << (PHY_DX_GCR_WLRKEN_SHIFT)) +#define PHY_DX_GSR0 (0x001 << PHY_REG_SHIFT) +#define PHY_DX_GSR1 (0x002 << PHY_REG_SHIFT) +#define PHY_DX_BDLR0 (0x003 << PHY_REG_SHIFT) +#define PHY_DX_BDLR1 (0x004 << PHY_REG_SHIFT) +#define PHY_DX_BDLR2 (0x005 << PHY_REG_SHIFT) +#define PHY_DX_BDLR3 (0x006 << PHY_REG_SHIFT) +#define PHY_DX_BDLR4 (0x007 << PHY_REG_SHIFT) +#define PHY_DX_LCDLR0 (0x008 << PHY_REG_SHIFT) +#define PHY_DX_LCDLR1 (0x009 << PHY_REG_SHIFT) +#define PHY_DX_LCDLR2 (0x00A << PHY_REG_SHIFT) +#define PHY_DX_MDLR (0x00B << PHY_REG_SHIFT) +#define PHY_DX_GTR (0x00C << PHY_REG_SHIFT) +#define PHY_DX_GSR2 (0x00D << PHY_REG_SHIFT)
#endif /* ARCH_DDRPHY_REGS_H */ diff --git a/arch/arm/mach-uniphier/dram/ddrphy-training.c b/arch/arm/mach-uniphier/dram/ddrphy-training.c index a348136..2ea5c77 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-training.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-training.c @@ -8,35 +8,35 @@ #include <linux/err.h> #include <linux/io.h>
-void ddrphy_prepare_training(struct ddrphy __iomem *phy, int rank) +void ddrphy_prepare_training(void __iomem *phy_base, int rank) { + void __iomem *dx_base = phy_base + PHY_DX_BASE; int dx; - u32 __iomem tmp, *p; + u32 tmp;
for (dx = 0; dx < NR_DATX8_PER_DDRPHY; dx++) { - p = &phy->dx[dx].gcr; - - tmp = readl(p); + tmp = readl(dx_base + PHY_DX_GCR); /* Specify the rank that should be write leveled */ - tmp &= ~DXGCR_WLRKEN_MASK; - tmp |= (1 << (DXGCR_WLRKEN_SHIFT + rank)) & DXGCR_WLRKEN_MASK; - writel(tmp, p); + tmp &= ~PHY_DX_GCR_WLRKEN_MASK; + tmp |= (1 << (PHY_DX_GCR_WLRKEN_SHIFT + rank)) & + PHY_DX_GCR_WLRKEN_MASK; + writel(tmp, dx_base + PHY_DX_GCR); + dx_base += PHY_DX_STRIDE; }
- p = &phy->dtcr; - - tmp = readl(p); + tmp = readl(phy_base + PHY_DTCR); /* Specify the rank used during data bit deskew and eye centering */ - tmp &= ~DTCR_DTRANK_MASK; - tmp |= (rank << DTCR_DTRANK_SHIFT) & DTCR_DTRANK_MASK; + tmp &= ~PHY_DTCR_DTRANK_MASK; + tmp |= (rank << PHY_DTCR_DTRANK_SHIFT) & PHY_DTCR_DTRANK_MASK; /* Use Multi-Purpose Register for DQS gate training */ - tmp |= DTCR_DTMPR; + tmp |= PHY_DTCR_DTMPR; /* Specify the rank enabled for data-training */ - tmp &= ~DTCR_RANKEN_MASK; - tmp |= (1 << (DTCR_RANKEN_SHIFT + rank)) & DTCR_RANKEN_MASK; - writel(tmp, p); + tmp &= ~PHY_DTCR_RANKEN_MASK; + tmp |= (1 << (PHY_DTCR_RANKEN_SHIFT + rank)) & PHY_DTCR_RANKEN_MASK; + writel(tmp, phy_base + PHY_DTCR); }
struct ddrphy_init_sequence { @@ -49,60 +49,60 @@ struct ddrphy_init_sequence { static const struct ddrphy_init_sequence init_sequence[] = { { "DRAM Initialization", - PIR_DRAMRST | PIR_DRAMINIT, - PGSR0_DIDONE, - PGSR0_DIERR + PHY_PIR_DRAMRST | PHY_PIR_DRAMINIT, + PHY_PGSR0_DIDONE, + PHY_PGSR0_DIERR }, { "Write Leveling", - PIR_WL, - PGSR0_WLDONE, - PGSR0_WLERR + PHY_PIR_WL, + PHY_PGSR0_WLDONE, + PHY_PGSR0_WLERR }, { "Read DQS Gate Training", - PIR_QSGATE, - PGSR0_QSGDONE, - PGSR0_QSGERR + PHY_PIR_QSGATE, + PHY_PGSR0_QSGDONE, + PHY_PGSR0_QSGERR }, { "Write Leveling Adjustment", - PIR_WLADJ, - PGSR0_WLADONE, - PGSR0_WLAERR + PHY_PIR_WLADJ, + PHY_PGSR0_WLADONE, + PHY_PGSR0_WLAERR }, { "Read Bit Deskew", - PIR_RDDSKW, - PGSR0_RDDONE, - PGSR0_RDERR + PHY_PIR_RDDSKW, + PHY_PGSR0_RDDONE, + PHY_PGSR0_RDERR }, { "Write Bit Deskew", - PIR_WRDSKW, - PGSR0_WDDONE, - PGSR0_WDERR + PHY_PIR_WRDSKW, + PHY_PGSR0_WDDONE, + PHY_PGSR0_WDERR }, { "Read Eye Training", - PIR_RDEYE, - PGSR0_REDONE, - PGSR0_REERR + PHY_PIR_RDEYE, + PHY_PGSR0_REDONE, + PHY_PGSR0_REERR }, { "Write Eye Training", - PIR_WREYE, - PGSR0_WEDONE, - PGSR0_WEERR + PHY_PIR_WREYE, + PHY_PGSR0_WEDONE, + PHY_PGSR0_WEERR } };
-int ddrphy_training(struct ddrphy __iomem *phy) +int ddrphy_training(void __iomem *phy_base) { int i; u32 pgsr0; - u32 init_flag = PIR_INIT; - u32 done_flag = PGSR0_IDONE; + u32 init_flag = PHY_PIR_INIT; + u32 done_flag = PHY_PGSR0_IDONE; int timeout = 50000; /* 50 msec is long enough */ #ifdef DISPLAY_ELAPSED_TIME ulong start = get_timer(0); @@ -113,7 +113,7 @@ int ddrphy_training(struct ddrphy __iomem *phy) done_flag |= init_sequence[i].done_flag; }
- writel(init_flag, &phy->pir); + writel(init_flag, phy_base + PHY_PIR);
do { if (--timeout < 0) { @@ -122,7 +122,7 @@ int ddrphy_training(struct ddrphy __iomem *phy) return -ETIMEDOUT; } udelay(1); - pgsr0 = readl(&phy->pgsr[0]); + pgsr0 = readl(phy_base + PHY_PGSR0); } while ((pgsr0 & done_flag) != done_flag);
for (i = 0; i < ARRAY_SIZE(init_sequence); i++) { diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index 82ab63c..90e7f2d 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -13,7 +13,7 @@ #include <asm/processor.h>
#include "../init.h" -#include "ddrphy-regs.h" +#include "ddrphy-init.h" #include "umc-regs.h"
#define DRAM_CH_NR 2 diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index 4a7aa78..5447fa9 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -13,7 +13,7 @@ #include <asm/processor.h>
#define DRAM_CH_NR 2 diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index 568a007..61369f1 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -13,7 +13,7 @@ #include <asm/processor.h>
Do not hard-code the number of DX blocks because it is a different value for LD11 SoC.
Move the macro NR_DATX8_PER_DDRPHY to ddrphy-training.c since it is the last user.
arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 88 ++++++++++++++------------- arch/arm/mach-uniphier/dram/ddrphy-init.h | 3 - arch/arm/mach-uniphier/dram/ddrphy-training.c | 3 + 3 files changed, 50 insertions(+), 44 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c index 3dae129..c868eb0 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c @@ -11,7 +11,6 @@ #include <linux/sizes.h>
#include "../soc-info.h" -#include "ddrphy-init.h" #include "ddrphy-regs.h"
/* Select either decimal or hexadecimal */ @@ -23,22 +22,29 @@ /* field separator */ #define FS " "
-static unsigned long uniphier_ld4_base[] = { - 0x5bc01000, - 0x5be01000, - 0 /* sentinel */ +struct phy_param { + resource_size_t base; + unsigned int nr_dx; };
-static unsigned long uniphier_pro4_base[] = { - 0x5bc01000, - 0x5be01000, - 0 /* sentinel */ +static const struct phy_param uniphier_ld4_phy_param[] = { + { .base = 0x5bc01000, .nr_dx = 2, }, + { .base = 0x5be01000, .nr_dx = 2, }, + { /* sentinel */ } };
-static unsigned long uniphier_sld8_base[] = { - 0x5bc01000, - 0x5be01000, - 0 /* sentinel */ +static const struct phy_param uniphier_pro4_phy_param[] = { + { .base = 0x5bc01000, .nr_dx = 2, }, + { .base = 0x5bc02000, .nr_dx = 2, }, + { .base = 0x5be01000, .nr_dx = 2, }, + { .base = 0x5be02000, .nr_dx = 2, }, + { /* sentinel */ } +}; + +static const struct phy_param uniphier_sld8_phy_param[] = { + { .base = 0x5bc01000, .nr_dx = 2, }, + { .base = 0x5be01000, .nr_dx = 2, }, + { /* sentinel */ } };
static void print_bdl(void __iomem *reg, int n) @@ -50,17 +56,17 @@ static void print_bdl(void __iomem *reg, int n) printf(FS PRINTF_FORMAT, (val >> i * 6) & 0x3f); }
-static void dump_loop(unsigned long *base, +static void dump_loop(const struct phy_param *phy_param, void (*callback)(void __iomem *)) { void __iomem *phy_base, *dx_base; int p, dx;
- for (p = 0; *base; base++, p++) { - phy_base = ioremap(*base, SZ_4K); + for (p = 0; phy_param->base; phy_param++, p++) { + phy_base = ioremap(phy_param->base, SZ_4K); dx_base = phy_base + PHY_DX_BASE;
- for (dx = 0; dx < NR_DATX8_PER_DDRPHY; dx++) { + for (dx = 0; dx < phy_param->nr_dx; dx++) { printf("PHY%dDX%d:", p, dx); (*callback)(dx_base); dx_base += PHY_DX_STRIDE; @@ -80,12 +86,12 @@ static void __wbdl_dump(void __iomem *dx_base) readl(dx_base + PHY_DX_LCDLR1) & 0xff); }
-static void wbdl_dump(unsigned long *base) +static void wbdl_dump(const struct phy_param *phy_param) { printf("\n--- Write Bit Delay Line ---\n"); printf(" DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM DQS (WDQD)\n");
- dump_loop(base, &__wbdl_dump); + dump_loop(phy_param, &__wbdl_dump); }
static void __rbdl_dump(void __iomem *dx_base) @@ -97,12 +103,12 @@ static void __rbdl_dump(void __iomem *dx_base) (readl(dx_base + PHY_DX_LCDLR1) >> 8) & 0xff); }
-static void rbdl_dump(unsigned long *base) +static void rbdl_dump(const struct phy_param *phy_param) { printf("\n--- Read Bit Delay Line ---\n"); printf(" DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM (RDQSD)\n");
- dump_loop(base, &__rbdl_dump); + dump_loop(phy_param, &__rbdl_dump); }
static void __wld_dump(void __iomem *dx_base) @@ -120,12 +126,12 @@ static void __wld_dump(void __iomem *dx_base) } }
-static void wld_dump(unsigned long *base) +static void wld_dump(const struct phy_param *phy_param) { printf("\n--- Write Leveling Delay ---\n"); printf(" Rank0 Rank1 Rank2 Rank3\n");
- dump_loop(base, &__wld_dump); + dump_loop(phy_param, &__wld_dump); }
static void __dqsgd_dump(void __iomem *dx_base) @@ -142,12 +148,12 @@ static void __dqsgd_dump(void __iomem *dx_base) } }
-static void dqsgd_dump(unsigned long *base) +static void dqsgd_dump(const struct phy_param *phy_param) { printf("\n--- DQS Gating Delay ---\n"); printf(" Rank0 Rank1 Rank2 Rank3\n");
- dump_loop(base, &__dqsgd_dump); + dump_loop(phy_param, &__dqsgd_dump); }
static void __mdl_dump(void __iomem *dx_base) @@ -158,12 +164,12 @@ static void __mdl_dump(void __iomem *dx_base) printf(FS PRINTF_FORMAT, (mdl >> (8 * i)) & 0xff); }
-static void mdl_dump(unsigned long *base) +static void mdl_dump(const struct phy_param *phy_param) { printf("\n--- Master Delay Line ---\n"); printf(" IPRD TPRD MDLD\n");
- dump_loop(base, &__mdl_dump); + dump_loop(phy_param, &__mdl_dump); }
#define REG_DUMP(x) \ @@ -178,15 +184,15 @@ static void mdl_dump(unsigned long *base) printf("%3d: DX%d%-7s: %p : %08x\n", \ ofst >> PHY_REG_SHIFT, (dx), #x, reg, readl(reg)); }
-static void reg_dump(unsigned long *base) +static void reg_dump(const struct phy_param *phy_param) { void __iomem *phy_base; int p, dx;
printf("== PHY%d (base: %p) ==\n", p, phy_base); printf(" No: Name : Address : Data\n"); @@ -216,7 +222,7 @@ static void reg_dump(unsigned long *base) REG_DUMP(MR2); REG_DUMP(MR3);
- for (dx = 0; dx < NR_DATX8_PER_DDRPHY; dx++) { + for (dx = 0; dx < phy_param->nr_dx; dx++) { DX_REG_DUMP(dx, GCR); DX_REG_DUMP(dx, GTR); } @@ -228,17 +234,17 @@ static void reg_dump(unsigned long *base) static int do_ddr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char *cmd = argv[1]; - unsigned long *base; + const struct phy_param *phy_param;
switch (uniphier_get_soc_type()) { case SOC_UNIPHIER_LD4: - base = uniphier_ld4_base; + phy_param = uniphier_ld4_phy_param; break; case SOC_UNIPHIER_PRO4: - base = uniphier_pro4_base; + phy_param = uniphier_pro4_phy_param; break; case SOC_UNIPHIER_SLD8: - base = uniphier_sld8_base; + phy_param = uniphier_sld8_phy_param; break; default: printf("unsupported SoC\n"); @@ -249,22 +255,22 @@ static int do_ddr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) cmd = "all";
if (!strcmp(cmd, "wbdl") || !strcmp(cmd, "all")) - wbdl_dump(base); + wbdl_dump(phy_param);
if (!strcmp(cmd, "rbdl") || !strcmp(cmd, "all")) - rbdl_dump(base); + rbdl_dump(phy_param);
if (!strcmp(cmd, "wld") || !strcmp(cmd, "all")) - wld_dump(base); + wld_dump(phy_param);
if (!strcmp(cmd, "dqsgd") || !strcmp(cmd, "all")) - dqsgd_dump(base); + dqsgd_dump(phy_param);
if (!strcmp(cmd, "mdl") || !strcmp(cmd, "all")) - mdl_dump(base); + mdl_dump(phy_param);
if (!strcmp(cmd, "reg") || !strcmp(cmd, "all")) - reg_dump(base); + reg_dump(phy_param);
return CMD_RET_SUCCESS; } diff --git a/arch/arm/mach-uniphier/dram/ddrphy-init.h b/arch/arm/mach-uniphier/dram/ddrphy-init.h index 3fc610b..4216745 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-init.h +++ b/arch/arm/mach-uniphier/dram/ddrphy-init.h @@ -10,9 +10,6 @@ #include <linux/compiler.h> #include <linux/types.h>
-/* for LD4, Pro4, sLD8 */ -#define NR_DATX8_PER_DDRPHY 2 - int uniphier_ld4_ddrphy_init(void __iomem *phy_base, int freq, bool ddr3plus); void ddrphy_prepare_training(void __iomem *phy_base, int rank); int ddrphy_training(void __iomem *phy_base); diff --git a/arch/arm/mach-uniphier/dram/ddrphy-training.c b/arch/arm/mach-uniphier/dram/ddrphy-training.c index 2ea5c77..b161dbf 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-training.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-training.c @@ -11,6 +11,9 @@ #include "ddrphy-init.h" #include "ddrphy-regs.h"
+/* for LD4, Pro4, sLD8 */ +#define NR_DATX8_PER_DDRPHY 2 + void ddrphy_prepare_training(void __iomem *phy_base, int rank) { void __iomem *dx_base = phy_base + PHY_DX_BASE;
Add the LD11 SoC data and adjuts the printf() format because this is a 64-bit SoC. Otherwise, 16-digits pointer addresses would break the log format.
arch/arm/mach-uniphier/Kconfig | 3 ++- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 22 +++++++++++++++++----- 2 files changed, 19 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 7bee6c7..aa3909a 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -99,7 +99,8 @@ config CMD_PINMON
config CMD_DDRPHY_DUMP bool "Enable dump command of DDR PHY parameters" - depends on ARCH_UNIPHIER_LD4 || ARCH_UNIPHIER_PRO4 || ARCH_UNIPHIER_SLD8 + depends on ARCH_UNIPHIER_LD4 || ARCH_UNIPHIER_PRO4 || \ + ARCH_UNIPHIER_SLD8 || ARCH_UNIPHIER_LD11 default y help The command "ddrphy" shows the resulting parameters of DDR PHY diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c index c868eb0..9730330 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c @@ -22,6 +22,8 @@ /* field separator */ #define FS " "
+#define ptr_to_uint(p) ((unsigned int)(unsigned long)(p)) + struct phy_param { resource_size_t base; unsigned int nr_dx; @@ -47,6 +49,11 @@ static const struct phy_param uniphier_sld8_phy_param[] = { { /* sentinel */ } };
+static const struct phy_param uniphier_ld11_phy_param[] = { + { .base = 0x5bc01000, .nr_dx = 4, }, + { /* sentinel */ } +}; + static void print_bdl(void __iomem *reg, int n) { u32 val = readl(reg); @@ -174,15 +181,17 @@ static void mdl_dump(const struct phy_param *phy_param)
#define REG_DUMP(x) \ { int ofst = PHY_ ## x; void __iomem *reg = phy_base + ofst; \ - printf("%3d: %-10s: %p : %08x\n", \ - ofst >> PHY_REG_SHIFT, #x, reg, readl(reg)); } + printf("%3d: %-10s: %08x : %08x\n", \ + ofst >> PHY_REG_SHIFT, #x, \ + ptr_to_uint(reg), readl(reg)); }
#define DX_REG_DUMP(dx, x) \ { int ofst = PHY_DX_BASE + PHY_DX_STRIDE * (dx) + \ PHY_DX_## x; \ void __iomem *reg = phy_base + ofst; \ - printf("%3d: DX%d%-7s: %p : %08x\n", \ - ofst >> PHY_REG_SHIFT, (dx), #x, reg, readl(reg)); } + printf("%3d: DX%d%-7s: %08x : %08x\n", \ + ofst >> PHY_REG_SHIFT, (dx), #x, \ + ptr_to_uint(reg), readl(reg)); }
static void reg_dump(const struct phy_param *phy_param) { @@ -194,7 +203,7 @@ static void reg_dump(const struct phy_param *phy_param) for (p = 0; phy_param->base; phy_param++, p++) { phy_base = ioremap(phy_param->base, SZ_4K);
- printf("== PHY%d (base: %p) ==\n", p, phy_base); + printf("== PHY%d (base: %08x) ==\n", p, ptr_to_uint(phy_base)); printf(" No: Name : Address : Data\n");
REG_DUMP(RIDR); @@ -246,6 +255,9 @@ static int do_ddr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case SOC_UNIPHIER_SLD8: phy_param = uniphier_sld8_phy_param; break; + case SOC_UNIPHIER_LD11: + phy_param = uniphier_ld11_phy_param; + break; default: printf("unsupported SoC\n"); return CMD_RET_FAILURE;
Introduce run-time DDR PHY training.
arch/arm/mach-uniphier/dram/ddrphy-regs.h | 2 + arch/arm/mach-uniphier/dram/umc-ld11.c | 415 ++++++++++++++++++++++++++++-- 2 files changed, 394 insertions(+), 23 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/ddrphy-regs.h b/arch/arm/mach-uniphier/dram/ddrphy-regs.h index 13ce54c..fb77015 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-regs.h +++ b/arch/arm/mach-uniphier/dram/ddrphy-regs.h @@ -33,6 +33,7 @@ #define PHY_PIR_INITBYP BIT(31) /* Initialization Bypass */ #define PHY_PGCR0 (0x002 << PHY_REG_SHIFT) #define PHY_PGCR1 (0x003 << PHY_REG_SHIFT) +#define PHY_PGCR1_INHVT BIT(26) /* VT Calculation Inhibit */ #define PHY_PGSR0 (0x004 << PHY_REG_SHIFT) #define PHY_PGSR0_IDONE BIT(0) /* Initialization Done */ #define PHY_PGSR0_PLDONE BIT(1) /* PLL Lock Done */ @@ -57,6 +58,7 @@ #define PHY_PGSR0_DTERR_SHIFT 28 /* Data Training Error Status*/ #define PHY_PGSR0_DTERR (7 << (PHY_PGSR0_DTERR_SHIFT)) #define PHY_PGSR1 (0x005 << PHY_REG_SHIFT) +#define PHY_PGSR1_VTSTOP BIT(30) /* VT Stop (Pro5~) */ #define PHY_PLLCR (0x006 << PHY_REG_SHIFT) #define PHY_PTR0 (0x007 << PHY_REG_SHIFT) #define PHY_PTR1 (0x008 << PHY_REG_SHIFT) diff --git a/arch/arm/mach-uniphier/dram/umc-ld11.c b/arch/arm/mach-uniphier/dram/umc-ld11.c index 1be18a8..6b660d1 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld11.c +++ b/arch/arm/mach-uniphier/dram/umc-ld11.c @@ -8,11 +8,13 @@ #include <asm/processor.h>
#include "../init.h" +#include "ddrphy-regs.h" #include "umc64-regs.h"
-#define CONFIG_DDR_FREQ 1866 +#define DDR_FREQ 1600
#define DRAM_CH_NR 2 +#define RANK_BLOCKS_TR 2
enum dram_freq { DRAM_FREQ_1600M, @@ -25,26 +27,373 @@ enum dram_size { DRAM_SZ_NR, };
-/* umc */ -static u32 umc_cmdctla[DRAM_FREQ_NR] = {0x060D0D20}; -static u32 umc_cmdctlb[DRAM_FREQ_NR] = {0x2D211C08}; -static u32 umc_cmdctlc[DRAM_FREQ_NR] = {0x00150C04}; -static u32 umc_cmdctle[DRAM_FREQ_NR] = {0x0078071D}; -static u32 umc_cmdctlf[DRAM_FREQ_NR] = {0x02000200}; -static u32 umc_cmdctlg[DRAM_FREQ_NR] = {0x08080808}; - -static u32 umc_rdatactl_d0[DRAM_FREQ_NR] = {0x00000810}; -static u32 umc_rdatactl_d1[DRAM_FREQ_NR] = {0x00000810}; -static u32 umc_wdatactl_d0[DRAM_FREQ_NR] = {0x00000004}; -static u32 umc_wdatactl_d1[DRAM_FREQ_NR] = {0x00000004}; -static u32 umc_odtctl_d0[DRAM_FREQ_NR] = {0x02000002}; -static u32 umc_odtctl_d1[DRAM_FREQ_NR] = {0x02000002}; -static u32 umc_acssetb[DRAM_CH_NR] = {0x00000200, 0x00000203}; -static u32 umc_memconfch[DRAM_FREQ_NR] = {0x00023605}; +/* DDR PHY */ +const int rof_pos_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; +const int rof_neg_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; +const int rof_pos_shift[RANK_BLOCKS_TR][2] = { {-35, -35}, {-35, -35} }; +const int rof_neg_shift[RANK_BLOCKS_TR][2] = { {-17, -17}, {-17, -17} }; +const int tof_shift[RANK_BLOCKS_TR][2] = { {-50, -50}, {-50, -50} }; + +/* Register address */ +#define PHY_ZQ0CR1 0x00000184 +#define PHY_ZQ1CR1 0x00000194 +#define PHY_ZQ2CR1 0x000001A4 +#define PHY_DX0GCR 0x000001C0 +#define PHY_DX0GTR 0x000001F0 +#define PHY_DX1GCR 0x00000200 +#define PHY_DX1GTR 0x00000230 +#define PHY_DX2GCR 0x00000240 +#define PHY_DX2GTR 0x00000270 +#define PHY_DX3GCR 0x00000280 +#define PHY_DX3GTR 0x000002B0 + +#define PHY_DXMDLR(dx) (0x000001EC + 0x40 * (dx)) +#define PHY_DXLCDLR0(dx) (0x000001E0 + 0x40 * (dx)) +#define PHY_DXLCDLR1(dx) (0x000001E4 + 0x40 * (dx)) +#define PHY_DXLCDLR2(dx) (0x000001E8 + 0x40 * (dx)) +#define PHY_DXBDLR1(dx) (0x000001D0 + 0x40 * (dx)) +#define PHY_DXBDLR2(dx) (0x000001D4 + 0x40 * (dx)) + +/* MASK */ +#define PHY_ACBD_MASK 0x00FC0000 +#define PHY_CK0BD_MASK 0x0000003F +#define PHY_CK1BD_MASK 0x00000FC0 +#define PHY_IPRD_MASK 0x000000FF +#define PHY_INHVT_MASK 0x04000000 +#define PHY_VTSTOP_MASK 0x40000000 +#define PHY_WLD_MASK(rank) (0xFF << (8 * (rank))) +#define PHY_DQSGD_MASK(rank) (0xFF << (8 * (rank))) +#define PHY_DQSGX_MASK BIT(6) +#define PHY_DSWBD_MASK 0x3F000000 /* bit[29:24] */ +#define PHY_DSDQOE_MASK 0x00000FFF + +void ddrphy_maskwritel(u32 data, u32 mask, void *addr) +{ + u32 value; + + value = (readl(addr) & ~(mask)) | (data & mask); + writel(value, addr); +} + +u32 ddrphy_maskreadl(u32 mask, void *addr) +{ + return readl(addr) & mask; +} + +/* step of 0.5T for PUB-byte */ +u8 ddrphy_get_mdl(int dx, void __iomem *phy_base) +{ + return ddrphy_maskreadl(PHY_IPRD_MASK, phy_base + PHY_DXMDLR(dx)); +} + +/* Calculating step for PUB-byte */ +int ddrphy_hpstep(int delay, int dx, void __iomem *phy_base) +{ + return delay * ddrphy_get_mdl(dx, phy_base) * DDR_FREQ / 1000000; +} + +/* VT caclulation Prohibit-> prh_on=1 Permit-> prh_on=0 */ +void ddrphy_cntrl_vt_calc(int prh_on, void __iomem *phy_base) +{ + if (prh_on == 1) { + /* Prohibit VT Caclulation */ + ddrphy_maskwritel(0x04000000, PHY_INHVT_MASK, + phy_base + PHY_PGCR1); + while ((readl(phy_base + PHY_PGSR1) & PHY_VTSTOP_MASK) != 0x40000000) + cpu_relax(); + } else { + /* Permit VT Caclulation */ + ddrphy_maskwritel(0x00000000, PHY_INHVT_MASK, phy_base + PHY_PGCR1); + readl(phy_base + PHY_PGCR1); + } +} + +void ddrphy_set_ckoffset_qoffset(int delay_ckoffset0, int delay_ckoffset1, + int delay_qoffset, int enable, + void __iomem *phy_base) +{ + u8 ck_step0, ck_step1; /* ckoffset_step for clock */ + u8 q_step; /* qoffset_step for clock */ + int dx; + + dx = 2; /* use dx2 in sLD11 */ + + ck_step0 = ddrphy_hpstep(delay_ckoffset0, dx, phy_base); /* CK-Offset */ + ck_step1 = ddrphy_hpstep(delay_ckoffset1, dx, phy_base); /* CK-Offset */ + q_step = ddrphy_hpstep(delay_qoffset, dx, phy_base); /* Q-Offset */ + + ddrphy_cntrl_vt_calc(1, phy_base); + + /* Q->[23:18], CK1->[11:6], CK0->bit[5:0] */ + if (enable == 1) + ddrphy_maskwritel((q_step << 18) + (ck_step1 << 6) + ck_step0, + PHY_ACBD_MASK | PHY_CK1BD_MASK | PHY_CK0BD_MASK, + phy_base + PHY_ACBDLR); + + ddrphy_cntrl_vt_calc(0, phy_base); +} + +void ddrphy_set_wl_delay_dx(int dx, int r0_delay, int r1_delay, + int r2_delay, int r3_delay, int enable, void __iomem *phy_base) +{ + int rank; + int delay_wl[4]; + u32 wl_mask = 0; /* WriteLeveling's Mask */ + u32 wl_value = 0; /* WriteLeveling's Value */ + + delay_wl[0] = r0_delay & 0xfff; + delay_wl[1] = r1_delay & 0xfff; + delay_wl[2] = r2_delay & 0xfff; + delay_wl[3] = r3_delay & 0xfff; + + ddrphy_cntrl_vt_calc(1, phy_base); + + for (rank = 0; rank < 4 ; rank++) { + wl_mask |= PHY_WLD_MASK(rank); + /* WriteLeveling's delay */ + wl_value |= ddrphy_hpstep(delay_wl[rank], dx, phy_base) << (8 * rank); + } + + if (enable == 1) + ddrphy_maskwritel(wl_value, wl_mask, phy_base + PHY_DXLCDLR0(dx)); + + ddrphy_cntrl_vt_calc(0, phy_base); +} + +void ddrphy_set_dqsg_delay_dx(int dx, int r0_delay, int r1_delay, + int r2_delay, int r3_delay, int enable, + void __iomem *phy_base) +{ + int rank; + int delay_dqsg[4]; + u32 dqsg_mask = 0; /* DQSGating_LCDL_delay's Mask */ + u32 dqsg_value = 0; /* DQSGating_LCDL_delay's Value */ + + delay_dqsg[0] = r0_delay; + delay_dqsg[1] = r1_delay; + delay_dqsg[2] = r2_delay; + delay_dqsg[3] = r3_delay; + + ddrphy_cntrl_vt_calc(1, phy_base); + + for (rank = 0; rank < 4; rank++) { + dqsg_mask |= PHY_DQSGD_MASK(rank); + /* DQSGating's delay */ + dqsg_value |= ddrphy_hpstep(delay_dqsg[rank], dx, phy_base) << (8 * rank); + } + + if (enable == 1) + ddrphy_maskwritel(dqsg_value, dqsg_mask, phy_base + PHY_DXLCDLR2(dx)); + + ddrphy_cntrl_vt_calc(0, phy_base); +} + +void ddrphy_set_dswb_delay_dx(int dx, int delay, int enable, void __iomem *phy_base) +{ + u8 dswb_step; + + ddrphy_cntrl_vt_calc(1, phy_base); + + dswb_step = ddrphy_hpstep(delay, dx, phy_base); /* DQS-BDL's delay */ + + if (enable == 1) + ddrphy_maskwritel(dswb_step << 24, PHY_DSWBD_MASK, phy_base + PHY_DXBDLR1(dx)); + + ddrphy_cntrl_vt_calc(0, phy_base); +} + +void ddrphy_set_oe_delay_dx(int dx, int dqs_delay, int dq_delay, + int enable, void __iomem *phy_base) +{ + u8 dqs_oe_step, dq_oe_step; + u32 wdata; + + ddrphy_cntrl_vt_calc(1, phy_base); + + /* OE(DQS,DQ) */ + dqs_oe_step = ddrphy_hpstep(dqs_delay, dx, phy_base); /* DQS-oe's delay */ + dq_oe_step = ddrphy_hpstep(dq_delay, dx, phy_base); /* DQ-oe's delay */ + wdata = ((dq_oe_step<<6) + dqs_oe_step) & 0xFFF; + + if (enable == 1) + ddrphy_maskwritel(wdata, PHY_DSDQOE_MASK, phy_base + PHY_DXBDLR2(dx)); + + ddrphy_cntrl_vt_calc(0, phy_base); +} + +void ddrphy_ext_dqsgt(void __iomem *phy_base) +{ + /* Extend DQSGating_window min:+1T max:+1T */ + ddrphy_maskwritel(PHY_DQSGX_MASK, PHY_DQSGX_MASK, phy_base + PHY_DSGCR); +} + +void ddrphy_shift_tof_hws(void __iomem *phy_base, const int shift[][2]) +{ + int dx, block, byte; + u32 lcdlr1, wdqd; + + ddrphy_cntrl_vt_calc(1, phy_base); /* Prohibit VT Calculation */ + + for (block = 0; block < RANK_BLOCKS_TR; block++) { + for (byte = 0; byte < 2; byte++) { + dx = block * 2 + byte; + lcdlr1 = readl(phy_base + PHY_DXLCDLR1(dx)); + wdqd = lcdlr1 & 0xff; + wdqd = clamp(wdqd + ddrphy_hpstep(shift[block][byte], dx, phy_base), + 0U, 0xffU); + lcdlr1 = (lcdlr1 & ~0xff) | wdqd; + writel(lcdlr1, phy_base + PHY_DXLCDLR1(dx)); + readl(phy_base + PHY_DXLCDLR1(dx)); /* relax */ + } + } + + ddrphy_cntrl_vt_calc(0, phy_base); /* Prohibit VT Calculation */ +} + +void ddrphy_shift_rof_hws(void __iomem *phy_base, const int pos_shift[][2], + const int neg_shift[][2]) +{ + int dx, block, byte; + u32 lcdlr1, rdqsd, rdqnsd; + + ddrphy_cntrl_vt_calc(1, phy_base); /* Prohibit VT Calculation */ + + for (block = 0; block < RANK_BLOCKS_TR; block++) { + for (byte = 0; byte < 2; byte++) { + dx = block * 2 + byte; + lcdlr1 = readl(phy_base + PHY_DXLCDLR1(dx)); + + /* DQS LCDL RDQNSD->[23:16] RDQSD->[15:8] */ + rdqsd = (lcdlr1 >> 8) & 0xff; + rdqnsd = (lcdlr1 >> 16) & 0xff; + rdqsd = clamp(rdqsd + ddrphy_hpstep(pos_shift[block][byte], dx, phy_base), + 0U, 0xffU); + rdqnsd = clamp(rdqnsd + ddrphy_hpstep(neg_shift[block][byte], dx, phy_base), + 0U, 0xffU); + lcdlr1 = (lcdlr1 & ~(0xffff << 8)) | (rdqsd << 8) | (rdqnsd << 16); + readl(phy_base + PHY_DXLCDLR1(dx)); /* relax */ + } + } + + ddrphy_cntrl_vt_calc(0, phy_base); /* Prohibit VT Calculation */ +} + +void ddrphy_boot_run_hws(void __iomem *phy_base) +{ + /* Hard Training for DIO */ + writel(0x0000f401, phy_base + PHY_PIR); + while (!(readl(phy_base + PHY_PGSR0) & PHY_PGSR0_IDONE)) + cpu_relax(); +} + +void ddrphy_training(void __iomem *phy_base) +{ + int ext_dqsgt_on = 1; + + /* DIO roffset shift before hard training */ + ddrphy_shift_rof_hws(phy_base, rof_pos_shift_pre, rof_neg_shift_pre); + + /* Hard Training for each CH */ + ddrphy_boot_run_hws(phy_base); + + /* DIO toffset shift after training */ + ddrphy_shift_tof_hws(phy_base, tof_shift); + + /* DIO roffset shift after training */ + ddrphy_shift_rof_hws(phy_base, rof_pos_shift, rof_neg_shift); + + /* Extend DQSGating window min:+1T max:+1T */ + if (ext_dqsgt_on == 1) + ddrphy_ext_dqsgt(phy_base); +} + +static void ddrphy_init(void __iomem *phy_base, enum dram_freq freq) +{ + writel(0x40000000, phy_base + PHY_PIR); + writel(0x0300C4F1, phy_base + PHY_PGCR1); + writel(0x0C807D04, phy_base + PHY_PTR0); + writel(0x27100578, phy_base + PHY_PTR1); + writel(0x00083DEF, phy_base + PHY_PTR2); + writel(0x12061A80, phy_base + PHY_PTR3); + writel(0x08027100, phy_base + PHY_PTR4); + writel(0x9D9CBB66, phy_base + PHY_DTPR0); + writel(0x1a878400, phy_base + PHY_DTPR1); + writel(0x50025200, phy_base + PHY_DTPR2); + writel(0xF004641A, phy_base + PHY_DSGCR); + writel(0x0000040B, phy_base + PHY_DCR); + writel(0x00000d71, phy_base + PHY_MR0); + writel(0x00000006, phy_base + PHY_MR1); + writel(0x00000098, phy_base + PHY_MR2); + writel(0x00000000, phy_base + PHY_MR3); + + while (!(readl(phy_base + PHY_PGSR0) & BIT(0))) + cpu_relax(); + + writel(0x00000059, phy_base + PHY_ZQ0CR1); + writel(0x00000019, phy_base + PHY_ZQ1CR1); + writel(0x00000019, phy_base + PHY_ZQ2CR1); + writel(0x30FC6C20, phy_base + PHY_PGCR2); + + ddrphy_set_ckoffset_qoffset(119, 0, 0, 1, phy_base); + ddrphy_set_wl_delay_dx(0, 220, 220, 0, 0, 1, phy_base); + ddrphy_set_wl_delay_dx(1, 160, 160, 0, 0, 1, phy_base); + ddrphy_set_wl_delay_dx(2, 190, 190, 0, 0, 1, phy_base); + ddrphy_set_wl_delay_dx(3, 150, 150, 0, 0, 1, phy_base); + ddrphy_set_dqsg_delay_dx(0, 750, 750, 0, 0, 1, phy_base); + ddrphy_set_dqsg_delay_dx(1, 750, 750, 0, 0, 1, phy_base); + ddrphy_set_dqsg_delay_dx(2, 750, 750, 0, 0, 1, phy_base); + ddrphy_set_dqsg_delay_dx(3, 750, 750, 0, 0, 1, phy_base); + ddrphy_set_dswb_delay_dx(0, 0, 1, phy_base); + ddrphy_set_dswb_delay_dx(1, 0, 1, phy_base); + ddrphy_set_dswb_delay_dx(2, 0, 1, phy_base); + ddrphy_set_dswb_delay_dx(3, 0, 1, phy_base); + ddrphy_set_oe_delay_dx(0, 0, 0, 1, phy_base); + ddrphy_set_oe_delay_dx(1, 0, 0, 1, phy_base); + ddrphy_set_oe_delay_dx(2, 0, 0, 1, phy_base); + ddrphy_set_oe_delay_dx(3, 0, 0, 1, phy_base); + + writel(0x44000E81, phy_base + PHY_DX0GCR); + writel(0x44000E81, phy_base + PHY_DX1GCR); + writel(0x44000E81, phy_base + PHY_DX2GCR); + writel(0x44000E81, phy_base + PHY_DX3GCR); + writel(0x00055002, phy_base + PHY_DX0GTR); + writel(0x00055002, phy_base + PHY_DX1GTR); + writel(0x00055010, phy_base + PHY_DX2GTR); + writel(0x00055010, phy_base + PHY_DX3GTR); + writel(0x930035C7, phy_base + PHY_DTCR); + writel(0x00000003, phy_base + PHY_PIR); + readl(phy_base + PHY_PIR); + while (!(readl(phy_base + PHY_PGSR0) & PHY_PGSR0_IDONE)) + cpu_relax(); + + writel(0x00000181, phy_base + PHY_PIR); + readl(phy_base + PHY_PIR); + while (!(readl(phy_base + PHY_PGSR0) & PHY_PGSR0_IDONE)) + cpu_relax(); + + writel(0x44181884, phy_base + PHY_DXCCR); + writel(0x00000001, phy_base + PHY_GPR1); +} + +/* UMC */ +static const u32 umc_cmdctla[DRAM_FREQ_NR] = {0x060B0B1C}; +static const u32 umc_cmdctlb[DRAM_FREQ_NR] = {0x27201806}; +static const u32 umc_cmdctlc[DRAM_FREQ_NR] = {0x00120B04}; +static const u32 umc_cmdctle[DRAM_FREQ_NR] = {0x00680607}; +static const u32 umc_cmdctlf[DRAM_FREQ_NR] = {0x02000200}; +static const u32 umc_cmdctlg[DRAM_FREQ_NR] = {0x08080808}; + +static const u32 umc_rdatactl[DRAM_FREQ_NR] = {0x00000810}; +static const u32 umc_wdatactl[DRAM_FREQ_NR] = {0x00000004}; +static const u32 umc_odtctl[DRAM_FREQ_NR] = {0x02000002}; +static const u32 umc_acssetb[DRAM_CH_NR] = {0x00000200, 0x00000203}; + +static const u32 umc_memconfch[DRAM_FREQ_NR] = {0x00023605};
static int umc_dc_init(void __iomem *dc_base, enum dram_freq freq, unsigned long size, int ch) { + /* Wait for PHY Init Complete */ writel(umc_cmdctla[freq], dc_base + UMC_CMDCTLA); writel(umc_cmdctlb[freq], dc_base + UMC_CMDCTLB); writel(umc_cmdctlc[freq], dc_base + UMC_CMDCTLC); @@ -52,14 +401,14 @@ static int umc_dc_init(void __iomem *dc_base, enum dram_freq freq, writel(umc_cmdctlf[freq], dc_base + UMC_CMDCTLF); writel(umc_cmdctlg[freq], dc_base + UMC_CMDCTLG);
- writel(umc_rdatactl_d0[freq], dc_base + UMC_RDATACTL_D0); - writel(umc_rdatactl_d1[freq], dc_base + UMC_RDATACTL_D1); + writel(umc_rdatactl[freq], dc_base + UMC_RDATACTL_D0); + writel(umc_rdatactl[freq], dc_base + UMC_RDATACTL_D1);
- writel(umc_wdatactl_d0[freq], dc_base + UMC_WDATACTL_D0); - writel(umc_wdatactl_d1[freq], dc_base + UMC_WDATACTL_D1); + writel(umc_wdatactl[freq], dc_base + UMC_WDATACTL_D0); + writel(umc_wdatactl[freq], dc_base + UMC_WDATACTL_D1);
- writel(umc_odtctl_d0[freq], dc_base + UMC_ODTCTL_D0); - writel(umc_odtctl_d1[freq], dc_base + UMC_ODTCTL_D1); + writel(umc_odtctl[freq], dc_base + UMC_ODTCTL_D0); + writel(umc_odtctl[freq], dc_base + UMC_ODTCTL_D1);
writel(0x00000003, dc_base + UMC_ACSSETA); writel(0x00000103, dc_base + UMC_FLOWCTLG); @@ -93,6 +442,7 @@ int uniphier_ld11_umc_init(const struct uniphier_board_data *bd) { void __iomem *um_base = (void __iomem *)0x5B800000; void __iomem *umc_ch_base = (void __iomem *)0x5BC00000; + void __iomem *phy_base = (void __iomem *)0x5BC01000; enum dram_freq freq; int ch, ret;
@@ -105,6 +455,24 @@ int uniphier_ld11_umc_init(const struct uniphier_board_data *bd) return -EINVAL; }
+ writel(0x00000101, umc_ch_base + UMC_DIOCTLA); + while (!(readl(phy_base + PHY_PGSR0) & PHY_PGSR0_IDONE)) + cpu_relax(); + + writel(0x00000000, umc_ch_base + UMC_DIOCTLA); + writel(0x00000001, umc_ch_base + UMC_DEBUGC); + writel(0x00000101, umc_ch_base + UMC_DIOCTLA); + + writel(0x00000100, umc_ch_base + UMC_INITSET); + while (readl(umc_ch_base + UMC_INITSTAT) & BIT(8)) + cpu_relax(); + + writel(0x00000100, umc_ch_base + 0x00200000 + UMC_INITSET); + while (readl(umc_ch_base + 0x00200000 + UMC_INITSTAT) & BIT(8)) + cpu_relax(); + + ddrphy_init(phy_base, freq); + for (ch = 0; ch < bd->dram_nr_ch; ch++) { unsigned long size = bd->dram_ch[ch].size; unsigned int width = bd->dram_ch[ch].width; @@ -117,6 +485,7 @@ int uniphier_ld11_umc_init(const struct uniphier_board_data *bd)
umc_ch_base += 0x00200000; } + ddrphy_training(phy_base);
um_init(um_base);
2016-10-27 23:46 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
- DDR PHY init code updates
- Some bug fixes
Masahiro Yamada (11): ARM: uniphier: enable SSC for more PLLs for LD20 SoC ARM: uniphier: remove unused board attribute macros ARM: uniphier: update DRAM init code for LD20 SoC (3rd) ARM: uniphier: rename ddrphy-ld20-regs.h to ddruqphy-regs.h ARM: uniphier: fix DRAM init poll address for LD4, Pro4, sLD8 ARM: uniphier: enable clocks to MIO/STDMAC on LD11 if USB is enabled ARM: uniphier: do not run harmful code for USB boot mode of LD11 ES3 ARM: uniphier: rework existing DDR PHY code to reuse for LD11 SoC ARM: uniphier: refactor DDR PHY parameter dump command ARM: uniphier: support DDR PHY parameter dump command for LD11 ARM: uniphier: update DRAM init code for LD11 SoC
Series, applied to u-boot-uniphier/master.
Masahiro Yamada
