[U-Boot] [PATCH] Add support for Faraday Ethernet IP FTMAC100
This patch adds support for Faraday Technology Ethernet IP - FTMAC100
Signed-off-by: Po-Yu Chuang <ratbert at faraday-tech.com> --- diff -ruN u-boot-2009.03/drivers/net/ftmac100.c FA5A320LINUX26_u-boot/drivers/net/ftmac100.c --- u-boot-2009.03/drivers/net/ftmac100.c 1970-01-01 08:00:00.000000000 +0800 +++ FA5A320LINUX26_u-boot/drivers/net/ftmac100.c 2009-03-31 15:20:33.000000000 +0800 @@ -0,0 +1,219 @@ +/* + * Faraday FTMAC100 Ethernet + * + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#undef DEBUG + +#include <config.h> +#include <common.h> +#include <net.h> +#include <asm/io.h> +#include "ftmac100.h" + +DECLARE_GLOBAL_DATA_PTR; + +static unsigned int ftmac100_base = CONFIG_SYS_MAC100_BASE; + +static volatile struct ftmac100_txdes txdes[1]; +static volatile struct ftmac100_rxdes rxdes[PKTBUFSRX]; +static int rx_index; + +/* + * Reset MAC + */ +static void +ftmac100_reset(void) +{ + debug("ftmac100_reset()\n"); + + outl(FTMAC100_MACCR_SW_RST, ftmac100_base + FTMAC100_OFFSET_MACCR); + + while (inl(ftmac100_base + FTMAC100_OFFSET_MACCR) & FTMAC100_MACCR_SW_RST); +} + +/* + * Set MAC address + */ +static void +ftmac100_set_mac(const unsigned char *mac) +{ + unsigned short maddr = mac[0] << 8 | mac[1]; + unsigned int laddr = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5]; + + debug("ftmac100_set_mac()\n"); + + outl(maddr, ftmac100_base + FTMAC100_OFFSET_MAC_MADR); + outl(laddr, ftmac100_base + FTMAC100_OFFSET_MAC_LADR); +} + +/* + * disable transmitter, receiver + */ +void +eth_halt(void) +{ + debug("eth_halt()\n"); + + outl(0, ftmac100_base + FTMAC100_OFFSET_MACCR); +} + +int +eth_init(bd_t *bd) +{ + int i; + unsigned int maccr; + + debug("eth_init()\n"); + + ftmac100_reset(); + + /* set the ethernet address */ + + ftmac100_set_mac(gd->bd->bi_enetaddr); + + /* disable all interrupts */ + + outl(0, ftmac100_base + FTMAC100_OFFSET_IMR); + + /* initialize descriptors */ + + rx_index = 0; + + txdes[0].txdes1 = FTMAC100_TXDES1_EDOTR; + rxdes[PKTBUFSRX - 1].rxdes1 = FTMAC100_RXDES1_EDORR; + + for (i = 0; i < PKTBUFSRX; i++) { + rxdes[i].rxdes2 = (unsigned int)NetRxPackets[i]; /* RXBUF_BADR */ + rxdes[i].rxdes1 |= FTMAC100_RXDES1_RXBUF_SIZE(PKTSIZE_ALIGN); + rxdes[i].rxdes0 = FTMAC100_RXDES0_RXDMA_OWN; + } + + /* transmit ring */ + + outl(txdes, ftmac100_base + FTMAC100_OFFSET_TXR_BADR); + + /* receive ring */ + + outl(rxdes, ftmac100_base + FTMAC100_OFFSET_RXR_BADR); + + /* poll receive descriptor automatically */ + + outl(FTMAC100_APTC_RXPOLL_CNT(1), ftmac100_base + FTMAC100_OFFSET_APTC); + + /* enable transmitter, receiver */ + + maccr = FTMAC100_MACCR_XMT_EN + | FTMAC100_MACCR_RCV_EN + | FTMAC100_MACCR_XDMA_EN + | FTMAC100_MACCR_RDMA_EN + | FTMAC100_MACCR_CRC_APD + | FTMAC100_MACCR_ENRX_IN_HALFTX + | FTMAC100_MACCR_RX_RUNT + | FTMAC100_MACCR_RX_BROADPKT; + + outl(maccr, ftmac100_base + FTMAC100_OFFSET_MACCR); + + return 0; +} + +/* + * Get a data block via Ethernet + */ +int +eth_rx(void) +{ + volatile struct ftmac100_rxdes *curr_des = &rxdes[rx_index]; + unsigned short rxlen; + + if (curr_des->rxdes0 & FTMAC100_RXDES0_RXDMA_OWN) { + return -1; + } + + if (curr_des->rxdes0 & ( FTMAC100_RXDES0_RX_ERR + | FTMAC100_RXDES0_CRC_ERR + | FTMAC100_RXDES0_FTL + | FTMAC100_RXDES0_RUNT + | FTMAC100_RXDES0_RX_ODD_NB)) { + return -1; + } + + rxlen = FTMAC100_RXDES0_RFL(curr_des->rxdes0); + + debug("eth_rx(): RX buffer %d, %x received\n", rx_index, rxlen); + + /* pass the packet up to the protocol layers. */ + + NetReceive((void *)curr_des->rxdes2, rxlen); + + /* release buffer to DMA */ + + curr_des->rxdes0 |= FTMAC100_RXDES0_RXDMA_OWN; + + rx_index = (rx_index + 1) % PKTBUFSRX; + + return 0; +} + +/* + * Send a data block via Ethernet + */ +int +eth_send(volatile void *packet, int length) +{ + volatile struct ftmac100_txdes *curr_des = txdes; + int tmo; + + if (curr_des->txdes0 & FTMAC100_TXDES0_TXPKT_TXDMA_OWN) { + debug("eth_send(): no TX descriptor available\n"); + return -1; + } + + debug("eth_send(%x, %x)\n", (int)packet, length); + + /* initiate a transmit sequence */ + + curr_des->txdes2 = (unsigned int)packet; /* TXBUF_BADR */ + + curr_des->txdes1 &= FTMAC100_TXDES1_EDOTR; + curr_des->txdes1 |= FTMAC100_TXDES1_FTS + | FTMAC100_TXDES1_LTS + | FTMAC100_TXDES1_TXBUF_SIZE((length < 64) ? 64 : length); + + curr_des->txdes0 = FTMAC100_TXDES0_TXPKT_TXDMA_OWN; + + /* start transmit */ + + outl(1, ftmac100_base + FTMAC100_OFFSET_TXPD); + + /* wait for transfer to succeed */ + + tmo = get_timer(0) + 5 * CONFIG_SYS_HZ; + while (curr_des->txdes0 & FTMAC100_TXDES0_TXPKT_TXDMA_OWN) { + if (get_timer(0) >= tmo) { + debug("eth_send(): timed out\n"); + return -1; + } + } + + debug("eth_send(): packet sent\n"); + + return 0; +} + diff -ruN u-boot-2009.03/drivers/net/ftmac100.h FA5A320LINUX26_u-boot/drivers/net/ftmac100.h --- u-boot-2009.03/drivers/net/ftmac100.h 1970-01-01 08:00:00.000000000 +0800 +++ FA5A320LINUX26_u-boot/drivers/net/ftmac100.h 2009-03-31 15:49:05.000000000 +0800 @@ -0,0 +1,146 @@ +/* + * Faraday FTMAC100 Ethernet + * + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __FTMAC100_H +#define __FTMAC100_H + +#define FTMAC100_OFFSET_ISR 0x00 +#define FTMAC100_OFFSET_IMR 0x04 +#define FTMAC100_OFFSET_MAC_MADR 0x08 +#define FTMAC100_OFFSET_MAC_LADR 0x0c +#define FTMAC100_OFFSET_MAHT0 0x10 +#define FTMAC100_OFFSET_MAHT1 0x14 +#define FTMAC100_OFFSET_TXPD 0x18 +#define FTMAC100_OFFSET_RXPD 0x1c +#define FTMAC100_OFFSET_TXR_BADR 0x20 +#define FTMAC100_OFFSET_RXR_BADR 0x24 +#define FTMAC100_OFFSET_ITC 0x28 +#define FTMAC100_OFFSET_APTC 0x2c +#define FTMAC100_OFFSET_DBLAC 0x30 +#define FTMAC100_OFFSET_MACCR 0x88 +#define FTMAC100_OFFSET_MACSR 0x8c +#define FTMAC100_OFFSET_PHYCR 0x90 +#define FTMAC100_OFFSET_PHYWDATA 0x94 +#define FTMAC100_OFFSET_FCR 0x98 +#define FTMAC100_OFFSET_BPR 0x9c +#define FTMAC100_OFFSET_TS 0xc4 +#define FTMAC100_OFFSET_DMAFIFOS 0xc8 +#define FTMAC100_OFFSET_TM 0xcc +#define FTMAC100_OFFSET_TX_MCOL_SCOL 0xd4 +#define FTMAC100_OFFSET_RPF_AEP 0xd8 +#define FTMAC100_OFFSET_XM_PG 0xdc +#define FTMAC100_OFFSET_RUNT_TLCC 0xe0 +#define FTMAC100_OFFSET_CRCER_FTL 0xe4 +#define FTMAC100_OFFSET_RLC_RCC 0xe8 +#define FTMAC100_OFFSET_BROC 0xec +#define FTMAC100_OFFSET_MULCA 0xf0 +#define FTMAC100_OFFSET_RP 0xf4 +#define FTMAC100_OFFSET_XP 0xf8 + +/* + * Interrupt status register & interrupt mask register + */ +#define FTMAC100_INT_RPKT_FINISH (1 << 0) +#define FTMAC100_INT_NORXBUF (1 << 1) +#define FTMAC100_INT_XPKT_FINISH (1 << 2) +#define FTMAC100_INT_NOTXBUF (1 << 3) +#define FTMAC100_INT_XPKT_OK (1 << 4) +#define FTMAC100_INT_XPKT_LOST (1 << 5) +#define FTMAC100_INT_RPKT_SAV (1 << 6) +#define FTMAC100_INT_RPKT_LOST (1 << 7) +#define FTMAC100_INT_AHB_ERR (1 << 8) +#define FTMAC100_INT_PHYSTS_CHG (1 << 9) + +/* + * Automatic polling timer control register + */ +#define FTMAC100_APTC_RXPOLL_CNT(x) (((x) & 0xf) << 0) +#define FTMAC100_APTC_RXPOLL_TIME_SEL (1 << 4) +#define FTMAC100_APTC_TXPOLL_CNT(x) (((x) & 0xf) << 8) +#define FTMAC100_APTC_TXPOLL_TIME_SEL (1 << 12) + +/* + * MAC control register + */ +#define FTMAC100_MACCR_XDMA_EN (1 << 0) +#define FTMAC100_MACCR_RDMA_EN (1 << 1) +#define FTMAC100_MACCR_SW_RST (1 << 2) +#define FTMAC100_MACCR_LOOP_EN (1 << 3) +#define FTMAC100_MACCR_CRC_DIS (1 << 4) +#define FTMAC100_MACCR_XMT_EN (1 << 5) +#define FTMAC100_MACCR_ENRX_IN_HALFTX (1 << 6) +#define FTMAC100_MACCR_RCV_EN (1 << 8) +#define FTMAC100_MACCR_HT_MULTI_EN (1 << 9) +#define FTMAC100_MACCR_RX_RUNT (1 << 10) +#define FTMAC100_MACCR_RX_FTL (1 << 11) +#define FTMAC100_MACCR_RCV_ALL (1 << 12) +#define FTMAC100_MACCR_CRC_APD (1 << 14) +#define FTMAC100_MACCR_FULLDUP (1 << 15) +#define FTMAC100_MACCR_RX_MULTIPKT (1 << 16) +#define FTMAC100_MACCR_RX_BROADPKT (1 << 17) + +/* + * Transmit descriptor, aligned to 16 bytes + */ +struct ftmac100_txdes { + unsigned int txdes0; + unsigned int txdes1; + unsigned int txdes2; /* TXBUF_BADR */ + unsigned int txdes3; /* not used by HW */ +} __attribute__ ((aligned(16))); + +#define FTMAC100_TXDES0_TXPKT_LATECOL (1 << 0) +#define FTMAC100_TXDES0_TXPKT_EXSCOL (1 << 1) +#define FTMAC100_TXDES0_TXPKT_TXDMA_OWN (1 << 31) + +#define FTMAC100_TXDES1_TXBUF_SIZE(x) ((x) & 0x7ff) +#define FTMAC100_TXDES1_LTS (1 << 27) +#define FTMAC100_TXDES1_FTS (1 << 28) +#define FTMAC100_TXDES1_TX2FIC (1 << 29) +#define FTMAC100_TXDES1_TXIC (1 << 30) +#define FTMAC100_TXDES1_EDOTR (1 << 31) + +/* + * Receive descriptor, aligned to 16 bytes + */ +struct ftmac100_rxdes { + unsigned int rxdes0; + unsigned int rxdes1; + unsigned int rxdes2; /* RXBUF_BADR */ + unsigned int rxdes3; /* not used by HW */ +} __attribute__ ((aligned(16))); + +#define FTMAC100_RXDES0_RFL(des) ((des) & 0x7ff) +#define FTMAC100_RXDES0_MULTICAST (1 << 16) +#define FTMAC100_RXDES0_BROADCAST (1 << 17) +#define FTMAC100_RXDES0_RX_ERR (1 << 18) +#define FTMAC100_RXDES0_CRC_ERR (1 << 19) +#define FTMAC100_RXDES0_FTL (1 << 20) +#define FTMAC100_RXDES0_RUNT (1 << 21) +#define FTMAC100_RXDES0_RX_ODD_NB (1 << 22) +#define FTMAC100_RXDES0_LRS (1 << 28) +#define FTMAC100_RXDES0_FRS (1 << 29) +#define FTMAC100_RXDES0_RXDMA_OWN (1 << 31) + +#define FTMAC100_RXDES1_RXBUF_SIZE(x) ((x) & 0x7ff) +#define FTMAC100_RXDES1_EDORR (1 << 31) + +#endif /* __FTMAC100_H */ diff -ruN u-boot-2009.03/drivers/net/Makefile FA5A320LINUX26_u-boot/drivers/net/Makefile --- u-boot-2009.03/drivers/net/Makefile 2009-03-22 05:04:41.000000000 +0800 +++ FA5A320LINUX26_u-boot/drivers/net/Makefile 2009-03-31 15:35:35.000000000 +0800 @@ -38,6 +38,7 @@ COBJS-$(CONFIG_EEPRO100) += eepro100.o COBJS-$(CONFIG_ENC28J60) += enc28j60.o COBJS-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o +COBJS-$(CONFIG_DRIVER_FTMAC100) += ftmac100.o COBJS-$(CONFIG_GRETH) += greth.o COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o
kind of redundant statement considering the summary ...
you should really be using git to generate patches and send e-mails. also, signed-off-by (and similar tags) use real addresses, not munged ones. -mike
Hi Po Yu Chang,
Please use a valid e-mail address (hint - it should have an @ sign). You may want to provide a brief description of the controller here.
It's best to use git tools to generate the patch. If you use git-send-email you're more-or-less guaranteed to avoid line-wrapping issues.
- Faraday FTMAC100 Ethernet
- (C) Copyright 2009 Faraday Technology
- Po-Yu Chuang ratbert@faraday-tech.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
+#undef DEBUG
- Reset MAC
- debug("ftmac100_reset()\n");
- outl(FTMAC100_MACCR_SW_RST, ftmac100_base + FTMAC100_OFFSET_MACCR);
- while (inl(ftmac100_base + FTMAC100_OFFSET_MACCR) & FTMAC100_MACCR_SW_RST);
- Set MAC address
- unsigned short maddr = mac[0] << 8 | mac[1];
- unsigned int laddr = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5];
This is a strange way of doing this. Do you really need to use two variables?
- debug("ftmac100_set_mac()\n");
- outl(maddr, ftmac100_base + FTMAC100_OFFSET_MAC_MADR);
- outl(laddr, ftmac100_base + FTMAC100_OFFSET_MAC_LADR);
Others have mentioned not using outl(), so echo'd here
- disable transmitter, receiver
- debug("eth_halt()\n");
- outl(0, ftmac100_base + FTMAC100_OFFSET_MACCR);
Please don't use the old-style API (eth_halt(), eth_init() etc.) You should have a single xxx_initialize() function that fills in an eth_device struct with function pointers to static functions. You'll find lots of examples in drivers/net
- int i;
- unsigned int maccr;
- debug("eth_init()\n");
- ftmac100_reset();
- /* set the ethernet address */
- ftmac100_set_mac(gd->bd->bi_enetaddr);
- /* disable all interrupts */
- outl(0, ftmac100_base + FTMAC100_OFFSET_IMR);
- /* initialize descriptors */
- rx_index = 0;
- txdes[0].txdes1 = FTMAC100_TXDES1_EDOTR;
- rxdes[PKTBUFSRX - 1].rxdes1 = FTMAC100_RXDES1_EDORR;
- for (i = 0; i < PKTBUFSRX; i++) {
- /* transmit ring */
- outl(txdes, ftmac100_base + FTMAC100_OFFSET_TXR_BADR);
- /* receive ring */
- outl(rxdes, ftmac100_base + FTMAC100_OFFSET_RXR_BADR);
- /* poll receive descriptor automatically */
- outl(FTMAC100_APTC_RXPOLL_CNT(1), ftmac100_base + FTMAC100_OFFSET_APTC);
- /* enable transmitter, receiver */
- maccr = FTMAC100_MACCR_XMT_EN
- outl(maccr, ftmac100_base + FTMAC100_OFFSET_MACCR);
- Get a data block via Ethernet
- volatile struct ftmac100_rxdes *curr_des = &rxdes[rx_index];
- unsigned short rxlen;
- if (curr_des->rxdes0 & FTMAC100_RXDES0_RXDMA_OWN) {
return -1;
- if (curr_des->rxdes0 & ( FTMAC100_RXDES0_RX_ERR
| FTMAC100_RXDES0_FTL
return -1;
- rxlen = FTMAC100_RXDES0_RFL(curr_des->rxdes0);
- debug("eth_rx(): RX buffer %d, %x received\n", rx_index, rxlen);
- /* pass the packet up to the protocol layers. */
- NetReceive((void *)curr_des->rxdes2, rxlen);
- /* release buffer to DMA */
- curr_des->rxdes0 |= FTMAC100_RXDES0_RXDMA_OWN;
- rx_index = (rx_index + 1) % PKTBUFSRX;
- Send a data block via Ethernet
- volatile struct ftmac100_txdes *curr_des = txdes;
- int tmo;
- if (curr_des->txdes0 & FTMAC100_TXDES0_TXPKT_TXDMA_OWN) {
return -1;
- debug("eth_send(%x, %x)\n", (int)packet, length);
- /* initiate a transmit sequence */
- curr_des->txdes2 = (unsigned int)packet; /* TXBUF_BADR */
- curr_des->txdes1 &= FTMAC100_TXDES1_EDOTR;
- curr_des->txdes1 |= FTMAC100_TXDES1_FTS
| FTMAC100_TXDES1_LTS
- curr_des->txdes0 = FTMAC100_TXDES0_TXPKT_TXDMA_OWN;
- /* start transmit */
- outl(1, ftmac100_base + FTMAC100_OFFSET_TXPD);
- /* wait for transfer to succeed */
- tmo = get_timer(0) + 5 * CONFIG_SYS_HZ;
- while (curr_des->txdes0 & FTMAC100_TXDES0_TXPKT_TXDMA_OWN) {
return -1;
- debug("eth_send(): packet sent\n");
- Interrupt status register & interrupt mask register
- Automatic polling timer control register
- MAC control register
- Transmit descriptor, aligned to 16 bytes
- unsigned int txdes0;
- unsigned int txdes1;
- unsigned int txdes2; /* TXBUF_BADR */
- unsigned int txdes3; /* not used by HW */
- Receive descriptor, aligned to 16 bytes
- unsigned int rxdes0;
- unsigned int rxdes1;
- unsigned int rxdes2; /* RXBUF_BADR */
- unsigned int rxdes3; /* not used by HW */
In general, this is quite promising - thanks a lot! We tend to not include drivers without a board that uses it. Please consider submitting your board code too.
regards, Ben
Ben Warren
Jean-Christophe PLAGNIOL-VILLARD
Mike Frysinger
PoYu_Chuang
