[PATCH 1/2] riscv: Fix sbi_remote_sfence_vma{,_asid}
Currently sbi_remote_sfence_vma{,_asid} does not pass their arguments to SBI at all, which is semantically incorrect.
This keeps in sync with Linux kernel commit: a21344dfc6ad: fix sbi_remote_sfence_vma{,_asid}
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/riscv/include/asm/sbi.h | 19 ++++++++++++------- 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/arch/riscv/include/asm/sbi.h b/arch/riscv/include/asm/sbi.h index ced57de..d5081f9 100644 --- a/arch/riscv/include/asm/sbi.h +++ b/arch/riscv/include/asm/sbi.h @@ -20,22 +20,27 @@ #define SBI_REMOTE_SFENCE_VMA_ASID 7 #define SBI_SHUTDOWN 8
-#define SBI_CALL(which, arg0, arg1, arg2) ({ \ +#define SBI_CALL(which, arg0, arg1, arg2, arg3) ({ \ register uintptr_t a0 asm ("a0") = (uintptr_t)(arg0); \ register uintptr_t a1 asm ("a1") = (uintptr_t)(arg1); \ register uintptr_t a2 asm ("a2") = (uintptr_t)(arg2); \ + register uintptr_t a3 asm ("a3") = (uintptr_t)(arg3); \ register uintptr_t a7 asm ("a7") = (uintptr_t)(which); \ asm volatile ("ecall" \ : "+r" (a0) \ - : "r" (a1), "r" (a2), "r" (a7) \ + : "r" (a1), "r" (a2), "r" (a3), "r" (a7) \ : "memory"); \ a0; \ })
/* Lazy implementations until SBI is finalized */ -#define SBI_CALL_0(which) SBI_CALL(which, 0, 0, 0) -#define SBI_CALL_1(which, arg0) SBI_CALL(which, arg0, 0, 0) -#define SBI_CALL_2(which, arg0, arg1) SBI_CALL(which, arg0, arg1, 0) +#define SBI_CALL_0(which) SBI_CALL(which, 0, 0, 0, 0) +#define SBI_CALL_1(which, arg0) SBI_CALL(which, arg0, 0, 0, 0) +#define SBI_CALL_2(which, arg0, arg1) SBI_CALL(which, arg0, arg1, 0, 0) +#define SBI_CALL_3(which, arg0, arg1, arg2) \ + SBI_CALL(which, arg0, arg1, arg2, 0) +#define SBI_CALL_4(which, arg0, arg1, arg2, arg3) \ + SBI_CALL(which, arg0, arg1, arg2, arg3)
static inline void sbi_console_putchar(int ch) { @@ -80,7 +85,7 @@ static inline void sbi_remote_sfence_vma(const unsigned long *hart_mask, unsigned long start, unsigned long size) { - SBI_CALL_1(SBI_REMOTE_SFENCE_VMA, hart_mask); + SBI_CALL_3(SBI_REMOTE_SFENCE_VMA, hart_mask, start, size); }
static inline void sbi_remote_sfence_vma_asid(const unsigned long *hart_mask, @@ -88,7 +93,7 @@ static inline void sbi_remote_sfence_vma_asid(const unsigned long *hart_mask, unsigned long size, unsigned long asid) { - SBI_CALL_1(SBI_REMOTE_SFENCE_VMA_ASID, hart_mask); + SBI_CALL_4(SBI_REMOTE_SFENCE_VMA_ASID, hart_mask, start, size, asid); }
#endif
There is no need for S-mode U-Boot to call sbi_clear_ipi() as it can be cleared directly from S-mode. This saves some cycles.
arch/riscv/lib/sbi_ipi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/lib/sbi_ipi.c b/arch/riscv/lib/sbi_ipi.c index 9a698ce..abafca9 100644 --- a/arch/riscv/lib/sbi_ipi.c +++ b/arch/riscv/lib/sbi_ipi.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/encoding.h> #include <asm/sbi.h>
int riscv_send_ipi(int hart) @@ -19,7 +20,7 @@ int riscv_send_ipi(int hart)
int riscv_clear_ipi(int hart) { - sbi_clear_ipi(); + csr_clear(CSR_SIP, SIP_SSIP);
return 0; }
Reviewed-by: Lukas Auer lukas@auer.io
Hi Rick,
Ping?
I think these 2 patches in this series should be in v2020.04
Regards, Bin
Bin Meng
Lukas Auer
