[PATCH] mtd: rawnand: omap_elm: Fix elm_init definition
The macro ELM_BASE is defined in mach/hardware.h and is not visible at the omap_elm.h header file. Avoid using it in omap_elm.h.
Reported-by: Hong Guan hguan@ti.com Fixes: 7363cf0581a3 ("mtd: rawnand: omap_elm: u-boot driver model support") Signed-off-by: Roger Quadros rogerq@kernel.org --- drivers/mtd/nand/raw/omap_elm.c | 4 ++-- drivers/mtd/nand/raw/omap_elm.h | 6 ------ 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/nand/raw/omap_elm.c b/drivers/mtd/nand/raw/omap_elm.c index 56a2c39e4f..015ec9bc2d 100644 --- a/drivers/mtd/nand/raw/omap_elm.c +++ b/drivers/mtd/nand/raw/omap_elm.c @@ -185,7 +185,6 @@ void elm_reset(void) ; }
-#ifdef ELM_BASE /** * elm_init - Initialize ELM module * @@ -194,10 +193,11 @@ void elm_reset(void) */ void elm_init(void) { +#ifdef ELM_BASE elm_cfg = (struct elm *)ELM_BASE; elm_reset(); -} #endif +}
#if CONFIG_IS_ENABLED(SYS_NAND_SELF_INIT)
diff --git a/drivers/mtd/nand/raw/omap_elm.h b/drivers/mtd/nand/raw/omap_elm.h index a7f7bacb15..f3db00d55d 100644 --- a/drivers/mtd/nand/raw/omap_elm.h +++ b/drivers/mtd/nand/raw/omap_elm.h @@ -74,12 +74,6 @@ int elm_check_error(u8 *syndrome, enum bch_level bch_type, u32 *error_count, u32 *error_locations); int elm_config(enum bch_level level); void elm_reset(void); -#ifdef ELM_BASE void elm_init(void); -#else -static inline void elm_init(void) -{ -} -#endif #endif /* __ASSEMBLY__ */ #endif /* __ASM_ARCH_ELM_H */
base-commit: 2f0282922b2c458eea7f85c500a948a587437b63
Roger Quadros
